Blatboy Posted April 26, 2020 Posted April 26, 2020 (edited) On 4/20/2020 at 4:42 AM, Hawkeye said: Thanks, @xarolium, @latigid on already completed the boards - we're now working on the case and the software. That is wonderful news, Hawkeye! I am happy to hear we may get a second chance. I’m still kicking myself for missing that first group buy. Edited April 26, 2020 by Blatboy 1
kogz23 Posted May 1, 2020 Posted May 1, 2020 Here here! I just hope I don't forget to keep on checking back with this thread. Is there a waitlist or something we can get on? Cheers! 1
latigid on Posted May 1, 2020 Author Posted May 1, 2020 No waiting list! There might be a teaser soon but it's hard to guess timelines at the moment. Hopefully there'll be something to tease shortly. Best, Andy 1
xarolium Posted June 19, 2020 Posted June 19, 2020 On 01/05/2020 at 2:44 AM, latigid on said: No waiting list! There might be a teaser soon but it's hard to guess timelines at the moment. Hopefully there'll be something to tease shortly. Best, Andy Any news ?
latigid on Posted June 19, 2020 Author Posted June 19, 2020 We're making good progress! It's a fancy new app with a fancy new display and fancy new other things. :)
Altitude Posted June 27, 2020 Posted June 27, 2020 was the alt-page thing ever fixed? so you could scroll up and down in note view?
latigid on Posted June 27, 2020 Author Posted June 27, 2020 No it wasn't. Peter is into the code now and would know if it can be implemented /reimplemented.
sbm Posted August 30, 2020 Posted August 30, 2020 On 12/26/2015 at 10:33 AM, sbm said: Well, from bad to worse, looks like my board is shorted now. Not sure how that happened but I measure 2.5 ohms resistance between ground and 5V. That was a waste. :-/ Should have updated this....an air-driven reflow station is your friend when it comes to making fixes to SMD parts! This was a lot of fun to do and get working. Looking forward to building another one day.
latigid on Posted August 31, 2020 Author Posted August 31, 2020 I'm very glad; that's a great resolution! :)
Phatline Posted April 14, 2021 Posted April 14, 2021 hey @latigid on ... do you know how to: offset the DIN-SR-NR (Code > 32bit) ? > i need a DINx4, in the start of the SR-Chain > then after this the BLM... i ask because the BLM has no "Thru" Port... i already put the blm_scalar.c and blm_scalar.h into my project (so i can change it - if necessery) ( i dont need any info about the LED-Part --- there i dont need a offset)
latigid on Posted April 14, 2021 Author Posted April 14, 2021 Hello, Not sure sorry... But you should be able to interrupt the J8/9 header with your module. Best, Andy
Phatline Posted April 14, 2021 Posted April 14, 2021 to add an DINx4 module in front of the BLM16x16+x-Module, do following... blm_scalar.c add the SR_off Part.... ///////////////////////////////////////////////////////////////////////////// //! This function gets the DIN values of the selected row. //! call it from APP_SRIO_ServiceFinish() hook! ///////////////////////////////////////////////////////////////////////////// s32 BLM_SCALAR_GetRow(void) { // decrememt debounce counter if > 0 if( blm_scalar_button_debounce_ctr ) { --blm_scalar_button_debounce_ctr; } // since the row line of the buttons is identical to the row line of the LEDs, // we can derive the button row offset from blm_scalar_selected_row 909 >>>>>>>>>>>>>>>> here is the offset? int selected_row = (blm_scalar_selected_row-1) & 0x7; // &: bitwise AND 0x7: 7 // check DINs int mod; for(mod=0; mod<5; ++mod) { // 5: Module-Nr int sr = blm_scalar_config.din[mod]; static u8 SR_off = 4; // Shiftregistor Offset -- if you have a DINx4 Module before the BLM-Module if( sr ) { MIOS32_DIN_SRChangedGetAndClear(sr-1 + SR_off, 0xff); // ensure that change won't be propagated to normal DIN handler u8 sr_value = MIOS32_DIN_SRGet(sr-1 + SR_off); // ignore as long as debounce counter != 0 if( !blm_scalar_button_debounce_ctr ) { // determine pin changes u8 changed = sr_value ^ blm_scalar_button_row_values[mod][selected_row]; if( changed ) { // add them to existing notifications blm_scalar_button_row_changed[mod][selected_row] |= changed; // store new value blm_scalar_button_row_values[mod][selected_row] = sr_value; // reload debounce counter if any pin has changed blm_scalar_button_debounce_ctr = blm_scalar_config.debounce_delay; } } } } return 0; }
Blatboy Posted April 14, 2021 Posted April 14, 2021 14 hours ago, Phatline said: wow. this looks amazing! 1
Hawkeye Posted April 17, 2021 Posted April 17, 2021 Super small demo of the newest hardware variant: Enjoy the weekend and many greets! Peter
mex Posted April 24, 2021 Posted April 24, 2021 Hello, man this is a huge setup, i think i am going to built one of those kits for myself. I just signed up to the mailinglist in the midiphy shop. But as soon es one is available feel free to hit me up personally, i also cold be some kind of beta tester :) I did built the Midibox SID, it seems to work :) and the Midibox sequencer. If i understand right this matrix controller only works together with the sequencer. Thanks a lot for all that effort. Best wishes.
Phatline Posted April 24, 2021 Posted April 24, 2021 3 hours ago, mex said: f i understand right this matrix controller only works together with the sequencer. Best wishes. or other midi devices... or you could program your own custom sequencer into the matrix (it is a32bit core now?...thats whaz i did with V1 off the blm16*16+x
Hawkeye Posted April 24, 2021 Posted April 24, 2021 @mex very cool! We're still sourcing a few parts and finalizing documentation, as well as expanding the software a bit - so it will still require some time, but it's working nicely (the build is also already externally verified :)) @Phatline yes, 32-bit :) Many greets and have a nice weekend, Peter
Hawkeye Posted November 20, 2021 Posted November 20, 2021 The new version now is finally available! Check this thread: Best regards, Peter
Phatline Posted January 24, 2023 Posted January 24, 2023 On 4/14/2021 at 4:05 PM, Phatline said: to add an DINx4 module in front of the BLM16x16+x-Module, do following... blm_scalar.c add the SR_off Part.... ///////////////////////////////////////////////////////////////////////////// //! This function gets the DIN values of the selected row. //! call it from APP_SRIO_ServiceFinish() hook! ///////////////////////////////////////////////////////////////////////////// s32 BLM_SCALAR_GetRow(void) { // decrememt debounce counter if > 0 if( blm_scalar_button_debounce_ctr ) { --blm_scalar_button_debounce_ctr; } // since the row line of the buttons is identical to the row line of the LEDs, // we can derive the button row offset from blm_scalar_selected_row 909 >>>>>>>>>>>>>>>> here is the offset? int selected_row = (blm_scalar_selected_row-1) & 0x7; // &: bitwise AND 0x7: 7 // check DINs int mod; for(mod=0; mod<5; ++mod) { // 5: Module-Nr int sr = blm_scalar_config.din[mod]; static u8 SR_off = 4; // Shiftregistor Offset -- if you have a DINx4 Module before the BLM-Module if( sr ) { MIOS32_DIN_SRChangedGetAndClear(sr-1 + SR_off, 0xff); // ensure that change won't be propagated to normal DIN handler u8 sr_value = MIOS32_DIN_SRGet(sr-1 + SR_off); // ignore as long as debounce counter != 0 if( !blm_scalar_button_debounce_ctr ) { // determine pin changes u8 changed = sr_value ^ blm_scalar_button_row_values[mod][selected_row]; if( changed ) { // add them to existing notifications blm_scalar_button_row_changed[mod][selected_row] |= changed; // store new value blm_scalar_button_row_values[mod][selected_row] = sr_value; // reload debounce counter if any pin has changed blm_scalar_button_debounce_ctr = blm_scalar_config.debounce_delay; } } } } return 0; } now i need this for the DOUT-Registers... i got the 16x16 working with following code .... but the Extra-XY stay dark - any Idea? cant get forward, since Latigid Ons BLM has no J89 thru, i have to put the BLM at the end of the SR-Chain (3xDIN, 4xDOUT in front off the BLM) ///////////////////////////////////////////////////////////////////////////// //! This function prepares the DOUT register to drive a row DOUT-SR-OFFSET HERE!!!!!!!!!!!!!!! //! should be called from APP_SRIO_ServicePrepare() ///////////////////////////////////////////////////////////////////////////// s32 BLM_SCALAR_PrepareCol(void) { // increment row, wrap at 8 if( ++blm_scalar_selected_row >= 8 ) { blm_scalar_selected_row = 0; } // select next DOUT/DIN row (selected cathode line = 0, all others 1) u8 dout_value = ~(1 << blm_scalar_selected_row); // apply inversion mask dout_value ^= blm_scalar_config.cathodes_inv_mask; // output on CATHODES* registers u8 SRo_off = 4; //Shiftregister offset int mod; for(mod=0; mod<5; ++mod) { int sr = blm_scalar_config.dout_cathodes[mod]; // 5: Module-Nr if( sr ) { MIOS32_DOUT_SRSet(sr-1 + SRo_off, dout_value); } // SR-CHain: BLM > Dout.... //if( sr ) { MIOS32_DOUT_SRSet(sr+3, dout_value); } // SR-Chain: DoutX4 > BLM } // output colours for(mod=0; mod<5; ++mod) { int colour; // 5: Module-Nr for(colour=0; colour<2; ++colour) { // 2: Color-Nr int sr = blm_scalar_config.dout[mod][colour]; // Module 8 Rows Color Blink u8 STEPs= blm_scalar_led[mod][blm_scalar_selected_row][colour][0]; int val; if (blinky && BLM_BLINK_ACT) { // turn of the blinking Steps u8 FLAM = blm_scalar_led[mod][blm_scalar_selected_row][colour][1]; // compare FLAM and STEPs with Bitwise XOR! val = FLAM ^ STEPs; } else { val = STEPs; } // Set it if( sr ) { MIOS32_DOUT_SRSet(sr-1 + SRo_off, val); } //Shiftregister offset, val); } // SR-CHain: BLM > Dout.... //if( sr ) { MIOS32_DOUT_SRSet(sr+3, val); } // SR-Chain: DoutX4 > BLM Geht zumindest für ie Hauptmatrix 8080 /// ///////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////////777 } } return 0; }
Phatline Posted January 25, 2023 Posted January 25, 2023 ok i got it... if you have for example follwing Shiftregister Chain- Scenario: DINx3 > DOUTx4 > BLM (instead of BLM > DIN > DOUT... which is not possible because of not having a J8/9 output on the BLM) go to blm_scalar.c and change following: ///////////////////////////////////////////////////////////////////////////// //! Initializes the BLM_SCALAR driver //! Should be called from Init() during startup ///////////////////////////////////////////////////////////////////////////// s32 BLM_SCALAR_Init(u32 mode) { // define default configuration (can be changed during runtime) int mod; for(mod=0; mod<5; ++mod) {// count thru Scalar Modules // DOUT int mod_sr_offset = (3 * mod) + 4; // 4: DOUTX4 OFFSET 3: 1-Cathode, 2-Color1, 3-Color2 blm_scalar_config.dout_cathodes[mod] = mod_sr_offset + 1; int colour; for(colour=0; colour<2; ++colour) blm_scalar_config.dout[mod][colour] = mod_sr_offset + colour + 2; // offset 2..3(..4) // DIN blm_scalar_config.din[mod] = mod + 1 + 3; // 3 = DINX3 OFFSET } ....................................... have fun!
