The MBSEQv4 beginner's guide is now up on the wiki with some images. I've used EsotericLabs' eps files (based on Wilba's design) for frontpanel overview images, I hope it's ok.
In principle the guide is exportable as pdf and printable (there's a button on the right), though at the moment certain "table like things" don't get rendered correctly. I might replace the "tables" with images to take care of the problem.
If you want to add sections and correct stuff, go ahead, that's the wiki way :-)
The path to the guide from the wiki front page:
MIDIbox Projects -> MIDIbox SEQ V4 -> MBSEQv4 Beginner's Guide
http://wiki.midibox.org/doku.php?id=mididocs:seq:beginners_guide:start
Edited by jjonas
typo
  • Like 8
  • TK. pinned this topic
  • 1 year later...
  • 9 months later...
  • 1 year later...
  • 6 months later...
  • 1 year later...
Hi, When I try to export these pages as PDF, it is missing al the screenimages, alyone else has this problem?
Cheers,
Kees
I get the same, but one trick is to highlight the entire contents and "print" the page to PDF. Then you should get the images in line.
Best,
Andy
Edited by latigid on
  • Like 1
Best,
Andy
That worked, tnx!
Cheers,
Kees
