lis0r Posted April 27, 2017 Posted April 27, 2017 Hi all, First things first: I've got TK's and Wilba's blessing for this. I have almost all the parts required to build a SEQ v4 except the control surface PCB, which has been out of stock. So I've recreated my own clone from the available schematics and dimensional drawings. I have permission to run a small batch, and sell those surplus to my personal requirements. Would anybody else be interested in this? Is there anyone with the needed skills who'd be willing to help me verify the board layout before it gets sent for manufacturing, please? I'm pretty sure it's right, but I'd like to make sure it's right first time. Thanks! Lisa
r0main Posted May 17, 2017 Posted May 17, 2017 Dear Lisa, I'd like to get a pcb, how to deal? Best regards, Romain
Metalldorn Posted May 17, 2017 Posted May 17, 2017 I'm also interested if you're planning on doing a bulk order.
gerald.wert Posted May 18, 2017 Posted May 18, 2017 I have made a few of my own small boards and can take a look at it.
lis0r Posted May 18, 2017 Author Posted May 18, 2017 Thanks Gerald - I will try and sort something out for you to look at this evening. Thanks!
gerald.wert Posted May 18, 2017 Posted May 18, 2017 I have an empty case from julianf so should be able to print a PDF of the board and check if it will fit and line up in there as well.
Humpink Posted May 20, 2017 Posted May 20, 2017 Could also take a look at it and I am also interested in buying one or two. The only thing that prevents me from building the sequencer is that the seq cs board is always out of stock, it's very frustrating.
lis0r Posted May 20, 2017 Author Posted May 20, 2017 An SVG of my layout is available from http://www.bismuth83.co.uk/~lisa/v4.svg If this needs converting to PDF to be printable, please let me know. Because I'm allergic to the bad GUI that is kicad, I built this design using PCB-RND. If anyone has sufficient knowledge to review it electrically, I can send them the source file that will be used to generate gerbers, etc. To protect the midibox IP, I won't be making it publicly available. Thanks! Lisa
Antichambre Posted May 20, 2017 Posted May 20, 2017 Hi Lisa, I don't know PCB-RND , like you I hate Kicad ... I use Eagle, in it, there 's some electrical check named ERC which check Layout from diagram. This ERC can be fine but first thing to check is your schematic ;) When that's done and clear, you need to do a DRC which will check production rules match, depends on manufacturer you use to be sure no error will be produced during this last step. Antichambre
lis0r Posted May 20, 2017 Author Posted May 20, 2017 Yeah, I've used the rule checks in Eagle before, but this board is too big for the free version! It's passed all the tests (automatic and manual) that I have available to me, but due to the nature of the board, it'll cost a non-trivial amount of money to run, so I'm trying to avoid getting it wrong!
Antichambre Posted May 20, 2017 Posted May 20, 2017 (edited) If you're sure of your schematic and mechanical constraints, like switches, encs, leds and holes positions, it just remains Design rules. You can share it in eagle? And tell where you want to manufacture it... Hope during too much time to see another status than "Sold out" for this item and others, that's a shame... I think I will take part of this bulk too. It should be fine as a first test for my OLRE16. Edited May 20, 2017 by Antichambre
ilmenator Posted May 20, 2017 Posted May 20, 2017 44 minutes ago, Antichambre said: Between you and me ;) it's easy to get the full version. Please, let's not promote this kind of software. The programmers should be rewarded for their work. If you can't or don't want to afford the legitimate version, then go for free software instead. Heck, you even know there is one out there but "hate" it. I don't get it...
Antichambre Posted May 20, 2017 Posted May 20, 2017 (edited) 1 hour ago, Antichambre said: I don't say you to do it Maybe my english is not enough 'subtile' I'm agree with you, my version is a full one with my own license, same thing for others like Autocad, one of the more expensive, AND I'm not a big society I'm freelance then believe me I know the price! And what they win... Then ok for this first thing, now. For Kicad, we can talk about and put Pros and Cons on a table, it's just my opinion after tried it, and it's not the purpose of the topic, you're not obliged to be agree with me, I understand that you can love it, I "get it". Like me you can just respect my opinion. I changed my post, for next time in MP please. @Lisa, I've got this licenced tool if you want to follow the rules. BR Edited May 20, 2017 by Antichambre
gerald.wert Posted May 22, 2017 Posted May 22, 2017 L31 is placed rotated 180 from all other leds on the board. It would not keep it from working but it would be good to rotate it for consistency. The SVG also seems to be off scale by about 5% or so. If I set the scale to 100% and print to 11x17 it is small. That may be something on my end I am just printing from chrome. Can not get to my inscape machine right now. I would route the red trace on the inside of the top right mounting hole and give the mounting hole plenty of clearance that way you can use washers if you want when you mount for strain relief. It is ground so not sure it matters it just sticks out to me. I have not seen anything else yet but will look some more as I have time.
lis0r Posted May 23, 2017 Author Posted May 23, 2017 I believe L31 is rotated on the original CS PCB, so I duplicated that to ensure the same instructions could be followed. i will have a think about the trace - the board is autorouted, and the tool is a bit of a pain to use. i'll try and find the time to make a PDF, hopefully that will deal with scale better than SVG.
gerald.wert Posted May 23, 2017 Posted May 23, 2017 I was comparing to this version: http://midibox.org/forums/topic/10998-mb-seq-v3v4-control-surface-pcb-and-matching-case/?do=findComment&comment=93863 It is rotated on the newer single board version on the wiki. Guess it really does not matter much it is not functional. Not sure the scale matters unless the board manufacturer will hit you with an additional setup fee if it is off. That is if they check for that. SVG should print accurately though. I might just be my setup. If the scaling error is in the gerber though that would be bad. Does it print scaled properly on your end?
lis0r Posted May 31, 2017 Author Posted May 31, 2017 (edited) Ignore this, it looks like the conversion from EPS to PDF has screwed it up. Edited June 1, 2017 by lis0r
lis0r Posted June 6, 2017 Author Posted June 6, 2017 http://www.bismuth83.co.uk/~lisa/v4.pdf When I load this in preview, the dimensions look about right, so fingers crossed this has converted properly this time.
Metalldorn Posted June 9, 2017 Posted June 9, 2017 Found these on the wiki. I'm not an expert on these in-board connections but maybe someone could use these for reference. http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=wilba_mb_seq:wilba_mbseq_pcb.pdf http://www.midibox.org/dokuwiki/lib/exe/fetch.php?media=wilba_mb_seq:wilba_mbseq_pcb_dimensioned.pdf
lis0r Posted June 9, 2017 Author Posted June 9, 2017 Those are exactly what I used for reference :) The thing is, I have gerbers, so once I'm happy with them, I can get boards made.
Metalldorn Posted June 10, 2017 Posted June 10, 2017 On 6/9/2017 at 2:18 AM, lis0r said: I can get boards made. Get boards made! ;D
julianf Posted June 10, 2017 Posted June 10, 2017 Lisa - just wondering if you have a time scale in mind? Im wondering, both for myself (ive never managed to get hold of a pcb set so far!) and also if i shouldnt be trying to make some cases for people in preparation.
lis0r Posted June 10, 2017 Author Posted June 10, 2017 Sadly my home printer is not really good enough for the task. Hopefully I will find the time to try printing out the layout elsewhere so I can compare it to panels, etc. early next week. Anything anyone can do to help regarding layout review would be much appreciated.
gerald.wert Posted June 12, 2017 Posted June 12, 2017 You should be able to print to a custom page. Just get some 11x17 paper and cut it 8.5 wide. set the custom paper as 8.5x17 and you have plenty of space to print it out. I have access to a large format printer and have printed what you have posted so far on 11x17 and it is scalled 10 to 15% smaller than it should be for some reason.
Synthy Posted June 27, 2017 Posted June 27, 2017 Hi Lisa, Did you order yet or could you put me on the list? Regards, Pim.
