Karg Posted July 10, 2019 Posted July 10, 2019 @latigid onObviously, the SJs were the problem. I swapped their positions, and all tests work well now. Will continue with the build, there should be only the case left now :) Thanks a lot for the help again!!!
Karg Posted July 10, 2019 Posted July 10, 2019 @latigid onAll assembled and works well! Thanks a lot for the help again, it always pointed to the right location. Pictures for the s/n will follow soon :)
latigid on Posted July 10, 2019 Author Posted July 10, 2019 Well done! I think yours is the first green-blue one, will be nice to see it! Best, Andy P.S. cheers!
lukas412 Posted July 15, 2019 Posted July 15, 2019 Hey guys having some issues with my jog wheel module. I think my core is ok, I can load programs and scripts and connect without issue. I'm trying to test the jog wheel module and getting crazy results. After loading the seq_l script no buttons work and all LED's light up. when i touch the back of the PCB everything goes crazy. tons of input to MIOS studio and random LED's lighting up. I check each led orientation as well as the diodes and other parts. I reflowed everything with the exact same behavior. All of my parts came from the Mouser list I imported on the Midiphy site. thanks, Luke
lukas412 Posted July 15, 2019 Posted July 15, 2019 (edited) 59 minutes ago, lukas412 said: Hey guys having some issues with my jog wheel module. I think my core is ok, I can load programs and scripts and connect without issue. I'm trying to test the jog wheel module and getting crazy results. After loading the seq_l script no buttons work and all LED's light up. when i touch the back of the PCB everything goes crazy. tons of input to MIOS studio and random LED's lighting up. I check each led orientation as well as the diodes and other parts. I reflowed everything with the exact same behavior. All of my parts came from the Mouser list I imported on the Midiphy site. thanks, Luke Ahhh! I should have read the thread I see Karg just had the same problem! Looks like I have the wrong part too. thanks all. Update, and of course it all works perfectly! Edited July 15, 2019 by lukas412
Karg Posted July 16, 2019 Posted July 16, 2019 Yes, it happens so quickly, and it is not that there aren't any warnings to pay particular attention to use the bussed network. :)
lukas412 Posted July 21, 2019 Posted July 21, 2019 (edited) Does anyone know what the part number for the Green LED in the Midiphy kit is? I broke one of mine and was going to order another set from Midiphy but the shipping is really steep to the USA for such a cheap part. thanks, Luke Edit: Midiphy are amazing I had a whole additional bag of LED's because they send you extra in the kit! Edited July 21, 2019 by lukas412
Adam Schabtach Posted August 20, 2019 Posted August 20, 2019 Okay, this is sad, but my construction efforts have run into problems at the first test point: loading the firmware onto to the MCU. Eventually I figured out that there's a short between +5V and GND on the USB PCB itself. I finally isolated it to this PCB by disconnecting the ribbon cable between the two PCBs. I've also removed the TVS diode, figuring that it might be the most likely place for a solder short. I've examined my solder joints with a magnifier and microscope(!) and have found nothing. Could I obtain either a schematic or the PCB artwork for this PCB? It would help with locating the problem if I knew which traces are +5V and which are GND. I'm assuming that +5V is on the first two conductors of the ribbon cable and GND is the last two conductors, based on the silkscreen notations near the ribbon cable connector. The next thing I'm going to have to do is start removing parts one by one, which is unfortunate since removing things like the USB connectors will not be easy. Thanks-- --Adam
latigid on Posted August 20, 2019 Author Posted August 20, 2019 Can you post a picture of the soldering? The most likely place is on either of the two USB connectors. This is the bottom of the board with the +5V and 0V connections highlighted.
Adam Schabtach Posted August 20, 2019 Posted August 20, 2019 Thanks. I can post a photo later today, but I'm looking at the PCB artwork you posted, and I am confused because it appears that the +5V and AGND nets are connected together in several places by the copper pour? Thanks-- --Adam
latigid on Posted August 20, 2019 Author Posted August 20, 2019 Please check the locations I mentioned and post a photo of your soldering. Don't worry, the pours are not connected otherwise nobody's board would work...
Adam Schabtach Posted August 20, 2019 Posted August 20, 2019 24 minutes ago, latigid on said: Please check the locations I mentioned and post a photo of your soldering. Don't worry, the pours are not connected otherwise nobody's board would work... Those are the first locations I checked since obviously they're the most likely to be shorted by a solder bridge. Here's the photo; thanks for looking at it for me. It's possibly worth mentioning that I have a lot of experience with this sort of work. I'm used to hand-soldering 0603s and TQFP100 packages. Obviously there's a mistake somewhere, though. I understand that nobody's board would work if +5 and GND are connected, but you're showing me an image which appears to show that they are connected. Hence my confusion.
latigid on Posted August 20, 2019 Author Posted August 20, 2019 Ha, you're right, the +5V plane is connected on this revision. Don't worry, we'll sort you out with a replacement. Peter will be in touch.
Adam Schabtach Posted August 20, 2019 Posted August 20, 2019 Hah! Okay then. Thanks for the confirmation. I will move on to other parts of the kit and await a replacement for the USB PCB. Maybe I will check for +5V/GND shorts on the other PCBs before I start soldering them. Thanks-- --Adam
Hawkeye Posted August 20, 2019 Posted August 20, 2019 @studio nebula Wow, very well spotted and thanks for finding and reporting the problem as soon as you did! It was correlated with our move to the new ENIG PCB process - will contact you shortly via email on how to proceed. What we will do: * check the other ENIG PCBs for this special problem (we don't believe others are affected, but we will check anyways) * contact everyone affected buying the core board since the switch to the new manufacturing process (about a month ago). * submit an express PCB manufacturing job and send the replacement boards free of charge to you and the other affected customers, as soon as we have the replacements in hand. Thus you will also get another "core main board", that you can use as a backup, as only the breakaway USB part is affected. * say "sorry" with a "free shipping" flag to everyone affected, thus you won't pay for shipping whatever you order, whenever you order next. From my main job as a consultant i learned that mistakes happen all the time, the difference is how you handle them, we hope to do the best here. Have a good day and best regards! Peter
Adam Schabtach Posted August 20, 2019 Posted August 20, 2019 13 minutes ago, Hawkeye said: @studio nebula Wow, very well spotted and thanks for finding and reporting the problem as soon as you did! [...] From my main job as a consultant i learned that mistakes happen all the time, the difference is how you handle them, we hope to do the best here. Hi Peter, I wish I had found the problem sooner; I had to delay work on my kit for awhile because of other demands on my spare time. Hopefully I found it early enough that you can contact most other affected customers before they begin soldering. Mistakes do indeed happen--I completely understand. After over 20 years in the music-tech business, and shipping over 40 software and hardware products, I have also handled many mistakes. Thanks for your help. You have a good day, too! Warm regards, --Adam
otropom Posted August 21, 2019 Posted August 21, 2019 @latigid on Hi everybody, I would like to put a simple on/off switch on the beast. Do you have any advice on wich emplacement i can safely cut a trace to do so ? thanks :)
latigid on Posted August 21, 2019 Author Posted August 21, 2019 Hello, There is no power switch, as you should typically ensure a stable power rail before connecting data and the solution to that was a bit to complicated. Imagine if it was already connected to your computer with data being sent but no power rail because it was switched off. I'm honestly not sure if this would be a problem for the SEQ or the computer. But if you would like to try, maybe something like this? You would need a USBA-USBA cable. https://solarbotics.com/product/19068/ Or a USB B with a switch on it: https://www.amazon.co.uk/Snowball-B-Male-Switch-Printers-devices/dp/B07GGT9XGT If you would like to drill a hole in the case, how about interrupting the +5V line from the USB board to the Core? This assumes that you haven't used the Molex power headers on the USB board. Simply wire an SPST switch to reconnect the +5V.
Antichambre Posted August 21, 2019 Posted August 21, 2019 5 hours ago, latigid on said: There is no power switch, as you should typically ensure a stable power rail before connecting data and the solution to that was a bit to complicated. Imagine if it was already connected to your computer with data being sent but no power rail because it was switched off. I'm honestly not sure if this would be a problem for the SEQ or the computer. Hi, there's no problem with that. 2 cases, device says "I'm here!" or host polls something like "are you here?"... In both cases the device always waits for a stable power to say something. No need of a complicated solution. Best regards Bruno 1
otropom Posted August 22, 2019 Posted August 22, 2019 Thank you latigid on and antichambre , i'm going to work on it :)
Antichambre Posted August 22, 2019 Posted August 22, 2019 In complement for an external power supply and USB power management. With this circuits the external power has priority over USB power. It works fine cause this is the one there is on all arduino uno board, so well improved. And I did the same thing on the dipBoardF4 external power module and use it. Best regards Bruno
knochenfabrik Posted August 31, 2019 Posted August 31, 2019 (edited) Hi guys, just finished my DOUT and AOUT modules. J8/9 goes directly from the LEMEC_R to the DOUT-module. When I turn the sequencer on it shows a strange menu (see picture). Do I have to conifgure something to use the module first or does this more look like a hardware issue? Thanks in advance, Alex Edited August 31, 2019 by knochenfabrik
latigid on Posted August 31, 2019 Author Posted August 31, 2019 Directly connected means no line transmit board? How long is the cable? What happens when you unplug J8/9 from le mec_R? Are any ribbon cables improperly assembled (shorts etc.)? Can you exit this menu? Do you notice strange DIN events with MB_NG loaded?
