274 -
26
Everything posted by dwestbury
Do it yourself open source SID - Announcement
dwestbury replied to Noise-Generator's topic in MIDIbox SID
This is becoming a promising endeavor! Total BOM costs include, the Teensy4 @ ~$20 USD, the PCB @ $17.50 USD, plus some pins and SMD parts. So, still a bit more expensive than the average street price for a Nano SwinSIDb, but Teensy4's will get cheaper soon and someone may already be planning a bulk order of PCBs soon, which would reign in the costs quite a bit. The most important consideration in my view is this being a live projects, with active development. There's always the possibility that FreeSID could come out sounding significantly better than SwinSID. Anxious to hear examples if anyone winds up building one or otherwise getting their hands on some. Cheers. -
- 88 replies
- 1
- sid replacement
- sid clones
(and 4 more)
Tagged with:
I finally found a little window of time to plop a set of ARM2SIDs into a MIDIbox SID to play with some patches, and.... WHOAH... In my humble opinion, they perform exceptionally well. I tested them with default configs (i.e., dropped them into a MIDIbox SID with no config changes), and can say that they combine a very low noise floor (e.g., nonexistent), and produce very accurate SID sound emulation, with reliably consistent volume levels, across all voices and various patches (So, Win-win-win.... ). The price-point for an ARM2SID set is ~$48 USD, which is a bit more expensive than purchasing 2 * SwinSIDs (which avg. ~$15-$20 each on eBay, or $30-$40 for a pair), but ARM2SIDS sound very accurate and produce consistently powerful output levels, irrespective of the patch chosen. I'm more than happy to share sounds from some patches or a popular SID track, if anyone is interested. Best, -Darrell
- 88 replies
- 1
- sid replacement
- sid clones
(and 4 more)
Tagged with:
By the way, I'm selling this synth in the Fleamarket [EDIT: SOLD] Which is why I got a bit nostalgic when I thought about actually parting with it, and I drafted the note above. I may never find out who the mysterious builder / seller is or was, but I'm certainly grateful for the transaction... ;-) Cheers all, -Darrell
Apologies for the suspense, but I struggle to find a few free minutes sometimes... Good news is, they test perfectly under minimal load on a breadboard. Not sure when I’ll have a chance to test one in an actual build though.
Seems like there are no takers here in the forum, so I'd like to try to sell these through another channel if possible. Any concerns with that? Thanks, -Darrell
To add some more context to this topic, I’m sharing the full side-by-side comparison as an Excel doc. The BOM reference is for a complete MB-6582 build, with two sets of sourcing options (one using mostly premium components from Mouser and the other uses more economical alternatives, from the likes of AliExpress, eBay, Amazon and elsewhere). _MB 6582 BOM - Economy vs Premium Build Cost Comparison - Oct 2020.xlsx The short of it is, you can make a complete MB-6582 today for around $513 USD, when you only consider the costs for required BOM components. However your total out of pocket expenses will actually be significantly higher, because you'll need to buy in bulk to get better volume prices (e.g., closer to $1,127 USD). This obviously means that after the build, you’ll have plenty of spares sitting around for your next build or another project. For a premium build, which uses real SIDs (8580 R5s), panels from FPE / Shaeffer and components sourced mostly through Mouser, your BOM will run closer to $1,221 USD. In this case, out of pocket expenses would come in closer to $1,661 USD, which means you'll still have plenty of spare parts left over, but far fewer than with the more economic option above. There are obviously many other sourcing and bulk volume options that can be considered and all of them would have an impact on these numbers, so consider this to be some type of rough guidance. Hope you find it as useful as I did when planning your own build(s)... Cheers, -Darrell
I’m guessing that SID playback should work, since that already works well to a MB-6582 or sammichSID using MIDI Patchbay and TK’s ASID mod for SIDPlayer. However, using MIDI encapsulation to manage the ARM2SID config is an altogether different animal... Waiting for a window of free time to give this a try though... Cheers
- 88 replies
- sid replacement
- sid clones
(and 4 more)
Tagged with:
For the most part, I've been sourcing my components from either Mouser and or Digikey, but lately I've started placing one-off bulk orders with AliExpress. You can typically find what appear to be great prices on larger quantities of discreet component, but then there's always that large shipping fee (at least to the US) and the significant wait time for deliveries (which typically take 4-12 weeks in my experience). So, I decided to take a look at some of the components I need for a particular BOM and compare the actual costs, side-by-side: In each case, I tried to source the cheapest components from reputable suppliers with the most positive reviews and feedback. You'll notice that the volume and quantities aren't exactly the same for all items, since Mouser required some minimum qty. for certain items. But in the end, the cost delta worked out to only be around 9%, so I decided to stick with Mouser for most of this order and benefit from the trusted quality and faster shipping time. Apologies if this is stating the obvious, but the exercise was helpful for me, so I thought it was worth sharing. Cheers, -Darrell
[EDIT: Both have been sold] Selling two sammichSIDs which were built earlier this year (March and May 2020). The silver one has two 6581 R4AR SIDs and the black one has two 8580 R5s. Both are running the latest MIOS 1.9h and firmware 2.044 Both come preloaded with tons of patches and ensembles from the forums and elsewhere. Happy to sell them together as a set or separately. If you already happen to have your own SIDs I can sell them cheaper with empty sockets. I’m based in the US (NYC area), so a domestic buyer would experience the fastest, cheapest and most reliable shipping. PM if interested...
I would suggest trying Julian's shop first: http://thebeast.co.uk/?product_cat=midibox He’s based in the UK and he typically has panel sets ready to ship internationally. And as I said above, his prices are the best I've seen (e.g., £80 vs £170) If you want to source local to Germany (Berlin), you can try Shaeffer: https://www.schaeffer-ag.de/en/front-panel-designer/?lang=en Whichever way you go, good luck with your build and post some pics when you're done.
I was planning to configure them using my Ultimate 64 (https://ultimate64.com/Ultimate-64) I can certainly give the Vice + ASID thing a try (Hmmm... Interesting)
- 88 replies
- sid replacement
- sid clones
(and 4 more)
Tagged with:
[SOLD] MB-6582 with Original SmashTV PCB and 8 * SwinSID Nano
dwestbury posted a topic in Fleamarket
I'm selling my first MB-6582, which has been with me for several years and has never let me down... I just finished building a brand new MB-6582, so it's finally time to pass along the baton to someone else, who wants a pre-built system to play with and learn from. Included are: 8 * SwinSID Nano Chips, which were recently assembled and they sound great IMHO (all configured to use the 8580 filter) 16 * 22nf metal film capacitors, just in case you want to swap in some real 8580s 4 * brand new PICs, flashed with BSL 1.2b, MIOS 1.9h & firmware v2.044 Banksticks are pre-loaded with plenty of patches from TK and the rest of the MIDIBox Community Using JST XH cables and connectors, which enables quick-and-easy removal and maintenance of the Control Surface Comes with a 12VDC 3A Power Supply compatible with 110VAC US power sources (it says it supports 240VAC, but I haven't tested that) Power Supply 5v regulator has been swapped from a linear 7805, which ran VERY HOT, to a nice-and-cool Recom switching regulator (e.g., https://www.mouser.com/ProductDetail/RECOM-Power/R-78B50-15?qs=YWgezujkI1JgY7IeN1uB3w%3D%3D) I’m based in the US (NYC area), so a domestic buyer would experience the fastest, cheapest and most reliable shipping. PM if interested... ** EDIT: This has been sold ** -
- 88 replies
- sid replacement
- sid clones
(and 4 more)
Tagged with:
