stryd_one
Frequent Writer-
8,840 -
Way to go dave! This kind of thing can be really helpful. Not to mention just fun to see what others are up to ;) May I suggest that, if you want to separate the posts into individual threads, you link to your other threads, so that if someone stumbles across part 2, they can find part 1?
Thanks Haris, but... Where are you?
He was on a mission for Mr Bin Laden. True! ;D Cimo: Sahira grows up so fast!!
MB-SEQ V3/V4 Control Surface PCB and matching case
stryd_one replied to Wilba's topic in MIDIbox SEQ
Nah not really..... It's a replacement module. I guess maybe you could do something tricky and connect wires from the core32 module, to the PIC socket on the old board... But some parts would need to be replaced too. Preferably, this is probably a job for ultracore32, but it should be possible without tooo much mucking about. -
Looks nice! Hope you don't mind, I edited your post to make the images fit in the window.
I should elaborate - the reason I suggested upgrading is also that there is a possibility the upload did not work properly last time. That's why it's important to use mios studio in smart mode and all that, just to confirm it. The ain64_din128_dout128 app is fairly simple, just need to tell the app how many ain and dins you have, and recompile. Once you've replied to jim's post (which has good advice in it which you should follow) if you are not able to compile it as such, I'll know your setup and can do it for you.
Thanks W! Now I know the type you mean.... Do you have a pinout for that one?
gen.c:12715 symbol iTemp6 = [ chn_msg_mask ] is in code space
stryd_one replied to This N°9's topic in MIOS programming (C)
Hmm... your example makes this smell like a gplink bug or something.... but the code you posted doesn't compile here: main.c:66: error 78: incompatible types from type 'struct midi_bus [16] ' to type 'char generic* ' main.c:71: error 78: incompatible types from type 'struct midi_bus [16] ' to type 'char generic* ' make: *** [_output/main.o] Error 1 Which is still leaving me wondering about your toolchain. ;) -
That display gives me wood.
Google seems to have confirmed my suspicion that monolithic refers to the method of construction, rather than the material used.... not sure whether a monolithic ceramic is interchangeable with a (not-monolithic) ceramic though?
Liar! that's a digeridon't! ;D
MIDIBox Mixer - A PGAx311 Audio Mixer
stryd_one replied to lylehaze's topic in MIDIbox User Projects
We like your OCD. Rock on. -
Also, yum.
That'll be a URL filter, I guess the whole chat app is not stored locally.... This is frustrating cause the new chat is rather nice. Maybe you could use another web-based IRC client, and it won't be blocked? We miss you G!
A butterfly flaps it's wings, Hermine the Huntsman Spider sees it, and it gets eaten? (For the non-chat-dwellers, that's my resident pal. Isn't she pretty?!)
Video of MB Sid, Seq, + Klee Sequencer all in 1 unit
stryd_one replied to Smithy's topic in Miscellaneous
Jst t clrfy - 'm nt rfrrng t th bxs n th ntl pst, r thr crtr. Dnn th stry thr nd cldn't cr, tht's nt th sbjct f th dscssn 'm hvng. mn. S, yr lgc s, tht ppl rn't ctv n th frm, bcs thy dn't wnn b dssd fr nt syng thnky? r jst bcs thy gnrlly dn't lk hvng t srvd p jst lk t s? f s, 'm gld - cn crtnly lv wtht sch ppl. 'll dss thm nywy, thy'll sht th mssngr. t's th dn thng. t lst y hv th chns t sy t 't my fc', bt y'r stll shtng th mssngr. Crm t p yr hlr thn th, bgfght ;D (PS: nyn NT hvng mtllc sng stck n yr hds nw, cn lv) t lst h hs th blls nd pssn t stnd p fr smthng thr thn lyng dwn fr vryn. Y'r bng sft. Clm bhvr s gd fr clm mmnts. c-bmbs r gd fr ppl ctng lk c-bmbs. Sy t lk t s smthy, sy t hw t fls, nt hw y'r mnt t ct. lkd t bttr whn y shwd sm pssn. 'v cnsrd th hck tt ths pst jst fr y prm. 'm stll nt sr f tht ws th rght thng t d, fnd bf's nd yr tttds fr mr ffnsv thn ny swr wrd...ll f whch hrd n 2nd grd...srsly mn, tghn p, swrng s nt gng wy, y bttr gt sd t t. S th thng s, f fnd yr tttd ffnsv, shld y stp xprssing t? nd, f y fnd my wrds ffnsv, shld stp syng thm? S f y cn fll n th blnks n th n nswr t bth qstns: F*** n. t's nt lk nyn hr swrs *lt*. f smn ws rlly tt ln, swrng ll vr nd mkng th frm gnrlly xclsv f yngr/ldr/rlgs/tc dds, tht mght b dffrnt, bt ths ws n swr wrd, sd n n pprprt cntxt. Th wy y gys bhv, t's lk dsgrmnts dn't hppn whr y lv r smthng. Lk y dn't spprt th cncpts f pssn r mtn rngr r frstrtn r stndng nd vcng nd fghtng fr yr blfs.... Yt, hr y r, stndng nd vcng nd fghtng fr yr blf, tht ppl (smthy nd n ths cs) shld nt stnd nd vc nd fght fr thr blf....Whch mks m wndr: r thr ny gd prtmnts fr rnt n Jptr? -
confession: I *still* use them every time i solder a board. It's either that, or rely on my memory. *Not* a good idea ;D
Are you sure J5 is behaving normally as a test? (IE, not with this app?)
'm knd wth smthy n ths n. ftr ll tht th cmmnty (nt nly TK, w ll spprt ch thr) gvs t hlp ppl b bl t crt mdbx, t wld crtnly b nc f thy spnt fw scnds t sy thnks, nd gv smthng bck. t's nt lk w xpct thm t dlvr tch spprt nd fght bgs nd sch, t's nt "rl" r nythng stpd... jst cmmn gd mnnrs. f smn dsn't wnt t d s, tht's thr prrgtv.... nd t's mn t btch nd mn bt th rd bstrds ;) Jst bcs ccpt smn's rght t chs fr thmslvs, dsn't mn hv t gr wth thm. -
That's probably not necessary. The idea is to use the zip files on ucapps.de, as they have been tested. Cowboy developers like me may have broken the SVN versions ;)
Sweet! Can you tell us more about the linux software? Is it uCLinux or ..? Curiosity.....
Is there much in the way of DIY projects around that beastie yet? (the NGW) Something else worth considering is an asus eeebox... They're numerous, so they're cheap, and there's lots of support. About the size of a hardback at 223x178x26mm...no PCI slots but plenty of USB, and WLAN built in, etc... at 350USD it's more than the parts for a real embedded system, but you might save a lot of hassle...
PM coming your way ;)
