pay_c
Frequent Writer
    1,468
Everything posted by pay_c
  1. Perhaps a little burn out of the PIC. To avoid something like that: Before you begin working (or better said touching) on the core or other modules touch a grounded piece (blank metal piece of your heater will do just fine) with the one hand first and then touch the ground of the core (or whatever) with the other hand. That will bring you and your stuff on the same ground level (ground potential) and electrical charges are down to zero.
  2. ;D ;D ;D *without words*
  3. pay_c
    shops@berlin!!!
    Gaaaaaaanz wichtig: Reichelt!!! www.reichelt.de anklicken und Katalog kommen lassen! Weil: Die kosten die Hälfte von Conrad und haben (meist) bessere Bauteile!
  4. For the amperage: Yepp, if you got a LCD with BL you´re pretty sure above the 200 mA limit. *If* you still want to measure it, just detach the LCD. Should be well below 200 mA then. But if the 7805 does get *decent* warm like you described everything should be just very fine. Those (sometimes indestructible - ;) ) 78xx work up to a temperature of appr. 80°C. So you only want to be concerned if you are likely to burn your fingers. ;D Hoping for another 9,95-deal for you! ;D Greetz!
  5. For the shutting down and powering back on very fast: That´s pretty normal. The cap stores a little energy over a short time, so if you power back on within a range of let´s say 2-4,5 Volt, everything is messed up (especially the LCD controller) - so no problem about that. For the Midi problem: Did you use a LTC? You did not use the MAX-IC, right? Looks like your Midi In somehow gets to the Midi Out. For testing out the Core (only) unplug the Optocoupler (small 8-pin IC) and look if it works then (just keep the LCD connected - the LCD has nothing to do with the MIDI stuff). Greets!
  6. I can´t help you with the schematic thing right now, but at least your second core works! I´m sorry for the 2x40´s! That´s hard! If the new core works, just try them again! And: Nope, never seen a fading like you described on a LCD... For the current measuring: Some meters do have: First a fuse (inside) which is burnt really often, second another In only for amperage stuff. Did you try? In series means that you used your meter as some sort of power switch, right? One pin (core) goes to power, the other first into the meter, from the meter to the power, right? Don´t give the displays up already! Normally they´re pretty indestructible (with what do I know secure stuff). *thumbspushing*
  7. If you use 78xx the caps *should* be there in any case - should means no must anyhow. So at least you should use one cap (like 1000 µF) between the power and the 7809 and another one after the 7809. And then the normal caps already on the core. I would even think about adding more of those things, because: 16 Volt - 9 Volt = 7 Volts; 7 Volts * lets say 300 mA = 2,1 watts pure heat - really much for a 78xx (heatsink!!!) Perhaps a 7812, then the 7809 and back to the core (7805)?
  8. What about reburning the bootstrap loader? This way, you delete everything else on there...
  9. I am not sure if albs has those (as they produce theirselves, the chances are pretty good) - what about an email to info@albs.de?
  10. Ooooops... 4,25 Volt are to less. Did you connect the +5 Volt as shown on UCapps.de? http://www.ucapps.de/mbhp/mbhp_4xsid_c64_psu_optimized.pdf Looks like you connected the 5 Volts to the In of the 7805? Anyhow: Does your 7805 get very hot? I *think* the PIC gets to less voltage and so goes into a boot loop - so it is sending MIDI data all the time.
  11. albs has a whole bunch of knobs also: www.albs.de But be warned: Although the knobs themselves are pretty fair-priced, the minimum order starts @ 60.- Euros for private, they won´t give you anything if you land below that. Fortunately they also got ALPS Pots/Faders/Encoders etc. I do not know if they ship to countries outside Germany, but anyhow, just ask them. Here are *some* of their products - more on the page They also got a good variety of fader knobs!
  12. - W e I r D - ??? Well, ok. What crystal do you use? 10 MHz, right? Sometimes swapping the pins can help, but that´s more or less some seldom thing. Did you install the small ceramic bypass caps as mentioned on UCApps.de? They could help, too. Did you already attach a heatsink to the 7805? And do check the current. Still hoping...
  13. Does your 7805 get very hot? What power supply do you use (enough power? Voltage?) ? Did you check the main voltage? +5 Volts (+/- 0,2 Volt max) / Ground?
  14. ;D Well... *I* do sell some, too! ;) http://www.midibox.org/forum/index.php?topic=5328.0 Just look up there, I´m selling 30 used (but rechecked) buttons like those TK used. If you also need other stuff (which you see there - should all be relatively self-explaining - if you don´t understand something just ask me) just contact me. BUT: The posting fees from Germany to the Netherlands are 17,50 Euros, so if you *only* want the buttons, stick to Voti. *Just* wanted to mention ;D ;D ;D
  15. Jojo, ich halt den Thread immer auf dem neuesten Stand. Alles was du auf der ersten Seite siehst ist auch da! PCB-mäsig werd ich dir wahrscheinlich nicht mehr weiterhelfen können, Rio ist gerade an den letzten DINs und DOUTs interessiert. Schau einfach mal rein, schreib dann gleich oder PN mir einfach.
  16. Also wenn ich´s als Großbrief verschick (gepolstert türlich), dann sinds genau 20 Öcken. Außer du willst es als Paket haben (ist halt die sicherste Methode). Aber ich glaub, mike verschickt sein Zeuch auch immer in Großbriefen, richtig? Also müsste das schon koscher sein. Also mit Großbrief 20 Euronen für 3x DIN, 1x DOUT. Gebongt?
  17. Those used by TK are found @ Reichelt: www.reichelt.de Ordernr: e.g. "Taster 3301D" for 0,10 Cents a piece. But they can be found nearly anywhere, since those are nearly standard-buttons, like already stated. Here is the datasheet for them: http://www.reichelt.de/inhalt.html?SID=18Irg%2540WKwQARMAAEK12Ige7c286d03cd8dad506fc7653ee2dfa80;ACTION=7;LASTACTION=6;SORT=artikel.artnr;GRUPPE=C223;WG=0;SUCHE=Taster%25203301B;ARTIKEL=TASTER%2525203301B;START=0;END=16;STATIC=0;FC=670;PROVID=0;TITEL=0;DATASHEETSEARCH=TASTER%25203301B;FOLDER=C200;FILE=TASTER33%2523APM.pdf;DOWNLOADTYP=1;DATASHEETAUTO=;OPEN=0
  18. Ööööhm, nojo: 12x "74HC 165" bei Reichelt: 12x0,36 = 4,32 Euro Also eigentlich ja kein Prob, nö? Ich mach leider nur z.Zt. keine Reichelt-Bestellung, sonst hätt ich die schon längst nachinstalliert. Also ich glaub schon, daß 18.- Euro für das Zeug ein sehr guter Preis ist, vor allem, weil man nix mehr zu löten hat. Also... find ich jetzt... :)
  19. LOL ;D Jau, das ist dann türlich cool... 8) Ich versuch mir gerade vorzustellen, wie eine MB... mit 20 2x40ern ausschaut... *Größenwahnmoduseinschalt* ;D Hast schon recht, der Unterschied zwischen MB64 und MB64E ist fast nur noch Formsache. *Einziges* Prob: Dadurch, daß du den Multiplexer einschalten musst, um genügend Potis anzusteuern, fangen die LED-Ringe das Flackern an (beim Drücken von Knöpfen) - hab ich noch nie selbst gesehen, wie das dann ausschaut, aber so stehts in der main.asm der MB64E. Muss man dann halt *noch mehr* LCDs verwenden... ;) In jedem Fall find ich, ist die MB64E zu bevorzugen, weil die flexibler ist. Aber zum Glück sind ja beide untereinander ohne Probs austauschbar (a bisserl die main.asm anpassen und dann funzts).
  20. Sind keine Bausätze, sind schon fertig... 8) Und ich hab leider nur 1x DOUT und 3x DIN hier vor Ort. Ich bin im Preis schon so weit runter wie möglich (3x DINx4 für 12.- Euro!!! Die *Bausätze* würden bei SmashTV zusammen 24 Euro kosten), von daher 18.- Euronen zusammen (Neupreis Smash: 32 Euronen für die Bausätze).
  21. Also wegen den MB64 oder MB64E find ich: Eigentlich wurst jetzt, oder? Du kannst auch mit 1x AIN, 1x DIN als MB64 anfangen (wie schon vorgeschlagen), schauen was du weiter brauchst bzw. was du als Encoder ausführen willst. Denn: Die AIN lässt sich dann in der neuen Version von MB64E weiterverwenden! Sprich: Encoder, Potis, Schalter... total egal, passt alles rein. Darum find ich eigentlich, daß nix gegen ein paar Pots spricht, die kann man immer gebrauchen (bspw. 32 Encoder, 64 Potis, 64 Schalter und ne Meeeeenge LEDs ;) ). Den Vorteil, den ich für Pots empfinde (wenn man keine LED-Ringe hat) -> man "sieht" immer die Position. Bei nem Encoder nicht unbedingt... Bei meinem Traktor-Controller Projekt werden jedenfalls auch Pots eingesetzt werden (neben den Encodern). Nojo, hat jeder so seine Vorzüge, oder? ;D
  22. :P http://www.midibox.org/forum/index.php?topic=5404.0 Greets :)
  23. Hmmm, ich hab jetzt gerade rumgegooglet, aber nix Dolles gefunden... Kannst du mal ein Datenblatt o.ä. hier rein stellen (Link). Oder was willst du denn alles steuern? Allgemein kannst du auch erst einen kleineren MB64 bauen (mit meinetwegen 16 Pots o.ä.) und später darauf aufbauen und erweitern (ist dank Modularität schön einfach). Gruß pay.c
  24. :o And you got noise?!? Woah... I´m about to remember Edirol... Only idea then: Also try a shorter firewire cable (I had probs with a to long USB cable once). If the cable gets to long it will act like a antenna.
  25. Recheck your connection between the core and the LTC. Perhaps there´s something (sounds like switched input/output or similar). If not: Try plugging in the LTC without the 74HCs. If everything works, put back the one 74HC for the LEDs, if that still works etc. This way you come closer to the problem.
