nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. Moved & renamed accordingly ;)
  2. Without saying that any of the below is correct, there's more than tzwo options :) a) SIDs were broken to begin with b) Damage during transport, kinda unlikely though c) broken while fiddling with and trying to build them into a midibox SID d) aliens obducted them and brokeded them in the process (aliens do not like chiptunes)
  3. C9, C10, C13 and C14 are part of the DACs' sample and hold circuits. The 2n7 is the suggested value from the YAC512 datasheet. Pick something decently close and it'll work (possibly not as nicely).
  4. Eigentlich eher +12. Aber 128x64 Pixel VFDs sind mir in letzter nicht allzu viele über den Weg gelaufen.
  5. Doch. Reset, heißt ja nicht "so lange das HIGH (oder LOW, Datenblatt fragen) ist, wird das Display immer wieder zurück gesetzt", sondern, "wenn's HIGH (oder LOW, Datenblatt fragen geht) ist, ist das Display an". Du kannst Dir den Reset-Pin also als Ein-/Ausschalter vorstellen.
  6. Muss ich wohl mal wieder nach München kommen, was? ;)
  7. ...and that's fairly common with SIDs, especially with 6581s.
  8. You'll have to get all of the parts for the control surface from somewhere else, as Smash doesn't stock those. You seem to have a bunch of SIDs, some C64 PSUs... I guess once you have the baseboard kit you're ready to go :) You don't *need* the CS for it to make sound and play .sid files etc, so tackle the baseboard first :)
  9. You measured the resistance of the caps... Interesting ;) Since you don't really know what's hooked up to the caps in the SID (unless you can read the die-shots) the only thing you can learn from that is that, well, they're different. That doesn't really tell you anything though. The filters in the SID are analog and hence have some tolerance, hard to tell to which degree those tolerances are "normal".
  10. "As standard as possible" with 8 SIDs == mb6582
  11. If *everything* except for the filters is working, then your SIDs most likely have broken filters. Do you have a way of testing them in a C64 or some other known-to-work circuit?
  12. No. Someone's simply trying to keep the forum somewhat readable. And full quotes are completely unnecessary and pointless, especially when the quoted text isn't even being referenced.
  13. Also im Endeffekt keine echten Probleme, sondern kleine Unannehmlichkeiten.
  14. de.rs-online.com - nicht die allergünstigsten, dafür versandkostenfrei, was bei winzigen Bestellungen recht nett ist. Suchhilfen: "Stiftleiste" oder "pin header". Kann sein, dass Du Probleme haben wirst die in der Länge zu finden. Da kannst Du entweder mittels eines männlichen+eines weiblichen schummeln, oder einfach mal Wilba fragen. Der kann bestimmt per Brief einen an Dich schicken :thumbsup:
  15. Gar nicht. Neuen Header kaufen.
  16. Whee :frantics:
  17. Where'd my first post go... Oddness.
  18. Should work.
  19. Soundwell
  20. Topic moved and renamed. Please follow the instructions...
  21. CopyPasta und nILSTranslate um genau zu sein.
  22. Ob das wohl rechtens wäre? Aha. Das legen die dann einfach fest, obwohl es ein Geschenk ist? Ist doch eins. Steht doch drauf. Das will ich sehen. Viel Spaß beim zählen der Widerstände, Herr Zoll. Außerdem ist der Warenwert doch 100AUD. Steht doch drauf. Nö. Weil wegen is nich'. Und es geht auch keinen was an. Wenn ich meiner Kleenen 'nen Ring schenke, muss ich doch auch dem Juwelier mein Motiv nicht erklären (und sie erst recht nicht). Ist halt ein toller Freund, der Dir verspätet zum Geburtstag was schickt. Ist doch auch völlig Rille. Ist ein Geschenk. Alternativ, kannst Du natürlich auch mit eine Rechnung (so es denn sowas gäbe, weil es ja ein Geschenk ist) beim Zoll antanzen und löhnen. Das ist aber aus Deiner "die notieren alles"-Denke raus für alle anderen ganz doof. Weil dann wissen die "oha, da stimmt was nicht!". :whistle:
  23. Meine (völlig legitime) Herangehensweise: Ist ein Geschenk (deshalb steht's ja so auch drauf), da gibt's selbstverständlich keine Rechnung zu. Also kann ich auch keine vorbeibringen. 100AUD steht drauf, weil das so ist. Kann ich jetzt bitte mein Geschenk haben, ich will nämlich löten. Danke.
  24. Glad you got it to work :)
