nILS
Frequent Writer
    4,313
    3
Everything posted by nILS
  1. Ooooooh! You better make sure your imaginary g/f never reads that ;)
  2. nILS
    Clockbox
    main.c
  3. ...mainly that means you need a new mulitmeter ;)
  4. Cool, now I gotta find something to actually put em on ;D
  5. nILS
    Hilfe bei Din Modul
    Genau. Ob man bei 0 oder bei 1 anfängt zu zählen nimmt sich ja nix.
  6. [ x ] POIDH
  7. ...Protel/Altium Designer, Pads, Diptrace (comes with a freeware version as well), Osmond PCB (mac only iirc), Rimu PCB,...
  8. Correct, the vreg is just sitting there as a size-reference ;)
  9. ;) I am not dangerous. And I never do dangerous stuff like mod tubeamps or the likes ;D
  10. My head is always shaking really fast. Crack + coffee == bad combo ;)
  11. whee ;D
  12. nILS
    Hilfe bei Din Modul
    http://www.reichelt.de/?;ARTICLE=8233;
  13. I got bored a while back: [img width=640]http://schickt.de/temp/whee2.JPG
  14. eww green stars!!!!!!1111oneeleven [me=nILS Podewski]runs to the hills[/me]
  15. This topic has been moved to MIDIbox of the Week. [iurl]http://www.midibox.org/forum/index.php?topic=13484.0[/iurl]
  16. Es liegt _nicht_ an Windows, sondern an irgendwelcher Software, die da irgendwo laeuft und da irgendwie reinfingert ;)
  17. Try following these instructions they should answer your questions: http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_quickstart
  18. Continuity with 0 Ohms between +5V and Ground is usually a very bad thing ;)
  19. SIDs do have a tendency to get pretty warm (you should at all times be able to keep your finger on it). If it gets hotter than that there's possibly sth wrong. Check the wiring, voltages, ... If that doesn't bring solve it - add a heatsink.
  20. Solidworks is not over the top, but a really bad choice. If you're not already really really good at laying out PCBs you should really really go with a pcb design app, as they do a lot of the work for you. Like error checking and the likes ;)
  21. I am optimistic I can fit them within the freeware-eagle size limit ;) (this is me kidding btw, I haven't even seen the schem)
  22. For me it's: * The UI actually got worse. It runs a lot slower than 4.x on pretty much any Windows machine I tried it on (supposedly this is not the case on MacOS) * The new drawing algorithm limits the selection of useful colors even further as most color combinations just lead to an unreadable mess. * A lot of commands have been moved into popup menus that were not there on 4.x, which means a lot of extra mouse moving and clicking. That doesn't really sound all that bad, but it's incredibly annoying when you're tweaking a layout and spend 30% of the time clicking menu items that weren't necessary or even there at all before.
  23. nILS
    Hilfe bei Din Modul
    Woher Du Masse für den Abblockkondensator nimmst ist egal. Am besten möglichst nah am +5V Pin.
