812 -
Everything posted by bugfight
	oh there definitely seems to be an ego trip going on... maybe i will if you will, i've given one ref, that's enough for now, where's yours?? because it is intentional ignorance. so you claim now. scroll up. from your own words. read them again. try to be objective. if you didn't mean to say what you did say, a retraction might help sheesh, this is why i posted anywayz, because of your outrageous claim of nameity based on "a billion dictionaries and music theory books backing up my statement" i settled this argument for myself over 20 years ago, and see no need to rehash it now, but i couldn't let that claim stand. you are definitely entitled to your own opinion about it... and now you claim to know my subconscious mind... you made a claim of originality, which i refuted. you made a claim of nameity, which i refuted. then you resorted to an ad hominem argument. it is quite disappointing...
				SwinSID - a pin compatible alternative to the SID chip
bugfight replied to TheFumigator's topic in MIDIbox SID
this is all that is really important. there's nothing wrong with vias in general (unless you are etching your own pcbs) but i do avoid placing them near pins under an smd, since a solder bridge there will not be visible. you can use the vRestrict layer to prevent the autorouter from doing this -
	aha! that's why i felt smarter yesterday! it's true: more posts makes you smarter. now i just have be careful to avoid the effects of the curse... *whack*
	i didn't mention my degree to diminish anyone who doesn't have one (though you seem to want to do so to anyone who does), only to support the fact that i have read many music theory texts. while most of them didn't bother to specifically touch on the definition, the ones that did agree with the previously linked definition and none agreed with your "original" definition was this your reason for claiming the following? while it is noble to take responsibility for you own education (something i also do), there is nothing noble in denegrating all universities and all people who attend them without even attending one
	does a degree in music count? from wikipedia (http://en.wikipedia.org/wiki/Music): "Music is an art form in which the medium is sound organized in time." this is in line with most music theory texts i've read. btw, Messiaen annotated bird song in his music, i don't like it much, but it's music (hey i feel much smarter today)
	the original is greek, and applied to all the arts...
	d00dz, how about this for make the ableton live controller? seemz goodz 2 me... http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=170167364317
	hmmmm, not recommended. you can exponentiate electronically, but these circuits are finicky and the pots are probably not true log curves, so you would wind up with nonlinear response anyway. you can use a look up table but you lose resolution (and more at one end than the other) and you would need to fine tune the table for each pot to come close to linear... otoh, those would be great for an analog audio device
				2 sids to 1 core clarification (a.k.a. Noob goes stereo)
bugfight replied to Snoozr's topic in MIDIbox SID
as wilba already pointed out, for one stereo pair, it is 1:1 (except for that pesky pin labeled "SO" on SID1 R) here's an easy way to make this cable: - make a ribbon cable with a connector on each end and one in the middle (make sure they are all oriented correctly with pin 1 on the same wire) - connect each end to a sid module with pin 1 at SO - connect the middle connector to the core - cut just the SO wire on the SID R side of the core connector, and pull some of that wire away from the ribbon (enough to reach J14) i find it unlikely that you will get noise from the power supply connections on J10 with just a stereo pair. if you do, you can always cut those two lines later and connect them directly to the psu as in the pdf -
	i have to say, despite the comedy gold of the "yo dawg, d00d" etc, there's not too much i disagree with. he has some good advice for a budget home studio. the behringer can go away, and so can the carpet all over the place... i can forgive him for not getting into real acoustic treatment in a budget studio, but then maybe neumann and genelec don't belong either...
	hehe, "i'll be *whack*"
	cv == control voltage. with the midibox aout module you get 8 cv outs, which can be used to control anything that takes a cv input, for example a modular synth, or an analog keyboard or expander or or... the midibox cv is an application that implements midi control of the aout (as well as some other goodies). so it's not a filter, but you can control filters with it...
	oh cool, they are back in stock. i have a bunch of those, they are indeed the clicky kind. haven't used them yet, awaiting nicey caps for them...
				SIDbox in Progress, Core Done, LCD Working, DIN4X trouble solved?
bugfight replied to snebenan's topic in MIDIbox SID
uh oh, no they are two different signals. SO on core J9 connects to SO on DIN J1 if you have indeed connected it this way, this is the source of the trouble. it could just be due to a misreading of the labels on the DINx4 though. J1 on smash's din has no label for SI (SO is just a pass through to SO on J2 so you can connect a dout on the same chain) these headers have the exact same pinout as j8/j9 on the core, so all you have to do is make sure pin 1 on each side matches... -
i notice you are listing SI here, which should always be 5v during the srio test. you want to test SO (SO == serial out, SI == serial in) d0 on the lcd is a completely different signal. i think this must be a typo, since we tested the pins directly on the pic while in the chat, but lets be sure... -
	no doubt, all 8 going will rock. i'll remember to bring the right cables this time...
				Who wants +/-15 and +5 triple secondary toroids?
bugfight replied to Doug Wellington's topic in Bulk Orders
the xformer outputs 5vac, you still need to rectify and regulate it... i'm not sure the opl can take +-15v, but current draw is low enough you should be ok with feeding 12v regs from this xformer... btw, doug, i have had issues w/ using a 7vdc wallwart on the midibox core, which is what you should get from 5vac * 1.414 if it is rated at a higher current than you pull, it could be ok, but it is cutting it a bit fine for the usual 7805... -
	this seems a good place for this. here's a pic of lars threatening his midibox seq with a cigarette at a dfw sdiy meetup. he was controlling my mb-6582, which i managed to not get a shot of... trademark blurry camera phone shot too, there are some better shots taken by pristak (who organized the meetup) here: http://www.flickr.com/photos/29424740@N04/ the seq rocks and the combo is killer sdiy-dfw_lars.JPG
	you might try splitting your update into 2 sends... this should work fine. just disable ain. but it would be cool to combine motorfaders with a mixer... there's a nice pin ref in the wiki...
	and now bugfight.com is famous and popular! i mean i was always famous, just not many people knew... thanks, twin-x
	wow, 10 years. coolness. big thanks, tk. look what your "housings can you tinker itself" has become... it's customary to celebrate such major holidays on solstice or equinox. therefore, i suggest june 22 as midiboxday. there will be "it's working dances" and solderingironkisses and *whack*ing etc what will smashklaus bring me next year? btw, wasn't the midibox originally on a page on your personal webpage or likesuchas?
	this is fake! as you can clearly see at the 1:01 mark, he has removed some frames. nice try 8O... WATCH OUT, n00b, DON'T TRY THIS AT HOME!!
	ahhhh glad you have come to your senses. i accept your apology...
