Screaming_Rabbit
Frequent Writer-
1,431 -
Everything posted by Screaming_Rabbit
ALPS RSA0K11A1-B103 "K-Fader". Where to get in Germany?
Screaming_Rabbit replied to phunk's topic in Parts Questions
Since you ignored my first post... I'm just trying to avoid you spending money for nothing. ;) ... the only K-Type I can find at Farnell is LOG: http://de.farnell.com/jsp/endecaSearch/partDetail.jsp?sku=1191704 ... it says "Gehäusetyp: linear" which means "linear fader" but the taper is 10k LOG Greets, Roger -
Caution! The only K-Type I can find on the farnell webpage, is LOG. For MIDIbox you need a linear fader. Greets, Roger -
...yes. But there are also conductive plastic fader knobs available www.albs.de Greets, Roger
Are these encoders or its something else?
Screaming_Rabbit replied to Djo's topic in Parts Questions
http://www.gefran.com/files/prodotti//8ec05357-8f27-4ee2-b4d0-3a80e2544425_ds_PS_ing.pdf Greets, Roger -
Why not use an external MIDI-Thru to split the signal? http://www.ucapps.de/midibox/midi_thru.gif - connect the MIDI Out from your host to A3/B3 - connect the output of Y3 to A1/B1 and A2/B2 - so you'll get 3 "amplified" MIDI Outs at Y1, Y2 and Y4 Google for "DIY MIDI Thru"... I once saw some complete DIY shematics Greets, Roger
... just guessing: I think these are those Mackie shift-functions, where "arm" means "arm/write automation" and "fader position" means "snapshot to zero-/unity gain-position" of the fader. Greets, Roger
... don't hope too much. - This is the awful downside of free enterprise. Some decades ago it was Japan now it's China and Korea. You for shure are right and this situation makes me sick. But what do you want? If you want to be competitive in the marked, you have to buy the ICs and other components there, because your competitor will do it and he will beat the price down. The only way to do a tiny action against this is (that's what I do), not to buy those "over cheaped" end products like whole HiFi setups for $100, screwdrivers for $1 and, and, and... But the action is tiny, because your neighbor will buy the stuff for a couple of bucks and keeps the business running. Greets, Roger
... warum nicht OnLine? = Gratis Wenn Du unbedingt ein Buch haben willst... in der guten alten Brockenstube (so heisst das jedenfalls in der Schweiz... weisst Du, die Gebrauchtwaren-Schuppen von der Heilsarmee), gibt's tonnenweise Elektronik Bücher. Greets, Roger
Where else? ... Might be the reason that you can buy them for a few dollars ;) I think all displays are made in "cheap" china Greets, Roger
... no - PWM is digital driving
[s] studio parts (mixer, groovebox, synthesizer, turntable)
Screaming_Rabbit replied to basti's topic in Fleamarket
Everything for free? ... It seems so, since I can't find any prices. -
... das sind einfach 2 Dioden in einem LED-"Gehäuse". Diese LED's, von welchen Du sprichst, haben eine "common Cathode", was heisst, dass die minus pole der beiden Dioden intern (in der LED) zusammen gehängt sind. Du kannst also ganz einfach, wenn Du SmashTV's oder Mike's Bausätze verwendest, die mitgelieferten 220Ohm Widerstände verwenden und je einen Out-pin des DOUT-Boards auf jeweils eine Anode hängen und die eine (gemeinsame) Kathode zurück auf "Vs" des DOUT-Boards. Greets, Roger
... cool! I was thinking about that too but let it go exactly because of this problem :'( Greets, Roger
... I think I know what you want: Is it for triangle shaped LEDs? The problem is, that you wandt sharp edges but this is not possible, since you always have the diameter of the grinding tool. Triangle with sharp corners have to be punched or Laser-Cutted. Greets, Roger
Ist den der LCD mit dem Controller HD61200 kompaktible zur MIOS?
Screaming_Rabbit replied to kmboss78's topic in Deutsch
... wenn Du nicht ein geübter Elektronik Crack bist, musst Du Dich länger mit den Forumseinträgen rumschlagen, dann wird mit der Zeit manches viel klarer. Wenn Du aber per sofort, ohne die nötige Erfahrung, einen Controller bauen willst,dann baust Du am besten TK's Controller 1:1 nach, bestellst die selben Teile usw. Wenn Du jetzt einfach Teile drauflos kaufst, kannst Du viel Geld in den Sand setzen. Grüsse, Roger -
Hello Does anybody know about those displays (http://pdf1.alldatasheet.com/datasheet-pdf/view/103297/INFINEON/SLR2016.html) can be driven by MIOS and if yes, how? Thanks, Roger
...not mouser but cheap. http://www.bgmicro.com/prodinfo.asp?sid=0602418981481481816220133&prodid=LCD1022&page=1&cri=LCD&stype=2 Greets, Roger
http://www.ucapps.de/midibox_lc.html Bezüglich LCDs nötig oder nicht: Suche im Forum... X Artikel zu diesem Thema
suche im Forum!!! X Artikel zu diesem Thema
DIY illuminated buton, Datawheel for the MIDIbox Community
Screaming_Rabbit replied to moxi's topic in Parts Archive
http://users.adelphia.net/~skbosko/Robot_top.htm Greets, Roger -
... an other solution than ripping mices appart: http://www.alliedelec.com/Images/Products/Datasheets/BM/HONEYWELL_OPTO_PRODUCTS/Honeywell-Opto-Products_Actives-and-Passives_2760060.pdf another Fader technology which could be easy DIYed (mechanical wise): http://www.djstatus.com/rane3.html http://www.rane.com/ttm56video/colatest.wmv Greets, Roger -
...Yepp, kommt rüber und zurück ::) http://www.ucapps.de/mbhp.html Greets, Roger PS: Ich denke, das Design und die Funktionen sollten von Dir kommen, dass die dann halt so blinken, die einzelnen takte im beat :-\
I think your Joystick uses pots (perhaps even 10k) http://www.ucapps.de/mbhp_ain.html connect your pots directly to the AIN. - No need to convert any digital format. Greets, Roger
Grundlegende Fragen zum Motorfader und Meterbridge
http://www.ucapps.de/mbhp_mf.html ... suche im Forum danach, dies war mal ein Thema. Ich glaube aber, dass es niemand realisiert hat. http://www.ucapps.de/midibox_lc.html Greets, Roger
