1,184 -
30
Everything posted by Altitude
yes, that was kind of my goal in this exercise, It's just a hair bigger than the core depth wise and height wise the connections are pretty much sitting on the top of the midi connectors
This has been on my todo list for a while but could never get a spark going to get it done until I discovered square button caps (lame, I know, but it worked). The results: Got the case pretty much right the first time (SD card holes need to be moved back a bit) and I'll post the part numbers, case file, and other relevant bits shortly. Here is my case file
I actually recommend you start with just a Core17 and familiarize yourself with MIOS and studio. Its an easy build and a good opportunity to learn to use the console and basic uploading of apps. Once you have your head around that, you can start adding the interesting stuff. The documentation looks a little daunting but once it all sinks in everything will come into focus quickly.
the one I linked is still available cheap on ebay: http://www.ebay.com/itm/Bid1-iCA01-USB-Microchip-PIC-Programmer-Set-ICSP-Adapter-with-PICkit2-SW-/121183652404?pt=LH_DefaultDomain_0&hash=item1c371bca34, works fine for me and uses the microchip pickit2 software Stay away from the K150 clones, they do NOT support the bigger chips like the 4685
Damn it, I just figured that out.. Thought it was swedish or something. To add: You will also need the LPC17 development board which can be purchased at the same place you get your switches
Mouser: http://www.mouser.com/ProductDetail/Optrex/C-51850NFQJ-LG-ACN/?qs=sGAEpiMZZMt7dcPGmvnkBvYnOvX7dbDNGFPEbefb4Dw%3d Yeah, I just bread boarded it. Didnt feel like waiting 2 weeks and it took maybe half an hour
Ah, in your case you probably want them on since they serve as a line buffer
Ambika has the SD slot on the mainboard, this wouldn't be needed
impressive. Quite an undertaking..
hmm. What core? I tried 2 that I had with seqv4l and lpc17 and both didnt work..
Have you considered just attaching the driver boards directly to the control surface PCB via female DIL header (like on Anushri?) would save some wiring..
sammichSID Dual inline header with long tail part?
Altitude replied to internet's topic in Parts Questions
I could never get the newhaven OLED working correctly with my MB6582 due to the 4 bit communications, could be the same problem with the sammich. The Samtec headers at digikey come in any size you can imagine. http://www.digikey.com/product-search/en?WT.z_header=search_go&lang=en&site=us&keywords=sam1066-03-nd&x=-1021&y=-51 -
There is always this thing: http://www.christian-hartig.de/TR-8060/ . This is Substyer's project (x0xsh0p guy)
Kester 331 is water based, been around for years.. http://www.kester.com/download/331%20Flux-Cored%20Wire%20Data%20Sheet.pdf
or you can use a water based flux and just run the board under warm water and be done with..
Last I spoke to Smash about this (several weeks back on the forum), he stated that he still was using that list as a tally of who wants how boards (and kits also) and you should contact him and HE will put you on that list if you cant get registered at the wiki. Chat is where to find him easiest..
WTB/WTT for: Seq. V4 kit or Build or MB Kit or Build
Altitude replied to RyanFizmo's topic in Fleamarket
Try smash in the chat. you can usually catch him there -
http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_seq_pcb_bulk_order&s[]=smashtv
Those are fine, I use them all the time, I actually used those exact green ones on my SEQ.. Just make sure when shopping at Mouser. you go by the part#, not the picture when picking one out. The one in the link is a good example, the pic shows a white on black but the description is for a green one. I always check the Kyocera site, they are always correct there.. . Find my thread about improving the contrast on those, I had a really hard time getting them to look good (the backlight was shining through and they looked blotchy) so I made some changes to the circuit which improved things a lot
Hey Ryan, you will see quite a few familiar faces here :)
that's a deal breaker imho.. The one I linked was the only one I found that could be panel mounted
Yeah, LPC core for sure. I have used the 7bit microchip digipots and 10 bit analog devices ones for my day job. The microchip ones have a bit better i2C implementation and are available in a bunch of different pinout configurations (pot to ground, rheosat, etc), the AD ones were simple up/down serial jobs in a painfully tiny micro QFN package. We use them for setting gain settings and I dont think they are something that would be of use in something like this since the settle time between taps is 1-2 seconds. Further more, there is no way to read the resistance of the part, they way that it is done is that it uC does a reset and then increments the taps to roughly the right spot resistance wise. I did a bunch of tests to measure the accuracy of this and its in the 5% range. I think a better approach would be to do something like how old school analog synths saved and recalled patches
actually Jeff based his work on the xlarge stuff so your on the same path. Unfortunately, the whole of the 808 forums wiped and all that knowledge is now gone :(
