790 -
3
Everything posted by julienvoirin
				midi Dj Cj controller 3.0 Usb complete
julienvoirin commented on Avarges-RU's gallery image in Members Gallery
				Building a "Stand-alone" SID-synth with control interface
julienvoirin replied to Soturi's topic in Design Concepts
Elektron Monomachine ? -
	there are 2 rows so that you can chain DOUT and DIN (notice So Si), a single DIN or DOUT being connected to the Core
	well, i learned C code by reading the sources of other members on the forum and TK tutorials. I do not know ASM and find it to hard to understand without some courses :/ that project doesn't require power/ressource as it is rather basic and MIOS is very well conceived. If i use MIOS32, it is because i got a spare STM32 and need 2 midi in/out.
	arf, so sad you don't do C. It is so easy to understand, and so portable. I will, of course, implement a control surface, based on PG 300 design, with faders (e.g L1 L2 L3 L4), knobs (e.g T1 T2 T3 T4) buttons (e.g OSC waveform) and LEDs :) EDIT : i moved to iPad TouchOSC and a custom Arduino translator to get dynamic patch view An original edit buffer will retain the original value and the modified one of each parameter and print it on a LCD Display. I already have that on my Matrix 1000 controller (C Code !) A stuff very useful is to send double control messages : control change to the DAW in order to record & edit curves, and sysex to the synth. That's why i coded the translator on the 106. --> EDIT : true and false, MIOS32 is faster than the Juno and CC curves from Logic make hear stepper ladder artifacts :$
	i will try to code it so that it can be adapted to Mios8
	there are FSR sensor http://www.ladyada.net/learn/sensors/fsr.html
				Roland Juno 106 and Alpha Juno 2 sysex translator
julienvoirin replied to julienvoirin's topic in MIDIbox User Projects
I quickly started the new application for my Juno 2 : it converts CC to Alpha Juno2 sysex, as i wanted to know if there is scales effect while moving parameters (I got that on my Oberheim Matrix 1000 and it is shit!). There is no scale effect ! :frantics: so the next step is to build a dedicated control surface. This application does convert Control Change messages to Juno 2 sysex messages so that you can control your synth with a DAW that doesn't support sysex (e.g Ableton live). Connect your Juno to Midi in/out sockets 1 of STM32 and USB to your computer. Midi in/out 2 is the same as USB (e.g to connect to an Akai MPC). See tables below to edit your Juno parameters (CC84 to CC119). Have fun ! PS : Am I right we all posess Juno 106 AND Juno2 ?! /* * Roland Juno 2 SysEx Translator * * =============================================================================== * Copyright (C) 2011 Julien Voirin (julien.voirin@free.fr) * * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <mios32.h> #include "app.h" #include "mios32_config.h" ///////////////////////////////////////////////////////////////////////////// // Translate a DAW CC string from a Juno 2 SysEx string on a destination port ///////////////////////////////////////////////////////////////////////////// void Translate_CC_SysEx(mios32_midi_package_t midi_package, mios32_midi_port_t port) { static u8 stream_sysex[10]; // convert CC:USB0 -> Sysex:UART0 : translate CC to SysEx if( midi_package.type == 0xb){ // define sysex stream stream_sysex[0] = 0xf0; // header stream_sysex[1] = 0x41; // Roland stream_sysex[2] = 0x36; // Juno 2 in Individual Tone Parameters mode stream_sysex[3] = midi_package.evnt0 & 0x0f; // midi channel : 0n stream_sysex[4] = 0x23; // format type stream_sysex[5] = 0x20; // unknown stream_sysex[6] = 0x01; // unknown stream_sysex[7] = midi_package.evnt1 - CC_Offset; // Parameter number stream_sysex[8] = midi_package.evnt2; // Parameter value stream_sysex[9] = 0xf7; // EOX // send stream to midi out1 MIOS32_MIDI_SendSysEx(port, stream_sysex, 10); //MIOS32_MIDI_SendSysEx(USB0, stream_sysex, 7); // DEBUG :°) } } ///////////////////////////////////////////////////////////////////////////// // This hook is called after startup to initialize the application ///////////////////////////////////////////////////////////////////////////// void APP_Init(void) { // initialize all LEDs MIOS32_BOARD_LED_Init(0xffffffff); } ///////////////////////////////////////////////////////////////////////////// // This task is running endless in background ///////////////////////////////////////////////////////////////////////////// void APP_Background(void) { /* // endless loop while( 1 ) { // toggle the state of all LEDs (allows to measure the execution speed with a scope) MIOS32_BOARD_LED_Set(0xffffffff, ~MIOS32_BOARD_LED_Get()); } */ } ///////////////////////////////////////////////////////////////////////////// // This hook is called when a MIDI package has been received ///////////////////////////////////////////////////////////////////////////// void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package) { // toggle Status LED on each incoming MIDI package MIOS32_BOARD_LED_Set(1, ~MIOS32_BOARD_LED_Get()); #if TERM_DEBUG // send received MIDI package to MIOS Terminal MIOS32_MIDI_SendDebugMessage("Port:%02X Type:%X Evnt0:%02X Evnt1:%02X Evnt2:%02X\n", port, midi_package.type, midi_package.evnt0, midi_package.evnt1, midi_package.evnt2); #endif // forward USB0->UART0 and UART0->USB0 switch( port ) { case USB0: // convert CC:USB0 -> Sysex:UART0 : translate CC to SysEx Translate_CC_SysEx(midi_package, UART0); MIOS32_MIDI_SendPackage( UART0, midi_package); // forward all messages break; case UART1: // convert CC:UART1 -> Sysex:UART0 : translate CC to SysEx Translate_CC_SysEx(midi_package, UART0); MIOS32_MIDI_SendPackage( UART0, midi_package); // forward all messages break; case UART0: // translate sysex from Juno to CC : not yet implemented //Translate_SysEx_CC( port, midi_package); // passthrough midi messages except SysEx if (midi_package.type > 0x7 && midi_package.type < 0xf) // all except SysEx MIOS32_MIDI_SendPackage(USB0, midi_package); // USB Port MIOS32_MIDI_SendPackage(UART1, midi_package); // Midi Out2 Port break; } } Juno_2_SysEx_Translator_v0.1.zip -
	bad LCD Cable. check it. i debug a similar problem on a MB6582, and the cable was cut (but wasn't visible, f***ing ribbon)
next step but i need to create a control surface first -
	Here is my first custom app using the "new" mios32 environment. :thumbsup: It only uses a STM 32 board : Juno 106 is connected to Midi in/out 1 and the core32 can be connected to your computer via USB or Midi in/out 2 The purpose is to convert the sysex from the Juno 106 to Control change messages (CC) (and vice versa), in order to edit automations in DAW that don't support sysex (e.g Ableton Live). Moreover it is really easier to edit CC messages (curves) than sysex ones (list of numbers) ! It does also convert CC messages received on USB and Midi in/out 2 to juno 106 sysex. In Control mode (meaning just moving the faders of the Juno), it sends simple CC. In Patch mode (e.g recalling patch A45 on the Juno), it sends a program change message and all the data of the controls via 18 CC so that you will ever get the patch parameters ; playing the record will transmit those CC and your Juno will return to its original tone :thumbsup: [*]In Manual mode it only sends all 18 parameters when you press the Manual button on the Juno. Moving faders sends sysex as in Control mode. Notice that you have to be in Midi Mode III on the Juno. (the only mode that produce sysex) Control change messages are the following : Control number of control change message 00 = LFO rate CC 102 01 = LFO delay time CC 103 02 = DCO LFO CC 104 03 = DCO PWM CC 105 04 = DCO Noise CC 106 05 = VCF Freq CC 107 06 = VCF Res etc ... 07 = VCF Env 08 = VCF LFO 09 = VCF Kybd 0A = VCA Level 0B = ENV A 0C = ENV D 0D = ENV S ... 0E = ENV R CC 116 0F = DCO SUB CC 117 10 = Switches 1 (see below) CC 118 11 = Switches 2 (see below) CC 119 You can change it in app.h by editing CC_Offset. The 102 value has been retained because I needed 18 adjacent numbers. Enjoy ! Rq : For those curious of some code routines : /* * Juno 106 SysEx Translator v1.0 * * ========================================================================== * * Copyright (C) 2011 Julien Voirin (julien.voirin@free.fr) * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <mios32.h> #include "app.h" #include "mios32_config.h" ///////////////////////////////////////////////////////////////////////////// // Translate a DAW CC string from a Juno 106 SysEx string on a destination port ///////////////////////////////////////////////////////////////////////////// void Translate_CC_SysEx(mios32_midi_package_t midi_package, mios32_midi_port_t port) { static u8 stream_sysex[7]; // convert CC:USB0 -> Sysex:UART0 : translate CC to SysEx if( midi_package.type == 0xb){ // define sysex stream stream_sysex[0] = 0xf0; // header stream_sysex[1] = 0x41; // Roland stream_sysex[2] = 0x32; // Juno 106 Control mode stream_sysex[3] = midi_package.evnt0 & 0x0f; // midi channel : 0n stream_sysex[4] = midi_package.evnt1 - CC_Offset; // Control number stream_sysex[5] = midi_package.evnt2; // Control value stream_sysex[6] = 0xf7; // EOX // send stream to midi out1 MIOS32_MIDI_SendSysEx(port, stream_sysex, 7); //MIOS32_MIDI_SendSysEx(USB0, stream_sysex, 7); // DEBUG :°) } } ///////////////////////////////////////////////////////////////////////////// // Translate a Juno SysEx string from a midi port to a Control change string ///////////////////////////////////////////////////////////////////////////// void Translate_SysEx_CC(mios32_midi_port_t port, mios32_midi_package_t midi_package) { static u8 editbufferstatus; static u8 midi_channel; static u8 cc_param; static u8 cc_value; // static u8 patch_param[24]; // 24 bytes for a patch static u8 bank_patch_number; // for PC static u8 patch_value[24]; // Header + midi channel + PgChg + 18 values of controller + EOX // convert Sysex:UART0 -> CC:USB0 & CC:UART1 switch(editbufferstatus){ unsigned char i; // for the loop case 0: // Juno 106 Header // Control mode if( midi_package.type == 0x4 && midi_package.evnt0 == 0xf0 && midi_package.evnt1 == 0x41 && midi_package.evnt2 == 0x32){ #if DEBUG MIOS32_MIDI_SendCC(USB0, 15, 50, 50); #endif editbufferstatus = 1; } // Patch mode else if( midi_package.type == 0x4 && midi_package.evnt0 == 0xf0 && midi_package.evnt1 == 0x41 && midi_package.evnt2 == 0x30){ #if DEBUG MIOS32_MIDI_SendCC(USB0, 15, 40, 40); #endif editbufferstatus = 30; //editbufferstatus = 4; } // Manual mode else if( midi_package.type == 0x4 && midi_package.evnt0 == 0xf0 && midi_package.evnt1 == 0x41 && midi_package.evnt2 == 0x31){ #if DEBUG MIOS32_MIDI_SendCC(USB0, 15, 30, 30); #endif editbufferstatus = 40; //editbufferstatus = 4; } else editbufferstatus = 0; break; case 1: // 2nd block (3 bytes) : Control if( midi_package.type == 0x4) { midi_channel = midi_package.evnt0; // CC 1st byte cc_param = midi_package.evnt1; // CC 2nd byte (+2 avoid pb with bender) cc_value = midi_package.evnt2; // CC 3rd byte #if DEBUG MIOS32_MIDI_SendCC(USB0, 15, 60, 60); // debug OK #endif editbufferstatus = 2; } else editbufferstatus = 0; break; case 2: // EOX Control if( midi_package.type == 0x5 && midi_package.evnt0 == 0xF7){ MIOS32_MIDI_SendCC(USB0, midi_channel, cc_param + CC_Offset, cc_value); // USB Port MIOS32_MIDI_SendCC(UART1, midi_channel, cc_param + CC_Offset, cc_value); // Midi Out2 Port #if DEBUG MIOS32_MIDI_SendCC(USB0, 15, 70, 70); // debug OK :) #endif editbufferstatus = 0; } else editbufferstatus = 0; break; case 30: // blocks patch 0n pp dd if(midi_package.type == 0x04){ patch_value[3] = midi_package.evnt0; // midi channel patch_value[4] = midi_package.evnt1; // bank patch number patch_value[5] = midi_package.evnt2; // ctrl 01 LFO Rate // notice that : midi_channel = patch_value[3]; bank_patch_number = patch_value[4]; // send PC over USB et midi out2 MIOS32_MIDI_SendProgramChange(USB0, midi_channel, bank_patch_number); MIOS32_MIDI_SendProgramChange(UART1, midi_channel, bank_patch_number); // next step editbufferstatus = 31; } else editbufferstatus = 0; break; case 31: // blocks patch dd dd dd if(midi_package.type == 0x04){ patch_value[6] = midi_package.evnt0; // ctrl 02 LFO delay time patch_value[7] = midi_package.evnt1; // ctrl 03 DCO LFO patch_value[8] = midi_package.evnt2; // ctrl 04 DCO PWM // next step editbufferstatus = 32; } else editbufferstatus = 0; break; case 32: // blocks patch dd dd dd if(midi_package.type == 0x04){ patch_value[9] = midi_package.evnt0; // ctrl 05 DCO noise patch_value[10] = midi_package.evnt1; // ctrl 06 VCF Freq patch_value[11] = midi_package.evnt2; // ctrl 07 VCF Res // next step editbufferstatus = 33; } else editbufferstatus = 0; break; case 33: // blocks patch dd dd dd if(midi_package.type == 0x04){ patch_value[12] = midi_package.evnt0; // ctrl 08 VCF env patch_value[13] = midi_package.evnt1; // ctrl 09 VCF LFO patch_value[14] = midi_package.evnt2; // ctrl 10 BCF kbd // next step editbufferstatus = 34; } else editbufferstatus = 0; break; case 34: // blocks patch dd dd dd if(midi_package.type == 0x04){ patch_value[15] = midi_package.evnt0; // ctrl 11 VCA Level patch_value[16] = midi_package.evnt1; // ctrl 12 Env A patch_value[17] = midi_package.evnt2; // ctrl 13 Env D // next step editbufferstatus = 35; } else editbufferstatus = 0; break; case 35: // blocks patch dd dd dd if(midi_package.type == 0x04){ patch_value[18] = midi_package.evnt0; // ctrl 14 Env S patch_value[19] = midi_package.evnt1; // ctrl 15 Env R patch_value[20] = midi_package.evnt2; // ctrl 16 DCO Sub // next step editbufferstatus = 36; } else editbufferstatus = 0; break; case 36: // blocks patch dd dd F7 if(midi_package.type == 0x07){ patch_value[21] = midi_package.evnt0; // ctrl 17 Switches 1 patch_value[22] = midi_package.evnt1; // ctrl 18 Switches 2 patch_value[23] = midi_package.evnt2; // ctrl EOX /* // send PC over USB et midi out2 MIOS32_MIDI_SendProgramChange(USB0, midi_channel, bank_patch_number); MIOS32_MIDI_SendProgramChange(UART1, midi_channel, bank_patch_number); */ // send the patch param via CC for(i=5; i < 23; i++){ MIOS32_MIDI_SendCC(USB0, midi_channel, (i-5)+CC_Offset, patch_value[i]); MIOS32_MIDI_SendCC(UART1, midi_channel, (i-5)+CC_Offset, patch_value[i]); editbufferstatus = 0; } // return to start editbufferstatus = 0; } else editbufferstatus = 0; break; case 40: // blocks MANUAL 0n pp dd !NO PROGRAM CHANGE! if(midi_package.type == 0x04){ patch_value[3] = midi_package.evnt0; // midi channel patch_value[4] = midi_package.evnt1; // bank patch number patch_value[5] = midi_package.evnt2; // ctrl 01 LFO Rate // notice that : midi_channel = patch_value[3]; bank_patch_number = patch_value[4]; // DON'T send PC over USB et midi out2 //MIOS32_MIDI_SendProgramChange(USB0, midi_channel, bank_patch_number); //MIOS32_MIDI_SendProgramChange(UART1, midi_channel, bank_patch_number); // next step editbufferstatus = 31; } else editbufferstatus = 0; break; case 4 : // end of Blocks break; } } ///////////////////////////////////////////////////////////////////////////// // This hook is called after startup to initialize the application ///////////////////////////////////////////////////////////////////////////// void APP_Init(void) { // initialize all LEDs MIOS32_BOARD_LED_Init(0xffffffff); } ///////////////////////////////////////////////////////////////////////////// // This task is running endless in background ///////////////////////////////////////////////////////////////////////////// void APP_Background(void) { /* // endless loop while( 1 ) { // toggle the state of all LEDs (allows to measure the execution speed with a scope) MIOS32_BOARD_LED_Set(0xffffffff, ~MIOS32_BOARD_LED_Get()); } */ } ///////////////////////////////////////////////////////////////////////////// // This hook is called when a MIDI package has been received ///////////////////////////////////////////////////////////////////////////// void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package) { // toggle Status LED on each incoming MIDI package MIOS32_BOARD_LED_Set(1, ~MIOS32_BOARD_LED_Get()); #if TERM_DEBUG // send received MIDI package to MIOS Terminal MIOS32_MIDI_SendDebugMessage("Port:%02X Type:%X Evnt0:%02X Evnt1:%02X Evnt2:%02X\n", port, midi_package.type, midi_package.evnt0, midi_package.evnt1, midi_package.evnt2); #endif // forward USB0->UART0 and UART0->USB0 switch( port ) { case USB0: // convert CC:USB0 -> Sysex:UART0 : translate CC to SysEx Translate_CC_SysEx(midi_package, UART0); MIOS32_MIDI_SendPackage( UART0, midi_package); // forward all messages break; case UART1: // convert CC:UART1 -> Sysex:UART0 : translate CC to SysEx Translate_CC_SysEx(midi_package, UART0); MIOS32_MIDI_SendPackage( UART0, midi_package); // forward all messages break; case UART0: // translate sysex Translate_SysEx_CC( port, midi_package); // passthrough midi messages except SysEx if (midi_package.type > 0x7 && midi_package.type < 0xf) // all except SysEx MIOS32_MIDI_SendPackage(USB0, midi_package); // USB Port MIOS32_MIDI_SendPackage(UART1, midi_package); // Midi Out2 Port break; } } Juno_106_Translator_v1.0.zip
	me want that :)
	contact julianf for frontpanel : high qulity and rather cheap
	Hi folks Is there someone who added a Piano Keyboard to its MB6582 ? The best would be to add 1DIN and 1 DOUT connected to J8 J9 to control a 8x8 Matrix scanning a keyboard (M Audio, Edirol, etc)
	headphone socket is a add on. Wilba thought to this in order to make a ALL 4 SID in one stereo pair. Somewhere he explains how to cable it (with 10k resistor to attenuate crossrejection signal). If you can find it, i am interested too. You hear SID1 (and only this one) in the headphone cause headphone is connected to stereo jack of SID1 (and only this one, that's why there is the 1k parallels resistor trick to create under the PCB) If I well understand, the 1k resistors form a passive mixer and there is a trick with the cutting jacks http://www.panoramiccomputing.com/TomAnselmo/Computing/12.0Speakers/PassiveMixer.gif
	:thumbsup:
	need to cut inner edges of case with a Dremel (front side) contact me via PM for sale
	using signal diodes (1n4148) permits use of a matrix, i.e 64 buttons with only 8 outputs (1x74HC595) and 8 inputs (1x74HC165) some complexe example here http://midibox.org/forums/forum/43-midibox-blm/ more simple http://www.midibox.org/forum/index.php/topic,10476.msg79411.html the idea is the following : A column is ON, the others 7 are OFF. then we scan what Row is ON, corresponding to a button press. the do it again with next Column, etc...
	Belgium rules !!!! :thumbsup:
				1 or 2 TLV5630IDW DACs in Germany/Europe?
julienvoirin replied to sylwester's topic in Parts Questions
you should add a run/stop and a clock jack hole + some multi -
	if you are sure of that it is rather easy to code : l evel = velocity if level > 64 then Led0 on Led1 On Led2 On if level >80 then Led0 on Led1 On Led2 On Led3 On etc .. search in BLM with RGB Led there is a sort of this code if the velocity is under 64, there is only one led if 64<velocity<80 there is 2 leds is >80 there is 3 led i've coded in 8 colors (so 8 leds) velocity scale (0-127)
				Simple Balanced Audio Circuits Possible with MB-6582?
julienvoirin replied to m00dawg's topic in Design Concepts
DI Box ! -
DI = Direct Input
