matoz
302 -
Everything posted by matoz
See Wilba OPL3 Bulk order: http://www.midibox.org/dokuwiki/doku.php?id=wilba_opl3_bulk_order
Yes, the power transformer is missing. I' ve found the user' s manual but it i didn' t find any schematics. Regards Loic
Futureman: the transfo is missing, could you tell me what kind of transfo is it? I saw it should be a parallel (symetric)psu but what voltage is it?
Thanks, so, i just need only 1 core and 1 Aout LC and MBCV appli? if i have understood well, i just need 1 CV out?
Hi all, A good friend of me have found a YAMAHA CS 5 in a bin (mega lucky man!!), and we would like to midificate it. It will be the first time i midificate an instrument, and don' t know at all how doing it. I saw in the forum lot of midification but these are all spécific. Is someone know how should i do? thanks best regards
Thanks Seppoman, So, if i understand well, for my project, i should use 2 MBCV (2 core+2Aout NG) and control them with a little Mb64 (core with Ain and 16 pots). I just want a real time control but i think if i want i can recording pot movements in mbseq and automatize them.
we can use double pots for stereo cut and stereo q? Automation can be recorded and reproduced by a seq, in midi.
yes, thanks i saw it, but i' d like to have 16 dedicated pot to control filters. I could use 3 core and 3 Aout NG on them with mbsid V2 Appli but i think it it will be very hard modify MBSID V2 to have the control surface of 16 pot. What about MB64, one AIN , one core , one Aout and one SHX8?
Hello All, My project is a multi filter box. I have 5 SSM2044 seppo boards and i' d like to use them as 6 mono filters et 2 stereo one. And i' d like to have 6cut/6Q mono and 2cut/2Q stereo on a control surface so 16 pot in Ain module. But how should I connect ssm seppo boards in one core? I thought i should use an AOUT module with a SHX8 to have my 20 CV out. And use MB64 Appli. Is it right? Is it possible to link several AoutNG on one core? Thanks
to rosch: i 've posted this topic here because it is very hard for me to understand english technic explications. But i will try to post it in english. julien: je pense qu' on doit utiliser les encodeurs "assign" en appuyant sur control dans l' occilateur et l' enveloppe. et il me semble qu' on peut mettre un Aout NG maximum par core, et dans l' optique des 4 filtres stéréo sur les 4 sorties stereo, il y a un Aout Ng branché sur chaque core et un SSm seppo module branché sur chaque Aout NG. à vérifier. Mais pour mon projet, je pense que ça pourrait être plus simple d' utiliser un core, un aout et un SHX8 pour avoir les 20 Sorties gérées par une seul core. Comme ça je pourrait brancher directement les 5 modules SSM seppo. Et le tout serait contrôlé par 16 potars branchés sur un AIN qui serait connecté au core. Le tout géré par l' appli MB64. Qu' en pensez vous?
merci, je ne savais pas qu' on pouvait chainer les Aout NG. Et combien peut on en brancher au maxi sur un pic, parce que si j' ai bien compris un Aout NG offre 8 sorties CV et comme j' en ai besoin de 20, il faudrait que je chaine 3 Aout NG sur le pic? En comment faire pour brancher les 16 potars ( 6 Cut+6Q mono et 2cut+2Q Stereo)? ça va être un enfer pour modifier l' appli sid V2?
Je viens de revoir tous les sujets sur le SSM2044, et je me dis que peut être, je ferais mieux de coupler 3 core, et de brancher un AOUT NG par core, et d' utiliser l' appli SID V2 sans les sid. Par contre au niveau surface de controle, je sais pas trop comment faire, sachant que j' aimerais bien avoir les 16 potars présents sous la main. Quelqu' un a une idée?
Bon apparemment, il n' y a que la Mb64 qui pourrait convenir, sur laquelle je peux brancher un AOUT avec un SHX8 pour avoir les 20 sorties CV. Par contre, ça va être la galère pour les 2 SSM2044 pcb que je voudrais faire fonctionner en stéréo. Je me demande si je peux utiliser 2 doubles potars pour contrôler d' un coup les 2 cut et les 2 res d' un SSM2044 pcb. Je me demande s' il ne va pas y avoir des problèmes d' affichage ou de transfert de signal en envoyant deux informations d' un coup et faire des cracs avec les filtres.
Salut, Je pose ma question ici parce que j' ai un peu de mal avec les explications en anglais. Je voudrais préparer un module spécial filtres, et j' aimerais savoir 1/ combien de ssm2044 pcb peut on brancher au maximum sur un Aout NG? j' ai cru comprendre que le Aout NG a 8 sorties Aout, donc je me dis, sachant que chaque ssm2044 pcb demande 4 entrées CV (2 cut et 2 res) qu' on peut mettre maximum 2 ssm2044 par Aout NG. c' est juste? 2/ combien de Aout NG peut on brancher sur un core au maximum? 3/ je voudrais contrôler le tout avec 16 potars avec un AIN sur le core (8 cut et 8 res) Sachant que je veux contrôler 5 SSM2044 pcb , 2 couplées en stereo et 3 en mono, ce qui me fait 8 cut et 8 res. Auriez vous des conseils à me donner sur le type d' application que je doit utiliser: MB 64 ou MB CV? 4/SHX8 module pourrait il être intéressant à utiliser dans ce cas? sachant que j' ai besoin au total de 20 sorties CV? Merci
group buy #2 for ultracore (core + 4x IIC + 8 banksticks)
matoz replied to ultra's topic in Bulk Orders
hI Is this ultracore will work for Mb Seq V4? -
Hi, pcb received, thanks for spares... regards
Hi Prof, I ' ve sent you a PM, i ' interested by 1 Pack JB Weld and the set of Albs Knobs. I wait your request. Thanks, regards.
Hi all, i have several question about SSM2044 filter: Is it possible to control ssm2044 filter with Mb16e or Mb 64e(Aout NG stuffed)? How about calibration? Thanks, regards
Hi Mike, mail sent best regrards Matoz
Hi all, go and see here http://www.narrat1ve.com/
Hello Mike, i' m interested to buy your PCB's. If these are not sold yet. I live in Besancon / France.
Yes, i saw he tested 4 channel board, but perhaps he has made new tests...
Hi Lylehaze, i' d like to know how many channel boards in one mixer have you tested? What is the maximum tested OK? I didnt find any layout, where is it possible to find them, to make tests? Thanks, best regards
Salut, j' ai pas compris grand chose. C' est quoi ton patch routing d' effets? la référence? y' a une prise midi in? ou Cv in? Tu voudrais "ouvrir et fermer des portes" de façon manuelle (en temps réel) ou automatisée ou les deux?
Salut, tu l' as fait avec quoi ton dessin en 3d?
