m00dawg
    1,404
    16
Everything posted by m00dawg
  1. Late to respond but thought I would offer my $0.02 based on my 6582 experience. I was using a custom PSU with it, both for real SIDs and a pair of ARMSIDs. The problem I was having was a bit of 5V droop due to the cable length and my power connector was a bit sketch. So I've since converted it over to the switching 7805 regulator method which seems to be working for both ARMSIDs and real ones. One thing I really like about real SIDs is they can offer a sort of chorus in stereo mode due to differences in each chip. I don't get that with ARMSIDs. On the MB6582 I plan to always run both. I believe you are correct, though, that the ARMSIDs only need 5V though there isn't much harm in keeping your 9/12 rails if you want to populate real SIDs at a later date. The switching PSU method does require changing things around a bit. It can be reverted but not easily, although it can be made to work with 6581 or 8580/6582 SIDs (and ARMSID) which might be worth a look if you're not already running this option. I do find being able to choose between them is really nice. The real SIDs, sure they're noisy, but the filter sounds better and you can mitigate the noise with a gate. When I'm doing a lot of filter stuff or just want that chorus/phasey kinda sound, I'll reach for them. Otherwise the ARMSIDs are less fickle. I do wish we'd see an update to the MBSID firmware to support some of the enhanced ARMSID options but I've been quite happy with them and plan on picking up more (once retrocomp.cz is able to ship to the US again). I recently busted out my sammichSID again while the band is considering live shows so my current ARMSIDs are stuffed in that guy.
  2. That's really nice looking! Digging that case in particular.
  3. Making a control surface the modular way is a good idea. These days being able to laser cut and 3D print things might also be options to consider. Those weren't nearly so readily available when MidiBox first started and the MBSID is one of the oldest MidiBox designs. Speaking of modular though, Modular Addict sells the MB6582 base and CS boards. I know you mentioned only wanting 2 SIDs, but it's still something to consider. You only need to populate what you want to use and can also use things like ARMSIDs. My own MB6582 is just that, 2 6582's and 2 ARMSIDs. The wiki has the build information so while it's not a small project, it's doable. The main thing is having that full control surface already made and designed makes using the synth soooo much easier.
  4. This is more MIdiBox adjacent since it's more chiptune. I've been very active working on my native tracker for the Commander X16 65C02 based modern 8-bit computer. Though it is still alpha (mostly because the file format may change still), it's quite usable. I've been working on a demo-tune to show at least some of the capabilities: Folks that want to know more can join the band this Friday at 8pm CST where I'll be doing a show and tell of DreamTracker and answering questions. I can even dig into the code if anyone is interested. We're doing it through Bandcamp which requires an RSVP (though the event is free) so folks can sign up here: https://victimcache.bandcamp.com/merch/dreamtracker-showcase-bandcamp-friday
  5. That's absolutely glorious Peter! Nice work (as always!)
  6. I'm liking mine! Though I will admit I use the real SIDs more often. I still haven't sorted out why the right channel doesn't always work (only for real SIDs and it doesn't matter which ones) in half my MB6582 sockets. I have the real SIDs in channel 3. ARMSIDs are in 1. Side by side, I still notice a lot more interesting stereo affects using the real SIDs. But the ARMSIDs are certainly cleaner and clearer.
  7. Nice looking great! Congrats!
  8. Thanks! The main vox was done by my bandmate. He's arguably the "front-man" but you can hear me way in the back on the choruses :)
  9. We finally released a new song! It's a cover and mostly showcases more of my Eurorack and things, but the MB6582 makes an appearance with it's juicy filtered squares:
  10. Both the 4922 and 525 use SPI though yeah? 525 has more channels though certainly. Going SMD there's options for 8 channels even. It's good point though I hadn't though if/how SPI works on the MidiBox platform and which pins are available for the chip-select. My Mutant Brain has 4 CVs along with 12 triggers, which is usually plenty for me, though designing something with a few more CVs could be nice. I had thought of how I might go about making a base module (which houses the uC) and then having modules you can add which have an addition DAC and Op-amp and perhaps some sort of shift-register to provide a set of gates with it too. Good point about the receiver though, I hadn't thought of that. Actually I think I could just mount that whole module to the back of the case and call it good? And/or the MIDI in/out's if I can internally route them over to the CV modules. I'll have to look again at all the Midiphy options there as I know they're fairly numerous!
  11. I've been looking at MIDI -> CV again. While I like the Mutant Brain Eurorack module (and Polyend's MIDI->CV looks amazing), I built my own custom expandable case (which by the way is available in kit form for those interested) and am looking at some of the modules that have external I/O and seeing what I can do to route those to the back. Having a MIDI cable always connected to the front of my rack feels out of place, and it gets in the way where it can just live along the back of the rack (that's where the power is already). Mutable Instruments' CVPal, along with some others, use the MCP4822 chip. It's 2 channel but has an internal voltage reference and it's 1/3rd the price of the MAX525. Buying 2 still is only 2/3rd's the price of a 525. The CVPal has a calibration procedure, similar to what I was thinking. I was actually going to use a LUT for all the notes so each note has a specific calibrated value (CVPal tests at the first and 7th notes of the octave to derive offsets). Anyways I'm flying off the rails a bit I guess. The point was, curious why no AOUT_4822 exists since that seems like a favorable option to the AOUT_LC? For my application, I'll probably end up on a Teensy and using the Arduino platform but the MBCV project has _a ton_ more going for it by comparison (though it doesn't easily fit inside a Eurorack format I don't think?)
  12. Ah good deal! I wasn't sure if sharing the direct BINs (as opposed to the C64 PRGs) was allowed but Martin was kind enough to send me those for directly programming it from the Arduino Shield. Hindsight, using a shield is a lot easier I'm sure but the breadboard method did work. I got it setup just in time too as my SSM2144 Eurorack filter (the Electrosmith) came in so I could finally mess around with some bassline patches (albeit not in stereo as I only have 1 filter). Both the ARM2SID and my 8580 pair sounded pretty great with a VCA and the filter. The real SIDs have a bit more "charm" but being 8580's, the ARM2SID has a really nice filter emulation by comparison. Not as good as my actual 6581 but I know if I cough too close to that thing it'll die :P and it's awfully noisy compared to the ARM2SID. Most of this has already been discussed above so I'm just rehashing what's known. For the filter though, yeah it works! Since I am not using AOUT I have to control the Eurorack bits via a MIDI CV (Mutant Brain) but it's not too bad to mess around. The one thing I did seem to notice is the ADSR bug seems faithfully replicated and/or I haven't found a way to properly sync the drums and turning the ADSR bug workaround off/on does have an affect. Not having to mess with that would be nice but it's not the worst. I can (and have) just sampled the drums directly it just takes more effort. Apart from the initial setup bumps, that's my only "gripe" and I use quotes because it's sorta unfair to complain about such an issue when it's faithful to the original! I expect I'll populate my MB6582 with at least one more ARM2SID pair. I think that'll be a good balance (4 8580's, 4 ARMSIDs)
  13. Update to the above, yep, I contacted Martin and it did indeed require using the Beta firmware. I flashed the chip, popped it in and now I have delicious stereo SID pair goodness!
  14. Ah yep good call. I wasn't sure if it was a quick fix. I'm worried it's something with the cable connections but when I ran wires to the 2nd socket (I did all that on a breadboard), both SIDs were detected. Though it could be firmware - I'm noticing it'll do stereo if the filter isn't involved. I gotta say, since I have 8580's (well I have one precious 6581 from my actual C64), I forgot how deep the filter is on the 6581's. Turn it to 6581 mode was quite a treat!
  15. My ARM2SID arrived today yay! And I have to say it DOES sound good for being an emulation. Only trouble is, despite verifying ARMSID is setup in socket mode, as soon as I put on a patch that has different settings between L/R (such as a Bassline patch), audio drops out on the SID socket and I only here occasional clicks and crackles from that. I've tried swapping L/R in the app (I'm using minicom with the Arduino Tester program), SID emulation modes, tried swapping which socket the main chip is in, tried moving them both to another pair of sockets in the 6582, tried switching the direction of the included molex cable, but nothing seems to fix it. Anyone else run into this issue?
  16. I feel like I need to defend SID's filter a little here. You mentioned subjectivity and I think that easily applies to the SID filters - or any filter for that matter. The SID filter is what it is. I'm not sure any filter is better or worse. My OB-6 sounds BEAUTIFUL but it in now way sounds remotely close to a SID, never will. I have Seppoman's boards and a few SSM2044 chips ready for whenever I finally get around to building an AOUT module and the audio demos of the SID + 2044 sound glorious! But I'd also argue, it sounds a lot less SID-like. Sounds sort of like its own synth in its own right, perhaps as it should. But it doesn't replace SID's quirky filter. I love it for what it is, not what it isn't.
  17. Well I grabbed up an ARMSID dual socket. I've spent a few days messing about with my MB6582. I was getting some odd crackle on one of the channels but only after it had been warm-ed up for a while. Since I don't use it in 8 SID monster mode all that often, I decided to pair it down to 2 real SIDs. But I'd still like to have another pair to play with drums and things or a bassline. I was just getting nervous hearing about the supply of SID dwindling I thought I'd better not needlessly have them sitting there largely doing nothing. I'm looking forward to it! Anyone know of the ARMSID avoids the ADSR bug (as in might drums be easier to use?)
  18. Well in a way I suppose, though with a real control surface with is just sooooo much nicer (for me anyway) than a VST.
  19. Better is relative depending on your goal. If your goal is a SID-like sound, but you can't find any real SIDs, the various alternatives are certainly better than no SID at all :) Especially if you want to find matched SIDs for stereo pairs or want to populate an entire MB6582. I'm quite fortunate I bought several when Wilba found that stash of 6582's but I am still working out some random bugs in my 6582 build. I do wonder, MBSID itself supports CV so curious about some sort of external filter solution that might approximate the gritty filter of the SID itself. That would help bridge the gap between the alternatives by having some sort of analog filter.
  20. Nice! Enjoy, it's a great synth! Answers to your Qs: 1. Yes, there's the default patch set, 127 Arps (on the forum), and I think a few others on the forum. You'll have to poke around for those but they exist. The default patch set is a good place to start. CTRLR works though I tended to have issues with it while using my DAW so I mostly just went through the painstaking process of editing patches on the Sammich as I didn't often need to use the advanced features (like wavetables). This is where the MB6582 (the sammichSID's much bigger brother) or a custom MBSID with a full control surface becomes useful since you don't have to step out of your DAW as much. If you have trouble with CTRLR, the standalone SID patch editor is another thing to try (it's on ucapps.de). 2. I believe sammichSID only has 5 banks (4 normal patches, 1 for ensembles). Been a while since I opened mine up but I'm pretty sure this is the case. 3. Yes, should work like normal program changes do on other synths. That's been the case for me anyway. Note when you switch patches you may hear some audio pops. 4. No, sammichSID runs the 2 SIDs in a stereo pair. MBSID itself can support up to 8 SIDs (4 pairs), though most folks going that route would use the MB6582 boards (that's what I did) since it saves a ton of space over using the individual boards, although you definitely can do it that way as well. 5. I dunno off hand you'll have to go look (ucapps.de is the place to go for firmware) Hope that helps! I will say some of these Qs you should find answers to in the docs, so giving them a good read will be really useful, especially for your first question (patch editing) as there's LOTS you can do with these synths but, to your point, given the sammichSID's more barebones control surface, it takes a bit more understanding of what things do when working on it.
  21. Thanks as always Hawkeye! Yep they're a bit more subtle this time. I finished my MB6582 late in the album so while it makes a showing, I think we'll do a lot more with it in the next one (once I figured out why I tend to get some crackling after a while on the 3L SID anyway)
  22. It's been uhhh some number of years, but we finished our 3rd album, Alien Me (available here: https://music.victimcache.com/album/alien-me). It's not super chiptuney but is quite synthy and features the sammichSID and, on one song, the MB6852 (as I finally finished the thing!). I also use nILS' GM5x5x5 for most of my studio MIDI stuffs. The sammichFM didn't make as much of a showing this time, since the TX81z had more of the sound we were going for given the genre. Anyways hope ya'll like it!
  23. You can certainly use Renoise to interact with MidiBox gear, I've done some of that. It's not quite the same as using, say, GoatTracker or dedicated SID trackers, but it does work and does allow you to do some effects like you would using a dedicated SID tracker. MidiBox SID treats the SIDs differently than a typical tracker which is one way it can produce some really rich and interesting sounds but which differ from how one would approach using the SID in a tracker. MBSID treats the SID sort of like its own complete instrument, whereas a tracker treats each voice as an instrument. Ultimately if you want to make SID-style tracker music, your best option is perhaps something like GoatTracker, using the C64 directly, or perhaps one of the new retro solutions that have SID or SID-like implementations, like the C256 Fenix or Mega65. There's a tracker for the Fenix but I don't think it supports their FPGA SID engine yet though. Mega65 I think uses an FPGA SID design of some sort. When the MBSID is playing a SID tune via MIDI it's using the ASID protocol in a special mode. If you wanted to try and use a tracker in this mode, you'll likely need some special software on both your computer and MBSID to do that I suspect. The docs for MBSID are quite good, so I do recommend giving them a read as it will give you some ideas about what you can (and can't) do with MBSID. They are available here: http://ucapps.de/midibox_sid_manual.html
  24. Hmm I think the issue might be related to needing to update the MBSID firmware. Looking at the ARM2SID page, this jumps out at me: "Expander emulation is possible only if the adapter or board supports DFxx addressing on the second socket (e.g. MixSID and ULTIMATE-64)." This would imply to me that MBSID doesn't do this out of the box, but likely could with some modifications.
