1,236 -
28
Everything posted by Smithy
Bump! What fuses would you recommend for the c64 brick, inside the plug itself? (Im assuming the plug fuse can be counted as primary side also?) I was thinking of a 1A Fast acting fuse, just in case anything was to happen the mb-6582, yes i've started it. ;) "Fast-acting fuses have no intentional built in slow-blow and are used in circuits without transient inrush currents. Fast-acting fuse opens on overload and short-circuits very quickly. This type of fuse is not designed to withstand temporary overload currents associated with some electrical loads." Would one of those be okay for use on 230V mains? Have no idea what cases you could have temporary overload currents or not. :/
In the Drum Engine, if you have SQC = * (Internal Sequencer Active), and its playing back, if you then go to the Random Generator Menu, and Press All, i notice that the Sequencer gets deactivated after a random patch is generated and playback stops. Would it be possible to allow it to keep active when random patches are generated? Or maybe its mandatory to reset the oscillators or something.
Which i had known about that before i destroyed the gm5. :/
Keeping MB-6582 PSU options "open" (quite literally!)
Smithy replied to Smithy's topic in MIDIbox SID
Thanks a lot for the reply Wilba. Yeah ive only 6582As to my name now, so I'll probably go with option B in case i get 6581s down the line. I was thinking it was better to use both rails alright, as the current load will be shared between both rather than just the 9V AC. Sounds like hte thing to do! -
Yes, I'm finally going to start mb-6582. :wink: However i will like to have a choice of using PSU Options A, B, and C down the line. Im planning on doing this by soldering SIL headers on J71, J72, J73, J74 and using pin jumpers to configure each option, (as opposed to soldering permanent bridges.) Is it possible to stuff V1, V2, V3, V4, C13 and C14 on the board, without them causing any problems provided the jumpers are set correctly? Is there any other important things i have overlooked, or need to be aware of? Any help will be thoroughly appreciated.
It looks epicly fun alright! Oh momma, thanks for sharing. Theres some awesome projects on there. Like individual clones for each TR-808 drum. Mmmmm, must make nao.
Wiki's Captcha is evil for registered users
Smithy replied to m00dawg's topic in MIDIbox Documentation Project
BAH and +1 to the OP. Isnt the captcha for registration enough to prevent spam? -
Is this is about as minimal as it gets: http://www.asciilifeform.com/parallelsid/parasid.html But of course you'll need a computer with an old printer port. Not sure if a usb to parallel cable would do.
Using a Character LCD to display Graphs / Animations
Smithy replied to Smithy's topic in Design Concepts
U iz 2 slow, so i buyz RS7000 insted, kthxbai. :wink: -
Yet? Hes sold a few thousand 6582 (the same as 8580) since then, but unfortunately the stock seems to have dried up since.
This related site is also excellent! http://misuse.su/vse-posty/ One of my favourites:
Awww isnt he so cute all wrapped up in his little bed there. I hope you sent him back home by 1st Class! ;) (Deutsche Post)
Just spotted this through google, didnt spot it on the forum! And its pretty awesome! Is the frog sent by post, or does the blogger actually visit each place? Btw, this should be blogged on midbox.org! :wink: Although MIOS Studio 2 is a bit more important!
Didnt spot the Kaffe logo reply the last time round. And on a seq-related note, you can haz finish this project plz? :wink: http://midibox.org/forums/index.php?showtopic=8364 An MB Midi Looper, would be sweet, if anyone wants to make one! I cant really find any dedicated midi loopers/loop pedals out there. -
Knowing TK, he may have added an option where you can choose between Enabling or disabling the original notes!
Heat isnt the only cause of a pic restarting, usually its due to a loose connection or a short.
Everything you need to know is available on: http://ucapps.de http://www.midibox.org/dokuwiki/ - The Wiki and by searching on the forum. The community encourages people to read first and then ask questions, just to let you know. :thumbsup:
This is absolutely awesome! It is like the Arcade Cabinet of music production, in terms of shape, fun, and ease of use! Google Translation: C'est absolument incroyable. C'est comme la borne d'arcade de la production musicale, en termes de forme, le plaisir et la facilité d'utilisation!
Oh and btw Rosch, the guys said 1A was adequate by using a 9V AC (Option C) only! So you *may* need something better rated for the 5V DC line, at this point id recommend you find out for sure!
I guess you could use a 7 Pin male DIN connector for the wires coming from both transformers, (just like the plug on the c64) So you could use a pin for GND, a pin for 5V DC, and 2 pins for 9V AC. That would it make it backwards compatible with a c64 PSU, as long as the correct pins are used.
