technobreath
Frequent Writer
    877
Everything posted by technobreath
  1. Just thought I'd shoot in a comment. I can't remember it being discussed in this thread. The MeanWell powersupply is: "Fixed switch frequency at 100KHz" - which is well above audible range. But it might be a bad idea to go there if you record or if it is possible that you will ever record it with those high sample rates, 192khz, no? It is IT and Med. equipment approved, but that does not automatically mean that this is suitable for musical applications... Just a heads up if some of u didn't think of it already. If building your own is an option - then have a look at this: http://www.murata-ps.com/data/power/oki-78sr.pdf <- switch frequency @ 500khz. I have seen similar ones @ 1 MHz too, but then it get a bit more spendy :P. This one is fairly cheap @ Mouser, but expensive in comparison to linear regulators bought from shanghai @ ebay :D. I have not much experience in building switchers. It's a bit more rocket sciency than the most basic linear designs, but not impossible at all if you read some d.sheets, app. notes. of course it helps if u know a thing or two about electronics. <- which can be learnt also :). I have learnt most of what I know from internet studies. But also from some electronics school books I got from a friend and also some from my brother way back - really helps you grow an instinct on how to seperate the good stuff from the bad stuff online. I also had VERY much help from many people @ midibox.org. So I know that: ... you don't need to go there - at least not in the long run. You probably buy one now (and we have no problems with that hehe), but I guarantee you will enjoy making your own once u get a bit more hang of the elctronics. EDIT: It has the DIN c64 power connector indeed. And it also got regulation circuit. BUT read the wikipedia site - it's all in there - there are several powering options, and not reading this, just assembling it and put the plug in and power it up is not a smart thing to do at all. You are partially right here. You are right, it gives you v5 and +/-12V. But SID 8580 and 6582 does NOT accept +12V without a fight. They need +9V. 6581 uses 12V. Also be aware of the powering specs of the -12v rail (depends on what you are using it for, but it might not be big enough). So basically what you can do is to leave the vregs on the PCBs where the 9v SIDs is gonna live, then feed it with all the 12v you want ;). It is important to think of PSU as a the whole circuit, not just the external stuff u buy or build -> there might be PSU components on the midibox pcbs also :). The C64 brick needs modifications? No, it just needs external regulator circuit to give u everything you need. I understood what you meant ytsestef, but I just wanted to clarify what you were saying. On MB6582, you have the luxury of setting it up for all kinds of powering options. It is described very well by Wilba in the wiki pages. Have a nice day / morning ;).
  2. technobreath
    MB6582 New panel
    Hehe. Dudes! We've got a new CNC in our worldwide toolbox :D. Go tell it on the mountain! :P. But seriously... How is the cover made? Milled down edges and glue it on the back?
  3. technobreath
    MB6582 New panel
    Looks really nice antix! I like it!, you're building a second one too?
  4. Dude, probably we can't expect more from these hehe. So it looks like the datasheet is wrong then... Interesting to know. Btw, don't tell missus I wad here, I am supposed to be at SARC. If she catches me in here I would probably end up in trouble :-p
  5. Yeah :). I havent seen any of mikes stuff. I didnt aim for a single sided board from the start. It was part of another more complicated PCB I made with 2xDIN / 1xDOUT / 8xBS on the same board :). So I just thought I should offer this part of it, since there didnt seem to be a lot of alternatives - I didnt want to retetris it to single sided when it was already done :).
  6. technobreath
    technobreath - All synth related
    Album about my midiboxing life Update: 2019: This gallery is very old. Do not pay too much attention to it. :) I have other stuff going on that may happen to be seen here one of these days :).
  7. technobreath
    Bankstick x8
    From the album: technobreath - All synth related
    I just saw a thread on bankstick in the forum. thought I should post this. I made it a while back, and it has sort of been sitting in my eagle project folder since then. If anyone want the files, just send me a PM :).
    © Ingebret Særheim a.k.a. technobreath
  8. I have eagle files on a rather compact bankstick x 8 board if u or any other are interested. I can mail em on request - just leave a PM. ;)
  9. technobreath
    SMPSU5V
    Hi hawk. First I thought this was gonna serve as psu for non musical stuff - like the mb64e-ish box Im building. Then I decided to try it in my SID synths too. - for 5v rail. I still gonna use linear standard approach on 9 / 12v rails for SIDs. - so sure Im interested in that! ;) For the stereo SID synth - the one that is getting the funky spaceship case - Im gonna need +5v, and +/-9v, for 8580s and a balanced transformer output. thought I would just get away with using 9v, on both the SIDs and the audio circuits to reduce the number of vregs in there. Can then use a 12v centertapped transformer on everything if the switcher design works out well :D.
  10. technobreath
    SMPSU5V
    Here's a switcher board. This is gonna be my prototype, but I haven't got all the parts yet. Anyway - the board has place for enough smoothing caps to acommodate pretty high current draw. Rectifier bridge has place for pretty big diodes. The vreg comes in 5 and 3.3 volt versions, and is pin compatible with 78xx vregs. So 1 or 2 smoothingcaps / diodes / vreg can be adjusted to specific needs. I hope it works, because what attracts me to this is the high input voltage range. No need for mor than 1 transformer even if you are making a 5 and 15v power supply. This is part of my &quot;modular&quot; supply.
    © Ingebret Særheim / technobreath
  11. Man, this is a nice thread. And man, there has happened a lot with availability in good switched regulators since that thread started. I have previously said I would never be converted to do switchers instead of linear, but with the speeds of modern switchers, this all seems way more attractive to me than before. But in that thread there are lots of info if you are hungry for that. Another tip that I can give you - if we step away from the DIY (oof hehe) for a little while. Many people buy their power supplies anyway, so I gather it is OK hehe. My thought is - get someone to help you build it if you (after reading the thread) isn't able to build it yourself. You know any electronics students? or one that teaches it? Don't even need to know people - you could contact a school where they teach electronics - I bet designing and building a power supply like this would be an interesting project for at least a couple of students. Just a thought. But then again, I really really want to encourage you to learn this yourself. A basic powersupply is basically made out of 3 parts. 1: rectifier 2: smoothing caps (which is related to rectifiers) 3: regulation/protection. Regulators made out of ICs (most common around here at least) mostly has the protection you need in most cases (temp.shutdown, over current shutdown and so on). If you study these things - and there are a lot of online material - you should be able to construct your own. Be sure ALWAYS to use fuses though. IMPORTANT :). <- might not help you protect the circuit from getting "fried", but it will probably prevent fire :D. I have had myself a PCB on my bench cooking / frying becasue I had no fuse when there occured an error - haven't concluded what went wrong there yet, but we think it's a faulty vreg. That in combination with a big battery and no fuses made PCB cooking possible. EDIT/ADD: I have no idea how this works in USA, but in Norway I would make a phonecall to teacher / faculty bossy guy, and present my project / my intentions of calling him... http://www.ece.ucsd.edu/ No idea what kinda place this is - after all, I'm only a norse guy. But it looks like they are good enough equipped to help you out if they want to :).
  12. TV shop salesman: Salad Chef utilizes centrifugal high speed technology to spin the salad -> Oh, so it has a gear... :D dude!
  13. Hmm... Well, if you got SIDs waiting for a good home and sammich is gone - then all you have to do is to build it with modules instead. No problem at all.
  14. Playing hawkeye's proton blender. Wife fell asleep on the couch next to me now :P - you should take that as a compliment hawk hehe. :D
    1. Show previous comments  2 more
    2. Hawkeye
      Hawkeye
      hehe, let´s hope she does not read this :)
    3. jojjelito
      jojjelito
      Don't incite the rebellion :D
    4. technobreath
      technobreath
      Don't wake the mob huh? :).
  15. Yes and amen dude. I know of nobody else who would do what you do! :).
  16. yeah dude. short answer is www.midibox-shop.com ;)
  17. F I N A L L Y ! I finished the custom mb6582 front panel file and sent it to julianf. Waiting for his judgement on it now :).
    1. Show previous comments  3 more
    2. wicked1
      wicked1
      Im thinking about having a 19" panel made.. just have the controls over to one side.. the dead space behind the other part of the panel would be where the aouts and filters get mounted. I'm wanting everything to fit in a rack so I can transport it w/out too much effort...
    3. technobreath
      technobreath
      I have also thought of doing a rackmount, but I scrapped it as it won't fit my gig needs very good - I need the controls in front of me together with the master keyboard, and that doesn't work too good with a rackmount. But I might consider doing a rack mount for the FM when I build that.
    4. jojjelito
      jojjelito
      Yay! Julian F makes kick-ass high quality panels :) Have fun!
  18. technobreath
    25down15togo
    Hehe, I never heard of zendrum before now. Cool - hybrid between a lot of instruments. Reminds me of the sax... by the way - really nice work!
  19. edited my previous post.
  20. Edit: I might have interpreted original post the wrong way, therefore this post doesn't make sense anymore. All I'm saying - It's important that when u design and run bulk order, it is important to do it in an ethical way. I still stand by words, that your whole thing here can be interpreted the way I did, but if you say so I will take your word for it, so my appologies for being that hard. I still think you repsonded a very bad way to the critisism that u met. I'm saying one more thing - people who are on Tim's list, should really stand up to their commitment. When Tim get response from 1 out of 10, that is horrific statistics. Tim's services aint to be taken for granted!
  21. yo electro. I totally understand the frustration you feel, and everyone can slip a few words in frustration, including smashtv, and also myself :P. I am sure you understand that your first post could seem a bit frustrating to Tim, who does everything he can to supply as fast as possible, at the same time trying to be fair to everyone, putting thousands of dollars into this etc. Here's my few words about my experience with Tim. 1. Always reliable 2. Service is far beyond excelent 3. Quality control way beyond what I have seen anywhere else 4. High standards 5. Fair If you deal with Tim I'm sure you will not be disappointed (though this has taken a bit longer than anyone want). By the way, it looks like the PCBs are now available in his shop. The last thing we need is a fight. And everyone is welcome to contribute of course, but I really think it's fair to give the guy who invested a lot of money in this a chance to get the boards shipped. I know you will not be disappointed when dealing with Tim ;). Have a nice summer evening ;).
  22. is playing with car mechanics and body work :). Repairing front fender (crushed by the previous owner and a little bit by missus hehe) and replacing a faulty fuel injection nozzle, though I have no idea which one of them are faulty... guess I gotta do a little guesswork :P
    2. Hawkeye
      Hawkeye
      yes, the old ones were so rusty, it was fun! The only problem was to get the brake cylinder back, as i could not bleed it (bleeder rusted, too), once again brute force (and some tools) helped :)
    3. technobreath
      technobreath
      yep, and here's the secret - the bleeder aint there to help get the piston back either ;) - it is only there to bleed air out of the system in case u change pipes or in some other way have to disconnect pipes. The correct way to do is to use some tools and brute force :D hehe.
    4. Hawkeye
      Hawkeye
      hehehe :-D
  23. Mmmm. Finally a media streaming client that can play full hd video on my tv with 5.1!
    1. Show previous comments  5 more
    2. technobreath
      technobreath
      Yeah, J is right. I would rather have a PC, and I have pre ordered the raspberry pi some time ago, and that will probably become the real media center when it is up and running. Meanwhile I'm pretty happy with the samsung all-share thingy ;).
    3. technobreath
      technobreath
      Right now I'm trying to minimize the stuff I have under my TV, because the kid is too fond of remote controls and cables nowdays :P. But the PI can be attached behind the tv with dualsided tape :P hehe
    4. gslug
      gslug
      I intend to get a Pi to replace my car stereo. I may end up using another as a home media player - if I can persuade it to run MythTV frontend.
  24. What to do when fever / sore throat hit u? Keep midiboxing :D.
    1. jojjelito
      jojjelito
      Take a break and listen to some music? Eat chicken soup :)
    2. Hawkeye
      Hawkeye
      ah, get better soon! :)
  25. Very pleasant to deal with you :). Good package etc.
