422 -
24
Everything posted by jjonas
Simultaneous bank and program change messages to several cores
jjonas replied to jjonas's topic in MIDIbox SID
I have the same problem with Rosegarden (and midi files generated by it) sending simultaneous Bank and Patch Change commands to multiple cores on the MB6582. Right now the solution is that I send Bank and Patch changes only to cores 2-4, and only a Patch change command to core 1. That way the sounds to be played seem to be selected correctly, and if core 1 needs a bank change, I will have to remember to do that manually. If I add the Bank Change command to core 1 as well, the patches get messed up as described above. If there can be a solution to this problem, I'm willing to test different combinations, attach midi files which replicate this etc. -
Hi, I cannot answer all of your questions, but there's a free program called MidiEditor (Linux or Windows) that you can use to "merge" tracks from separate midi files. I use quotes because there's no "Merge" command per se that automates the process for you, but what you can do is open a midi file, select "Edit -> Select all events from channel/track", then "Copy events", then open another midi file and select "Edit -> Paste to channel/track". You probably have to familiarise yourself with MidiEditor's usage of "Channel" and "Track", I personally haven't done it yet well enough so that I could explain it confidently, sorry about that. I also haven't look into all the details of the program, but what I have done is select all the events on a channel and change them to listen to some other channel. I've also done this with files exported from Ardour, to set the tempo of the file (Ardour doesn't support exporting tempo at the moment.) UPDATE: TiMidity++ (a command line midi player) tells me that a MBSEQ4 exported midi file is "format: 1". MidiEditor crashes when trying to open it, though Ardour midi import works ok.
Is it possible to select each trigger layer in a track directly by assigning the corresponding function to a button in the hw configuration file? The default version of the configuration file (4.097 for Wilba frontpanel) has assignments only for trigger layers A, B and C (BUTTON_TRG_LAYER_A etc.). I'm not sure what it means but the ChangeLog entry for 4.090 could mean that it is possible: But perhaps I'm mistaken, because adding "BUTTON_TRG_LAYER_D" assignment in the hwcfg file produces this in MIOS Studio (2.4.9.): For what it's worth, I would be interested in making a small separate button panel (nowhere near the size of a BLM) to quickly navigate Drum Track trigger layers, which are now two button presses away (1. press Trigger Layer C button, 2. press a GPB to select a layer).
sammichSID Bulk Order Run #29/#30 - preorder form online
jjonas replied to nILS's topic in Bulk Orders
Someone please lock this thread, it's just encouraging false hopes that something's going to happen. -
The precompiled MIOS Studio available for Linux on this page works on my desktop computer but not my Thinkpad T400 (both computers are running Arch Linux). Attempting to run it on the laptop gives an "illegal command" error message. (I'm not too familiar with these things, but the desktop is AMD while the laptop is Intel, perhaps that makes a difference if the downloadable version was compiled on an AMD computer?) Anyway, I would like to attemp compiling it myself for the laptop, but I cannot locate the unpack_me.zip in the Github repository. The MIOS Studio page says, "The source code is available in the GIT Repository. It requires the Juce v2 release to compile; just unpack the files under tools/juce/unpack_me.zip", but there's no such file in the directory at the link. Where is it?
Hi, I haven't promoted my band's music on the forum before, but we have been grinding out a number of EPs since 2015 that feature the Midibox SID. Here's a link to our newest, published today: https://astrometrics.bandcamp.com/album/paradroid
The order number is 002188 (it was shipped on 12 January). Unfortunately I don't have a C64 available. I think the cable was correctly connected. But I can test it again, both with the cable and without it, and see if it makes a difference in my situation.
- 88 replies
- sid replacement
- sid clones
(and 4 more)
Tagged with:
Hi Martin, thanks for your input into the discussion! My message was based on my direct (and relatively uninformed otherwise) experience, where putting an ARM2SID pair into my MB6582 SID synth (connected with the included cable, and replacing two 6581 SIDs which produced a stereo sound) resulted in a mono sound, while putting two "main" chips (taken from two ARM2SID pairs) into the same sockets (without the connecting cable) resulted in a stereo sound. I didn't change any settings in the chips, or in the synth. What could explain this? Do you think it can be explained by looking at the ARM2SID pair alone, or should the MBSID harware and firmware be considered as well?
- 88 replies
- sid replacement
- sid clones
(and 4 more)
Tagged with:
I bought two pairs of ARM2SIDs, here's my experience. The first thing to say is: in my opinion one should not buy one ARM2SID for their MBSID for any reason. Buy two ARMSIDs instead. If it's true as dwestbury says a few messages above — and it would seem to be true — then the other chip in an ARM2SID pair is a dummy which makes no actual sound; instead the sound of the main chip is just doubled. Obviously that doesn't produce a stereo sound, only a louder mono sound. Maybe that's what a C64/128 user needs, but it's the wrong solution for an MBSID. Fortunately I could use the main ARMSID from each pair I bought to make one independent pair where each chip produces its own sound. And that sound is very good, I do recommend it (just check dwestbury's sound samples above). Unfortunately I effectively paid almost double the price for two ARMSIDs because I could use only half of what I bought (ARMSID = 28€ vs ARM2SID = 48€). But that's the nature of DIY sometimes :-) Hopefully this "research" will benefit someone else! As to the installation, it was a drop-in affair — no configuration needed on an actual Commodore 64/128 (which I don't have). Not sure whether it makes any difference, but I'm giving them 9VDC and that seems to work.
- 88 replies
- 1
- sid replacement
- sid clones
(and 4 more)
Tagged with:
If it's possible to do a popular SID track (which I guess could be easily compared to something on YouTube), that would be great!
- 88 replies
- sid replacement
- sid clones
(and 4 more)
Tagged with:
Have you had a look at the Beginner's Guide? Perhaps section 4. Entering notes (and subsection 4.1.4. Live recording) could be useful for your situation.
I didn't make any progress after the last message I wrote, unfortunately. I don't remember the details anymore, but based on what I wrote above — that sending 4000 bytes from the computer works ok, but sending a somewhat smaller number of bytes from the synth doesn't — I think I concluded that it's too much work for too unlikely gains. One of the reasons for this lack of faith is that the synth in question, DSI Tetra, has some problems, or at least some unpolished characteristics, with the combo mode. That's why I think it's possible that the syxdump problems might be because of the implementation of the synth, and that there's nothing I can do on the MBNG side. After all, a big test file dump from the computer to the MBNG works ok.
I uncommented all RECEIVERs and SENDERs except for one RECEIVER that receives the dump. My setup is such that the dump from the synth goes through a SEQv4 (v4+.095) before reaching the NG. If I bypass the SEQv4+ and put the dump directly into the NG, there doesn't seem to be dropped bytes, but if the dump goes through SEQv4+, some bytes (somewhere after the 1000 bytes mark) would seem to drop. The router on the relevant ports on the SEQv4+ is all channels in, all channels out (not sure if that affects sysex). Is it expected that routing the dump through the SEQv4+ could cause problems? The seq's info page shows CPU load 15% during the dump and no registered drops. UPDATE: I noticed today (13.2.) that even though I get the dump directly into the NG (and with only one receiver event) some bytes are jumping around between requests. So it might not have anything to do with SEQv4. I tried sending a 4000 byte test file from the computer to NG, that seemed to work ok, maybe I'll have to try different midi cables... UPDATE2: I tried 4 different midi cables, no difference. The next thing to try is to dump the data on the computer and diff the files to see if it's the synth that's sending inconsistent dumps.
I think what's limited to 8 characters is the label variable (like ^destpane), not the actual string that's displayed on the LCD. In your example above you have strings that are more than 8 characters ("VCO1 FREQ" has 9 characters), and in fact you're not limited to 8 characters with the "VCO1 FREQ" style texts you want to show on the LCD. The variable length in characters (^destpane) and the string length in characters ("VCO1 frequency") are not related, so you can have short variable names and long strings for them.
I ran into this a while ago. From the docs for NGL:
Hi, I trying to pick parameter values from a sysex dump that's over 1000 bytes long (a DSI Tetra combo edit buffer dump), is that too much for syxdump_pos? It's not possible to request a smaller slice. Requesting and receiving 439 bytes (normal mode edit buffer dump) seems to work ok, but with the <1000 dump I'm getting strange results at least from byte 137 onwards for some reason. Parameters values that should be in bytes one after the other are not; it appears as if some bytes are missing in between. For the moment I'd just like to determine whether or not it's a syxdump_pos limitation that might be causing the behaviour.
Not sure if this old thread is relevant anymore, but since it's pinned, I'll mention it here: I have three setups which take 41%, 44% and 95% of the available memory (64k) and contain 472, 569 and 1037 events respectively (as reported by MIOS Studio). I had to comment out some events in the last setup to make it fit (1066 events was a couple too much!). However, I don't require any changes, I didn't have to let go of anything important.
If you want to change the code to effect this, I cannot help, but the patch that comes up after power-on is saved with the emsemble.
Thanks! I will be able to check this next Friday when I'm back home.
The reason why the sender id's are the same: In this TK's example on if_equal the id's are the same for each command. I assume this works because the conditions are mutually exclusive, so that only one of the events will be triggered at any one time. The same id for all senders works ok with one button, but not with one encoder, which leads me to think it's not the sender id that's the problem.
The following setup is the same as above, only for a button instead of an encoder (the encoder setup is commented out). The button if_equal setup works as expected, the encoder one doesn't, even though to me they seem the same. The encoder value changes and the label updates on the display, but no receiver is receiving; for some reason the if_equal condition doesn't trigger like it does for the equivalent (so it seems to me) button value condition. RESET_HW ENC n=1 sr=1 pins=0:1 type=detented3 ROUTER n= 1 src_port=IN1 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n= 2 src_port=IN1 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 3 src_port=IN1 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n= 4 src_port=IN2 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 5 src_port=IN2 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n= 6 src_port=IN3 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 7 src_port=IN3 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n= 8 src_port=IN4 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 9 src_port=IN4 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n=10 src_port=SPI4 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=11 src_port=SPI4 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=12 src_port=SPI4 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=13 src_port=USB1 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=14 src_port=USB1 src_chn=0 dst_port=OUT2 dst_chn=0 ROUTER n=15 src_port=USB1 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n=16 src_port=USB1 src_chn=0 dst_port=OUT4 dst_chn=0 MAP1 1 5 6 9 10 12 16 EVENT_BUTTON id=33 hw_id=33 range=map1 value=1 label="@(1:35:1)Ch: %02d@(1:34:2)^synth" button_mode=Toggle EVENT_ENC id=1 hw_id=1 range=1:16 value=1 label="@(1:35:1)Ch: %02d@(1:34:2)^synth" # receive on channel 1 on port 1 EVENT_RECEIVER id=1 fwd_id=SENDER:1 fwd_to_lcd=1 type=NoteOn chn=1 key=any lcd_pos=1:1:1 label="Receiver%3i: %e" ports=0000100000000000 # send on channel 6 on ports 3-4 EVENT_SENDER id=1 if_equal=Button:33:1 fwd_to_lcd=1 type=NoteOn chn=1 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 EVENT_SENDER id=1 if_equal=Button:33:5 fwd_to_lcd=1 type=NoteOn chn=5 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 EVENT_SENDER id=1 if_equal=Button:33:6 fwd_to_lcd=1 type=NoteOn chn=6 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 EVENT_SENDER id=1 if_equal=Button:33:9 fwd_to_lcd=1 type=NoteOn chn=9 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 EVENT_SENDER id=1 if_equal=Button:33:10 fwd_to_lcd=1 type=NoteOn chn=10 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 EVENT_SENDER id=1 if_equal=Button:33:12 fwd_to_lcd=1 type=NoteOn chn=12 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 EVENT_SENDER id=1 if_equal=Button:33:16 fwd_to_lcd=1 type=NoteOn chn=16 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:1 fwd_to_lcd=1 type=NoteOn chn=1 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:5 fwd_to_lcd=1 type=NoteOn chn=5 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:6 fwd_to_lcd=1 type=NoteOn chn=6 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:9 fwd_to_lcd=1 type=NoteOn chn=9 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:10 fwd_to_lcd=1 type=NoteOn chn=10 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:12 fwd_to_lcd=1 type=NoteOn chn=12 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000 # EVENT_SENDER id=1 if_equal=Enc:1:16 fwd_to_lcd=1 type=NoteOn chn=16 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000
Hi, I'm trying to use an encoder to select the outgoing midi channel by using receiver, sender and if_equal. I'm able to change the channel in a "static" way, regardless of the encoder value, but I'm unsuccessful in trying to use if_equal to control which sender gets activated. The following setup (with only one sender and router routings disabled) works if I remove the if_equal=Enc:1:1. If it's in, the receiver does work, but the sender won't send anything, no matter what the encoder value is. Am I thinking this the right way? RESET_HW ENC n=1 sr=1 pins=0:1 type=detented3 ROUTER n= 1 src_port=IN1 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n= 2 src_port=IN1 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 3 src_port=IN1 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n= 4 src_port=IN2 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 5 src_port=IN2 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n= 6 src_port=IN3 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 7 src_port=IN3 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n= 8 src_port=IN4 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n= 9 src_port=IN4 src_chn=0 dst_port=OUT4 dst_chn=0 ROUTER n=10 src_port=SPI4 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=11 src_port=SPI4 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=12 src_port=SPI4 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=13 src_port=USB1 src_chn=0 dst_port=OUT1 dst_chn=0 ROUTER n=14 src_port=USB1 src_chn=0 dst_port=OUT2 dst_chn=0 ROUTER n=15 src_port=USB1 src_chn=0 dst_port=OUT3 dst_chn=0 ROUTER n=16 src_port=USB1 src_chn=0 dst_port=OUT4 dst_chn=0 # select outgoing channel EVENT_ENC id=1 hw_id=1 value=1 range=1:16 label="@(1:35:1)Ch: %02d@(1:34:2)^synth" # receive on channel 1 on port 1 EVENT_RECEIVER id=1 fwd_id=SENDER:1 fwd_to_lcd=1 type=NoteOn chn=1 key=any lcd_pos=1:1:1 label="Receiver%3i: %e" ports=0000100000000000 # send on channel 6 on ports 3-4 EVENT_SENDER id=1 if_equal=Enc:1:1 fwd_to_lcd=1 type=NoteOn chn=6 key=any lcd_pos=1:1:2 label="Sender%3i: %e" ports=0000001100000000
First two giveaways (3 DINS + 1 DOUT) to me please!
