Againsistm Posted January 8, 2020 Posted January 8, 2020 Hi @TK. This morning i flashed 0.95 and it started working again and now flashing 0.96 pre9 and that one also works perfectly. Now i flashed the 0.96 again and it works . So i dont get it anymore but didn't change anything with last night test but happy that it works now :)
TK. Posted January 8, 2020 Author Posted January 8, 2020 Hi @sis.tm this is interesting! I noticed a similar effect some weeks ago, first download was incomplete. Since neither the bootloader, nor MIOS Studio have been changed, my conclusion was that it's either related to my USB Hub, or a MacOS update. Are you also using MacOS "Catalina" (10.15)? Best Regards, Thorsten.
Againsistm Posted January 8, 2020 Posted January 8, 2020 Hi @TK. yes i also use 10.15. Normally I never have probs with mios updating and yesterday I tried it several times and all functionality worked except it crashed while pressing play. I removed the sd card. Emptied it etc but all no luck in getting it to run. This morning I went back to 0.95 and then up to 0.96 again (same file as yesterday) and now it works. Can't put my finger on it to be honest except that I don't like Catalina with all the strange thingies. You also use cv modules right? Do you also get noise when you connect the midibox to your computer by usb and try to record stuff in the daw? When the midibox is connected by usb I get a lot of ground hum. Just wondering if you have the same issue. Cheers Niels
TK. Posted January 9, 2020 Author Posted January 9, 2020 @sis.tm concerning MacOS update: I will observe this - once I got more indicators what could go wrong there, I will try to safeguard the upload. There are already some measures (e.g. checksums and handshakes), but it seems that this isn't enough. Otherwise: sometimes patience is a virtue - hopefully Apple will fix this. Concerning CV modules: just tested at my side. No ground hum, and no noticeable noice. Only if I extremely amplify the audio signal in my DAW, I can notice some digital noise (at an ignorable -80 dB level) which disappears if I disconnect CV and Gate, but definitely no hum. The system: MBSEQ is connected via a externally powered USB Hub to a MacMini 2012, a "Kraftzwerk" is connected to the CV interface, and Audio is connected to a Firestudio Mobile. Best Regards, Thorsten.
Againsistm Posted January 9, 2020 Posted January 9, 2020 (edited) Hi @TK. i think you are right about the waiting of a new apple update , at least that is mostly what i always do but ok i am not a programmer at all :) thanks for testing the cv modules out for me and glad it works for you ! For now i reinstalled Mojave back on my mac. Catalina gave me way to much audio problems. Edited January 10, 2020 by sis.tm
lukas412 Posted January 17, 2020 Posted January 17, 2020 On 1/8/2020 at 3:18 PM, sis.tm said: You also use cv modules right? Do you also get noise when you connect the midibox to your computer by usb and try to record stuff in the daw? When the midibox is connected by usb I get a lot of ground hum. Just wondering if you have the same issue. Cheers Niels I get this as well. I have been working through the problem with Andy, but haven't fully solved it yet. I have pretty much the same setup as @TK (4ms pod) and I get hum. Its much worse than @TK indicated his was, I see about a 20db increase in noise. I also notice that the more step LEDs I light up the louder the noise gets. I'm not even sure its ground hum. The only solution I have found so far is to use a USB cable connected directly to power and not the computer. Everything works great if there is no MBSeq -> PC connection. Another odd note is that it's some how related to the actual USB signal. In one case I was using a USB hub connected to my PC and thought I had solved the problem. Turned out that the USB cable I was using was bad and the hub was only giving the MB power, not actually connecting to the PC. As soon as I replaced it the hum came back again. Luke 1
Hawkeye Posted January 18, 2020 Posted January 18, 2020 @lukas412 If the computer introduces the noise, you could try to use a galvanic USB isolator, a potential model and how it could be attached is linked in the eurorack modules thread: I've spent a few hours measuring things with the scope over here: while i get minor digital noise with the v4+/Eurorack modules connected to the PC, i get no noise at all when connecting to a Laptop with a "travel adapter", that uses a 2-pin ac plug (without ac mains earth connection). I noticed some eurorack module manufacturers like Waldorf do use a "galvanic isolator" in the modules, e.g. in their "nw1 wavetable" module, probably to avoid similar noise problems in some setups. So, i'd recommend to try with a galvanic USB isolator, that powers the v4+ side with the same USB-only PSU, that gives you no trouble when connecting without PC. There should then be a very high likelihood, that the noise is gone, as there is no more directly wired connection to the PC. Best regards and have a nice weekend! Peter
TK. Posted January 18, 2020 Author Posted January 18, 2020 @lukas412 I remember that I got increased noise when the module is supplied from MBSEQ, therefore I jumpered it so that it's supplied from the 4ms pod PSU Best Regards, Thorsten.
Againsistm Posted January 18, 2020 Posted January 18, 2020 22 hours ago, lukas412 said: I get this as well. I have been working through the problem with Andy, but haven't fully solved it yet. I have pretty much the same setup as @TK (4ms pod) and I get hum. Its much worse than @TK indicated his was, I see about a 20db increase in noise. I also notice that the more step LEDs I light up the louder the noise gets. I'm not even sure its ground hum. The only solution I have found so far is to use a USB cable connected directly to power and not the computer. Everything works great if there is no MBSeq -> PC connection. Another odd note is that it's some how related to the actual USB signal. In one case I was using a USB hub connected to my PC and thought I had solved the problem. Turned out that the USB cable I was using was bad and the hub was only giving the MB power, not actually connecting to the PC. As soon as I replaced it the hum came back again. Luke Hi Lukas412, these are exactly my symptoms as well . I didn't try the galvanic usb isolator because i workaround the problem by powering the seq by an external power adapter and use a separate midi cable from my computer to the seq for the communications. This works quite good for me at the moment but i am very curious about the galvaniser. Maybe i will order one next month to try if this fixes it.
lp1977 Posted January 20, 2020 Posted January 20, 2020 Hi, In the SEQ V4+, is there a way to have a Parameter Layer affect another? Or, more specifically, assign a probability percentage to a Parameter Layer? For example, on a drum track, if I have a snare on a step and I have the Probability Parameter Layer engaged and set to 75% and the Roll Parameter Layer engaged with one of the roll lengths selected, the step will play on average 75% of the time and it will always have roll when it does play. Is there a way to have it play n% of the time and also have the Roll/Roll2 Parameter Layer be activated n% of the time? For example, 75% Step Gate probability with 25% Roll/Roll2 probability. So there's a mixture of single snare hits and rolled snares when the step does play. I see that there's a 'Ro' setting in Nth1 and Nth2 deterministic options, just curious if this can be done somehow with Probability for a more dynamic, random result. I did try some probability settings in the trigger layers A and B, but the probability setting affected the velocity gate, too, which muted the step with the same probability. Thanks in advance for any guidance.
TK. Posted January 26, 2020 Author Posted January 26, 2020 Unfortunately further probability values can't be added, this would result into too many layer assignment options which can't be implemented. So, only "workaround" that I see: use a second drum track. Best Regards, Thorsten.
lukas412 Posted January 27, 2020 Posted January 27, 2020 On 10/17/2019 at 2:36 PM, Rowan said: I've just had a chance to test this with 2 x AOUT_NG boards and I think I've came across a bug. The shift register that is assigned to CV_GATE_SR2 in the HWCONFIG file will only trigger once and then remains on. I thought I had a hardware problem initially but after some trouble shooting I'm pretty confident its a software problem, either user error or a bug. The reason this is that I swapped the CV_GATE_SR assignment for SR1 and SR2 in the hardware and the problem is always present Shift Register assigned to CV_GATE_SR2. Both of the AOUT_NG boards are working correctly. @Rowan and @TK I am having the exact same issue. CV_GATE_SR2 only triggers one time and then stays on. It's not the module as I swapped two of the gate modules and the one connected to CV_GATE_SR1 always works fine. This happens with the latest release. thanks, Luke
TK. Posted January 27, 2020 Author Posted January 27, 2020 This should be fixed now, please try this version: http://www.ucapps.de/mios32/midibox_seq_v4_097_pre1.zip Best Regards, Thorsten.
lukas412 Posted January 27, 2020 Posted January 27, 2020 1 hour ago, TK. said: This should be fixed now, please try this version: http://www.ucapps.de/mios32/midibox_seq_v4_097_pre1.zip Best Regards, Thorsten. Looking good @TK.! Thanks! Luke
lukas412 Posted January 28, 2020 Posted January 28, 2020 Hello @TK. I was wondering if it would be possible to add additional clock dividers to the analog clock out. Having PPQN is nice, but being able to divide it down further would be really useful for me. In a modular a lot of time I will take 1 PPQN out and send to a clock divider module to create longer intervals. This can be worked around using the trigger out or a gate out but then you loose a track. thanks, Luke
k2z3k0 Posted January 29, 2020 Posted January 29, 2020 On 6.01.2020 at 9:44 PM, TK. said: MIDIbox SEQ V4.096 has been officially released under http://www.ucapps.de/mios32_download.html ChangeLog: MIDIboxSEQ V4.096 ~~~~~~~~~~~~~~~~~ o the MIDI mixer can now send CC values to a bus. This especially allows to record CC changes (configure MENU->MIDI->Port accordingly so that it listens to the bus in Jam mode) hello everybody just testing new release and about MIDI MIXER CC to BUS is it possible now from MIDI MIXER to change for example Track #1 Semi Transpose(CC48)? just like with New parameter layer "Ctrl"? thanks in advance Kazik
k2z3k0 Posted January 30, 2020 Posted January 30, 2020 hello again Idea for option in LIVE REC MODE or maybe any REC MODE , that listen to incoming data from recording port and checks channel number changes and immediately is selecting track accordingly on MbSeq So if during recording i move encoder of midi channel #1 it will select Track #1 on MbSeq Also after channel number change he waits (some number of steps for example) and then if channel number is changed then change it,this is to protect from short switches between channels which can cause undesired effects. i think this little feature can improve live recording during the performance kinda "multitrack" recording thanks for your time Kazik
Rio Posted January 30, 2020 Posted January 30, 2020 (edited) Please be careful with such suggestions of implementation and if it is useful please only suggest this as an explicit option. Other data can also be transmitted to MIDI IN (routing, etc.) than just what is to be recorded (even while recording ...). Edited January 30, 2020 by Rio
TK. Posted February 9, 2020 Author Posted February 9, 2020 On 28.1.2020 at 10:48 PM, lukas412 said: Hello @TK. I was wondering if it would be possible to add additional clock dividers to the analog clock out. Having PPQN is nice, but being able to divide it down further would be really useful for me. In a modular a lot of time I will take 1 PPQN out and send to a clock divider module to create longer intervals. This can be worked around using the trigger out or a gate out but then you loose a track. Hi @lukas412 should be possible, I added this to the wishlist On 30.1.2020 at 7:44 AM, k2z3k0 said: Idea for option in LIVE REC MODE or maybe any REC MODE , that listen to incoming data from recording port and checks channel number changes and immediately is selecting track accordingly on MbSeq So if during recording i move encoder of midi channel #1 it will select Track #1 on MbSeq Also after channel number change he waits (some number of steps for example) and then if channel number is changed then change it,this is to protect from short switches between channels which can cause undesired effects. Hi @k2z3k0 I added this to the wishlist as well. Could be available if Channel "Auto" is selected in Jam Mode MIDI Routing Config The mentioned wait time will be important (e.g. switch only if within the last second no event from another MIDI channel has been received). Best Regards, Thorsten.
k2z3k0 Posted February 11, 2020 Posted February 11, 2020 On 9.02.2020 at 6:54 PM, TK. said: Hi @k2z3k0 I added this to the wishlist as well. Could be available if Channel "Auto" is selected in Jam Mode MIDI Routing Config The mentioned wait time will be important (e.g. switch only if within the last second no event from another MIDI channel has been received). Best Regards, Thorsten. hi Tk thank you for considering this idea "Auto" Channel is exact idea kind regards Kazik
k2z3k0 Posted February 14, 2020 Posted February 14, 2020 hello everyone While working with MORPHING(mbseqv4),i thought would be great to be able , to have option that when called(puch button) leaves currently Morphed values and sets Morph back to zero This way you could quickly build patterns just from using Morph thank you for your time Kazik
TK. Posted February 16, 2020 Author Posted February 16, 2020 Should be possible - would it be sufficient to provide such a function in the Morph page, e.g. GP button #6? Best Regards, Thorsten.
k2z3k0 Posted February 16, 2020 Posted February 16, 2020 Exactly! thank you for such quick response best regards Kazik
TK. Posted February 16, 2020 Author Posted February 16, 2020 Ok, something to try out: http://www.ucapps.de/mios32/midibox_seq_v4_097_pre2.zip It also features the auto-track selection for recording (in MIDI configuration page, turn Chn. encoder to right to select "Auto") Best Regards, Thorsten.
