latigid on Posted June 24, 2020 Report Posted June 24, 2020 Hi Bruno, My understanding of the selection buttons (around the datawheel) is: click and release: change the selection row to that function click and hold: temporarily switch to this function, when released it will revert back to the previous selection. Does it work that way on your side? Best, Andy Quote
Antichambre Posted June 24, 2020 Report Posted June 24, 2020 (edited) On my side, for the mute button, click and hold temporary switch to layers mute, then switch to tracks mute on button release. Always whatever the previous function(menu) was. And the others behaves pretty the same. If you are talking about something like short and long press difference when you said "click&release" and "click&hold", it's not the case, there's no diff. I just upgraded to the last firm version to be sure, same... Best regards Bruno Edited June 24, 2020 by Antichambre Quote
latigid on Posted June 24, 2020 Report Posted June 24, 2020 I think what I would expect is the Selection (Sel) row to always indicate the function indicated on the 8x selection buttons (SB). So if I am in Track, the Sel row should choose tracks 1-16/GxTy. Switching (click and release) to the mute mode will show the mutes. From Track, click and hold on Mute should allow temporary switching to mutes, then when released back to Track. For me, it seems somehow to get "stuck" so the mute SB stays on and the OLEDs stay stuck in mute. I wonder if there is a conflict with option #9 Quote Whenever a track or parameter layer is unmuted, it will be automatically selected.This option can now be disabled in the OPTIONS page (item 9/29) or similar? Quote
Antichambre Posted June 24, 2020 Report Posted June 24, 2020 If you're already in track mode(only track button lit) and you press(short or long is the same) the mute button, both rows will shows the tracks mute(redundant), if you want to get back the track sel on the second row you must press track another time then track and mute buttons are lit, first row and oleds indicate the mutes, second row indicates the selection. 41 minutes ago, latigid on said: I wonder if there is a conflict with option #9 Quote Whenever a track or parameter layer is unmuted, it will be automatically selected.This option can now be disabled in the OPTIONS page (item 9/29) I have to admit that i don't understand this option :/ Quote
latigid on Posted June 24, 2020 Report Posted June 24, 2020 6 minutes ago, Antichambre said: If you're already in track mode(only track button lit) and you press(short or long is the same) the mute button, both rows will shows the tracks mute(redundant), if you want to get back the track sel on the second row you must press track another time then track and mute buttons are lit, first row and oleds indicate the mutes, second row indicates the selection. I think I notice this behaviour too and it could be improved! What I would expect: From SB Track or layers, press and hold SB Mute, the Sel row controls mutes, also displays on the OLEDs. Releasing SB Mute would revert to the previous Sel. Does that fit with your idea? Quote
Antichambre Posted June 24, 2020 Report Posted June 24, 2020 (edited) Not exactly ;) for now the tracks mute is a constant page(appears and stays), the layers mute page is temporary(by holding mute button). I wish the layers mute page to be a constant page too, shown on oleds + first row and keep the tracks mute on 2nd row. By using SHIFT + MUTE for example. Maybe just for the Drum tracks type. Note: for Drum Tracks it's the Instruments mute page in fact. Edited June 24, 2020 by Antichambre Quote
Antichambre Posted June 24, 2020 Report Posted June 24, 2020 (edited) What you expect, leave the MUTE page on MUTE button release and come back to previous page is not possible cause Layers mute will not be accessible any more. I had a look on the code @TK. clearly mention it and disabled it. static s32 SEQ_UI_Button_Mute(s32 depressed) { static seq_ui_sel_view_t prev_sel_view = SEQ_UI_SEL_VIEW_NONE; if( !depressed ) { prev_sel_view = seq_ui_sel_view; seq_ui_sel_view = SEQ_UI_SEL_VIEW_MUTE; seq_ui_button_state.TAKE_OVER_SEL_VIEW = 1; } else { if( !seq_ui_button_state.TAKE_OVER_SEL_VIEW ) seq_ui_sel_view = prev_sel_view; } seq_ui_button_state.MUTE_PRESSED = depressed ? 0 : 1; #if 0 // doesn't really work since MUTE button also selects layer mutes when pressed // if( seq_hwcfg_button_beh.mute ) { if( depressed ) return -1; // ignore when button depressed ui_mute_prev_page = ui_page; SEQ_UI_PageSet(SEQ_UI_PAGE_MUTE); } else { if( seq_ui_button_state.MUTE_PRESSED ) { ui_mute_prev_page = ui_page; SEQ_UI_PageSet(SEQ_UI_PAGE_MUTE); } else { if( ui_page == SEQ_UI_PAGE_MUTE ) SEQ_UI_PageSet(ui_mute_prev_page); } } #else if( depressed ) return -1; // ignore when button depressed SEQ_UI_PageSet(SEQ_UI_PAGE_MUTE); #endif return 0; // no error } Edited June 24, 2020 by Antichambre Quote
Antichambre Posted June 24, 2020 Report Posted June 24, 2020 (edited) My best idea is to use the MUTE button to alternate between TRACKS MUTE and LAYERS MUTE pages.When you click MUTE for first time(when previous page is something else than a MUTE page) you will enter in TRACKs MUTE page: OLEDs and 1st row show the TRACKs MUTE, 2nd row shows the TRACK SELection directly, instead of the redundant TRACKs MUTE, TRACK Sel and MUTE leds lit to indicates MUTE for TRACKs Clicking a second time the MUTE button switches to the LAYERs MUTE page: OLEDs and 1st row show the LAYERs MUTE, Instruments for a drum track, parameters for all others, 2nd row still shows the TRACK SELection, or the TRACKs MUTE. in live it's interesting to have the mutes for the 16 tracks and 16 percussions at the same time, this can be an option to choose. MUTE led still lit, but now INSTruments or PARAMeters led lit depending on the Selected Track type(Drum or other), it indicates we are in the LAYERs MUTE and which type of layer it is. Option34/34: For Layers Mute Page Direct tracks butt are: Track Selection for a non drum track, layer button lit: for a drum track, instrument button lit: Option34/34: For Layers Mute Page Direct tracks butt are: Track Mute Now second row indicates the Track mute instead of the Track Selection: Clicking another time on MUTE button switches back to TRACKs MUTE page etc...Clicking other button than MUTE leave the MUTE pages.And EXIT button can be used to come back to previous page if this last was memorized on first MUTE click. Best regards Bruno Edited June 26, 2020 by Antichambre 2 Quote
Antichambre Posted June 25, 2020 Report Posted June 25, 2020 (edited) Here a new github branch for the MUTE PAGES improvement, what i explained above, this is better than words, you can test it directly.https://github.com/midibox/mios32/tree/feature/seqv4+_mute_pages_improvement It remains me to add the option: For LAYERs MUTE page, second row is TRACK SEL or TRACK MUTE... For the moment it's TRACK SEL ;) Done! Best regards Bruno Edited June 26, 2020 by Antichambre address page corrected ;), Option added. Quote
Antichambre Posted June 25, 2020 Report Posted June 25, 2020 (edited) On 25/06/2020 at 7:41 PM, Rio said: Page not found... Corrected! thxseqV4+_mute_pages_impoved_project.hex.zip Here the precomplied hex file.!!! This is not official release !!! Edited June 27, 2020 by Antichambre Quote
modus0perandi Posted June 26, 2020 Report Posted June 26, 2020 (edited) Here is another Midibox in the wild. Lacking both time and skills to really build one myself, i had one of the trusted builder to handle that part for me. This one was built by @Menzman (Michael Menze) here on the forum. Very nice chap and highly recommended if anyone else wanna take this route to get your hands on this wonderful piece of hardware. You can find him via the trusted builders list @ midiphy) edit: if a moderator can move this to the correct thread in the forum (v4+) it would be great, i just saw i accidently put it in the wrong one :) sorry! @Hawkeye ? Edited June 26, 2020 by modus0perandi wrong part f of the forum 3 Quote
Hawkeye Posted June 26, 2020 Report Posted June 26, 2020 @modus0perandi no problem, just copied it over to the other thread, but you can also leave it in here - it's looking very good - enjoy! :)Many greets and have a nice weekend! Peter Quote
Rio Posted June 27, 2020 Report Posted June 27, 2020 On 25.6.2020 at 8:13 PM, Antichambre said: Corrected! thx Here the precomplied hex file.!!! This is not official release !!!seqV4+_mute_pages_impoved_project.hex.zip the prebuild is not for my cpu ... Can you provide a LPC17 prebuild or take a screenshot / short description? Quote
Antichambre Posted June 27, 2020 Report Posted June 27, 2020 Just now, Rio said: the prebuild is not for my cpu ... Can you provide a LPC17 prebuild or take a screenshot / short description? Full description is above in the thread ;)I didn't test it with a non Midiphy SeqV4!Here the whole release. !!! This is not official release !!! Quote
Rio Posted June 27, 2020 Report Posted June 27, 2020 (edited) 53 minutes ago, Antichambre said: Full description is above in the thread ;)I didn't test it with a non Midiphy SeqV4! The idea is not only for the CPU nor for my panel layout. I have not looked further in the sources, but if it is midiphy related it should only be available for the related midiphy layout (by compiler flag or explicit options). Otherwise the mute/select workflow should work as usual (as the default option). Edited June 27, 2020 by Rio Quote
Antichambre Posted June 27, 2020 Report Posted June 27, 2020 (edited) 1 hour ago, Rio said: The idea is not only for the CPU nor for my panel layout. I have not looked further in the sources, but if it is midiphy related it should only be available for the related midiphy layout (by compiler flag or explicit options). Otherwise the mute/select workflow should work as usual (as the default option). It should change the behaviour of the mute for your version too. Test it and tell me what happens. the 2nd row(Direct tracks selection buttons) workflow is not an issue for your version cause they don't exist on the wilba CS. There's no change for the 1st row(GP buttons) they show exactly the same thing as before. Edited June 27, 2020 by Antichambre Quote
Rio Posted June 27, 2020 Report Posted June 27, 2020 (edited) tested it. sorry, but the navigation for mute page is totally confusing for me now ... I don't see the advantage there either. It's too much "click" for me. In the end i just want to mute something on the page quick & simple. I also have no problem as it has been solved so far. Edited June 27, 2020 by Rio Quote
Antichambre Posted June 27, 2020 Report Posted June 27, 2020 (edited) 47 minutes ago, Rio said: tested it. sorry, but the navigation for mute page is totally confusing for me now ... I don't see the advantage there either. It's too much "click" for me. In the end i just want to mute something on the page quick & simple. I also have no problem as it has been solved so far. The advantage is to keep one hand free for something else during drum parts muting too. Question of taste and Live Act workflow habits, no worry. Edited June 27, 2020 by Antichambre Quote
Antichambre Posted June 27, 2020 Report Posted June 27, 2020 (edited) @Rio The mute button behaviours is now an option. Old fashion(default), hold mute button to access Layer page or click alternates between the Tracks an Layers Mute pages. It's Option#34. On 24/06/2020 at 9:20 PM, latigid on said: I think I notice this behaviour too and it could be improved! @latigid on The second row behaviour is improved for both mute pages access(Option#34). Second row indicates tracks selection for both pages by default and can be changed by option#35 for Layers Mute page , Rows are no more redundant.The branch and release above in the thread had been refreshed. Best regards Bruno Edited June 27, 2020 by Antichambre Quote
lp1977 Posted June 27, 2020 Report Posted June 27, 2020 @Antichambre, I just tried your precompiled hex file and it's pretty cool. Nice tweak! Completely unrelated: did you rotate your keycaps 180º? 1 Quote
Antichambre Posted June 27, 2020 Report Posted June 27, 2020 Just now, lp1977 said: @Antichambre, I just tried your precompiled hex file and it's pretty cool. Nice tweak! Thx! :) Just now, lp1977 said: Completely unrelated: did you rotate your keycaps 180º? Yep! If you ask yourself why... I'm also unable to give you an answer, I tried both and finally let it like that ;) Quote
lp1977 Posted June 27, 2020 Report Posted June 27, 2020 (edited) @Antichambre Ha, yeah, I guess window on top or bottom is a matter of personal taste. I'm about to pull my clear caps off and address the light bleed. Thinking about using some 3/4" heat shrink tubing cut into rings. I saw you settled on black magic marker. After that, I will be installing the windowed keycaps. It requires a lot of hand pressure to install the caps onto the switches before inserting them into the PCB. With you having installed different key caps and removing and reorienting them a few times, did you have any issues pressing them onto the switch with the switches already soldered in the PCB? Any advice? Thanks Edit: Sorry, perhaps this is for a different thread. Edited June 27, 2020 by lp1977 Different Thread Topic Quote
Antichambre Posted June 27, 2020 Report Posted June 27, 2020 @lp1977 I forgot to apply the option#28(Invert Mute Leds) to the 2nd line when it indicates Tracks Mute in Layers Mute Page. I corrected it and refreshed branch and precompiled another time. Quote
latigid on Posted June 27, 2020 Report Posted June 27, 2020 Would have to try it some time I still don't have my SEQ mounted in its case ; I think the UX idea with illuminating the respective track/layer SB LED seems logical but I haven't played with drum tracks enough. Another one that was intended to be developed was the mute/solo display rather than doubling up on redundancy. An obvious question is how forks in the software are managed if they diverge from the main branch and only Thorsten has "full" commit privileges. But that is a discussion for another thread probably. Quote
