latigid on
PCBs for sale
23 posts in this topic
Doing a bit of spring cleaning, maybe these might be of interest. Prices in euro plus shipping
  • 20180203_114614.thumb.jpg.c7ea79a739fb03
  • Pads WS2812 LEDs and Sparkfun silcone buttons/matrix
  • Availability: 10
  • Price: 8
  • 20180203_114653.thumb.jpg.40a2bdffee073b
  • Encs  WS2812 LEDs and illuminated encoders
  • Availability: 10
  • Price: 10
  • encoders: 1.5 each
  • 20180203_114750.thumb.jpg.10576bd87957e9
  • ELO WS2812 LEDs, illuminated encoders, optional touch sensors, OLED displays mounted at 45 degrees
  • Availability: 13
  • Price: 20 (it's a four-layer board...)
  • 0.96" white OLED: 5 each
  • 20180203_114721.thumb.jpg.9fb32249bd4e8d
  • CS1 button matrix, encoders (some illuminated), LCD/OLED mounting
  • Availability: 8
  • Price: 12
  • 20180203_114557.thumb.jpg.05e86764f4d612
  • DIN6DOUT4 SRIO, works well with Pads, Encs and CS1. Level shifter for 16 outputs (e.g. higher-voltage gates etc.)
  • Availability:  9
  • Price: 6
  • 20180203_114812.jpg.6873cec5238c5d6a6af0
  • MiniCore PIC, designed for BLM but could be useful elsewhere
  • Availability: 3
  • Price: 5
  • 20180203_114457.thumb.jpg.f311723183580e
  • Disp. driver buffers and CS lines for OLED displays (32 per PCB). Works, but J15 connector is mirrored...
  • Availability: 8
  • Price: 5 or 2 with any other purchase
  • 20180203_114900.thumb.jpg.c7bf77ebe92574
  • SCS OLED many configurations possible (1-4 OLEDs, encoder and/or buttons)
  • Availability: 7
  • Price: 6
  • populated with 4xOLED: 25 (1 available). Looks a bit dusty, but screen protection still on :sunglasses:
  • 20180203_114956.jpg.360914f5fc5d12633afc
  • AOUT4 MAX525-based AOUT, four channels
  • Availability: 6
  • Price: 5
  • 20180203_115018.thumb.jpg.fdb305fc3b705c
  • AIN4 protection/scaling circuit interfacing to a 3V MCU, four channels
  • Availability: 8
  • Price: 5
Edited by latigid on
updated
Share this post
Link to post
Share on other sites
Already ???
:rolleyes:
Best
Zam
Share this post
Link to post
Hello Andy,
What is the CS1 original purpose?
Could be fine for CS development , no?
Best Bruno
Share this post
Link to post
Sure, it was designed as a MBCV v2 setup working with the ENC/PAD/SR boards (the DIN6DOUT4 can stack on the rear). Other priorities for the moment, so it's on hold. TK. has even developed a HWCFG for it; it's just been on the backburner for a while...
Share this post
Link to post
the DIN6DOUT4 has pulldown/up resistors on board?
Share this post
Link to post
Yes! It's a SOIC 165 chip on one side and a MSOIC on the other, just like in the BLM16x16+X
1 person likes this
Share this post
Link to post
cool, you got pm i take 2...
Share this post
Link to post
ELO: please more information about the used 2812 LEDs, which color in your Setup... it looks like you used 2x Single Color LEDs? CD? Color? - thx.
Share this post
Link to post
Here is a walkthrough on the ELO boards by Andy:
https://www.youtube.com/watch?v=iKZ_7VVqbFo
The LEDs are RGB with an integrated controller (WS2812), fully mixable by MBNG, you can achieve many different colors.
Many greets,
Peter
Share this post
Link to post
he is talking about 5050 LEDs so these for example might fit: aliexpress..
Share this post
Link to post
got the pcps and parts a few days ago, thx man
Share this post
Link to post
Cool cool, still have to catch up on the doku... I have at least the parts guide for the 'ELO board.
Share this post
Link to post
If still available i am interested in one of each: pads, encs, cs1, din6dout4.
Share this post
Link to post
All good!
Sorry, been busy! Will answer PMs/orders as soon as I can.
Share this post
Link to post
a question to the elo-boards:
what is a:
TS16 R-EU_TS 0204TS
how does this touchsensor look? ( i am on ordering parts...)
Share this post
Link to post
0204 is just the "wire link" resistor package. Notice one of the pads is connected to the encoder body, so bridging the TS parts as drawn as a "resistor missing a side" with wire will connect the metal surface to the DIN chain. Then something like a metal washer or custom CNC part can be connected to the encoder body using the thread/nut/washer.
It was done like this so that the TS functions can be separate from the encoders if needed, and also that the metal surface can be "processed."
Share this post
Link to post
quest on disp.driver.pcb: Software-Side:
is there any speciality  by using the driver instead of not useing a driver? (could i just run/adapt the MB-Programmer code for example... or is there more to do?)
Share this post
Link to post
Just follow the normal LCD setup by defining the desired number of displays through the bootloader app. I think the first 8 are still selected by J15, but I'm sure you could configure 64 lines using the Disp Driver CS if wanted.
It may be useful to power the driver at +5V if the OLEDs are locally regulated.
1 person likes this
Share this post
Link to post
ok cs0-7 directly from core, the others then from display-driver - i think i will plug Display 0-7 then in J15B. and the  display driver with that mirrored cable on J15A then... (may 3.3 5V problems accour? see my last sentence below)
hmm what about J9 - for what is that? should that be a output or a input? i dont measure voltage there... do i have to connect to core? anwhere?
do you have wired already displays with that pcb? , a photo additional to wiki - would be helpful: http://wiki.midibox.org/doku.php?id=display_driver
what i see, i have to paralell wire 8 displays per 2x5 socket, and single wire the cs coming from the 2x5 socket,
the ground i can take from the 2x5 socket,
the +Potential  (in your shematic its 5V) i dont found... maybe that J9? on the 2x5 i dont found that 5vdc+. ....
by the way in this document: http://ucapps.de/mbhp/mbhp_lcd_ssd1306_single_mios32.pdf the display is connected via 3.3V, in your diagram it is on +5V
Share this post
Link to post
Sorry for missing this; J9 is the power supply if you would like to supply it through the J1-8 headers. It's separate from the 3v3 supply.
Here is the correct wiring (a bit messy)
fetch.php?w=600&tok=57ca86&media=dispdri
Yes. The SPI data/clock/#DC can be shared between a few OLEDs (e.g. ELO or SCS-OLED) with a separate CS to each display.
Or you can power the displays directly from your PSU. Depends on the current etc.
I think I did it this way as Core J10B is wired to 3v3 (3v0 on a Disco board). Generally the logic levels shouldn't be mixed. It's just a matter of how the display expects its data.
1 person likes this
Share this post
Link to post
Just a quick note: The OLEDs I received are able to run at 5V instead of 3.3V. They are also brighter at 5V. So you might not need a 3.3V reg. If you use an external 5V power supply for your cores, you are able to power them directly through this.
I'm pretty sure this is valid for other OLEDs too. I order mine at aliexpress for about $3 / pc.
Share this post
Link to post
