SIDControl VST-plugin for MBSID V1 (not V2!) by S.M.
does anyone here use Abelton Live?  The vst loads fine for me but it does not seem to send MIDI out?  This is related to Live I'm guessing because the VST works great for me in Audiomulch and many other people are having success with Cubase.
  • Replies 90
  • Created
  • Last Reply
Top Posters In This Topic
Hi there,
At this time i'm working on a new version of SID-Control.
Thanks for suggestions and bug-reports so far.
The new version will be available, soon and i will post it in here.
S.M.
hi there look at http://www.saschazone.de for the new SIDControl-VST plugin.
It's a little bit smaller (957kb) and has a new display-section + external patch-call function. ;)
Maybe I could kill some bugs....(I hope so)
... S.M.
I have fixed some script-errorson my page.
- following browsers are tested by my side :
Opera 8.02      ok :)
Mozilla 1.7.11  ok :)
Firefox 1.06      ok :)
IE (have none)  ?? ???
greetings and good luck !
...S.M.
tested successfully with internet exploder 6. Just for the record, this should not mean that it is a recommendable browser at all.  ;)
kind regards  kc
  • 2 weeks later...
  • 4 weeks later...
  • 2 weeks later...
Fantastic work SM, really something I could use. Can't believe I didn't discover this earlier, but then again, I only ever visit when I have a problem, so it's my fault. Makes me feel I should contribute to this community more.
I've had some annoying issues in using the MbSID in my sequencer, I belive it sends an "all controllers off" at the end of a recording, which seems to mute the MbSID, so I have to change the patch back and forth for every few bars of recording. Now I can avoid this and even automate controls!
You're my hero of the day!
  • 3 months later...
hi,
I have just uploaded an additional version of SidControl-VST.
The new version should support the Multi-Sid-Versions (it sends its data on up to 4 MIDI channels simultaneously).
I do not know if it's the best solution because I own a Single-Sid-Synth, only.
S.M.
  • 4 weeks later...
i have a nice and usefull program:
energ xt (demo version dowloadable from the site http://www.xt-hq.com/ )
with this progam you can use vst instruments (and even sequencers, arpeggio generators etc etc...)
like modules in a modular synth... try to belive!
but when i load the sid vst control there is not the midi out to connect it to the output of energy xt...
it's hard to explain... and i'm not so good in english...
i think that if you dowload the demo version of this great program and try to use this with vst sid control you'll understand.
I have just tried out the energy-XT-Demo and I found out that the current versions of SidControl are NOT compatible with this Software. -sorry....
It is not because of the missing midi-out connectors because SidControl HAS NO CONNECTORS. Try the latest demo of 'Audiomulch' - a powerful Host for 'chaining' VST-Plugins http://audiomulch.com/download.htm , load the SidControl-VST and you'll see what I mean. After setting up SidControls MIDI-port (only!) You can play the Plugin without any problems.
- Be sure that Audiomulch is running - if not press 'Play'
I think that energy-XT is not made for 'non-soundprocessing-VST-Synths' and it eats SidControl's MIDI-data ...
greetings by S.M.
  • 1 month later...
Just incredible . .  can i program the audiounit version  ? Or it's just compatible with Logic ?  Thanks !
For Logic, wouldn't you just create this in the Environment?
  • 1 month later...
Not true...  the program is using a direct midi out and not plugin midi out. Since there is no vst midi connection , the plugin cant send midi out to the program...
I am using of plenty of different midi only plugins in xt just fine
Peter
I've noticed that and I'll add an extra(internal) MIDI-out in the next release.
Maybe the plugin runs in energyxt then, too.  - just wait a few days....
... S.M.
Wonderful! This convinced me finally into the adventure of building my first own SID. I was somehow worried how to control it conveniently through the PC, but your plugin makes a very cool appearance! Thanks...
... S.M.
That would be great!
  • 1 month later...
i wanted your little plugin, but while tryin to register myself an error occured:
Parse error: parse error, unexpected '}' in /web/temp/getpasswd.php on line 186
please fix it :) wanna have the controlling vst ;)
  • 4 weeks later...
Yes, the next version has an internal MIDI-out (and it works so far ;D).
I have to do some internal optimizations (remove the multiport capacity-I think it's unnecessary).
I made a workaround on my page in the last few days which spent a lot of time. Now it's
more comfortable and it works good with IE (but I recommend Mozilla).
New user registration is switched off, yet - but only a few days (max.72hrs-from now).
The next version of SidControl (and some other new VST's) will be available soon.
When it's done I'll drop a post in here to let you know. ;)
greetings by S.M.
  • 1 month later...
Hi.
I have just updated my page with a new version of SidControl
It's done to 98% and if there are no problems I think this is the last beta version.
S.M.
