MIDIbox of the Week (MIDIbox SID of Jack)
Nice one Jack :) Similar colour scheme to mine, now I know it will look just as I imagined it :D Fantastic!
I'm guessing that the LCD is actually a PLED, visible at that angle...
Where'd the panel come from? Schaeffer/FPE?
;D ;D ;D
NICE! That black/green is perfect for sure! I especially like the LCD/OLED display which gives the wohle baby a little "wow" effect! Pretty stuffed inside, too! ;)
That is beautifull machine, Jack! Display is definitly kickass.
I am interested in black housing... I painted my Traktor controller black myself. But, your case is black inside. Was it originaly black or you painted it inside too? That pannel is made of??? and by???
Thank you guys for your comments!
The panel was made by someone on this forum. The result was not so good when you take a good look at it, and the panel was scratched on arrival. I e-mailed this person, telling him about my concerns, but he has not replied. Therefore I choose not to mention his name.
I painted the case myself. I have never heard of original black C64s. Do these exist?
Sweet Box,
was there ever a black C64 ? I don´t think so.
Concerning the panel, whoever made it... nice work so far and so close to perfect ;). Some slight modifications in the setup and in the machining-plan and it´s excellent next time.
What did it cost ?
The material looks like the brushed black eloxated aluminium, I use, too. Very, very, very difficult to work with and the pure hell to fill with color ;). Good, you didn´t try, lol.
Cheers,
Michael
Excellent work,
but let me allow one warning for other midiboxer:
I don't think, it is a good idea to put the power supply (and main power) without any case into the C64 box.
If you do so, never supply power to the box while it is opened.
Perhaps you also get some noise to the audio out?
(If I see it right it's a switching supply?)
So if you take my advise: Make a external power supply for safety reasons and for "no-trouble-with-noise" reasons. High-End equipment never houses a AC supply inside. Always external.
Please don't mind this .... always safety first. We don't want to loose anybody on the way ;D
greets
Doc
What exactly is wrong with the panel? It looks pretty good in the pics but then again the pics aren't close up of the entire panel.
What's up with that piece of paper that appears to be right above the power supply? Isn't that kind of a fire hazard?
@aileroned
I`ve been asked is my C64 originally black, and I aske back same question as you, because I`ve never heard there are black version. The guy said there are black C64. ??? I have about 10 C64 and they are all dirty white and light brown. Also, seams there is none of the exactly same colour and surface texture. Also they have clips on different places. They are all pretty different.
Maybe custom, but not from the shop... the SX64's are darker but it aint black either.
@Therezin+Sasa+aileroned:
yes, it's correct, only C16 has a black case...
Commodore produces never a black case for a C64...;)
really nice work, but i wouldn't built in the PSU into it too.
It doesn`t matter, they looks exactly the same. Originaly black case is better than custom made since they put pigment in the plastic in the mixing proces. Obviously C16 wasn`t popular as C64. Too bad.
I think it is OK if PSU is in it as long as it is shiedled in some metal housing with ventilation holes. It is more compact that way. You don`t gave to drag around one more PSU.
Do what the PC casemodders do - use vinyl dye instead of paint.  It soaks into the plastic.
