TK. Posted July 26, 2008 Author Report Share Posted July 26, 2008 RC24:[tt] o voice allocation of multi engine working again o Lead engine: MdW (ModWheel) and Key modulation source now provide a value in positive range only o overworked oscillator pitch handling: now completely linear frequency calculations. Advantages: - modulation frequency (e.g. LFO vibrato) independent from oscillator frequency - accurate filter key tracking - the O2A option (forward pitch to AOUT) doesn't result into out-of-scale SID frequencies anymore o the presets under presets/v2_vintage_bank.syx have been overworked according to the new osc frequency handling[/tt]Following sound samples demonstrate the difference between the old and new oscillator pitch modulation handling:Old handling: with higher frequencies, the LFO modulation of the pitch got less "intensive"http://www.ucapps.de/mp3/midibox_sid/mbsidv2_lfo_nonlin_osc_frq_mod.mp3New handling: same "intensity" of the pitch modulation independent from the OSC frequency:http://www.ucapps.de/mp3/midibox_sid/mbsidv2_lfo_lin_osc_frq_mod.mp3Please update your preset bank!Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted July 26, 2008 Report Share Posted July 26, 2008 - modulation frequency (e.g. LFO vibrato) independent from oscillator frequency - accurate filter key tracking - the O2A option (forward pitch to AOUT) doesn't result into out-of-scale SID frequencies anymoreOH AWESOME! Quote Link to comment Share on other sites More sharing options...
TK. Posted July 26, 2008 Author Report Share Posted July 26, 2008 And again a new version (RC25) with fixed SusKey behaviourRazmo is currently doing a lot of checks beside of bringing up his Soundforge based editor.Here a demo of some really punchy patches (created & manually played by Razmo)http://www.midibox.org/users/razmo/mbsidv2_PatchTest.mp3Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Pascal Posted July 28, 2008 Report Share Posted July 28, 2008 WTF! I want this patches! Quote Link to comment Share on other sites More sharing options...
Sasha Posted July 28, 2008 Report Share Posted July 28, 2008 Razmo, those samples sounds nice! :) Thanks for publishing it Thorsten. Quote Link to comment Share on other sites More sharing options...
Matrix12x Posted August 20, 2008 Report Share Posted August 20, 2008 Those patches are great and punchy. I can't wait to build my MIDIBOX SID!! Quote Link to comment Share on other sites More sharing options...
Goblinz Posted August 20, 2008 Report Share Posted August 20, 2008 Nice patches... especially the one starting at 35 seconds, I can see me using this (or at least attempting to use it). Can't wait to get my SID finished. G Quote Link to comment Share on other sites More sharing options...
ris8_allo_zen0 Posted August 24, 2008 Report Share Posted August 24, 2008 I have to report two issues related to 2x16 LCD display:Reading in the manual I casually discovered the "Dump" option in the Shift menu. I can't see it because my LCD doesn't display it and I can't scroll to it because the menu encoder works on the parameter previously selected before pressing SHIFT. Is there anything that can be done? (i don't need it so desperately, but who knows in the future...)While displaying the special "parameter assignment" page, part of the parameter string falls outside the LCD range, especially the oscillator/lfo/env number which is quite important.My proposal: for 2x16 displays only, sacrifice the | character and the space between the first string (defined in sid_par_table.inc) and the second one (created in sid_lcd.inc). In the latter one, eliminating the # character and shortening some long variants if needed.Many thanks!!Greetings, RAZ Quote Link to comment Share on other sites More sharing options...
ris8_allo_zen0 Posted August 26, 2008 Report Share Posted August 26, 2008 While enjoying this great synth (and taking my chance to learn piano), I think I discovered a bug in rc25.Steps to reproduce:1- activate the Multi engine2- enable the "meter" led matrix mode3- press some keys on your keyboardYou'll see that all 6 oscillators are working in turn.4- enable the arpeggiator5- press at least a key onceYou'll see only one oscillator working, as expected (Multi engine can't work with the builtin arpeggiator).6- disable the arpeggiator7- press some keys on your keyboardYou should see 6 oscillators, but only 5 work. The one chosen for arpeggiator doesn't participate anymore.If you repeat steps 4 to 7, you'll see other oscillators not working anymore, until monophony.Some workarounds:- change the engine and return to Multi.- restart the synth.- press six keys at the same time.Best regards, RAZ Quote Link to comment Share on other sites More sharing options...
TK. Posted August 26, 2008 Author Report Share Posted August 26, 2008 Unfortunately it isn't possible to solve this arpeggiator switching properly due to conceptional reasons.The special handling of an arpeggiator in multi mode was already an unplanned add-on which required a lot of branches to get it working properly.You are saying that "Multi engine can't work with the builtin arpeggiator".This is wrong - instead, it should work perfectly with the multi engine! The voice handling is similar like for mono instruments to ensure, that an arp is always played by the same voice and arp sequencer, so that up to 6 different arpeggio instruments can be played in parallel over different MIDI channels or keyboard zones with dedicated sounds.I spent a lot of time to get this working, but it was clear to me that the current implementation isn't a proper solution...Covering the "turn off arp" case properly would require an indicator in the voice queue which stores, how the voice is/was used. It would consume additional CPU cycles when searching for a free voice etc... I think that it isn't really worth the effort to fix this.Instead I think, that the listed workarounds are fine ;)Best Regards, Thorsten.P.S.: I will think about a better 2x16 LCD support sooner or later, but for me this is a minor issue, there are currently much more criticial bugs, e.g. sometimes the engine is so overloaded, that this results into hanging notes.I already consider to remove or disable features in order to overcome this Quote Link to comment Share on other sites More sharing options...
ris8_allo_zen0 Posted August 27, 2008 Report Share Posted August 27, 2008 Thanks TK for the explanation. I tried the arpeggiator with split keyboard just now. It's fantastic!!!Best regards, RAZ Quote Link to comment Share on other sites More sharing options...
dj3nk Posted August 27, 2008 Report Share Posted August 27, 2008 Is there a way to integrate analog multiplexing? If this can't be integrated in a future RC, is it integratable by hand? EDIT: Perhaps the slave cores could "share" the analog inputs somehow ?! Quote Link to comment Share on other sites More sharing options...
TK. Posted August 27, 2008 Author Report Share Posted August 27, 2008 No, the application uses its own ADC scanning routine which isn't extendible for analog multiplexers.Also the inputs of the slave cores cannot be scanned by the master core (event propagation from slave to master would lead to a performance loss)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Jurbo Posted October 9, 2008 Report Share Posted October 9, 2008 I have spent a couple of hours toying around the MBSID V2 - I'm slowly starting to understand the workings of it after upgrading from V1... This thing has seriously multiplied in capacity! The available ways to mangle the sound of the poor old SID are beyond belief! I had barely scratched the surface of the MBSID V1, thinking how versatile it was - and now I have this new beast in my hands... It's simply amazing!!!Thorsten - your work is simply fantastic! Maximum respect! 8) Quote Link to comment Share on other sites More sharing options...
puddingbrumsel Posted October 18, 2008 Report Share Posted October 18, 2008 Hi TK,is it possible to get a MidiClock-Signal on the supported Midi-out ? I wonder why there is no clock as the sid can be used as a drumsynth with TR-like-sequencer. And internal the clock is already available. So the SId can act as a real midi-master.best regards Quote Link to comment Share on other sites More sharing options...
TK. Posted November 16, 2008 Author Report Share Posted November 16, 2008 Jurbo: thank you! :)Puddingbrumsel: I could add a MIDI clock output, but there is a high danger that it will jitter, as the events have to be sent from a low priority task, while the internal synth is running on a high priority task (which isn't allowed to send MIDI...)So, under such circumstances, would it really be useful, or wouldn't it be better to use an external master for synching all your MIDI devices from the same source?Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
puddingbrumsel Posted November 17, 2008 Report Share Posted November 17, 2008 Puddingbrumsel: I could add a MIDI clock output, but there is a high danger that it will jitter, as the events have to be sent from a low priority task, while the internal synth is running on a high priority task (which isn't allowed to send MIDI...)So, under such circumstances, would it really be useful, or wouldn't it be better to use an external master for synching all your MIDI devices from the same source?you're right TK. I remembered another answer from you in another thread. So i decided to add a midi-thru to my sid. Shoud be the better choice. Thanks Quote Link to comment Share on other sites More sharing options...
TK. Posted December 20, 2008 Author Report Share Posted December 20, 2008 RC26 is available now.It contains some improvements for Super Poly mode and SysEx distribution via CANBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
renepela Posted December 22, 2008 Report Share Posted December 22, 2008 Could it be you forgot to change the version number? I uploaded RC26, but after the reboot it still shows version RC25 on my display.I use Setup_mb6582.hexBy the way: What is the difference between setup_mb8580 and setup_mb6582? The 6582 and 8580 are exactly the same chips if I'm not mistaking. Quote Link to comment Share on other sites More sharing options...
TK. Posted December 22, 2008 Author Report Share Posted December 22, 2008 Yes, version number isn't incremented this timeBy the way: What is the difference between setup_mb8580 and setup_mb6582? The 6582 and 8580 are exactly the same chips if I'm not mistaking.Some precompiled setups are part of this package: o setup_6581.hex (MBSID stuffed with 6581) o setup_8580.hex (MBSID stuffed with 8580) o setup_tk.hex (TK's Setup) o setup_mb6582.hex (MB-6582 Setup)[/code]To check the difference, type:diff setup_8580.asm setup_mb6582.asmBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
renepela Posted December 22, 2008 Report Share Posted December 22, 2008 Thanks Thorsten. It seems the differences are in the LCD display (4 lines instead of 2) and the shiftregisters.How can I compile myself to increment the version number? I found the version numer is in main.inc so all I have to do is change it there and then recompile.Or is there perhaps a way to change it directly in the hex file with a hex editor?Best regards,Rene Quote Link to comment Share on other sites More sharing options...
TK. Posted December 22, 2008 Author Report Share Posted December 22, 2008 Or is there perhaps a way to change it directly in the hex file with a hex editor?If you find the location and calculate a new checksum for the appr. line, it could work - but it's error prone.For details, how to build a new .hex file, see http://www.midibox.org/dokuwiki/application_developmentHowever, I re-uploaded the .zip package with changed version number.Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
renepela Posted December 22, 2008 Report Share Posted December 22, 2008 Thanks Thorsten. Quote Link to comment Share on other sites More sharing options...
nILS Posted January 18, 2009 Report Share Posted January 18, 2009 Found some oddness: * While playing around with the SID I noticed that it seems to be impossible to set the ARP direction via sysex (according to the sysex implementation sheet the editor is doing it right, it just doesn't have any effect). I asked Wilba to try to reproduce this and he had the same issue.* Rutger's editor shows some arp directions that are not documented in the sysex implementation docu. Quote Link to comment Share on other sites More sharing options...
TK. Posted January 18, 2009 Author Report Share Posted January 18, 2009 * While playing around with the SID I noticed that it seems to be impossible to set the ARP direction via sysex (according to the sysex implementation sheet the editor is doing it right, it just doesn't have any effect). I asked Wilba to try to reproduce this and he had the same issue.Works at my side with the latest editor release, and the improved version which is already in the repository.Maybe you tried to change the direction of an oscillator which isn't enabled? (check the waveform settings)It could also make sense to activate the oscillator link at the bottom of the editor.Rutger's editor shows some arp directions that are not documented in the sysex implementation docu.fixed in the docsBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
