        FantomXR
                Posts1,035
                Days Won22
Everything posted by FantomXR
	Same here. But it seems to be correct. I've used it a lot already.
	Ainser 64 config. 10..11bit with Traktor PRO pitch faderFantomXR replied to VNat's topic in MIDIbox NG If you set type=cc then it's logical that it only allows values between 0-127. If you want to send highres-midi you have to set the type=pitchbend or type=NRPN. If you substract 7682 from 8192 you will get 510, which is almost what you set with the range. In this case you have to use MAPs instead of standard ranges. Then it will work. Please refer to the NGC-manual. For testing purposed I'd recommend not to use ranges anyway.
- 4 replies
		- ainser 64
- pitch fader
					(and 5 more)
					Tagged with:
	Ainser 64 config. 10..11bit with Traktor PRO pitch faderFantomXR replied to VNat's topic in MIDIbox NG This should totally be possible. Would you please post the related parts of your NGC file?
- 4 replies
		- ainser 64
- pitch fader
					(and 5 more)
					Tagged with:
	@latigid on as this might effect the programma too, maybe you can answer this question: Is there any other way to achieve this?
	Any idea when this will be ready?
	As far as I know the maximum allowed number of banks is 127. So this shouldn't be a problem. You want 33 OLEDs? This is definitely nothing easy to do. You need to take care of the clock pin when doing the PCB layout. Nothing you can do on breadboard. Also you'd need a separate power supply for it.
	Hey TK., I wonder why RECEIVERS do not react to banks. This is the example code: EVENT_RECEIVER id=1 type=SysEX stream="0xf0 0x33 0x22 0x33 0x00 ^txt 0xf7" lcd_pos=1:1:1 bank=1 EVENT_RECEIVER id=2 type=SysEX stream="0xf0 0x33 0x22 0x33 0x00 ^txt 0xf7" lcd_pos=2:1:1 bank=2 I'd expect: When bank 1 is selected the text will be displayed on the first screen. When bank 2 is selected it will show up on the second display. If bank 3 is selected nothing should happen. But what happens is that it always shows up on both displays. Should it be like this? In my setup I send a bunch of SysEx strings to the midibox and I'd like to switch between them with banks. Is that possible? Thanks, Chris
	Please help me to understand how the NG app works internallyFantomXR replied to tago's topic in MIDIbox NG I don't see the reason why TK choosed sr=9 as emulated shiftregister. But anyway: When working with emulated elements (same is valid for button- & LED-matrices f.e.) it's always good to use a value that is definitely not blocked by real hardware. The keyboard blocks the first two digital input-SRs (usually HC165) and the first two digital output-SRs (usually HC595). dout_sr1=1 means the first HC595 in the digital chain. din_sr1=1 means the first HC165 in the chain. For a beginner this might be confusing. In NG you can set the total number of scanned shiftregisters with this command: SRIO num_sr=2 Even though in this example I set num_sr=2 I can connect in total 4 shift registers. 2x HC165 and 2x HC595.
	Please help me to understand how the NG app works internallyFantomXR replied to tago's topic in MIDIbox NG In your code you had assigned SR1 to both the keyboard and the DIO (J5A) module. This is invalid. You have to use a SR number that it not in use. And the last pin on the 8th SR is Pin 64 (8x8). So the first pin on the 9th is 65.
	Oh, really? I'll check again. If this is the case there must be a mistake somewhere else. I'll report back. But at least it's not true for receivers that receive sysex strings and forward them to displays. Correct?
	Hey people, In general I work with different banks. One thing that bothers me since starting working with NG is that it doesn't listen to all banks at the same time. So if I dump values to the midibox it only listens to the bank that it just activated. All other banks do not refresh. Is there a chance that this will be possible in the future? Thanks, Chris
	Yes. I still have some boards. Not soldered yet but I could do it. Pls drop me a message if interested.
- 19 replies
		- midibox kb
- fatar
					(and 2 more)
					Tagged with:
	I tried it now with a fresh firmware. I cloned the GitHub to get the latest version. Then I've copy/pasted the changes @TK. made into the code and compiled. I use the core and a classic AINSER8 module. PB8 goes directly from the discovery-board to a breadboard. There is a pullup resistor to 5V. PB8 goes into the CS-input. Result: It's working fine. If I now just change PB8 to PE8 (like in your example), nothing happens. Here is my NGC: RESET_HW AINSER n=1 enabled=1 cs=1 resolution=7bit num_pins=1 muxed=0 AINSER n=2 enabled=1 cs=2 resolution=7bit num_pins=1 muxed=0 Have you an idea?!
	Okay. I tried with a MIDIbox Core. Same: It's not working. Nothing happens... any help on this?!
	Ah, no. It's SMD soldered. So, traces are given. But I double-checked the schematic and all looks well. Here is the excerpt from the PCB layout: Pin 6 of the connector comes from PE6 of the STM. The rest is the same as on the other MCP.
	Invert?! What do you mean with that?
	Yes. I did. I see the pulses on the CS line.
	No. As I don't use any other app and I stated above that I want to use it in NG TK surely took care of it. This is ainser.c: // $Id$ //! \defgroup AINSER //! //! AINSER module driver //! //! \{ /* ========================================================================== * * Copyright (C) 2011 Thorsten Klose (tk@midibox.org) * Licensed for personal non-commercial use only. * All other rights reserved. * * ========================================================================== */ ///////////////////////////////////////////////////////////////////////////// // Include files ///////////////////////////////////////////////////////////////////////////// #include <mios32.h> #include "ainser.h" ///////////////////////////////////////////////////////////////////////////// // Local variables ///////////////////////////////////////////////////////////////////////////// static u8 num_used_modules = AINSER_NUM_MODULES; static u8 ainser_enable_mask; static u8 ainser_muxed_mask; static u8 num_used_pins[AINSER_NUM_MODULES]; static u16 ain_pin_values[AINSER_NUM_MODULES][AINSER_NUM_PINS]; static u16 previous_ain_pin_value; static u8 ain_deadband[AINSER_NUM_MODULES]; ///////////////////////////////////////////////////////////////////////////// // Local Prototypes ///////////////////////////////////////////////////////////////////////////// static s32 AINSER_SetCs(u8 module, u8 value); ///////////////////////////////////////////////////////////////////////////// //! Initializes AINSER driver //! Should be called from Init() during startup //! \param[in] mode currently only mode 0 supported //! \return < 0 if initialisation failed ///////////////////////////////////////////////////////////////////////////// s32 AINSER_Init(u32 mode) { s32 status = 0; int module, pin; // currently only mode 0 supported if( mode != 0 ) return -1; // unsupported mode #if AINSER_SPI_OUTPUTS_OD // pins in open drain mode (to pull-up the outputs to 5V) status |= MIOS32_SPI_IO_Init(AINSER_SPI, MIOS32_SPI_PIN_DRIVER_STRONG_OD); #else // pins in push-poll mode (3.3V output voltage) status |= MIOS32_SPI_IO_Init(AINSER_SPI, MIOS32_SPI_PIN_DRIVER_STRONG); #endif // extra CS pin #if AINSER_NUM_MODULES >= 3 MIOS32_BOARD_J10_PinInit(14, MIOS32_BOARD_PIN_MODE_OUTPUT_OD); #endif // SPI Port will be initialized in AINSER_Update() num_used_modules = AINSER_NUM_MODULES; #if AINSER_NUM_MODULES > 8 # error "If more than 8 AINSER_NUM_MODULES should be supported, the ainser_enable_mask variable type has to be changed from u8 to u16 (up to 16) or u32 (up to 32)" #endif #if AINSER_NUM_MODULES > 8 # error "If more than 8 AINSER_NUM_MODULES should be supported, the ainser_muxed_mask variable type has to be changed from u8 to u16 (up to 16) or u32 (up to 32)" #endif for(module=0; module<AINSER_NUM_MODULES; ++module) { num_used_pins[module] = AINSER_NUM_PINS; // ensure that CS is deactivated AINSER_SetCs(module, 1); AINSER_EnabledSet(module, 1); AINSER_MuxedSet(module, 1); AINSER_NumPinsSet(module, AINSER_NUM_PINS); AINSER_DeadbandSet(module, MIOS32_AIN_DEADBAND); // clear all values for(pin=0; pin<AINSER_NUM_PINS; ++pin) { ain_pin_values[module][pin] = 0; } previous_ain_pin_value = 0; } return status; } ///////////////////////////////////////////////////////////////////////////// //! \return the number of modules which are scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumModulesGet(void) { return num_used_modules; } ///////////////////////////////////////////////////////////////////////////// //! Sets the number of modules which should be scanned //! \return < 0 on error (e.g. unsupported number of modules) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumModulesSet(u8 num_modules) { if( num_modules >= AINSER_NUM_MODULES ) return -1; num_used_modules = num_modules; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the enable mask for modules which should be scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_EnabledGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; return (ainser_enable_mask & (1 << module)) ? 1 : 0; } ///////////////////////////////////////////////////////////////////////////// //! Sets the enable mask for modules which should be scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_EnabledSet(u8 module, u8 enabled) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module if( enabled ) ainser_enable_mask |= (1 << module); else ainser_enable_mask &= ~(1 << module); return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \retval 0 if 1-to-8 multiplexers disabled for the given module //! \retval 1 if 1-to-8 multiplexers enabled for the given module (default) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_MuxedGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; return (ainser_muxed_mask & (1 << module)) ? 1 : 0; } ///////////////////////////////////////////////////////////////////////////// //! Enables/disables the 1-to-8 multiplexer handling.\n //! Use muxed=0 for AINSER8 module, and muxed=1 for AINSER64 module (default) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_MuxedSet(u8 module, u8 muxed) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module if( muxed ) ainser_muxed_mask |= (1 << module); else ainser_muxed_mask &= ~(1 << module); return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the number of AIN pins per module which are scanned ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumPinsGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; // invalid module (return 0 pins) return num_used_pins[module]; } ///////////////////////////////////////////////////////////////////////////// //! Sets the number of AIN pins per module which should be scanned //! \return < 0 on error (e.g. unsupported number of pins) ///////////////////////////////////////////////////////////////////////////// s32 AINSER_NumPinsSet(u8 module, u8 num_pins) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module if( num_pins > AINSER_NUM_PINS ) return -2; num_used_pins[module] = num_pins; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the deadband which is used to notify changes //! \return < 0 on error ///////////////////////////////////////////////////////////////////////////// s32 AINSER_DeadbandGet(u8 module) { if( module >= AINSER_NUM_MODULES ) return 0; // invalid module (return 0) return ain_deadband[module]; } ///////////////////////////////////////////////////////////////////////////// //! Sets the difference between last and current pot value which has to //! be achieved to trigger the callback function passed to AINSER_Handler() //! \return < 0 on error ///////////////////////////////////////////////////////////////////////////// s32 AINSER_DeadbandSet(u8 module, u8 deadband) { if( module >= AINSER_NUM_MODULES ) return -1; // invalid module ain_deadband[module] = deadband; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// //! \return the AIN pin value of the given module and pin //! \return < 0 if wrong module or pin selected! ///////////////////////////////////////////////////////////////////////////// s32 AINSER_PinGet(u8 module, u8 pin) { if( module >= AINSER_NUM_MODULES ) return -1; if( pin >= AINSER_NUM_PINS ) return -1; return ain_pin_values[module][pin]; } ///////////////////////////////////////////////////////////////////////////// //! \return the previous value of the pin which has triggered the NotifyChanged hook.\n //! Only valid when function is called from this hook! ///////////////////////////////////////////////////////////////////////////// s32 AINSER_PreviousPinValueGet(void) { return previous_ain_pin_value; } ///////////////////////////////////////////////////////////////////////////// //! This function should be periodically called to scan AIN pin changes. //! //! A scan of a single multiplexer selection takes ca. 50 uS on a LPC1769 with MIOS32_SPI_PRESCALER_8 //! //! Whenever a pin has changed, the given callback function will be called.\n //! Example: //! \code //! void AINSER_NotifyChanged(u32 pin, u16 value); //! \endcode //! \param[in] _callback pointer to callback function //! \return < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 AINSER_Handler(void (*_callback)(u32 module, u32 pin, u32 value)) { // the mux_ctr -> pin mappin is layout dependend //const u8 mux_pin_map[8] = {0, 1, 2, 3, 4, 5, 6, 7 }; //const u8 mux_pin_map[8] = {1, 4, 3, 5, 2, 7, 0, 6 }; // reversed pins const u8 mux_pin_map[8] = {6, 3, 4, 2, 5, 0, 7, 1 }; // order of MUX channels static u8 mux_ctr = 0; // will be incremented on each update to select the next AIN pin static u8 first_scan_done = 0; static u16 link_status_ctr = 0; s32 status = 0; // init SPI port for fast frequency access // we will do this here, so that other handlers (e.g. AOUT) could use SPI in different modes // Maxmimum allowed SCLK is 2 MHz according to datasheet // We select prescaler 64 @120 MHz (-> ca. 500 nS period) status |= MIOS32_SPI_TransferModeInit(AINSER_SPI, MIOS32_SPI_MODE_CLK0_PHASE0, MIOS32_SPI_PRESCALER_64); // determine next MUX selection int next_mux_ctr = (mux_ctr + 1) % 8; // link LED will flash with PWM effect ++link_status_ctr; const u32 pwm_period = 20; // *1 mS -> 20 mS const u32 pwm_sweep_steps = 100; // *20 mS -> 2000 mS u32 pwm_duty = ((link_status_ctr / pwm_period) % pwm_sweep_steps) / (pwm_sweep_steps/pwm_period); if( (link_status_ctr % (2*pwm_period*pwm_sweep_steps)) > pwm_period*pwm_sweep_steps ) pwm_duty = pwm_period-pwm_duty; // negative direction each 20*25 ticks u32 link_status = ((link_status_ctr % pwm_period) > pwm_duty) ? 1 : 0; // loop over connected modules int module; u32 module_mask = 1; for(module=0; module<num_used_modules; ++module, module_mask <<= 1) { if( !(ainser_enable_mask & module_mask) ) continue; u8 muxed = ainser_muxed_mask & module_mask; // loop over channels int chn; for(chn=0; chn<8; ++chn) { // CS=0 status |= AINSER_SetCs(module, 0); // retrieve conversion values // shift in start bit + SGL + MSB of channel selection, shift out dummy byte MIOS32_SPI_TransferByte(AINSER_SPI, 0x06 | (chn>>2)); // shift in remaining 2 bits of channel selection, shift out MSBs of conversion value u8 b1 = MIOS32_SPI_TransferByte(AINSER_SPI, chn << 6); // shift in mux_ctr + "Link LED" status to 74HC595, shift out LSBs of conversion value u8 b2 = MIOS32_SPI_TransferByte(AINSER_SPI, ((chn == 7 ? next_mux_ctr : mux_ctr) << 5) | link_status); // CS=1 (the rising edge will update the 74HC595) AINSER_SetCs(module, 1); // store conversion value if difference to old value is outside the deadband u16 pin = muxed ? (mux_pin_map[mux_ctr] + 8*(7-chn)) : (7-chn); // the mux/chn -> pin mapping is layout dependend u16 value = (b2 | (b1 << 8)) & 0xfff; previous_ain_pin_value = ain_pin_values[module][pin]; int diff = value - previous_ain_pin_value; int abs_diff = (diff > 0 ) ? diff : -diff; if( !first_scan_done || abs_diff > ain_deadband[module] ) { ain_pin_values[module][pin] = value; // notify callback function // check pin number as well... just to ensure if( first_scan_done && _callback && pin < num_used_pins[module] ) _callback(module, pin, value); } } } // select MUX input mux_ctr = next_mux_ctr; // one complete scan done? if( next_mux_ctr == 0 ) first_scan_done = 1; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Internal function to set CS line depending on module ///////////////////////////////////////////////////////////////////////////// static s32 AINSER_SetCs(u8 module, u8 value) { switch( module ) { case 0: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE1, value); // spi, rc_pin, pin_value case 1: return MIOS32_SPI_RC_PinSet(AINSER_SPI, AINSER_SPI_RC_PIN_MODULE2, value); // spi, rc_pin, pin_value case 2: return MIOS32_BOARD_J10_PinSet(14, value); #if AINSER_NUM_MODULES > 3 # error "CS Line for more than 3 modules not prepared yet - please enhance here!" #endif } return -1; } //! \} and in mios32_config.h I set #define AINSER_NUM_MODULES 3 So, it should be exactly the same as in TKs branch.
	Dear @TK., could you help on this? I have no clue why this is not working at my side but at yours.
	Hey @TK., I tried it without success. I copied the code from you into my firmware. My NGC file looks like this: RESET_HW AINSER n=1 enabled=1 num_pins=1 cs=1 resolution=7bit AINSER n=2 enabled=1 num_pins=1 cs=2 resolution=7bit I have a potentiometer connected to the first analog input of the second and another one to the first input of the third module. The first module is not used at the moment. If I "set debug on" in the terminal, I see movements if I turn the potentiometer which is connected to the second module. Anyway I can not see anything when I turn the pot which is connected to the third module. I've tried both PP and OD mode (with 1k pullup to 5V). I use PE6, which should lead to MIOS32_BOARD_J10_PinInit(14, MIOS32_BOARD_PIN_MODE_OUTPUT_OD) and case 2: return MIOS32_BOARD_J10_PinSet(14, value); Any ideas what I do wrong?
	I'd strongly recommend to not use "normal" LEDs. It's much easier to use WS2812 RGB LEDs. Only one single data-line needed instead of 11 (in your case). And routing LED-matrix on a PCB is cumbersome.... Apart from that I can not answer your question...
	MB_NG supports up to 64 OLEDs from just one core ;-)
	It's actually 50€. @otropomhow much do you need of each? I need something from mouser as well and maybe it makes sense to combine both orders...
	It's just one line of code in the firmware. So you have to compile the firmware by yourself. Please note that both devices need to be powered from the same power source.
