1,285 -
72
Everything posted by Phatline
TM 4 BLM16 - TriggerMatrix remote via BLM16x16x
Phatline replied to Phatline's topic in MIDIbox User Projects
a jam session with the old UI: Triggermatrix as DrumSequencer, Trigger-Router, Melody-Retrigger > Soundengine: Nord3(efx), NordDrum2, KorgER2 2x Boss RC300 as Loopstation for Melody Loops (Subouts are routed to my filterdistortionADR-Drumtriggered-device...) LiveGituar on a Gutiarsynth RC20 (that makes them etnical sounds, no not the drums they are typical NordDrum2 yesss) -
From the album: TriggerMatrix
reuse instead of sale -
since i had a MB-SEQ-CS-PCB many years now - unused, without any case or frontpanel.... i decidet to hold it and use it i programm now a TriggerMatrix version for a more generic UI... so other people can "reUse" it, i skip my prototype UI. BLM16x16+x ( @latigid on ) MB-SEQ-CS ( @Wilba ) MB-LRE8x2CS ( @Fairlightiii ) To adapt my code i had to find out the pin-out of the new UI... here is the result: TriggerMatrix @ Generic MB-SEQ CS SEQ MENU – ENCODERS 62 54 ENC 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 59 50 SR 1 1 1 1 3 3 3 3 4 4 4 4 5 5 5 5 SWING PIN 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 63 55 58 49 ENC 16 JOG ROUTE FullVel SR 6 46 38 PIN 2 57 34 CC SetVel BLM+x 47 39 32 33 40 41 48 49 56 57 24 25 16 17 8 9 0 1 56 33 39 38 37 36 47 46 45 44 55 54 53 52 63 62 61 60 31 30 29 28 23 22 21 20 15 14 13 12 7 6 5 4 Intro Vel-Inv QntRec Swing Copy Paste Clear <Move Move> STORE LOAD Qnt16 Qnt32 Qnt64 Kill Hi Set Hi 35 42 43 50 51 58 59 26 27 18 19 10 11 2 14 30 35 43 42 51 PAGE 10 26 Copy Paste Clear BEAT STOP PLAY REC < > < > Kill Mid Set Mid 37 44 45 52 53 60 61 1 28 29 20 21 12 13 4 15 31 0? 41 40 48 FOCUS 18 19 11 3 2 9 25 Kill Lo Set Lo MB-LRE8x2 CS 2.5 in seriell to MB-SEQ CS Wilba 6 22 ENC Kill_M Dcy_M Vel_M Delay Swn16 Swn32 BTN 8 24 SR 7 7 8 8 9 9 10 10 LED PIN 0 4 0 4 0 4 0 4 ENC Kill_D Dcy_D Vel_D Kill_T FullVel Vel_Lo Vel_Mi Vel_Hi SR 7 7 8 8 9 9 10 10 PIN 2 6 2 6 2 6 2 6 programming setup: -
yesss... Triggermatrix is on the way to generic SOFTWARE: i stripped it a bit, and something... to find the pinning... and with pinning its easyer to program.... UI__SEQ-CS+LRE8x2CS.zip HARDWARE: STM34F4 CORE [J8/J9] > [J1]MB-SEQ-CS-Wilba[J2] > [IN]MB-LRE8x2CS-Fairlightii MB-SEQ CS BLMx ENCODERS BTN 62 54 ENC 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LED 59 50 SR 1 1 1 1 3 3 3 3 4 4 4 4 5 5 5 5 BTN 63 55 PIN 6 4 2 0 6 4 2 0 6 4 2 0 6 4 2 0 LED 58 49 BTN 46 38 ENC 16 JOG LED 57 34 SR 6 BTN 47 39 PIN 2 LED 56 33 BLMx BLM+x BTN 14 30 32 33 40 41 48 49 56 57 24 25 16 17 8 9 0 1 LED 10 26 39 38 37 36 47 46 45 44 55 54 53 52 63 62 61 60 31 30 29 28 23 22 21 20 15 14 13 12 7 6 5 4 BTN 15 31 35 42 43 50 51 58 59 26 27 18 19 10 11 2 LED 9 25 35 43 42 51 BEAT BTN 6 22 37 44 45 52 53 60 61 1 28 29 20 21 12 13 4 LED 8 24 0? 41 40 48 18 19 11 3 2 MB-LRE8x2 CS 2.5 in seriell to MB-SEQ CS Wilba ENC 0 2 4 6 8 10 12 14 SR 7 7 8 8 9 9 10 10 PIN 0 4 0 4 0 4 0 4 ENC 1 3 5 7 9 11 13 15 SR 7 7 8 8 9 9 10 10 PIN 2 6 2 6 2 6 2 6
thx so much.
the concept sounding logical.... i think i have something seen here http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F029_keyboard_velocity%2FREADME.txt no, mb_ng is to big (cant understand code which i havent programmed myself, or stripped down to the minimum working task) have to try to strip down the tutorial 29 code, by remove the Velocity calculating.
I want to program my own software running on the "Generic" SEQ-CS-Wilba - UI- PCB (Software: Triggermatrix) it has nothing to do with the SEQV4, except the BPM part, so ripp off the UI-Code for the Button-Matrix from SEQV4 is a no go > i dont understand it. i first wrote a small app to show me DIN-PINing off all Btns, (following Pins have a offset off 4 Shiftregisters ... because a MB-LRE-8x2CS is in the chain) then realized that not every btn has its very own PIN...ok i thougt, i know such things from LEDMatrices the other way arround. But Scan Matrices (BTNs) is newland for me... i quick search give me: mios32/trunk/apps/examples/fastscan_button_matrix_16x16 <<< should i start with that, or is there a more simple/better for learn-Code somewhere thanx MB-LRE8x2CS ROW 1 ENC 0 1 2 3 4 5 6 7 SR 1 1 1 1 2 2 2 2 Pin 0 2 4 6 0 2 4 6 MB-LRE8x2CS ROW 2 ENC 8 9 10 11 12 13 14 15 SR 3 3 3 3 4 4 4 4 Pin 0 2 4 6 0 2 4 BNT-SCAN-Matrix Nr. 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 BTN 46 46 LED BTN 47 47 LED BTN 46 46 LED BTN 47 47 LED BTN 47 47 40 41 40 41 40 41 40 41 40 41 40 41 40 41 40 41 LED BTN 47 47 43 42 43 42 43 42 43 42 43 42 43 42 43 42 43 42 LED BTN 47 47 45 44 45 44 45 44 45 44 45 44 45 44 45 44 45 44 LED
der schaut ja aus wie ein itt shadow DT6 nur Transparent mit LED eingebaut, bitte wo gibts den? https://www.reichelt.de/Eingabetaster-Digitast-/DT-6-SW/3/index.html?&ACTION=3&LA=2&ARTICLE=7241&GROUPID=3280&artnr=DT+6+SW
because of programming and messing arround, i have to press that button every programming session often... so you better wire a switch to the back off your device... Pin PA0 to 5V on the STM32F4 do the job... (the programming switch)
schreib den mal an, ober das projekt fertig gebracht hat: http://www.midibox.org/dokuwiki/doku.php?id=midiboxmixer
mios studio (ubuntu) ERROR file doesnt exist
Phatline replied to Phatline's topic in MIDIbox Tools & MIOS Studio
same Problem on MINT 17.3, which is based on Ubuntu 14.04. Host: daw Kernel: 4.2.0-30-generic x86_64 (64 bit) Desktop: Cinnamon 2.8.6 Distro: Linux Mint 17.3 Rosa -
i measure 4 you : @J11 Core 5v between VS and 4,1V Pin (should be 5V thenthe pcb is already labeld with +5V,) between VS and MI1-4 i measure 3Vs (should 3,3 maybe - my displays consume much...) between VS and MO1-4 i measure 0,5V @a midiport which is sending > has on my board 3,9VDC which i assume should be 5V - so 5V then! i use an application which uses 2xMIO Boards
Music: Aphex Twin - Drukqs interesting aspect... i am most of time solder silent... time for thinking, let pictures come from the past...
NEW Backpanel design for the SEQ4 aluminum case (LPC17 & STM32F4)
Phatline replied to kristal='s topic in MIDIbox SEQ
ah ok in this way...that way i did not know...FILE_Browser_Handler ... cool ... -
is it? which app (i need that)? the mass storage device app is written for stm32f10 and lpc17 only... -
well then build the BLM first, and then Touch/feel the buttons, what do the feel for you ... for me it dont have the feel/touch to play melodys on it, i mean you have to play precisely o..., and touch it the right way in order to activate the right.. ... i am no keyboarder yet, i stell play the last year from time to time, and as techno musican it gets wild... being in beat, hitting in beat -its then a. good to have this big white and black keys to hit the right note... (i talk about size not, the arrangement off keys) & b. the feeling the instrument is built for that so you can really punch it.... with the BLM i ever have the feeling of "not touching it to much" ... i even thougt about it, to exclude my 16 ROLL buttons (which i use most and hard) from the BLM-XY-ExtraBtns and take some more robust one (i havnt found them yet), i have thougt about DIY optical ones with Diodes/fototransistors, and AIN moduels...
...a heavy metal midi robot....
for me i dont need Velocity on the Harmonic table... since in my concept the melody-velocity is overruled from the Drum-Sequence-Velocity (in fact they only sound when a drumtrigger comes in).... but for the Drumsequence (remoted from BLM) i will need 16x Velocity-sense Pads, to trigger the Drumsequence in, in my concept the DrumTriggerpads are next to the BLMs Tracks, like your picture only in 2 rows...
i am plaing something like this, but with a custom Sequencer software and hardware instead of Wilbas Frontpanel in my case the Frontplates are individual Plates for the different devices, mounted on trusses...in order to be modular in the future... the trusses are mounted in a road-Case, which i will order from Thoman.de i am interested in your Harmonic Table!!! good idea! If the Buttons can be illuminated - and you plan to order a PCB for that? (illumination to show currently played MelodySequence &or harmonic fitting Notes) - i am possibly in for that, or @ least interesting @ the way you going it on....
ah ok thx 4 info
YEAAAAH!
FYI i have uploadet the APP: mios32/trunk/apps/misc/usb_mass_storage_device/project.hex on a STM32F4.... MiosStudio then say: "[16004.284] SD Card has been connected!" but linux (Ubuntu 15.10) dont recognize a new Drive. i have already tryd a other STM32F4 board - still the same. maybe because the code was written for the stm32F10? > (stm32F4 has on board SD-Card slot) - i dont know, but the application recognize a sd-card. "Required hardware: o MBHP_CORE_STM32 or MBHP_CORE_LPC17 o a SD Card connected to J16 of the core modulRequired hardware: "
Steps, Pages, Loop Length, Clock & Unstraight (odd) TACTs
Phatline replied to Phatline's topic in MIDIbox SEQ
AutoQuantize, some Excel again: Base = 12tics * 8 = 96tics between 2 16th Steps TIC Quantize 64 Quantize 32 Quantize 16 if * && if * Tic Step if * && if * Tic Step if * Tic STEP 0 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 1 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 2 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 3 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 4 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 5 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 6 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 7 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 8 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 9 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 10 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 11 <= Base 1 0 Current <= Base 2 0 Current <= Base 4 0 Current 12 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 13 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 14 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 15 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 16 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 17 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 18 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 19 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 20 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 21 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 22 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 23 > Base 1 <= Base 2 Base*2 Current <= Base 2 0 Current <= Base 4 0 Current 24 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 25 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 26 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 27 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 28 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 29 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 30 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 31 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 32 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 33 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 34 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 35 > Base 2 <= Base 3 Base*2 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 36 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 37 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 38 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 39 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 40 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 41 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 42 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 43 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 44 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 45 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 46 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 47 > Base 3 <= Base 4 Base*4 Current > Base 2 <= Base 4 Base*4 Current <= Base 4 0 Current 48 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 49 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 50 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 51 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 52 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 53 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 54 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 55 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 56 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 57 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 58 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 59 > Base 4 <= Base 5 Base*4 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 60 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 61 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 62 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 63 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 64 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 65 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 66 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 67 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 68 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 69 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 70 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 71 > Base 5 <= Base 6 Base*6 Current > Base 4 <= Base 6 Base*4 Current > Base 4 0 Next 72 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 73 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 74 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 75 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 76 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 77 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 78 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 79 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 80 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 81 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 82 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 83 > Base 6 <= Base 7 Base*6 Current >Base 6 0 Next > Base 4 0 Next 84 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 85 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 86 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 87 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 88 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 89 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 90 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 91 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 92 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 93 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 94 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 95 > Base 7 0 Next >Base 6 0 Next > Base 4 0 Next 96 Next 16th Note Next 16th Note Next 16th Note this code in a Function which delivers midi-input, writes on a specific STEP, a Sequencer-TIC-Offset, and a Velocity in specific Track, which means with that you have a stepsequencer with 96tic Resulution between 2 Step entrys....StepSend is the currently played step, TicSend the currently played 96th Tic which loops from 0-96 between 2 Notes //RECORD if(port == 1) { //MidiTrigger-Input (Real Drummer) if(Rec == 1) {//Record Switch Active //AutoQuantize OFF? if(AutQuntActive == 0) { Seq[note][StepSend] = velocity; // Write Velocity into current Step on Triggered Note SeqTic[note][StepSend] = TicSend;} // Write a "Time-Stemp" to realize Human Timing. (you can quantize later) //AutoQuantize ON? if(AutQuntActive == 1) {//Quantize while Recording is ON //32nd Quantize Mode if(QuantRate == 1) { //QuantRate0:16th,1:32nd, 2:64 //Write Velocity in currently played Step if(TicSend <= (BaseTic*6) ) { //12x6=72 (Tic 0-72) Seq[note][StepSend] = velocity; // Write Velocity into current sequenced Step with Triggered Note if(TicSend <= BaseTic*2) {SeqTic[note][StepSend] = 0;}//Straight 16th without delay if(TicSend > BaseTic*2 && TicSend <= BaseTic*4) {SeqTic[note][StepSend] = BaseTic*4;}//Delay 2 next 32nd Note if(TicSend > BaseTic*4 && TicSend <= BaseTic*6) {SeqTic[note][StepSend] = BaseTic*4;}}//Delay 2 previus 32nd Note else { //Write Velocity into Next note SeqTic[note][StepSend] = 0; // kick back to zero > straight machine time > no delay //Are we on Last Step of Loop? if(direction == 1) { //when in Forward Direction Sequencing Mode if(note == Last) { //when Last step is arrived Seq[First][StepSend] = velocity;} //then write Velocity in First Note of Loop if(note < Last) { //If not Last Step, then simply write in next Step: Seq[note][StepSend+1] = velocity;} //next step } if(direction == 0) { //when in Rewind Direction Sequencing Mode if(note == First) { //when First step is arrived (typical 0) Seq[Last][StepSend-1] = velocity;} //then write Velocity in Last Note of Loop (typical 16) if(note > First) { //If not First Step, then simply write in next Step: Seq[note][StepSend-1] = velocity;} //next step }} }
