nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. * What application do you use? * Can you either zip and attach or post your source code? * What do you mean by the "only working pin"?
  2. Why would you do that (except for not having the newer PICs *yet*)? Yes, with the 18F452. Why "or"? Yes, it is possible with the sid v2 hardware. On v1 they're a bit clustered in different places. It's all documented on ucapps.de though. As long as you DON'T upload the "no cs" version, the LCD will work right away, although you might wanna make some changes in main.asm to change the display size.
  3. http://www.midibox.org/forum/index.php/topic,9118.msg64842.html#msg64842 http://www.midibox.org/forum/index.php/topic,10910.msg84305.html#msg84305 http://www.midibox.org/forum/index.php/topic,10880.msg83929.html#msg83929 What's the matter ultrasound?
  4. http://www.midibox.org/forum/index.php/topic,9118.msg64842.html#msg64842 http://www.midibox.org/forum/index.php/topic,10910.msg84305.html#msg84305 http://www.midibox.org/forum/index.php/topic,10880.msg83929.html#msg83929 What's the matter ultrasound?
  5. [me=nILS Podewski]hugs cimo[/me] Sure I am!
  6. 23/8 = 2 remainder 7
  7. IFSET ist ein Makro, dass scheinbar bei Dir nicht da ist. Ersetze das ganze durch sowas wie btfsc MIOS_PARAMETER2, 0 return[/code] Das sollte das Problem beheben.
  8. Google is your friend: http://www.google.de/search?hl=de&client=firefox-a&rls=org.mozilla%3Aen-GB%3Aofficial&hs=3cS&q=google+sketchup+eps+export&btnG=Suche&meta= Yes.
  9. C-Skeleton versucht? So kommst Du um das vllt ein wenig abstrakt und abschreckend wirkende ASM herum ;) Soweit nicht weiter kompliziert. "Ich glaube" hilft beim Fehler finden nicht so richtig doll. Kopiere doch bitte die Ausgaben des Compilers und Deinen Source Code hier her.
  10. Well go get us some of the brownie goodness then!
  11. I have one, and I've made some pretty nice rectangular holes with it.... and that's exactly why I'm trying to cut down on the rectangular hole count ;D
  12. Assuming bugfight seconded the notion with his "yes! yes!" I'll third it :-) MTE go source those in round! ;D
  13. [me=nILS Podewski]sets the alarm clock[/me] jk, glad to see you're back here and back on it! ;D
  14. ...and another one to tell s1 he's taking the bad cop business a bit too serious ;)
  15. Congrats, buhler! I think we should start an "adopt a newbie"-Program - I wanna be adopted by s1 ;D
  16. She's technically not a premier, but you can have out chancellor Angela Merkel if you want!
  17. Funny how quick "newbies" start answering the question nowadays - I like it ;D
  18. It is possible :-) And it's not even all that hard. Some pointers: * read my HowTos on the WIKI they cover most of the stuff you'll need to do * cs_menu_buttons.inc is the file you'll need to edit
  19. Welcome aboard Sirkit ;D First off, do a lot of reading on ucapps.de and on the forum. All of your questions have been answered around here countless times. Some hints: * Pictures of different housings can be found in the "MIDIbox of the Week" section * A 2x20 show less information than a 2x40 (duh!) * More SID - ucapps.de -> mbSID buhler: Good boy ;D
  20. I just noticed the topic: "MIDIbox of the Week (MIDIbox LC made my MTE)" TK has an MTE which was made by a MIDIbox LC?! ;D
  21. Well, technically it *is* like that - you just need to extend the x-axis a bit: [################--------------------] ultra newbie expert ;D
  22. Yeah, I left it out to see if people would notice ;) It's in there now - thanks!
  23. the CS_MENU_GetMenuID_GNC function needs to be defined first. This should be done in cs_menu.inc in the section titled ;; -------------------------------------------------------------------------- ;; This function returns the CS_MENU_x_xxx ID depending on selected engine ;; --------------------------------------------------------------------------[/code] which is around line 2056.
  24. Go for it akcija! :-)
  25. Those two are all I can find: http://www.electronic.it/product/16436/Display-16X2.asp 16x2 1,80€ http://www.electronic.it/product/16287/Display-16X2.asp 16x2 1,99€ Is there more that I just can't find cuz my italian is not all that good? (read: I don't speak/read/write italian, altough I had 8 years of Latin) ;D
