Screaming_Rabbit
Frequent Writer-
1,431 -
Everything posted by Screaming_Rabbit
I did all the things I wanted to do (but still didn't have enough time) and now I'm asking myself sometimes: Why didn't I go to university? ;) Greets, Roger
capacitors. which are the best? which should be used?
Screaming_Rabbit replied to matrigs's topic in Parts Questions
http://my.execpc.com/~endlr/ Greets, Roger -
Ja, das ist eine geballte Ladung Information auf der rechten Seite... wird nicht einfach sein, die Übersicht zu behalten. Tipp: Vergiss das mit dem "Push to Crub". Ich nimm an, Du willst das mit einem Encoder mit eingebautem Metal-Dome Taster realisieren. - Das wir Dich später mehr stören als Dir helfen, da Du ständig beim Joggen ungewollt umschalten wirst. Greets, Roger Edit: Möchtest Du die Solo Taster nicht lieber gelb machen, um die vier Taster besser unterscheiden zu können?
Would like to build a Roland Programmer (JD990/MKS80-70, Etc)
Screaming_Rabbit replied to mkultra's topic in Design Concepts
Basically/Globally: Yes you can do what you want, if you say SoundDiver can control it. It mostly only depends on what your Synth lets you control over MIDI. If I look at your profile, I would suggest that you explore the forum and ucapps.de more (watch the "MB of the week"-section) and you will get inspired automatically. Some of your questions cannot be answered wth yes or no (You might have to change code in "C" or you might not... depends on what exactly you will do). Greets, Roger -
Hello Carlos (... from one of my favourite cities in Europe) ;) Welcome to the world of MidiBox and thanks for your offer for help in the analog world. Greets, Roger
... wie recht Du hattest ;) Greets, Roger
... that was quick... from the lap-top to the lab-top and back to the lap-top ;D
... and I thought those are for poking inside with a stick if the cat gets lame.
http://www.midibox.org/forum/index.php/topic,4074.0.html
... me too on every of four different computers (Vista&XP, IE6&7), since the forum was ported lately. Greets, Roger
... sorry for being a bit Off-Topic. Are you Swiss? Greets, Roger
... absolut! Würd ich auch meinen. Greets, Roger
... also ich möchte bei diesem Lärm nicht mehr mixen müssen und für das Ergebnis verantwortlich sein :-\ Greets, Roger
... das würde ich nicht überbewerten. Mabuchi macht von teuren CoreLess Motoren bis zu absolutem Billigschrott. - Mabuchi allein steht also in keinster Weise für Qualität, obwohl die CoreLess Motoren der Alps K-Type von Mabuchi sind und absolut zufriedenstellend sind. Das ist nicht zu vergleichen mit Maxxon, welche NUR Qualitätsmotoren herstellen (verwendet in den teuren P&Gs)... da kann man anhand der Marke sagen: Top Qualität. Greets, Roger
Die Frage ist, was mit axial/radial gemeint ist bzw. was zu was. Mein Verständnis würde bei "axial" meinen, dass die Motorachse längs/parallel zur Fader-Bahn liegt... also genau so, wie der aktuelle Alps N-Type gebaut ist. Mechanisch gesehen, ist das aufgrund der nötigen Umlenkungen ein absoluter Schwachsinn in Bezug auf die Performance bzw. auf die Leichtgängigkeit. Der einzige Grund, weshalb der N-Type so gebaut ist, besteht darin, dass man nur mit liegendem Motor eine solch geringe Bauhöhe erreicht. Von P&G gibt es ein Modell mit liegendem Motor, bei welchem eine Kevlar-Saite über Umlenkrollen geleitet wird, was zu einer beachtlich guten Performance führt. - Downside: Sündhaft teuer :( Da der Verkäufer aber sagt, dass der Motor im Gegensatz zum neueren Modell "axial anstatt radial" liegt, gehe ich davon aus, dass er ein anderes Verständnis hat als ich und damit meint, dass die Motorachse senkrecht zur Faderbahn liegt... also so, wie beim K-Type und den "normalen" P&Gs. Falls es Dir also nicht auf die Bauhöhe ankommt, wäre ein "stehender" Motor besser als ein liegender wie beim aktuellen Alps N-Type. Mir ist nicht bekannt, dass es den N-Type früher mit einem stehenden Motor gegeben hat. Ich bin mir deshalb nicht sicher, ob es sich nicht um einen Alpha Fader handelt. Alpha Fader sind mehr oder weniger Kopien von Alps und qualitativ leicht unterlegen (vor allem bei den teureren Modellen). Falls es sich wirklich um ein altes Modell handelt, bin ich mir fast sicher, dass diese schon lange nicht mehr hergestellt werden, was bedeuten würde, dass diese Fader welche Du kaufen willst, jahrelang in irgend einem Lager gelegen haben. Das Problem: Wenn die Fader über längere Zeit (ca. 1 Jahr) nicht bewegt werden, gewöhnt sich der Gummi des Zahnriemens an die Biegung der Umlenkrollen und will diese beibehalten. Dies macht sich dann bemerkbar, dass der Fader nicht gleichmässig läuft. Aud diesem Grunde findest Du in den SPEC-Sheets der Alps Fader: "Do not store longer than 1 Year" ;) Greets, Roger
Mackie Protocol - Data going from Software to the midibox
Screaming_Rabbit replied to DavidBanner's topic in MIDIbox HUIs
:) Well in this forum you get punished for not searching the forum. - By opening a new topic, it makes it much easier to search. -
Yes! You missed to start a new topic. >:( -
... I quit judging people without really knowing them a long time ago (was looking too many times like an idiot and was afraid what people would think about be). Now, if I want to be an idiot I just behave like an idiot ;D Correct. - That's what the Mackie protocol can transfer Can't tell you for sure, since I don't know if multible displays are working with multible types of displays. The way the charactres are addressed, I would say yes.... but... ??? Greets, Roger
... and then you have the gap between Ch 5&6. - You seem to like asymmetry ;D The Gap you get between the two displays mainly is due to physical measurements of them. Greets, Roger
Redesigned MIDIbox of the Year (3xMIDIbox LC of Axel)
Screaming_Rabbit replied to TK.'s topic in MIDIbox of the Week
... "wtwose" is not talking about a new box, but wants to have info on the display implementation. - What's wrong about that? ;) ... so Axel seems to be around. -
What's up? Did you blow it off? What host soft are you using? Nuendo? If so, you better buy an Euphonix "Artist" where there is all the functionality support by the EuCon protocol. Greets, Roger
... you're not really finding a good fader for 4-5€. http://www.produktinfo.conrad.com/datenblaetter/425000-449999/442844-da-01-en-STUDIO-FADER_10K_LIN.pdf This one is about €30... if you want to talk about good. ;) Greets, Roger
... yes, better concerning this issue. On the other hand, the DSP-processing is not very flexible when it comes to changing dynamically what it has to do. Both technologies have ups and downs. At this time, the Latency thing just weights much heavier than others... but the time will come, when... ;) Greets, Roger
No sorry, they're custom made 8) The encoder is a regular Alps type which is mechanically connected to the break. Greets, Roger
