Altitude
    1,184
    30
Everything posted by Altitude
  1. I stopped using the midibox mode :) I cant say if the old drivers still have the disappearing issues on 10 but the naming thing makes it a moot point since having 3 identical "MIDIIN1 ploytec midibridge (www,midibox.or" ports at once doesnt really do me any good. I'm happy with the 1.3.3 drivers, its been over a week and nothing has disappeared
  2. Thought I'd bring this up since I just took the leap to 10 (from 7) and in the process discovered a couple things. I love the GM5, hands down the best interfaces I've used but under windows 7, using more than one (i use 4), one or several would vanish periodically requiring it to be unplugged and plugged back in. Never found a reason and this was with the 1.1.1 drivers. With win10, I using the default drivers resulted in a naming problem where the name of the device was so long you could not differentiate which interface was which so I came looking and found that there is a 1.3.3 ploytec driver and that works perfectly under 10, no disappearing interface and the names are correct !
  3. I received no pm other than the one on the 2nd
  4. Are you canceling invoices?
  5. Is the pricing in the OP still correct?
  6. did you do a "save as"? and make sure it saves as a .brd file? Just tried it and it opens fine in 6.6
  7. owon or rigol are great entry level scopes and will do everything you need
  8. No. Some purists will swear by analog scopes for this and that reason but if you want something that you can use daily for everything, a modern DSO cant be beat. Mine has a dozen different measurements it can display (p-p voltages, frequency, DC offset etc) and having those outweighs any benefit an old analog one might have. I have a cheapo Owon and that thing got used more in one week than the big giant relic I bought used to date.
  9. Name PCB BLM PCB miniCore Case Shift button M2 hardware 4xLED availability 5 5 - 9 6 17 latigid on 1 1 1 1 1 1 Rowan 1 1 1 1 1 1 Phatline 2 2 1 1 1 1 TK 1 1 1 1 1 1 Altitude 1 1 1 1 1 1 Total 6 6 5 5 5 5
  10. holy zombie thread (last post was 4 years ago). Everything has been long sorted on this and smash has boards
  11. That's enough for me to get started. SMD ok?
  12. I'd be happy to help. Just need a schematic
  13. very nice. Dedicated control surface in the works?
  14. Since moving to a metal case, this is gathering dust and I am sure someone can put it to good use. Lexan window, switch for fan, some standoffs missing, coated vinyl overlay $40
  15. woah. The prodigal son returns
  16. I have 2. PM your info, just pay shipping and it's yours
  17. i might have one
  18. why single sided? there is no cost benefit for that
  19. cool, that was really what I was interested in, how the tact surface would be supported
  20. Wow. Out of left field.. Do you have an exploded view of the assembly? I'm curious how this will fit toghether
