Psykhaze
    311
    8
Everything posted by Psykhaze
  1. Impressionnant , j'avais deja vu quelques démos mais la ça bat des records. Le mode séquenceur en faders motorisés est tout bonnement excellent! Chapeau bas , la reactivité des faders et les fonctionnalités implémentées sont vraiment chouettes! Gros boulot ! Mes félicitations en tous cas. Jerome
  2. Always a pleasure to see #dawless music =) Bewarea bout not going off rythm too , after listening again there are (little parts) where it's sometimes tricky (but sh*t i like this battery pad ^^) However nice work ,hope to hear more !
  3. Hi folks, Seeing that the OLED subject is kinda hot these times, i was wondering if anybody has been playin with these ones : http://www.buydisplay.com/default/serial-spi-color-0-95-inch-oled-display-module-96x64-pixels-ssd1331 SSD derivative , with some code tweaking could be ported to MIDIbox for those interested, but color management might bring memory overloads?. If nobody feels like coding just put it in TK's TODO :D Bests Jerome
  4. Polivoks VCF gives SID nice ruffness =) Aerial and sweet style SIDhead-feeded , hawkeye's mark. like it ! Greets, Jerome
  5. Hey pretty one =) cheers Jerome
  6. Nice remake of the SeqV4 - adafruit size ?
  7. Sorry for laming . I'd just wanna say something about that great nice work
  8. Psykhaze
    nvm
    That was my pleasure @jaytee . It was my last 6582 chips from Wilba Mega Sales i had left for sale . Anyway i am going to test myself further sources i have on SID Chips ( 6581 / 6582 ) that I will compare to originals to test chips validity , not to mention i have a fine one for OPL3 sets. So if anyone interested please let me know =) greets, Jerome
  9. Great work on HMI abstraction and representation by LED-rings . I especially like the Sequence-Ring ^^
  10. brrr i don't like plastic shaft ^^ . But thanks for advice @Hawkeye a verified ebay seller is always a great information ! Personnally i wanted to try these : http://www.ebay.fr/itm/371632174956 with these as knobs : http://www.ebay.fr/itm/390749699344 Bests, JK
  11. I wanted to try some like those too but still not bought it yet. Regarding the price,the best way is to order a set and check by yourself, because there is sometimes (good or bad) surprises with chinese stuff. If by luck they are almost as good as the originals ALPS , you may share confirmation of the source =) Regards, Jerome
  12. Un sacré chemin accompli =)
  13. L'utilisation du Bus CAN est généralement réservée à la communication inter-MCU. Cela dit , intégrer un tel type de communication est plutôt simple niveau éléctronique (aussi simple que de relier une ligne Tx à une ligne Rx) Mais les architectures scalaires (comportant plusieurs unités de calcul type MCU) entraînent un certain nombre de paradigmes niveau programmation , notamment l'ordonnancement multi-processeurs pour ne citer que ça. Et c'est un sacré parpaing. Dit en plus court , c'est simple en théorie de relier plusieurs MCUs via CAN mais en pratique c'est plutôt hardcore surtout à cause de la gestion logicielle. Faut que ça soit calculé dès le début quoi ,ça se rajoute pas comme ça à la volée des fonctions SMP. Le plus simple pour relier 2 cores reste à mon avis le MIDI pour l'instant, car le chaînage et la synchronisation MIDI sont des concepts plutôt au point et ne nécéssiterai pas des mois de refonte MIOS32 . Je pense que 256 boutons illuminés peuvent cohabiter avec les 32 motorfaders sur un core32 . un module AINSER8 permettrait de gérer 8 éléments d'interface analogique type Potard rotatif ou Linéaire (fader) ,mais il me semble que la carte discovery as déjà un ADC sommaire intégré, cela éviterai de surcharger une configuration deja lourde avec un module supplémentaire si tu as juste un fader supplémentaire à intégrer. Une partie modulable DMX/Puissance standalone pourrait être envisagée mais je serait plus partisan de l'utilisation du SPI pour contrôler cela.
  14. Ok , special discount on this one , 18€ + shipping and i supply 2 additional MCP6004 for 5V option : http://wiki.midibox.org/doku.php?id=opl3_module_modified Regards, Jerome
    1. Antichambre
      Antichambre
      " He was officially pardoned by Queen Elizabeth II in 2013. "
      I ask who have to pardon!!?
    2. Psykhaze
      Psykhaze
      Better late than never.. Easier when peoples are dead from a long time xD
    3. Antichambre
  15. Tiens, un peu de lecture avant d'aller dormir =) http://www.st.com/content/ccc/resource/technical/document/datasheet/ef/92/76/6d/bb/c2/4f/f7/DM00037051.pdf/files/DM00037051.pdf/jcr:content/translations/en.DM00037051.pdf http://www.st.com/content/ccc/resource/technical/document/user_manual/70/fe/4a/3f/e7/e1/4f/7d/DM00039084.pdf/files/DM00039084.pdf/jcr:content/translations/en.DM00039084.pdf >Juste la première page pour le premier lien et page 22+24 sur le deuxième lien > Pins PA11/PA12 + PB5/PB6 par exemple , la board Discovery as un (double) Bus CAN 2.0b . Spécifications ici : http://www.mi.fu-berlin.de/inf/groups/ag-tech/projects/Z_Finished_Projects/ScatterWeb/moduleComponents/CanBus_canover.pdf https://en.wikipedia.org/wiki/CAN_bus Edit : https://www.kvaser.com/can-protocol-tutorial/ Bonne nuit !
  16. Une autre solution peut être de connecter 2 Core32 entre eux (Toujours via CAN?) et de répartir la charge totale de contrôle > 18 Faders motorisés+Demi matrice totale par Core ? Ou tout simplement se contenter de 32 faders motorisés et en prendre un classique pour le 33ème =) Edit : Tu as link le DIO sur le lien AINSER64
  17. Hey =) ! @latigid on Pas trop mal le français, je vais finir par t'écrire FR en privé pour tout ce qu'on as parlé en anglais :D Excellente suggestion pour les applications de type Boutons illuminés par exemple. LE DIO_MATRIX est une combinaison de DIN et de DOUT. @latigid on , @Zam : Comme le module MF-NG comporte un PIC18F , une utilisation du bus CAN à la place du MIDI pourrait être envisageable pour des applications comportant plus de 32 faders motorisés? Et comme on dit, "lentement mais sûrement" B)
  18. Ton dimensionnement me semble raisonnable =) Effectivement mieux vaut faire preuve d'un peu de patience , écrit un MP à @smashtv pour lui demander un ordre d'idée . Ca dépasse pas un ou 2 mois pour restocker les sold out généralement.
  19. Un design matriciel pour les boutons et les LEDs permet de réduire le nombre de DIN / DOUT nécessaire. Si toutes les sorties ne sont pas affectées cela n'est pas dramatique. Le Design matriciel ne fonctionne pas avec les encodeurs Le module MF-NG est connecté en MIDI - Le PIC présent sur le PCB gère le feedback fader. Si SmashTV n'as pas le module tout de suite à la vente et que tu es pressé : http://ucapps.de/mbhp/mbhp_mf_ng_v1.brd < Ce fichier te permettra de produire / faire produire le PCB http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2F > SVN MIOS32 . http://svnmios.midibox.org/listing.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Ftutorials%2F < Tutoriaux http://ucapps.de/mbhp_core_stm32f4.html
