audioworld Posted May 14, 2008 Posted May 14, 2008 I see, allright:I trust in my good old ERSA MS6000 station-)included 5 PCB's in my order,thanks again,karl.
Pascal Posted May 15, 2008 Posted May 15, 2008 That sounds good :-D Is it possible to merge two USB-Port for a 10x10 MIDI Interface?
madox Posted May 15, 2008 Posted May 15, 2008 That sounds good :-D Is it possible to merge two USB-Port for a 10x10 MIDI Interface? I imagine you could use a cheap USB hub to do that.edit- P.S. With 5 midi banks per USB chip, and 16 midi channels per midi bank, you are talking about 2 x 5 x 16 = 160 midi channels, right? Do you actually have so many midi devices? I think 5x16 is already many more than I can use, for one PC midi interface.
TK. Posted May 15, 2008 Author Posted May 15, 2008 Yes, an USB hub will helpThe advantage of seperate IOs: higher bandwidth (as MIDI events can be sent out in parallel to multiple MIDI outs), and you don't need to merge the inputs, resp. chain the IOsBest Regards, Thorsten.
Pascal Posted May 15, 2008 Posted May 15, 2008 Yes i have many MIDI-Devices in my Studio ;-) And i will set my MIDI-Configuration that i CAN (when i will) use all MIDI-Channels of my Synths when i will use without a collision to another Device or switch the MIDI-Cables or Channels. A USB Hub was Ok, when i can compile it in the Box. I will 1 USB connector for the full setup. Ok, so or so, i am happy with this :-)
Nestle Posted May 17, 2008 Posted May 17, 2008 Hah! I have been browsing USB-Midi cables and different USB and Firewire preamps for a few days now. Should have midi up, because I am about to fire up my V2 for the first time. But in the meanwhile I noticed that the not so ancient Soundblaster Extigy doesn't work in Vista - and it had my only midi-ports!!!This is more than luck! I placed 4/4 order.Many thanks for diggin' up this stuff for us Thorsten!!Nestle
Sebo Posted May 20, 2008 Posted May 20, 2008 Hi:I'm in with 2/2 for now, but I think some of my friends will want one.
Narwhal Posted May 21, 2008 Posted May 21, 2008 I split my order to allow others room to get in. All totals have been corrected using Excel too.
stryd_one Posted May 21, 2008 Posted May 21, 2008 I just noticed the PCB's are available on the wiki page now too. I was not the only one with a question mark next to my name there, so if you added your name for chips, but not PCB's you might want to get on that!</friendly reminder>
ilmenator Posted May 21, 2008 Posted May 21, 2008 My hesitation is intentional: I want to see what I get first - then I will decide if it is what I need, or whether I am better off doing my own board. As far as I remember, we only started to collect opinions on what type of board would actually be practical for most users? I'd happily go with the generic adapter solution suggested by nILS elsewhere, or even with a board that contained only headers (but no actual MIDI or USB sockets), but I don't know if that is what everybody else needs/wants!?Best regards, ilmenator
madox Posted May 21, 2008 Posted May 21, 2008 ...I was not the only one with a question mark next to my name there...</friendly reminder>Thanks, I hadn't checked the list for a while. Added a couple of PCBs for myself, and corrected the totals.
Nestle Posted May 22, 2008 Posted May 22, 2008 with this USB -interface added, do I need separate midi -addon if I want to use midi too or like to use both midi and USB at the same time? I have intentions to put internal USB -connection to my midibox SID and solder it directly to core module. So, do I add another midiout/in for midi connections?Thanks,Nestle
theprotool Posted May 22, 2008 Posted May 22, 2008 nestle: With this usb interface you could wire it up to the midi ports of your sid (as you are just replacing the midi cables and connectors with soldered wires) , although i think that its kind of a waste. :P If you wanted you sid to still be able to connect midi also i think (correct me if i'm wrong guys) your only other option would be to get and i2c midi interface to connect you to the core. http://www.ucapps.de/mbhp_iic_midi.html Have a look at that it should help you along. peace
TK. Posted May 22, 2008 Author Posted May 22, 2008 No, MBHP_IIC_MIDI is no option, as this module is not supported by the firmware.It is possible to connect the USB IOs directly to the core module (Port J11), but for a synth this isn't recommented, as this will result into a ground loop between the Audio and USB lines. Instead, I would isolate the MIDI INs with optocouplers, and don't connect the grounds together - as usualBest Regards, Thorsten.
Screaming_Rabbit Posted May 23, 2008 Posted May 23, 2008 any deadline?... would you have been asking thins question too, if your order would be in the second part of the 250? ;)
Jidis Posted May 24, 2008 Posted May 24, 2008 Thorsten-Have you gotten a chance to mess with any of the chips yet (or received them for that matter)?-- Not in any hurry, just excited about the concept like others here probably are, and hoping you haven't hit any major bumps. :)George
TK. Posted May 24, 2008 Author Posted May 24, 2008 Yes, it works great! I'm using it on a Mac since more than one week (e.g. while creating the MBSID Bassline Demo) and haven't noticed any failure :)The Windows driver is not ready yet, therefore I haven't got the chance to check, if it works better than the Microsoft Driver.Another good news: Ploytec offered the possibility to layout our own PCB, Nils is working on it. :)The PCB should have the same size like the original Ploytec evaluation board, otherwise we would have to pay more money for additional area - therefore the focus is to make it more DIY friendly (e.g. replacing SMD resistor/caps by through-hole parts)Best Regards, Thorsten.
SLP Posted May 24, 2008 Posted May 24, 2008 ... would you have been asking thins question too, if your order would be in the second part of the 250? ;)that's a good point ;D ...I was just wondering a bit how long it'll take until this groupbuy is closed.I don't want to be pushy in any kind! I don't want to hurry!I just want to know if I should already build a case for my MIDI/USB-interface or wait some time.btw: I've bought a cheap 4x-USB-Hub at RadioShack (6$).now i'm thinking about why I should build a MIDI-USB-Interface with 20 I/Os :P
stryd_one Posted May 24, 2008 Posted May 24, 2008 Another good news: Ploytec offered the possibility to layout our own PCBMan ploytec are rad.
Kartoshka Posted May 25, 2008 Posted May 25, 2008 I appreciate the developing of custom diy-friendly pcb; thanks for great approach, TK and Nils.
Jidis Posted May 25, 2008 Posted May 25, 2008 Great to hear it's off to a good start. :)Take your time and thanks as always!George
nILS Posted May 25, 2008 Posted May 25, 2008 Getting half my house blown up kinda set the process of finishing the PCB back a couple of days. I'm back on it though!
