Zeke Posted June 26, 2020 Posted June 26, 2020 Just as I was giving up hope, I got it to work. I spent all last night reading every post I could find and in one post in another thread @Zam talks about the fader plate being to thin for grounding or something along those lines. Anyways, as I was ready to pack it all up and thought let me try one more thing. Everything I tried was grounding to the case which is about 1mm thick but every time I grounded anything to the chassis, nothing got better. So I thought let me try something thicker, as soon as I grounded it to the rack rails of my desk (rack rails are 3mm thick) ...Voila! the noise was gone. @Zam was right all along. On 6/23/2020 at 7:32 AM, Zam said: You'll have to try to chassis ground fader metal part to minimize EMI leaking and motor sparkle. As soon as I grounded the J14, the fader metal and the motor case everything was noise free. It was the temporary case I was using that wasn't sufficient to be used as a ground. @Zamgave me the best advise (and I didn't listen) which was: On 6/23/2020 at 0:50 PM, Zam said: As a global rules, as it is for console integration, I'll suggest to build the thing as close as possible to final integration, to minimise bad surprise at the end as loosing time to fix issue that will not happen in the proper frame/mechanical integration. So now I'm off to design my face plate and get it either in 3mm aluminum anodized or aluminium powder-coated. If anyone knows if there is going to an issue with either of these materials and grounding please let me know. Thanks again @Zam for the help!
Zam Posted June 26, 2020 Posted June 26, 2020 Hello Zeke Good you find solutions to your problem It seem (I can be wrong) that you misunderstood the concept of ground, the thickness of a case have noting to do with it, I suspect in your fist attempt you just connect together your Vref (0V here), fader can and metal case, without path to safety/earth ground, meaning everything stay floating. As soon as you connect all this to rack frame you create a path via rail and other equipments, I suggest your fader rack get it's own path to main ground to not interfere with other equipment (otherwise parasitic current might flow trough them) technical note: powder coating as anodization (surface only) are non conductive ! for example you have to mask before coating or scratch surface after, if you want proper conduction between metal part in rack assembly. Best Zam
Zeke Posted June 26, 2020 Posted June 26, 2020 @Zam Feels good to solve a problem, that's for sure. Especially since I am very new to all this. You are right though, I may have confused the concept of grounding. As an experiment, I will try later today to scratch the case I have because it might be the coating that was causing it not to ground properly. I'm using Front panel designer and the materials that I can use for making the face plate aluminum anodized or aluminium powder-coated. What if I used Aluminum Raw is that conductive enough? I'm going to do more research on earth/ground but my understanding is grounding is done by going to a chassis and earth is going to..... well earth. My limited understanding is the way you earth is via the power receptacle but this board only has 2 holes, a negative and a positive. So I'll have to figure out how to earth it.
Zam Posted June 26, 2020 Posted June 26, 2020 Use the material you want for the visual finish you want ! row alu is ugly for front panel and easy to scratch... I'm just saying this in the manner that you should anticipate your enclosure design and be sure all metal part have good electrical connection between them, a recessed screw or countersunk head screw that fix front panel to frame should be enough (as milling will remove the surface anodization ) "basically" your pcb 0V should be hooked at one (and only one) solid screw at the frame (common ground), preferably close to the main entry, where you also connect the safety earth ground from the (close) main connector. In your particular usecase I think fader screw mount (countersunk) will do the job to connect fader metal can to common ground. Your fader 0V audio should not share the fader box common ground, it's already connected at console rack module via trace, pcb and local chassis common ground. Try to imagine the audio part of the fader as an isolated extension from outside the fader box. Best Zam
totoRaymond Posted August 20, 2020 Posted August 20, 2020 Hi! I'm having troubles setting up MF_NG. Everything seems to work fine, i was able to get faders moving and all, but there's a big rattle noise when faders are moving slowly (ie using the MIOS studio tool to make them move slowly, or following the daw automation). this rattling noise disapear when faders are moving fast. I tried to play with the different parameters, but i couldn't find a way to make that noise disapear. Currently i'm using ALPS K faders. but i got the same issue with an old P&G i had lying around. I tried 8 faders and had the issue with all of them. I'm pretty sure i'm doing something wrong here, but i can't figure out what... Thank for your help! Thomas
Zam Posted September 8, 2020 Posted September 8, 2020 Hello On 20/08/2020 at 0:11 PM, totoRaymond said: I'm pretty sure i'm doing something wrong here, but i can't figure out what... I'm not sure you do wrong, this is probably intrinsically related to PWM driver Best Zam
totoRaymond Posted September 8, 2020 Posted September 8, 2020 Hi Zam, After reading ths whole topic again last week-end, I tried to lower the voltage. With Vm down to about 4V, i was able to get rid of most of the mechanical noise, but now the faders are a bit sluggish (actually, there's only one fader wired to the board right now). The PWM might be the problem, I know you went another route for your analog automation system (I followed the story since the beginning on gdyi). Do you think we could get rid of that noise using a higher PWM frequency? Or is it necessary to drive faders with DACs instead? There must be a way to drive faders in silence, I work all day on digidesign D-Command, they use the same ALPS K-faders I have and they're very quiet (and fast). I think i could live with slow faders for a time, but I might try to move to another solution once my controller is finally assembled. Cheers, Thomas
Zam Posted September 8, 2020 Posted September 8, 2020 Hey Thomas As you notice I take another route long time ago, I'm not able to help you much about PWM handling I think I publish all my tries around PWM by that time, and there is probably other options to test today, including increasing frequency of the PWM (over audio range). IIRC mios8 on the pic can't do this ? Do you know how is handled the motor in the D-com ? Best Zam
totoRaymond Posted September 8, 2020 Posted September 8, 2020 No worrys, as I said, i think i will settle for this solution for now. I'd like to have a working build before end of the year and improve from there. If I remember well, you're problem with PWM was related to EMI leaking into the analog circuitry, not the actual physical noise of the fader. Am I right? You're right, the PIC used on MF_NG won't go higher in frequency, But if need be, i'm not afraid to port the code to a more capable micro... (as long as i have a working controller, i have all the time in the world to make it better... ) I never looked inside a D-command, but if i get a chance, i'll check the Ic's used (might even look inside an Avid S6, who knows, those faders are great). I'm going to start looking into some other controllers too. Thanks! Thomas
Zam Posted September 9, 2020 Posted September 9, 2020 17 hours ago, totoRaymond said: If I remember well, you're problem with PWM was related to EMI leaking into the analog circuitry, not the actual physical noise of the fader. Am I right? It was both, EMI not acceptable regarding technical performance I requested then, with that particularity that I have low level audio signal just across the digital circuit, which is not a question/issue for 99% of pple using MF_NG. As acoustic noise that can't match the quality standard at user side I was searching for, in a quiet as possible "high-end" control room I can't work with a bunch of printer like sound, unfortunately a fader automation is not a tool that you can put in the machine room In a way both noises are linked. Best Zam
Zeke Posted September 9, 2020 Posted September 9, 2020 I haven't posted in a while but I did get mine working after all. I'm using mine for automation of my channel strips, I record the levels into my DAW and it recalls with every session. so I don't really need any other buttons. My whole desk is custom so unfortunately, it's not in my desk at the moment because I would have to make a new desk, which will happen next year. So it's just sitting behind my desk out of sight. I end up controlling both fader banks with my avid artist mix or through the DAW. I will try and make a video so you can see it working. @totoRaymond are you trying to build a DAW controller or an automation system for a mixing console? Do you have all 8 faders attached to the module? I found that once you have all 8 faders populated, wired and grounded properly that if you power the modules at 7v this reduced the noise. There are some settings also that may help. I'll try to find them.
totoRaymond Posted September 12, 2020 Posted September 12, 2020 HI Zeke and thanks for the advice! I'm building a DAW controller, basically i'll emulate 3 Mackie Control Units plus a "generic remote" to control Nuendo. In the end, i hope to get 25 faders plus a bunch of stuff (including a touch screen with a lemur patch). I reported my progress in this thread (not updated very often though) : Right now i have only fader attached to the board. The wiring with this board is a bit of a mess so i'm currently making a new pcb with one connector for each fader to keep things tidy. I'll definitely try with 8 faders connected, but in the near future i have to build a prototype enclosure (made of MDF i have lying around) so i can start to assemble everything properly (and stop killing board with shorted wires). All the fine tuning will be done once I gathered all the parts. Cheers, Thomas
Reubenclarke.jpg Posted May 23, 2021 Posted May 23, 2021 Hey everybody. I'm having an issue that I'm hoping you will be able to help me with. I have got some weird connection issues when trying to connect and program my PIC18f452 The PIC runs at 4Mhz I have measured my Crystal Oscillator Mhz and its at 50hz (hz not Mhz!) I believe that this is throwing off my PIC and is causing me issues when trying to program it. (Roughly 4-20 times I click query I can get a response) What could cause this weird timing issue and how can I fix it. (Extra Notes) I can only get a response from the core, If I bridge the J11 contacts between the midi output and 5v with an LED I can only upload a .hex file with said LED removed I broke my 100nf Caps so im using 100nf 50v rating rather than 50-100v range that the original ones had. Would any of these give some clues to what is happening. (Sorry I'm very much a beginner)
Noise-Generator Posted May 23, 2021 Posted May 23, 2021 Do you have 5V or something less? You may know that but if you have an issue, the first step is to check the traces via eyes and than with the multimeter. Check every connection. A Capacitor in a circuit has to be the volt value with some room to the actual current. So if you work with 5V everything over that is ok.
Reubenclarke.jpg Posted May 26, 2021 Posted May 26, 2021 Nothing seems to be out of the ordinary. Only Issue I have found is the clock only has 30mV between the two contacts. What voltage should the 10.000Mhz clock run at?
Noise-Generator Posted May 27, 2021 Posted May 27, 2021 I don't know. The best way to find the issue is always check the connections via the multimeter-"beeper" mode and the schematic. 90% of all issues are connection errors.
Zeke Posted May 28, 2021 Posted May 28, 2021 On 5/26/2021 at 3:08 AM, Reubenclarke.jpg said: Nothing seems to be out of the ordinary. Only Issue I have found is the clock only has 30mV between the two contacts. What voltage should the 10.000Mhz clock run at? This may not help but I had all kinds of issues until I attached all the faders to the PCB. using one to test doesn't help. I learnt that the hard way. I would suggest doing that.
Reubenclarke.jpg Posted September 20, 2021 Posted September 20, 2021 Hey Everyone. After following through the troubleshooting guide I think I'm having an issue with my midi->usb cable. I'm running windows 10, I tried both a no name cable and an M-Audio Uno. Does anyone have any recomendations on cables that work well with windows 10? Thanks
Keeze Posted September 20, 2021 Posted September 20, 2021 10 hours ago, Reubenclarke.jpg said: Hey Everyone. After following through the troubleshooting guide I think I'm having an issue with my midi->usb cable. I'm running windows 10, I tried both a no name cable and an M-Audio Uno. Does anyone have any recomendations on cables that work well with windows 10? Thanks After some trial and error I had good luck with the Roland UM-ONE mk2 (YMMV). Cheers
novski Posted September 20, 2021 Posted September 20, 2021 6 hours ago, Keeze said: After some trial and error I had good luck with the Roland UM-ONE mk2 (YMMV). Cheers Maybe you whant to check/update the list: http://www.midibox.org/dokuwiki/doku.php?id=midi_interface_blacklist
Reubenclarke.jpg Posted November 30, 2021 Posted November 30, 2021 Spoiler Thanks for reccommending the Roland UM-ONE Mk2 it works great. I have 1 more issue. I have the same issue as Zeke had with his faders, this being a large stream of notes flooding through. Novski said to wire touch inputs to ground but that didn't do anything. What am I supposed tot do to get it to stop. I'd really like to still be able to use the touch sensors aswell. Thanks for help
koerschgen Posted October 12, 2022 Posted October 12, 2022 Hi, is there any chance to buy the preprogrammed PIC for this project anymore? Most of the old links are dead. I saw the blank PCB in a shop, but not a kit or the PIC... I would also buy a used kit or populated PCB. Thank You! Best, koerschgen
novski Posted October 12, 2022 Posted October 12, 2022 2 hours ago, koerschgen said: Hi, is there any chance to buy the preprogrammed PIC for this project anymore? Most of the old links are dead. I saw the blank PCB in a shop, but not a kit or the PIC... I would also buy a used kit or populated PCB. Thank You! Best, koerschgen Where are you located? I think i have several to give away, but i am in Switzerland. Postal costs are high in our sweet island…
koerschgen Posted October 24, 2022 Posted October 24, 2022 (edited) Hi Novski, sorry for my late reply, didnt get a notification ! i am located in Hamburg, Germany. do you habe some PICs or complete modules? i am interested in 4 modules/Pics thanks! Edited October 24, 2022 by koerschgen
Phatline Posted February 7, 2023 Posted February 7, 2023 hei i have those: SAON11M9-LIN10K I dont understand this touch feature... When my finger is the Ground/Touch, then there is still a plastic between the Fader and my finger, how does this work? (i have read till page 11 off this tread, but didnt found anyone questioned this...) do i need this (not in stock) chrome Fader-Lever? https://www.reichelt.de/at/de/faderknopf-gerippt-t-lever-chrome-knopf-18-5x1-5vc-p73957.html?&trstct=pol_14&nbc=1
