Altitude Posted November 30, 2019 Report Share Posted November 30, 2019 Nice. That's exactly what I had in mind. PM'd Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 1, 2019 Author Report Share Posted December 1, 2019 Thanks Bruno and Altitude! :) Altitude, will send you the acrylic case display cutout dimensions via PM or email shortly. Best regards and have a nice sunday! Peter Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 1, 2019 Author Report Share Posted December 1, 2019 @Altitude as requested, we've now released the acrylic frontpanel plan as a SVG, as another customer wants to create a custom 3D printed case and asked for it. There is a 3mm "size indication" in the SVG, which can be used as a reference for scaling on your side. The plan is linked on the bottom of the "caseless" LoopA shop page:https://www.midiphy.com/en/shop-details/139/69 Direct link:https://www.midiphy.com/files/d14/LoopA%20Acrylic%20Case%20Frontpanel.svg Have fun and best regards! Peter Quote Link to comment Share on other sites More sharing options...
Phatline Posted December 3, 2019 Report Share Posted December 3, 2019 very nice! will be my first invest in 2020. 1 Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 4, 2019 Author Report Share Posted December 4, 2019 @Phat, that sounds great! At some point in time, the LoopA software will probably get a CC track type, but it will never be as powerful as your dedicated CC Looper, that can just use the full STM32F4 memory for that single purpose :) Many greets, Peter Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 14, 2019 Report Share Posted December 14, 2019 Posting this in case I forget it. I couldn't receive a response from the Core using MIOS Studio 2.4.6 which i downloaded about 2 years ago. Using the latest version 2.4.8 allowed the core to respond and I was able to upload the firmware. Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 When pushing down the Headers for the OLED I noticed that the top of the 8 pin DIN for the BLM got in the way despite filing off the "nip" as Peter put it. I had to file the corner / back of the connector off at an angle even further so the standard SIL pins would have enough clearance. Maybe my connector is slightly different to the one Peter used in the video? It sure looked the same, as it has the metal tab on front that needed to be filed down. Case goes on tomorrow morning and I should be done! Quote Link to comment Share on other sites More sharing options...
latigid on Posted December 17, 2019 Report Share Posted December 17, 2019 Nearly there, cool! Could you post a photo of the clearance issue just to confirm? You mean that the soldered row on the rear of the plate PCB still conflicts? Did you trim the pins before soldering as suggested? Maybe more trimming is needed? That DIN8 is actually EOL anyway so we need to see how the replacement looks. Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 (edited) I have the row soldered and cut already but ill take a photo so you can draw imaginary lines down to the connector with your eyes! Ill take a photo and upload it at 9am GMT. Edited December 17, 2019 by Smithy Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 (edited) Photos aren't the best, I should really use an endoscope! But hopefully you can see it was necessary to trim the back upper corner of that connector. Edited December 17, 2019 by Smithy Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 17, 2019 Author Report Share Posted December 17, 2019 Wohoo, congrats to the nearly completed build @Smithy! :) Also thanks for your photos! I just measured with the caliper and think there should be >2mm of clearance, if the 8-pin connector has been filed "flat" at the top: The OLED pins should be cut close to the PCB, that is very true: We are aware of space restrictions within the case, but wanted to create a really slim DIY device, so this is on purpose! :) Many greets and enjoy your new LoopA! Peter Quote Link to comment Share on other sites More sharing options...
Antichambre Posted December 17, 2019 Report Share Posted December 17, 2019 It seems bottom of the metal enclosure will be blue ;) Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 (edited) 11 hours ago, Antichambre said: It seems bottom of the metal enclosure will be blue ;) Shhhh! Its a secret! ;) Guys i think the I was sent the wrong sized nuts for the rear acrylic panel where 2 nuts slip into the slots. The nuts have a 3mm height and will not fit. Luckily I have 3mm nuts with a height of about 2.3mm that will do the job nicely. Edited December 17, 2019 by Smithy 1 Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 Here's how the OLED header looks with the rear panel mounted: Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 A wild midiphy LoopA appears! Huge thanks to Andy, Peter and TK for making my dream looper come true! I just need to test MIDI I/O now. 1 Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 17, 2019 Author Report Share Posted December 17, 2019 Congrats to the finished build, well done! :) I think you are right with the M3 nuts for the case interlocks, these should be low-profile nuts and we probably have packed normal-sized M3 nuts in the first kits. We'll contact all customers of the acrylic kit variant and (if required) send them eight replacement nuts! Other than that: hope the build went well for you and that you enjoy your new toy! :) Many greets, Peter Quote Link to comment Share on other sites More sharing options...
TK. Posted December 17, 2019 Report Share Posted December 17, 2019 Reproducibility proven - great! :) Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 17, 2019 Report Share Posted December 17, 2019 Thansk guys! Yes even a noob like me can reproduce which is a good sign and will hopefully inspire other newbies! ;) By the way, all images have been fixed in my previous posts. I tried the right clicking, "copy image" and pasting from google images which caused the problem. This usually works fine on other sites but not with Community Software forums apparently. Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 18, 2019 Report Share Posted December 18, 2019 Here's the time lapse video i recorded of the LoopA. I gave up on the solder paste and hot air method early in the build, as the solder paste I used didnt come with a plunger and my plunger was a bit too narrow. I have officially converted over to drag soldering now and its much faster. When I soldered the Mattias switches the recording stopped as a calendar notification popped up on the phone! Luckily its 99% of it is there! Thanks again to everyone involved, everyone is credited at the end of the video. 1 Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 18, 2019 Author Report Share Posted December 18, 2019 @Smithy, super cool and very nicely done! What was your total time to build it? 8-10 hours? Now awaiting your first official jam with it! :) Many greets! Peter Quote Link to comment Share on other sites More sharing options...
Smithy Posted December 18, 2019 Report Share Posted December 18, 2019 Just now, Hawkeye said: @Smithy, super cool and very nicely done! What was your total time to build it? 8-10 hours? Now awaiting your first official jam with it! :) Many greets! Peter Lost count! Friday i spent most the day, saturday a half day, Sunday a half day, Monday most of the day, and finished it before lunch on Tuesday. But i take my time with things like this, and encountered a few problems like trying to fit the microcontroller in and cut all the legs! I think i was being overly cautious with cutting those pins as close as possible. Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 21, 2019 Author Report Share Posted December 21, 2019 Happy holidays! :) Here is a sneak preview of the upcoming 2020 LoopA "Pro" Metal Case, designed by Hallik Engineering: Hope that you like it and that the first LoopAs out there are already being built and maybe are even already used! :) Have a relaxing and healthy holiday season! Best regards, Peter Quote Link to comment Share on other sites More sharing options...
Elektruck Posted December 21, 2019 Report Share Posted December 21, 2019 Wow, looks beautiful! I just finished the eurorackmodules, will start on LoopA one of these days 1 Quote Link to comment Share on other sites More sharing options...
Hawkeye Posted December 22, 2019 Author Report Share Posted December 22, 2019 Thanks, @Elektruck! All credit for the LoopA metal case goes to @AdrianH, as usual! :) Have fun soldering and have a nice xmas time! Peter Quote Link to comment Share on other sites More sharing options...
JuanJerez Posted March 17, 2020 Report Share Posted March 17, 2020 Good afternoon, I introduce myself, my name is Juan and I currently reside in Spain. I'm a noob to synthesizers and music making gadgets, and when i saw loopA i knew i wanted to have one. So, little by little I was saving somemoney and after several emails with Peter, I decided to buy the device and finally I managed to build my loopA. Thank you very much to the team involved in buildingthis project. With your permission I am going to use this forum thread to ask my questions. I have problems to use software synth soft via virtual USB MIDI port. Configuration: windows 7. midi controller keyboard to computer and loopA to computer too. But dont work. ¿any suggestion? setup.txt 1 Quote Link to comment Share on other sites More sharing options...
