319 -
Everything posted by lemonhorse
VMidibox v1.01 F1 - F4 buttons
lemonhorse replied to banneduser's topic in MIDIbox Tools & MIOS Studio
Hi vybe, strange. yes - with my MB64 I figured out that these F1 to F4 buttons act like normal buttons with the MB64 firmware 1.0x (they just have special funktions with the MB64SEQ firmware). You just have to configure the F1 to F4 buttons like all the other buttons of the MB64 via vMIDIBox64. Normaly the F1-button = button 17 (@ vMIDIBox64), the F2 button = button 18 and so on... - Lemonhorse -
Thanks for your feedback chaps (what a community ;D)! ...and again and again: THANK YOU TK! With YOUR PROJECT you transform a piece of utopia in to a real "world-wide-web" fact. - Lemonhorse
Hi pay_c, ...the MidiBox64 supports 4x16 LCD's by the firmware ver. 1.0x (for the PIC16F877) - you just have to configure the MB64 via vMIDIBox64 (vMIDIBox64 is an editor/simulator for the MIDIBox64). http://users.pandora.be/sdrsite/sites/serge/vmidibox/ ...so you have direct information about the bankstick name and the MidiTimeClock (MTC). ...and there is TK's MIOS (MidiOS): ...but I have no experience with MIOS (jet ;D). greetings - lemonhorse
Hi nacho, welcome to the uCApps Forum! (Posts: 1 :)) Yes I think so. ...the LTC (LED/Thru/COM) module is useful if you have a need for a 2nd Midi-out and/or a Midi-thru port - and sometimes it is helpful to have information about the midi-in/out-activity (info LED's)... MB64 Buttons // with one Dinx4 module you'll have: 4 buttons for MB64 navigation 4 function buttons (F1 - F4) // they (can) act like normal buttons with the MB64 firmware but they have special funktions with the MB64SEQ firmware... 24 normal buttons (free assignable) Good Luck! - Lemonhorse // BTW - I have a lot of fun with my nearly finished 3rd MidiBox64 Â ;D // visual notes: http://www.subfrequenz.net/techlog/mb64nr3.htm Â
...that's damn right! ;D
I feel honoured Sire! ;) ;D :)
Hi out there! I just want to share my notes about switching the 24256 Eeprom devices (BankSticks) in context with the MidiBox64 - I call it "Internal BankStick Switching". [ technical notes about the 3-layer-rotary-multipoint-switch + the 24256 eeprom...] (updated) http://www.subfrequenz.net/techlog/mbox64b.htm (strange german/english mix  ;)) [see also T's bankstick info page...] http://www.ucapps.de/ - > Concepts -> BankStick Peace! - Lemonhorse
Yes I agree too ;D And I must confess that this forum and the hole fabulous MidiBoxSite has infected me with a lot of enthusiasm and fun!
Hi Justin, yes, the MB64 Sequencer generate a real time MIDI clock signal (BPM) - and can also be clocked by an external Midi Clock (via Midid-In). - Lemonhorse
good to know... what is about WinXP and the JDM - has anyone experience with this combination? - Lemonhorse
hi ladybug yes, i think so. there is no problem - you can use the 8.2V or the 8.7V Zener Diode for the JDM programmer :) - lemonhorse
Hi Amando, i think there is no problem with the v1.00 MB64 Firmware and your Greg Macmillan board. have a look @ http://www.ucapps.de/midibox/midibox64_v100.zip In this matter the Greg Macmillan board is the old hardware design - and the MBHP is the new hardware design. :) - Lemonhorse
Getting MB64 with old MF extension up and running
lemonhorse replied to banneduser's topic in Testing/Troubleshooting
Hi Stefan, (just a guess...) did you work with serge's "vmidibox64_0xx.zip" ( 0xx = MB64 0.33 & 0.34 Firmware)? - because the vmidibox64 ver. 1.00a is not compatible with the MB64 0.34 Firmware... yes - Lemonhorse -
yesterday night i was testing the MIDIbox64 V1.00 firmware in combination with your vmidibox64 1.00a - and it worked fine  :D thanks for this usefull piece of software serge! - lemonhorse
...the rotary encoders circuit ( http://www.ucapps.de/howtoenc/rotary_encoder_ciruit.gif ) is designed to work with the MIDIO128 - maybe i'm wrong but i think that the currend MB64-firmware do not work with relative midi messages and rotary encoders.
hi thorsten, [which additional informations should be displayed?]: in my view it would be very useful to have a free assignable "Name" for each BankStickBank on the display! Â :) best regards, lemonhorse
Hi djDim, In my view it is not possible. Because the MB64 project and the MB16E project require a discrete core-module with a separate pic-firmware. but of course you can integrate both projekts in one case ;) greetings - Lemonhorse
hi Simolch, einen sequencer in einem C64-gehäuse einzubauen ist eine coole idee - bin gespannt auf die bilder deiner midibox... wenn ich Dich richtig verstehe, fragst Du, ob Du bei einer MB64SEQ mit 64 LED's 20 taster anschlissen kannst?  - also zur zeit wirst Du mit 20 + 4 (F1-F4) + 4 (Navigation) tastern (buttons) so oder so kein problem bekommen - siehe:http://www.ucapps.de/mbhp/mbhp_dinx4_32buttons.pdf und solltest Du später noch mehr brauchen... ...+ ich bin mir (in meiner vermessenen forschheit) ziehmlich sicher (so wie ich Thorsten kenne), das eine spätere MB64-SEQ-Firmware die MB64 (V1.0) mit all ihren 64 pots, 64 LED's und 64 buttons unterstützen wird. gruss - Lemonhorse
...ja LED's sind schon was feines  ;D ...das ist gut, so muss ich die vorhandene MB64 nicht für kommende MB64SEQ-Firmware umbauen - kann sie weiter testen und mich in die Verwirklichung neuer MidiBoxen werfen ;)... In meinen Augen schreibst Du Midi-Geschichte!  + Danke für die Antworten Thorsten :) Gruß - Lemonhorse
Deine Vermutung war richtig Thorsten! Der Fehler hat sich beim PIC-Brennen eingeschlichen - ich hatte vergessen alle Optionen in IC-Prog (Fuses) zu überprüfen - jetzt zeigt Midi-OX wieder korrekte Midi-Daten an  :D Allerdings sendet die MB64-SEQ Sysex-Daten raus (anstatt Note ON/OFF usw...), wenn ich mit einem Bankstick arbeite - oder ist die Zusammenarbeit mit den BankStick-Eeproms (24265) noch nicht "enabled" in der Firmware ? P.S. Im Übrigen habe ich riesen Spass mit den MidiBoxen (" neuen Moeglichkeiten erforschen" 8)) - und es ist spannend zu sehen wie sich die MidiBox-Projekte weiterentwickeln... Durch dein Projekt habe ich Lust bekommen mich in's Programmieren einzuarbeiten (ich werde mich dann an Serge richten...) - es wird sicherlich noch lange dauern bis ich soweit bin, das ich Anwendungen bereitstellen kann (wenn ich es denn überhaupt schaffe...) - aber inspirierend und ein guter Anlass zum lernen sind die MidiBoxen allemal! P.P.S Und dann geht da wieder die Neugier mit mir durch ;) Ist das so gemeint, das jedes Poti sein eigenes LED bekommt ( 4 Tracks á 16 LED's)? - Wenn ja, was ist dann mit den LED's für die Buttons? - und in wie weit hängt das mit dem PIC18F452 zusammmen? yours - special agent lemonhorse  ;D
Servus Thorsten! MIDIbox64SEQ V0.90: Ich hatte gleich nach dem Erscheinen deine MIDIbox64SEQ Beta V0.90 Firmware auf meine 2. (extra für den Sequencer-Einsatz gebaute) MB64 gespielt - und bin total begeistert -  dein MB64SEQ Konzept trifft bei mir mal wieder genau ins Schwarze! :D MIDIbox64SEQ V0.91: Heute habe ich die MIDIbox64SEQ Beta V0.91 Firmware geladen - die Initialisierung ist ok gelaufen - die LCD-Anzeige zeigt auch Werte und Optionen an - aber am Zielort der Mididaten funktioniert nichts mehr so wie gedacht - bei "MIDI-Ox" sieht es wild aus (unknown events und viel buntes Durcheinander) - auch "Midi Learn" arbeitet nicht korrekt - kann es sein, das der "To-COM" (@ Midi Config.) immer aktiviert ist - auch wenn er laut LCD-Anzeige ausgeschaltet ist? ???
Help: 7805 gets very very hot! @ Core Module
hi André, i guess the 22uF cap is not the problem. what is the voltage value on your 7805 input pin? - if you have more then 10V it can cause the heat - in this case you should take a cooling element for the 7805 or another transformer. power supply: i made good experiences with 7805 (1A) and a 7.5V (800mA) transformer... ...but maybe it's a circuit problem - in this case you can: -  check all the soldering joints for short circuit or false connection (i know you have allready but who knows (i found some bugs after chcking the circuit-board about ten times...)) - the next option to find the bug is to remove suspect components step by step from the core modul and check the heat of the 7805 each time - if no component left over check the soldering joints again... ;) good luck! - lemonhorse -
hi djrd, my favorite is DESERT SILENCE 8)
