nILS
Frequent Writer
    4,314
    4
Everything posted by nILS
  1. http://www.midibox.org/dokuwiki/doku.php?id=sammichsid#sammichsid_build_guide ^- Official doco site with the latest docs.
  2. Moved to the "C" forum. The wiki page for the toolchain setup explains how to compile. You've downloaded a bunch of tools. Not an IDE (== integrated development environment). So with the tools you have now, you'll have to edit your code with Notepad++, fire up the command prompt and compile it from there. "cd" to the directory that has your code in it, type "make" and if you've setup everything according to the wiki, that'll already do. If you'd prefer an IDE search the wiki for Code::Blocks or Eclipse.
  3. Schlitzschrauben auf dem Panel? Wirklich?!
  4. Moved to Miscellaneous. The panel files can be found here (after 2 or 3 more clicks): http://tinyurl.com/6gzqaz3
  5. http://www.midibox.org/dokuwiki/doku.php?id=windows_toolchain_quickstart
  6. *yawn* http://www.ucapps.de Go read.
  7. Yes, all SIDs have the ADSR bug.
  8. Yes :thumbsup: It isn't, that's how we designed it to be. That's the spirit!
  9. 12.31V is within the tolerances (that's <3% off).
  10. Ponoko used to have 1.5mm clear acrylic :thumbsup: Just saying...
  11. A bit more verbose: Don't buy a book. Look at other people's code (preferrably code with lots of comments) try to understand it, if sth is unclear, google or ask in the chat (real-time support, hooray), pick tiny/small ideas and try to implement them.
  12. This is a good place to start: http://tinyurl.com/3vbpfkl
  13. This is the kind of project where the actual assembly is the most fun part :frantics: Congrats!
  14. I'm feeling fine and I am still alive, still alive, STILL ALIVE.
  15. F*ck yeh. :frantics:
  16. I've done some deleting and cleaning up of posts, but I can't remove members either...
  17. Am Freitag, den 27.05.2011 (also morgen) ist offizielles MIDIbox Meet'n'Greet ab 19:00 im "Ca Va" in der Kazmairstraße 44 in München. Dabei sein werden einige Urgesteine inklusive TK, Polykobol und - speziell für diesen Anlass aus AU eingereist - Wilba. Meiner einer wird auch da sein. Wir würden uns selbstverständlich über zahlreiches Erscheinen und ausgegebene Biere freuen, bei Rückfragen einfach an mich wenden, am besten per Mail (hol ich auch unterwegs) in ganz dringenden Fällen auch telefonisch (Nummer in rückwärts gibt's hier). Bis denne!
  18. Very nice work, Antix! :frantics:
  19. Stereo Kabel verwendet?
  20. Y-cable bad.
  21. I haven't read the whole thread, but anyways: MIDI splitting is fairly easy (see gm5x5x5) or http://m.bareille.free.fr/midithrubox/midithrubox.gif
  22. Das ist alles definitiv zu schaffen, ist aber ein ordentlich Haufen Arbeit. Wenn man sich den allerdings in kleine, überschaubare Häppchen zerlegt, ist das alles zu schaffen. Ich würde ganz klassisch vorgehen: 1) Mockup malen, das hilft nicht nur Dir genau zu sehen und zu verstehen ob evtl. irgendwo was fehlt oder nicht unbedingt ideal ist, und es hilft uns zu verstehen wie genau Dein Konzept aussieht. 2) Use-Cases mit denen des seq v4 vergleiche. Was gibt es schon, was gibt es nicht, was musst Du anpassen? 3) Eins nach dem anderen abarbeiten - dabei wird sich sicherlich noch das eine oder andere an Deiner Spezifikation ändern. 4) Uns auf dem Laufenden halten, damit wir Dir evtl. unter die Arme greifen können, bevor Du Dich aus dem Fenster stürzt ;)
