Wisefire
    416
Everything posted by Wisefire
  1. duke3d
  2. C is difficult.. but the most flexible.. why not include all 3 different settings and have the user define what he wants the mode to be..
  3. here in holland its raining..
  4. no voti.nl encoders are 1.19 euro..
  5. can we see one connected?? i wanna see what the backlight looks like..
  6. it must be that i am dumb.. but doesnt midibox just checks voltage.. as a pot is a voltage divider it doesnt really matter what kind of ohmage your your pots has.. as long as they arent 500k cuz those will probably start to flutter..
  7. you are right.. however the topic suggestion is that you wouldnt be able to use any other pot than 10k and this is clearly not true.. i had some spare 50k linears lying around.. and they work great.. very accurate.. no fluttering of data.. also i think you can reduce non linearity by having a higher value resistor across the contacts.. but this is just my guess..
  8. ive used 50k pots without any problems with midibox
  9. arent these drawbars able to be set halfway..that would mean 1 ain for every drawbar..
  10. link doesnt work.. shows me the feedback an ebay member
  11. the green red (1 wire pair) and the brown blue (another wire pair) both feed out AC.. this is normal and im not confused by that.. however ive got 2 pairs of 12VAC coming out of the ringkern.. and i only see one connection on your board for it (and a ground pin which i assume goes straight to earth)
  12. i meant the ringkern.. ive got blue brown.. and red green..
  13. hey NLX, i was wondering.. ive got 2x 12VAC wirepairs.. where should i attach the second pair??
  14. looks good.. very nice with the spacers under the core!!
  15. i have it built but i still have to test it.. ive built it for my fm synth but it still needs to be assembled..
  16. i am getting a backlight.. (its not the most bright ive seen but good enough for me) so or your display is broken .. or you have wired it incorrectly.. double check it..
  17. Wisefire
    Avatars
    ill shrink my sig somewhat... thnx for your 2 cents..! edit: jup that looks better imho.. thnx for the tip..
  18. Wisefire
    Avatars
    very well spotted.. burning ice.. it is indeed.
  19. Wisefire
    Avatars
    well.. i thought i would finally give in, and have some kind of avatar.. and a signature.. tell me if you like it.. and i'll tell you what it all stands for..
  20. my name is not list but i'll try to answer some of your questions.. first lets get our facts straight.. there is only one mios.. this is the operating system for most if not all the stuff you see here on ucapps.de the application itself (like the sid application or in your case the midibox64 application) runs on this operating system and is uploaded via midi. as is mios.. the bootloader (which makes it possible to upload the os and the application) is burned via a pic burner like your pic18f programmer kit.. as for mios studio.. this is a java based program which facilitates the upload via midi. this is not a program which needs to be uploaded to the PIC!!! as for uploading the m64 app to the PIC before you go all out.. this is absolutely possible.. it doesnt hurt the core in anyway.. but might want to be able to control the menu, then you would need a DIN board.. but i might be wrong about that.. but you want to use 32 buttons so a DIN would be implied.. hope this helps..
  21. ah now i understand.. instead of making a lot of different variables.. you make a list of variables.. i have programmed in the past.. basic, ti-basic, html(:P), and ive had c++ and max/msp lessons on my college. the c++ lessons where tailored to audio applications, so im not that noob to programming spirit.. also im not that bad at max/msp.. but syntax and actually doing something and finishing it in c++(or c) is another ball game.. so its always fun and VERY interesting to learn this stuff.. especially when you can create your own midicontroller..(come on how cool it that.. i now have a c64 controller, one of a kind.. with working lcd, 5 very smooth working pots, and 60 odd trigger keys.. plug it into ableton and you're cooking with gas!!..) i now have so much more respect for TK (and i had a whole lot to begin with) building the programs that control the hardware that he designed.. AND building the structure behind it so i can easily program my own stuff!! WOW.. simply wow.. ill be donating soon.. ive wanted to do it for a while but now im totally convinced.. and with this seq3 and sid2 coming i think he'll need it and deserves it..
  22. oh.. believe me.. you are telling me something new.. (except for the adding 20 to the pin.. i figured that much out..) however why shouldnt i be able to set some type of global variable which ads to the pin numbers.. because i cant control the ccs of the individual pots?? also i dont quite see how i would be able to use any CC remember im so incredibly new to this.. its not even funny anymore :P
  23. wow.. didnt know there was tutorial stuff on here.. cool! in the meantime ive rumaged through the forum and found almost all of it.. except for PIN being the cc number.. im actually beginning to understand the system a tiny bit.. however my idea that this could be conquered in a week was a tad optimistic.. it'll probably take a month :P thnx TK.. you rule.. as always!
  24. thnx.. is that where i need to be? even with unmuxed analog ins?..also i would probably have to code this in asm dont i :D.. right.. ill search the forums some more..
  25. god aint i a noob.. could someone give me a hand how to get my 5 pots working with my c64 controller.. i got the scan matrix going.. and it is sending out notes.. but now i want my 5 pots to send cc values which i can redirect in max/msp..
