374 -
8
Everything posted by sneakthief
	latigid on: it's the high speed SD card port that can't be used because of the audio dac using the same pin. AFAIK the SD card is accessed via a slower SPI port and the audio dac is available.
	chriss - sorry, looks like all 9 PCB pairs are accounted for. However, if anybody changes their mind, you're next in line.
	Do you mean something like this? http://www.ebay.com/sch/i.html?_nkw=5v%203.3v%20level%20converter&clk_rvr_id=764133331262&mfe=search
	[status: order closed] I'm ordering 10 pairs of Transmitter/Receiver boards and selling 9 pairs. I'll ship them out at the end of January and will only take payment at that time. Update as of 01.30.2015 @ 11.00 - all boards shipped: mfk: 1 pair- shipped borfo: 1 pair - shipped rowan: 1 pair - shipped CJ55: 1 pair - shipped jojjelito: 1 pair - shipped monokinetic: 2 pairs - shipped Ungleichklang: 1 pair - shipped grizz: 1 pair - shipped (Notes: This is just a one-off run, I won't be doing any more. If anyone else needs more, I suggest simply uploading the .brd files to OSHPark.com or following this thread for other possible groupbuys)
	Looks like MIDIbox CV2 supports LPC: http://svnmios.midibox.org/filedetails.php?repname=svn.mios32&path=%2Ftrunk%2Fapps%2Fprocessing%2Fmidibox_cv_v2%2Fsrc%2Fmios32_config.h
				axoloti a-digital-audio-platform-for-makers
sneakthief replied to Elektruck's topic in Miscellaneous
For those MIDIbox-ers wanting to experiment, you can compile this for the STM32F4 Discovery like so: https://raw.githubusercontent.com/JohannesTaelman/axoloti/master/doc/for%20stm32f4discovery.html Compiling info: https://github.com/JohannesTaelman/axoloti/blob/master/doc/compiling%20from%20source%20on%20osx.html https://github.com/JohannesTaelman/axoloti/blob/master/doc/compiling%20from%20source%20on%20windows.html Notes: You lose audio in and SD card (meaning you can only save one preset on board). MIDI I/O gpio pins are documented at the end of this file: https://github.com/JohannesTaelman/axoloti/blob/master/firmware/midi.c MIDI In/Out -
				SmashTV Core STM32F4 + MIDI_I/O Module PCB
sneakthief replied to fundamental's topic in Parts Questions
Like this? http://www.rapidonline.com/electrical-power/antenna-terminal-pcb-mount-90-degree-scrtm4ra-43-0786 -
Thanks so much, Tim!Mike. Very much appreciated. -
Thanks TK - I'll consider my question in this thread "closed" and see if Tim answers in my -
	[edit] my question was answered here: [/edit]
Is there any layout data for the mounting holes on the CORE_STM32F4 or the MIDI_I/O boards? I'm back to working on my MIDIbox CV2 case and the coordinates for the holes would be very helpful. -
	Hugo106 - I think you're confused. The AL-88c does 8x midi in and 8x midi out hardware ports - whereas ilmenator's has up to 56x ins and 56x outs. No contest. MIDIbox wins again! :D
				Let's buy TK a ridiculous amount of beer for Xmas
sneakthief replied to borfo's topic in MIDIbox SEQ
kristal= how about nootropics and beer? http://www.engadget.com/2014/12/22/the-problem-solver-beer-creativity/ -
4 beers from me! Alles jut, Herr Klose. -
	If I'm not mistaken, you need to use bash instead of sh: http://unix.stackexchange.com/questions/17727/why-does-my-shell-script-give-the-error-declare-not-found http://ubuntuforums.org/showthread.php?t=1658965 I find Googling compiler error output often very helpful.
	[edit] I was considering midifying a Yamaha CS70m keyboard but instead will use MIDIO128 [/edit]
	Thanks for confirming this. I'd fix it (and also finish my MIDIbox CV 2) but I'm sick as a dog all year and recovering from throat surgery - beware of solder fumes!
	I can't seem to get loop points over 16 steps to work! - Loop points 17-31 as well as 33 to 63 don't reset on those respective steps For example, if I set ALL Instruments to loop steps 1 to 17, A+B won't combine automatically. If I select A+B manually, it plays 32 steps instead of 17. However: - Setting loop points to 16 and under works correctly - Setting loop point to 32 combines A+B as well as C+D and works correctly - Setting loop point to 64 combines A+B+C+D and works correctly
	I assume that STM32F407 was being overclocked as the standard maximum speed is 168MHz. Seems plausible based on these test results: http://blog.stm32f4.eu/overclock-stm32f4-controllers/ http://sigalrm.blogspot.de/2014/01/overclocking-stm32f4.html
	What's the explanation for this behaviour? I would have only expected polyphony to be limited by card speed. Does it have to do with the filesystem?
