JohnnieBee
27 -
Everything posted by JohnnieBee
Hi Darrell This looks like an interesting solution to the problem of linking the two boards. But note that the cables need to be very short in order to reduce noise, the ones you linked to are 300mm, just under 12” to those of us still using imperial units and I’m fairly sure that they would be too long. The Amazon seller lists a similar set of cables that are 100mm that might be better but from what I remember from the original build discussion that may still be a bit “iffy”. Need to find the reference in the original thread, a quick effort to search didn’t locate what I was looking for, I’ll try and find time over the next couple of days to do a more thorough search. Best John
Hi Jay Tim (aka SmashTV) ceased suppling pcbs, kits, etc a while ago. Boards can now be purchased from Modular Addict. Good quality and service. However I don't think they supply kits and parts. Check MA out here: midibox Good luck John
Only 1 MIDI port detected with GM5x5x5 on OS X Yosemite
JohnnieBee replied to m00dawg's topic in Testing/Troubleshooting
Just tried my V4 sequencer (with STM32 core) on the MacMini running OSX 10.10.2 and it sees that but again I wasn't able to check whether there is any midi data transfer. It's my work computer so no music software installed. At least TK has Mac computers, although I have no idea what OSX version he is using. I seem to remember, in the past Ploytec have been able to get Apple to fix the drivers fairly quickly. But I agree Apple isn't all it claims to be - was once a fan-boy but no more - though I still have my Mac Plus that was upgraded from one of the very first batches of Macintosh 128K's that was imported into the UK back in 1984 - cost over 2000 GBP at the time !! -
Hi mOOdawg I've just checked one of my GM5x5x5's on a MacMini running OSX 10.10.2 and it's not showing up at all, works just fine with OSX 10.9. Also, checked one of the original 1x1 interfaces and it shows up - but the display in the midi window of the Mac Audio MIDI Setup utility is showing the icon for the 5x5x5. Go figure! Unfortunately not in a position at the moment to test actual midi data in and out on the MacMini. However, should TK need help with this I can certainly move some equipment around to assist any troubleshooting required. All the best John -
[S] TPD (Track Position Display) PCBs for sale
JohnnieBee replied to ilmenator's topic in Fleamarket
Please put me down for 2 of the TPD boards, Thank you ilmenator. Best regards John -
Is this what you are after? http://en.wikipedia.org/wiki/Shape_memory_alloy
Hi Bugfight Just encountered the same problem ........ you have to register to access the wiki ....... I used exactly the same username/password as the forums ....... seemed to work! Cheers John
R80 is between the U1-core1 and U1-core2 PIC ic sockets. Good Luck!
Put Waveblaster daughter board (Yamaha DB50XG) in a box?
JohnnieBee replied to SeverityOne's topic in Design Concepts
I recently saw an article in Nuts and Volts magazine (Feb 2009 edition, I think) showing a PIC based controller for the DB50XG. Had USB interface, but the PIC wasn't one we use here. Sorry to be so vague but I don't actually have mag in front of me. At the time I saw this I did a search on ebay and there were very few DB50XG's for sale. John -
Video of MB Sid, Seq, + Klee Sequencer all in 1 unit
JohnnieBee replied to Smithy's topic in Miscellaneous
K Gys, Nw tht w sgm t b clmng dwn. My pnt t th fct th Kl s cntrl vltg srt f bx rthr thn MD dvc, thrfr t s vry nlkly t b drvng th MBSD. Ths gy hs dls f nlg kt s h s lmst crtnly sng tht. n thrd ('ll dg t th lnk f nyn wnts t) n th lctr-msc.cm frms whr ths prtclr Kl (nd th vd) r dscssd, th prsnc f th MBSQ nd MBSD r dly ntd nd rcgnzd. -
group buy for ultracore (core + 4x IIC + 8 banksticks)
JohnnieBee replied to ultra's topic in Bulk Orders
Mine arrived here in Upstate New York today. Awesome job, thank you so much. John -
1K in parallel with 220R is approximately 180R which means more current therefore more brightness!!
Yes, those diodes should be fine.
Markus What are the diodes that you are using for the rectifier?
Markus The diagram that you have drawn over your circuit board shows the middle pin of the 7912 as the output. The middle pin is the input. Please check your board again!
SID's arrived here in upstate NY on Saturday. Thanks for everything Wilba!
Having this problem too. Happens with both Safari and Firefox (Mac OSX 10.4.11). I have tried removing the cookies, at least the obvious ones that I can find: forum.midibox.org PHPSESSID www.midibox.org PHPSESSID www.midibox.org midibox Removed them from the list in the preferences panel, even left the Midibox site before I did this, all to no avail. If anyone has any ideas on solving this rather aggravating problem I, for one, would be very grateful. Thanks John
Hi Asaf I bought one of these blue LCD's from Divineo awhile ago when they were mentioned in the MB6582 thread. It is very nice and have had absolutely no problems with it. I got the data sheet from the CrystalFontz website. Wilba was correct in saying the backlight adjustments on the Core module don't seem to have quite the same range as with most other displays, but I haven't found it to be a problem. Changing some resistor values would probably fix this issue anyway. John
Request for one time sale of MB6582 parts - SOLD
JohnnieBee replied to jonkull's topic in Sale Requests
Hi Jon I am assuming that the boards and panels are unused. If so, I would be very happy to take them off your hands. Let me know how much you want for them. My email should be in my profile. John -
Hi Max Are you going to take payment via PayPal?? If so, please count me in for 5 x 6581R4AR's Thanks John
Hi Goblinz I have an Epson 4800 inkjet printer and have purchased a roll of self adhesive vinyl for this very purpose. I actually have the front panel design for a Music from Outer Space SoundLab that I have nearly finished building ready to try. For this project I am using a 3U rack panel. There are also several MidiBox projects nearing completion so I hope this works! What I was thinking of doing was printing and applying a version of the panel with just the hole centers and any cut-outs marked. This could be used and abused during the fabrication of the panel. Once this stage was completed the vinyl could be stripped off and replaced with the final version. Not sure yet how best to apply the vinyl - I am going to try "floating" it into position with a little soapy water and then carefully squeezing this out. Once dry the vinyl could be trimmed with a very sharp knife. The inks from the printer are supposed to be waterproof so hopefully this will work without any smudging. Bubbles can be pricked with a sharp needle and the air released if this becomes a problem. I should be attempting this in the next week or two and will report back. All the best John
http://www.canakit.net/ http://www.profusionplc.com/products/RA-FX3C.html http://www.profusionplc.com/products/RA-FX1V.html Hi Stryd One The first link is for a kit using a Bucket Brigade Device similar to the one in the schematic that Nils posted. The problem with BBD devices is that they are noisy - hence compander cct in Ibanez design, they have poor distortion figures and the bandwidth is limited. To change the delay through the chip the clocking frequency is changed, this in turn changes the bandwidth - basic Nyquist theory. The other 2 links are for relatively cheap ready made digital delay boards, thinking about getting one myself to play around with. There are, of course, off the shelf units like Alesis' Picoverb and Behringer's MiniFex which aren't too expensive. Regards John
