1,240 -
28
Everything posted by Smithy
hehe, indeed! Have a free :clover: .
No need to be sorry, its good that you double checked, otherwise you could have blown a working sid!
Yep, this is correct. From the sammichSID manual: SID Voltage Jumpers The L-shaped header JP controls the voltage supplied to both SIDs. It will supply both SIDs with power from either the regulated 9V supply on the base PCB (i.e. directly from the 7809 voltage regulator) or from the input power supply which must be regulated 12V DC. So basically you cant use a 6581 and an 8580 together, if you set the voltage to 12V, the 8580 will blow. Has any actually tried supplying 9V to a 6581? I wonder if it would make any sound at all, probably not.
Well if it hasn't blown up your sid yet, then it should be fine! ;) It might be safer to use a 78xx though, just in case the voltage fluctuates.
Mmmmmmm..... Tonicccccccc. What type of Power Supply are you using? Could you give us more details.
Spam offer Count +2 Mebbé we all report auction as illegal? Mebbé pointless, but mebbé not so pointless if enough peoples clicky?
*1 year later* :poke: I haz no wai of getting MIDEH to mah computurrrrr nao, so i can't upload teh whole TWO patches i madez, neither can I download all the new patches in the sticky, but I'm really looking forward to trying them out! :rofl:
"Available in 12 inches only"
Mebbé we all make spam off fur of £1 nao?
Heh, just stocked up on SIL/DIL Headers, and connectors from this guy, his prices are the cheapest i've seen. Almost tempted to buy the red/orange 4x20 LCD as a spare, but i already have 2 black on green as spares! He also sells, a set of angled SIL headers, connectors and crimps. Ill be using this kit to connect the cables on the CS PCB: http://cgi.ebay.ie/5x-Connector-crimp-Header-PIN-1x8angle-8crimp-complet-/170422616083 If the plastic is too wide on that right angled SIL header, you can order the kind Hawkeye used: I'll be crimping the crimps to the ends of these cables, which I'm currently using on the Base Board side: http://www.reichelt.de/Platinen-Steckverbinder/PS-25-8G-BR/index.html?;ACTION=3;LA=2;ARTICLE=32346 The height of those connectors is about half the size of the normal white connectors, which is essential due to the lack of space in the PT-10. The end result will be a combination of what i'm currently using and what Hawkeye used. Its probably the best completely detachable solution.
Building a new OPL3 from discrete components -- possible?
Smithy replied to Green Xenon1's topic in MIDIbox FM
Google translate returns: "I'll beat me off" WTF???? This is worst than the time i googled the german word TK posted for that penis size comparison activity that ye sick german's do!!! Edit: + Exclamation Mark!
TK i never knew you had it in you, but that was comedy gold!
That is trully a work of art, and looks so modern :) Regards, ALCO(HOLIC :clover: )
Now that looks like a guitar that i could actually manage to play! :tongue:
Some very nice sounds in there, i love the beat also. List of gear used si vous plait? Oh and btw, LyssRock22 would get it. ;)
Of course not! What are you, crazy? :frantics: Hehe, 3 leds are not working, sometimes one or 2 encoders only work one direction, so basically it needs to be rewired /re-soldered, checked for shorts. Otherwise its running fine, need to add feedback pots then and it will be done!
Very Basic, one oscillator drums. Could be a lot better with more sounds and variation, but it was my first attempt. Can't wait to try making polyphonic drums, MB SID has huge potential for drums.
Must buy a mixer for play my machines, need suggestions.
Smithy replied to ganchan's topic in Miscellaneous
After a while of messing around, the crackle seemed to disappear. The only real notable changes i made was changing the sample rate from 44.1khz to 48khz, and rebooted. Edit: I can confirm that it must be a warm up issue - the crackle totally disappears after about 20 mins after the mixer is on. Still a great mixer though, well worth the money, i almost payed the same price for a new DJX-700 way back when they came out, and this is a lot more mixer! The headphone output can be noisey also, the desk is well worth buying and spending the money saved on upgrading caps and op-amps. -
*cough!* http://www.behringer.com/EN/Products/X32.aspx I actually bought a ddx3216 this weekend, but on closer inspection afterwards there is a crackle coming from the output - any output, regardless of what input is used, even the built in tone generator has a crackly sound coming through the output. I'm hoping its just a PSU issue (and not a dreaded DAC issue), and speaking of PSU that is primarily where the corners have been cut to make it affordable. There are many reports online of PSU's failing. This thread is a beautiful resource though, on upgrading the op amps, and later on in the thread; re-capping all caps in the PSU: http://www.prodigy-pro.com/diy/index.php?topic=29157.0 Also it appears Phonic have entered the lower price range of Digital Mixers: http://www.zzounds.com/item--PHOSUMMIT http://www.youtube.com/watch?v=E9RIDzT2NTA
