1,240 -
28
Everything posted by Smithy
Thanks man. I think I'll just post a picture of the wiring when im testing on this thread just to be sure and write a noob friendly how to guide. Really appreciate your efforts in improving MIDIbox designs.
Is there any chance you or someone else could do a wiring and install guide as the directions in the thread are a bit are a bit confusing? Finally I'll be able to stop using that damn power brick!
I wish I saw this post a few weeks ago before ordering one! The contrast is dissapointing and the background is a dark blue. The green on black ones I ordered ( which are not listed on the site, i had to email them) are much nicer, although I didnt test the refresh rate yet.
IIRC if you flash the MIDIBOX sid firmware file it is set to work with a 2 line character display. And if you flash the mb-6582 firmware it is set to work with a 4 line character display. This is way of getting around having to edit code. if you want to code it yourself reference this page, and scroll down: http://wiki.midibox.org/doku.php?id=lcd The crystal fonts displays should provide better constrast and viewing angles to el cheapo lcd displays. As for wiring Im pretty sure Ive my displays wired up for 4-bit, just try that first and if it works great! I wouldnt hesitate any further in ordering and installing a display.
MB-6582 board set availability (possible bulk order?)
Smithy replied to urtzurd's topic in MIDIbox SID
Just had a look on the MIDIbox shop today and the MB-6582 board sets are back in stock! :) As welll as Core STM32F4 boards and kit, and MIDI I/O boards and kit. -
Awesome, thanks for your help! And so the joruney begins!
Yep I saw that post earlier in the thread. Thanks. Did you consult Wilba's .fpd file for his Schaeffer alluminium front panel for the Control Surface at any point? For MB Quad Genesis, I was going to consult Saurean's .fpd file for his existing aluminium panel (C, and try to translate it for use with a Ponoko case. i.e.the size and placement of the holes for leds, buttons, and the engravings, but not the holes for the screws obviously. Would that be a stupid way of doing it, and should I only reference the control surface PCB? Or maybe I could reference both? Thats my interrogation over, i have no experience with creating cases.
+1 for interest in the files. I would be interested in learning from them to build a Ponoko case for MIDIbox Quad Genesis.
SammichSID with MIOS v2.044 - no boot after update
Smithy replied to tassadar's topic in MIDIbox SID
Yes its the most recent stable version. Upload instrcutions are explained in this post: -
Can someone put up a video demo of the Step Trigger Function on the MIDIbox SEQ? We need more SEQ videos!
Midibox SEQ V4 Red LEDs constantly on problem?
Smithy replied to LongShoreDrift's topic in MIDIbox SEQ
Does this happen on every page of the sequencer? if so, i would open it up and start checking for shorts on the control surface, like bridged solder points. You could also reflow each solder joint to make sure, and be sure to clean the board with isoprpyl alcohol to remove any flux residue that may be causing th issue. -
Using a second chip sounds like the easiest solution, I dont want my request to distract from the important features you're working on. I would definitely be interested in a front panel board! Thanks. Really appreciate all the hard work youre putting into this!
Hi Sauren, I have a simple feauture request. I would love to be able to play my favourite VGM files live on keyboard, like a lead melody on one channel or whatever. Would it be possible to be able to press a button that mutes the sequence data for a channel during VGM playback, but not muting the channel itself, thus allowing you to play it with a keyboard yourself? I hope this is clear! How is the development going on with this project? Do you have free time in the new year to work on it? I'd love to see this get finished, its an awesome device. Was talking to Dya / Aaron about your device earlier and he would love to build one also!
Yeah, i cant seem to find any demo videos of the MIDIRex to see exactly how it works though. I'm going to have start my own thread on a dream looper / sequencer. I'm thinking of something like the Kaoss Pad 3 style interface, but for MIDI instead of audio. Essentially an encoder used to set the pattern length (which can be done live during playback) and a numeric LED display, (or LCD Display) indicating the length of the pattern. There could also be an option to manually stop / end the pattern by pressing a button, like the Boss RC-505 and have it automatically trim the length based on the MIDI data. I seriously need to get this out of my head, even if no one develops it! I find the fact you have to pre-initialise tracks on the MB-SEQ a bit of a short coming, then again I don't have one to critique! Im sure it makes up for it in the amount of features packed in.
I guess a redeveloped SEQ with an emphasis on Live Looping is out of the question then! ;) I think we need to recruit / hire more developers who don't mind working for free!
in MIOS Studio? MIOS Studio is for uploading the firmware to MIDIbox SID, asfaik it never had a wavetable sequencer built in to it! :) Someone correct me if I'm wrong! Your best bet is using Rutgers editor.
sammichsid - any way to create/edit SID files or extract their sounds?
Smithy replied to cuca's topic in MIDIbox SID
I'm actually stoked with how Sauraen's MIDIbox Genesis project can support vgm files for playing back sequences or ripping instruments. I even purchased the FMDrive VST tonight which supports VGM import also, i cant wait to play classic Sega tracks with the real / emulated hardware. -
Have a look at Rutger's Java based editor for MIDIbox SID. The wavetable implementation is complete: http://www.ucapps.de/midibox_sid/v2_editor/MBSIDV2_Editor_v0_5.zip
There was a SID sound extractor created for the older HardSID PCI Cards by a guy called Ted Nilsen, called HardSID Ripper. You can download an .avi clip of it in action from his site, but you cannot download the tool itself: http://www.tednilsen.com/index.html#hSIDRipper I actually contacted the guy on facebook a good while back asking if he would be interested in sharing the source code for the SID communities, which would not just benefit us, but users of HardSID4u and even the SIDStation. But he just replied with "let me get back to you on that" and havent heard from him since which is a shame! Also, theres no telling now how well it performs across all SID files, he only shows 2 Rob Hubbard SID which would have a similar routine, it may not perform so well with other artists routines. Still though, its a real shame the author of the hardware is going to let it die considering the effort that went into developing it. -
Thanks a lot for sharing your work Mongrol. It will be awesome for the community to have a ready to order and cheaper option for a case!
Excellent eye candy Antichambre! Claire I'm looking forward to watch your idea develop, will be keeping a close eye. The Monome Arc is a thing of beauty, as used by one of my favourite electronic music artists James Holden:
Excellent work Andy! I personally find the dark -> one bright colour the most "readable" and logical for unipolar values i.e. 0% -> 100% For bipolar values I think: Left bright colour -> centre dark <- right birght colour would be the most readable and logical. Its great that we can change the script to suit our individual needs.
[success] Project: MidiBox SEQ V4 with Standalone LaunchPad Pro as BLM
Smithy replied to sylwester's topic in MIDIbox SEQ
Congratulations Sylwester! This will be an excellent tool for the MIDIbox community. -
As far as I can see the LPC 17 Core PCB is not available to buy anymore from Smash TV's and Mikes Midibox shops but you can still buy the newer CORE STM32F4 PCB and kit from SmashTV. http://midiboxshop.bigcartel.com/ Keep in mind you would need to purchase the STM32F407G-DISC1 evaluation board externally. That would be the easiest way to proceed. You should always make sure all components are available to buy (such as the PCB) before ordering anything, it can save cost in the long run. :)
