1,279 -
71
Everything posted by Phatline
Various C64 and MIDIbox parts - should I sell or trash?
Phatline replied to pingosimon's topic in MIDIbox SID
your in US... so nothting for me.... I would keep the C64s Keycaps, there are people who wants them - not specially here... DIN DOUT always good for a quick prototyp, the PSUs also usefull. -
Hi, i am currently finishing the TPD-Displays PCBs, and i write a Test App/or my first skeleton-UI to use it. Its all clear so far, i can print single digits, i know the pattern, the pinout..... i want to print for example: float BPM = 128.5; // for Example for Digit 1 2 8 5 --- As BPM Display but i stuck by Divididing the BPM Value into single Integers, by searching in internet i found: int i = BPM*10; // Elemenate FLOAT Digit! static char buf[4]; sprintf(buf, "%05.2f", i); // split it into CHARs but that dont work at all... (print "0" on the first digits, the others are OFF) i later print the "buf[x]" value to my Digit --- that works fine, when initalize "TPD_SEG" by hand with iniatl values, but not when filled with above code! // Transcode To Shiftregister-Friendly Array static u8 x=0; for (x=0; x<4; x++) { // 7 Segment PINOUT // [6] // [1] [5] // [0] // [2] [4] // [3] [7] // switch (buf[x]) { case 0: TPD_SEG[x][0] = 0; TPD_SEG[x][1] = 1; TPD_SEG[x][2] = 1; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 1: TPD_SEG[x][0] = 0; TPD_SEG[x][1] = 0; TPD_SEG[x][2] = 0; TPD_SEG[x][3] = 0; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 0; TPD_SEG[x][7] = 0; break; case 2: TPD_SEG[x][0] = 1; TPD_SEG[x][1] = 0; TPD_SEG[x][2] = 1; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 0; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 3: TPD_SEG[x][0] = 1; TPD_SEG[x][1] = 0; TPD_SEG[x][2] = 0; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 4: TPD_SEG[x][0] = 0; TPD_SEG[x][1] = 1; TPD_SEG[x][2] = 0; TPD_SEG[x][3] = 0; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 0; TPD_SEG[x][7] = 0; break; case 5: TPD_SEG[x][0] = 1; TPD_SEG[x][1] = 1; TPD_SEG[x][2] = 0; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 0; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 6: TPD_SEG[x][0] = 1; TPD_SEG[x][1] = 1; TPD_SEG[x][2] = 1; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 0; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 7: TPD_SEG[x][0] = 0; TPD_SEG[x][1] = 0; TPD_SEG[x][2] = 0; TPD_SEG[x][3] = 0; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 8: TPD_SEG[x][0] = 1; TPD_SEG[x][1] = 1; TPD_SEG[x][2] = 1; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; case 9: TPD_SEG[x][0] = 1; TPD_SEG[x][1] = 1; TPD_SEG[x][2] = 0; TPD_SEG[x][3] = 1; TPD_SEG[x][4] = 1; TPD_SEG[x][5] = 1; TPD_SEG[x][6] = 1; TPD_SEG[x][7] = 0; break; } }
2 left...
I have 3 TIA Cartridge PCBs, pay me the postage (AUSTRIA) - and i give it away for free: for info see here: http://wiki.midibox.org/doku.php?id=midibox_tia#the_midibox_tia_cartridge_version What not includet is: the 24LC512 aka "Bankstick", the 7805 aka "Voltage Regulator", the TIA aka "Soundchip", the 6N138 aka "Optocoppler". the 24LC512 to solder is not for Beginners! the Microcontroller is Preprogrammed with MIOS.
mb909hex.zip STM32F4 and LPC17 build.... i got some warnings when building LPC17 --- so try it out.
do you need it for lpc17 or STM32F4 board? (ask because the tread was started for the other way round...)
i cant download the Gitubfiles (dont see a download button, and i am a offline coder...)... so i can take the one i have on harddisc - it is from 23.OCT 2018 (dont know if they are the same)--- or you show me how to download it...
-so lpc or stm32F4?
send me the source-files (or give me a link), and i compile it... (but dont ask me about the firmware, didnot used it, nor i was involved in it...)
LRE 4x1 breakable RGB LED-Ring/Rotary-Encoder PCB bulk order
Phatline replied to weasel's topic in Bulk Orders
Question: at the end, what is the performance of this RGB-Ledrings - in sence of RAM, CPU, and so on... I imagine a simple midi-controller app, will do fine, BUT: i am asking, since most my applications are on the limits on the Microcontroller (mostly ram, sometimes CPU, > sequencers, synths), is this done by CCRAM now, is it the same perfomance like using H595 Registers and some single Color LEDs, some kind of background task? or is this heavy load, and i should forget the last 3 Pages i read...? If i have already a APP that uses 90% or more RAM (for example) will force that to NOT boot anymore? (i have read the last 3 pages) thx for sharing your experiance -
handle multiple Mididevices (up to 16) Thrubox? Merge? M16?...
Phatline replied to Phatline's topic in Design Concepts
Ah... i thought they have to be inverted back, thinking of the signal is 180° "inverted" and has to be "inverted again"... (yes Midibox cores...) Good to know that the ID will manage the Sysex "Channel"! -
i need to handle up to 16 (MIOS32) Devices, The OUT >>> Thrubox is the simple thing (i think), is that Shematic correct? (ignore the boxes on the rightside, these are Shroudet Pinheaders to cable my devices with Ribboncables...since that is cheaper then the DIN-Thing) I know there will be a M16-Module, but i think for my task it is a bit overkill (maybe on price...) but what is when i have 16 MIDI-IN to handle, merge isnt possible or?, or is it possible to adress 16 MidiinPorts on a STM32F4? else it will be M16 in the end.... background: I need to copy/route Patches (arreys of Data) from one Device to the other. (a recordet Envelope, Size off [4][4096]), dont really know at the moment how to achive that (Sysex?) there is one Remote Device, and 16 Slaves.... - so the data should be sent from one Slave to the Remote Device, and from the Remote Device there it will be sent to one of the other Slaves.... (they share the same PSU) ...CV1...
i renamed the title...treat thread thanks! English: mounting-block/cube , cube standoff German: Gewindeblock or Montageblock or better Leiterplatten-Montageblock (because Montageblock is used for Water-Installation-"Montageblocks" too) buerklin (29,75 € incl VAT, excl Shipping) ettinger (52,44 € incl VAT, excl Shipping) a bit strange that Reichelt/Mouser doesnt have it, they all have such Nylon Variants: https://www.reichelt.com/de/en/mounting-block-m3-16-mm-natural-rnd-610-00209-p254065.html?r=1
dipCoreF4 and dipBoardF4, a compact Core.
Phatline replied to Antichambre's topic in Design Concepts
Yes need it for a MCP6002 Rail.... is the jumper on the BOTTOM of the Dipcore? -
i made PCB for Pick and Place Service... and updatet the Wiki: (now waiting for the boards to come) clock2audio2clock
- 11 replies
- phatline
- audio to clock
- (and 9 more)
ok then i take J16 RC2 (PA4) and J16 RC1 (PC4) which are used for SD-Card - which i dont need here. so i gues MIOS32_DONT_USE_SDCARD ? @ Type DEF - is this done like on J10 for example: MIOS32_BOARD_J10_PinInit(0, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); MIOS32_BOARD_J10_PinSet (0, 1); for me Clear how to make it with J5 and J10 >>> MIOS32_BOARD_J16_PinInit(0, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); ??? thx -
i made a nother design with your Dipcore as brain (clock2audio2clock) I need one more LED in this shematic: every pin which is no connected (yellow cross) - i dont need - so these are possible for LED. any possible? thx 4 help - mike -
CV1 - ControlVoltage-ENV, LFO, MSQ and Sampler
Phatline replied to Phatline's topic in MIDIbox User Projects
started a wiki...well a lot off todoos... http://wiki.midibox.org/doku.php?id=cv1 -
currently working on a eurorack version - with DIPCORE as a brain... will be modular in a midibox of way ;) plan is to use for every filter, or amp or efx or mixer.... to use one off this "motherboards", to do basic stuff like "lfo, env1 env2, motionsequencer, cv mixing" - and then for every filter or whatever to make a decided "beside panel" ( cv-matrix, or simple encoders with displays to show and save the values --- memory modular...) -
as far i understand you take CORE32 connect that 16x16 FPGA Thingi - and you have very fast 16x16 Midi I/Os with large FIFO-Buffers - that are accessable from MIOS32-Code - your APP could be a router or a sequencer that dumps out AAALOOOT of notes - or whatever you make out off the MIOS32 (C). but maybe @Antichambre want to enlighten you ;)
may look @ http://wiki.midibox.org/doku.php?id=m16 will come in future, not released yet - ask antichembre - for infos
ok here is the kicad library for the V2C dipCoreF4-V2c-kicad.zip (as 3D Modell i took a IC-Socket + a Dip40 IC on it...)
