1,285 -
72
Everything posted by Phatline
interested in stm32f4 and discovery.
interested in tms32f4 and 2 midi io . rest i dont need.
pcb arrive, soldered 4 off them (12 channels) - the 4 others i make a nother time. (24ch in total) the display drivers from Andy work great again! the midibox code is working, the max for live patches too. (at least for this state i am happy to get automaticly the Channels names, and the Macronames!!! hell yeah!)
Lets get started... Goal is a midicontroller for Ableton live, at the beginning as simple midicontroller, maybe later to transfair Labels via max4Live to the controller... it will not a midibox-ng script, it will be a own program based on the MIOS-platform. Hardware first, i designed a 6xSSD1306 + 9 Encoder Board, that is scaleable --- i will use 8-10 off it, its documented here (incl gerbers): http://wiki.midibox.org/daw-encoder-display i already have the Motorfaders and the ready soldered and flashed mf-ng boards, i will controll them with a stm32F4 board... which also handles the encoders and displays. in order to drive the displays stable, i use latigid-ons display driver board. - this is also the offical discuss topic for this project (which is linked in the wiki)
dipCoreF4 and dipBoardF4, a compact Core.
Phatline replied to Antichambre's topic in Design Concepts
i guess not the pyboard uses a 12Mhz external crystal? and Mios32 needs? look at the Pinout: http://wiki.midibox.org/lib/exe/fetch.php?media=antichambre:pinout_compare_chart2.png a quick look at for example the SD-Card Pins - of the pyboard and on Dipcore or Discovery stm32F407VG - says that the use other GPIO to do things... So yes you may flash that pyboard, but the Mhz might not be right (aka need to replace the oscillator) So yes you might run MIOS afterwards... but you cant use for example the onboard SD-Card - because it is wired to other pins... you have to DO the work that antichambre did (change the GPIO ports in MIOS, make a new toolchain, and that is a Job for someone who knows what he does - i would be very happy if i could do that - or someone introduce that skill to me- but i dont have any glue about that) -
i am on work the last years, on my own midibox CV- project... since i am a one man show, and there are a lot of projects running in paralell - and money is aviable only all "holy times"... it is not finished, and will not be in near future, but it will be in far future, since it is a core thing in my setup. (since i am on the way to modular...) http://wiki.midibox.org/doku.php?id=cv1 it has not much to do with a NG, or MB-CV2... but it is a CV-Envelope Generator, Recorder and Looper, LFO, and Mixer, and the future goel is to have one UI that remotes a lot of Core-Modules which are connected to independend Midibox-AOUT-Modules, so you could use One to build up a complete midified (so you can save and load presets) Analog-Synthesizer - a drumsynth for example, and multiply that by for example by 8 so you have a 8part Drumsynth with one UI - so you save space in your eurorack... how ever not finished - if interestd follow this topic:
- 40 replies
- MBCV
- illuminated encoders
(and 1 more)
Tagged with:
@RIO linker? this is not a software swich/link... its a hardwareswitch, and if he had that switch in the firstcase, he might have solved the problem already. Since he was talking about a new SD-Card, and of corrupted Files, i thought there is maybe no hardware-config file (or 0kb file) on the new card. --- later on he posted a picture of the SD-Cards filestructure... and yes i now see there is a 22kb File on it > so yes he dont need the Hardwarefile because there is one - congrats! wilba: http://wiki.midibox.org/doku.php?id=wilba_mb_seq&s[]=wilba
" you may also need to put the hardware config file on the root of your new sd-card: i guess its a wilba without track-position LED-Matrix? then this is the hdwg-file: /midibox_seq_v4_096/hwcfg/wilba/MBSEQ_HW.V4 (is in the zipped firmware) " i already wrote where it is (read! and take it serios), it seems that you dont have a Wilba-Interface, looks like a standard DIY-Interface? i would first try to go into bootload mode via.: http://wiki.midibox.org/doku.php?id=home:mbhp:module:bootloader-switch build this switch, set the switch to bootload mode, reboot the core, then open mios studio, upload new SEQV4 code.
ok i am in austria... so maybe a other one?
LoopA V2 Introduction, Features & Support Thread
Phatline replied to Hawkeye's topic in MIDIbox User Projects
in a eurorack: -
where you located?
Euro Midi IO - with 3.5Jacks A-B-Selecter + Thru
Phatline replied to Phatline's topic in Design Concepts
I tryd this Variant for Midi-OUT Activity LEDs... as it works with NoteON-OFF Messages, it comes to its limits when transfairing high datarate - like midiclock. The steady Charge and discharge of C5, messes up the Datasignal, so it cant be used. Since i already used all Pins of 74HC14, i now need a second HC14, or some other Buffercircuit (for 2x Midi-OUT Activity LED) - any Ideas for that are welcome! -
quick update... i debugged Rev.A with a view Wires (and it works - almost), by doing this i made Rev.B - and updatet the wiki. For Rev. B i have to Cross J1 to J2, since i made a 1:1 Connection between this 2 Headers... - and that is not true... true would be: I2>I4, I4>I2, O2>O4... and so on -
yes they worked... and it looks very nice... i highly recommend latigid onś Display driver: http://wiki.midibox.org/doku.php?id=display_driver i tryed the multiplexing via J10B with a DoutX4 but i had walking lines here and there, so i took the display driver and it just works! This is the pinout from the display driver J1-J8 to connect 4 screens aka 2 PCBs to it. i made a video (build) - but i want to write some code first, so i have unit which i can work with it (to have a video jam for it...) so you can order at least the PCBs - this take some time... in the meantime i change the frontpanel: i would remove the mounting holes for the LRE8x2 first...
daily... have tok reload the side then it works
MSQ CC LRE - CC-Motion-Sequencer and Storage
Phatline replied to Phatline's topic in MIDIbox User Projects
currently working on V2 (now with Displays), wiki and programming currently on development.... http://wiki.midibox.org/doku.php?id=msq-cc-lre-v2 much to programm... but it combines the last modules i designed - to get it into Eurorack...- 4 replies
- controlchange bank
- controlchange
(and 3 more)
Tagged with:
http://wiki.midibox.org/doku.php?id=euro-aout-ng-connector-board A Eurorack Connector Board and Frontpanel for the classic Aout-NG-PCB
u use custom code? or ng script? I dont have any knowledge of NG-Script nor offical apps... i program my own based on MIOS. in my memory.... to get 8 additional only this is needet: (used in my filterbox - in my app.c in the init routine on startup....) // Set GPIO @ J10A for (x=0; x<16; ++x) { // Turn on all PINS --- activate Bypass Relais ssm2044 MIOS32_BOARD_J10_PinInit(x, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); MIOS32_BOARD_J10_PinSet (x, 1); } // LCD xLCDSemaphore = xSemaphoreCreateRecursiveMutex(); // create Mutex for LCD access MIOS32_LCD_DeviceSet(0); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(1); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(2); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(3); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(4); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(5); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(6); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(7); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(8); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(9); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(10); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(11); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(12); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(13); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(14); MIOS32_LCD_Init(0); MIOS32_LCD_DeviceSet(15); MIOS32_LCD_Init(0); exotics: example triggermatrix has 9 SSD1306 Displays so i needet one more the J15 can deliever the "Menue-LCD" ... my solution was to adapt the app_lcd.c (and .h) and includet it locally (in my project folder and changed the build path for it...) Since i did not know what was going on, i reduce the code as much i can (deletet all not "universal" LCD code, all Rotated-Display - and non SSD1306 variants) - so i had the change to understand the "need to know" - i cant remember why i did it that way...dont ask - but maybe it helps // LCD driver for 9x SSD1306 // MIOS32_LCD environment variable set to "universal" // reduced by Michael Sigl #include <mios32.h> #include <glcd_font.h> #include <string.h> #include "app_lcd.h" static unsigned long long display_available = 0; static u8 prev_glcd_selection = 0xfe; // the previous mios32_lcd_device, 0xff: all CS were activated, 0xfe: will force the update // pin initialisation >> Additonal CS-Line for the One MENUE-LCD inline static s32 APP_LCD_ExtPort_Init(void) { MIOS32_BOARD_J10_PinInit(8, MIOS32_BOARD_PIN_MODE_OUTPUT_PP); return 0; } ///////////////////////////////////////////////////////////////////////////// // Initializes the CS pins for GLCDs with serial port // - 8 CS lines are available at J15 // - additional lines are available J10 ///////////////////////////////////////////////////////////////////////////// static s32 APP_LCD_SERGLCD_CS_Init(void) { APP_LCD_ExtPort_Init(); int num_lcds = mios32_lcd_parameters.num_x * mios32_lcd_parameters.num_y; display_available |= (1 << num_lcds)-1; return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Sets the CS line of a serial GLCDs depending on mios32_lcd_device // if "all" flag is set, commands are sent to all segments ///////////////////////////////////////////////////////////////////////////// static s32 APP_LCD_SERGLCD_CS_Set(u8 value, u8 all) { // Note: assume that CS lines are low-active! if( all ) { if( prev_glcd_selection != 0xff ) { prev_glcd_selection = 0xff; MIOS32_BOARD_J15_DataSet(value ? 0x00 : 0xff); MIOS32_BOARD_J10_PinSet(8, value ? 0 : 1); } } else { if( prev_glcd_selection != mios32_lcd_device ) { prev_glcd_selection = mios32_lcd_device; u32 mask = value ? ~(1 << mios32_lcd_device) : 0xffffffff; MIOS32_BOARD_J15_DataSet(mask); MIOS32_BOARD_J10_PinSet(8, (mask >> (8)) & 1); } } return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Initializes application specific LCD driver ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Init(u32 mode) { if( mios32_lcd_device >= 9 ) { return -2; } // unsupported LCD device number // enable display by default display_available |= (1ULL << mios32_lcd_device); // the OLED works at 3.3V, level shifting (and open drain mode) not required if( MIOS32_BOARD_J15_PortInit(0) < 0 ) { return -2; } // failed to initialize J15 display_available |= 0xff; APP_LCD_SERGLCD_CS_Init(); // will also enhance display_available depending on total number of LCDs // wait 500 mS to ensure that the reset is released { int i; for(i=0; i<500; ++i) MIOS32_DELAY_Wait_uS(1000); } // initialize LCDs APP_LCD_Cmd(0xa8); // Set MUX Ratio APP_LCD_Cmd(0x3f); APP_LCD_Cmd(0xd3); // Set Display Offset APP_LCD_Cmd(0x00); APP_LCD_Cmd(0x40); // Set Display Start Line APP_LCD_Cmd(0xa1); // Set Segment re-map: rotated APP_LCD_Cmd(0xc8); // Set COM Output Scan Direction: rotated APP_LCD_Cmd(0xda); // Set COM Pins hardware configuration APP_LCD_Cmd(0x12); APP_LCD_Cmd(0x81); // Set Contrast Control APP_LCD_Cmd(0x7f); // middle APP_LCD_Cmd(0xa4); // Disable Entiere Display On APP_LCD_Cmd(0xa6); // Set Normal Display APP_LCD_Cmd(0xd5); // Set OSC Frequency APP_LCD_Cmd(0x80); APP_LCD_Cmd(0x8d); // Enable charge pump regulator APP_LCD_Cmd(0x14); APP_LCD_Cmd(0xaf); // Display On APP_LCD_Cmd(0x20); // Enable Page mode APP_LCD_Cmd(0x02); return (display_available & (1ULL << mios32_lcd_device)) ? 0 : -1; // return -1 if display not available } ///////////////////////////////////////////////////////////////////////////// // Sends data byte to LCD // IN: data byte in <data> // OUT: returns < 0 if display not available or timed out ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Data(u8 data) { // check if if display already has been disabled if( !(display_available & (1ULL << mios32_lcd_device)) ) { return -1; } // chip select and DC APP_LCD_SERGLCD_CS_Set(1, 0); MIOS32_BOARD_J15_RS_Set(1); // RS pin used to control DC // send data MIOS32_BOARD_J15_SerDataShift(data); // increment graphical cursor ++mios32_lcd_x; // if end of display segment reached: set X position of all segments to 0 if( (mios32_lcd_x % mios32_lcd_parameters.width) == 0 ) { APP_LCD_Cmd(0x00); // set X=0 APP_LCD_Cmd(0x10); } return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Sends command byte to LCD // IN: command byte in <cmd> ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Cmd(u8 cmd) { // check if if display already has been disabled if( !(display_available & (1ULL << mios32_lcd_device)) ) { return -1; } // select all LCDs APP_LCD_SERGLCD_CS_Set(1, 1); MIOS32_BOARD_J15_RS_Set(0); // RS pin used to control DC MIOS32_BOARD_J15_SerDataShift(cmd); return 0; } ///////////////////////////////////////////////////////////////////////////// // Clear Screen // IN: - // OUT: returns < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Clear(void) { s32 error = 0; u8 x, y; // use default font MIOS32_LCD_FontInit((u8 *)GLCD_FONT_NORMAL); // send data for(y=0; y<mios32_lcd_parameters.height/8; ++y) { error |= MIOS32_LCD_CursorSet(0, y); // select all LCDs APP_LCD_SERGLCD_CS_Set(1, 1); MIOS32_BOARD_J15_RS_Set(1); // RS pin used to control DC for(x=0; x<mios32_lcd_parameters.width; ++x) MIOS32_BOARD_J15_SerDataShift(0x00); } // set X=0, Y=0 error |= MIOS32_LCD_CursorSet(0, 0); return error; } ///////////////////////////////////////////////////////////////////////////// // Sets cursor to given position ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_CursorSet(u16 column, u16 line) { return APP_LCD_GCursorSet(mios32_lcd_x, mios32_lcd_y); } ///////////////////////////////////////////////////////////////////////////// // Sets graphical cursor to given position ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_GCursorSet(u16 x, u16 y) { s32 error = 0; // set X position error |= APP_LCD_Cmd(0x00 | (x & 0xf)); error |= APP_LCD_Cmd(0x10 | ((x>>4) & 0xf)); // set Y position error |= APP_LCD_Cmd(0xb0 | ((y>>3) & 7)); return error; } ///////////////////////////////////////////////////////////////////////////// // Initializes a single special character // only for Character-LCDs ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_SpecialCharInit(u8 num, u8 table[8]) { return -3; }// not supported ///////////////////////////////////////////////////////////////////////////// // Sets the background colour // Only relevant for colour GLCDs ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_BColourSet(u32 rgb) { return -3; } // not supported ///////////////////////////////////////////////////////////////////////////// // Sets the foreground colour // Only relevant for colour GLCDs ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_FColourSet(u32 rgb) { return -3; } // not supported ///////////////////////////////////////////////////////////////////////////// // Sets a pixel in the bitmap // IN: bitmap, x/y position and colour value (value range depends on APP_LCD_COLOUR_DEPTH) ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_BitmapPixelSet(mios32_lcd_bitmap_t bitmap, u16 x, u16 y, u32 colour) { if( x >= bitmap.width || y >= bitmap.height ) return -1; // pixel is outside bitmap // all GLCDs support the same bitmap scrambling u8 *pixel = (u8 *)&bitmap.memory[bitmap.line_offset*(y / 8) + x]; u8 mask = 1 << (y % 8); *pixel &= ~mask; if( colour ) *pixel |= mask; return -3; // not supported } ///////////////////////////////////////////////////////////////////////////// // Transfers a Bitmap within given boundaries to the LCD // IN: bitmap ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_BitmapPrint(mios32_lcd_bitmap_t bitmap) { // abort if max. width reached if( mios32_lcd_x >= mios32_lcd_parameters.width ) { return -2; } // all GLCDs support the same bitmap scrambling int line; int y_lines = (bitmap.height >> 3); u16 initial_x = mios32_lcd_x; u16 initial_y = mios32_lcd_y; for(line=0; line<y_lines; ++line) { // calculate pointer to bitmap line u8 *memory_ptr = bitmap.memory + line * bitmap.line_offset; // set graphical cursor after second line has reached if( line > 0 ) { mios32_lcd_x = initial_x; mios32_lcd_y += 8; APP_LCD_GCursorSet(mios32_lcd_x, mios32_lcd_y); } // transfer character int x; for(x=0; x<bitmap.width; ++x) APP_LCD_Data(*memory_ptr++); } // fix graphical cursor if more than one line has been print if( y_lines >= 1 ) { mios32_lcd_y = initial_y; APP_LCD_GCursorSet(mios32_lcd_x, mios32_lcd_y); } return 0; // no error } another example where i had to define CS pins, because i used Dipcore - with limitaded IO: /* * fixed Hardcoded for 4x >>> SSD1306! > CV1 Project > DIPCORE F4! * ========================================================================== * Changed Version - Michael Sigl * ========================================================================== */ #include <mios32.h> #include "glcd_font.h" #include <string.h> #include "app_lcd.h" ///////////////////////////////////////////////////////////////////////////// // pin mapping ///////////////////////////////////////////////////////////////////////////// #define SCLK_PORT GPIOD #define SCLK_PIN GPIO_Pin_6 #define SER_PORT GPIOD // used as DC (data/command select) for serial interfaces #define SER_PIN GPIO_Pin_2 #define E1_PORT GPIOC // used to control SCLK of serial interfaces #define E1_PIN GPIO_Pin_1 #define E2_PORT GPIOC #define E2_PIN GPIO_Pin_9 #define RW_PORT GPIOC // used to control data output of serial interfaces #define RW_PIN GPIO_Pin_12 #define CS1_PORT GPIOB // used to control SCLK of serial interfaces #define CS1_PIN GPIO_Pin_12 #define CS2_PORT GPIOC #define CS2_PIN GPIO_Pin_0 #define CS3_PORT GPIOC // LED 0 - Extra CS-Line on Dipcore #define CS3_PIN GPIO_Pin_6 #define CS4_PORT GPIOC // LED 1 - Extra CS-Line on Dipcore #define CS4_PIN GPIO_Pin_7 // you could define here more CS PINS! but be sure to deactivate the "Orginal" function of it... // following macros simplify the access to the pins #define PIN_SER(b) MIOS32_SYS_STM_PINSET(SER_PORT, SER_PIN, b) #define PIN_E1(b) MIOS32_SYS_STM_PINSET(E1_PORT, E1_PIN, b) #define PIN_RW(b) MIOS32_SYS_STM_PINSET(RW_PORT, RW_PIN, b) #define PIN_CS1(b) MIOS32_SYS_STM_PINSET(CS1_PORT, CS1_PIN, b) #define PIN_CS2(b) MIOS32_SYS_STM_PINSET(CS2_PORT, CS2_PIN, b) #define PIN_CS3(b) MIOS32_SYS_STM_PINSET(CS3_PORT, CS3_PIN, b) #define PIN_CS4(b) MIOS32_SYS_STM_PINSET(CS4_PORT, CS4_PIN, b) // you could define here more CS PINS! but be sure to deactivate the "Orginal" function of it... #define PIN_SERLCD_DATAOUT(b) MIOS32_SYS_STM_PINSET(RW_PORT, RW_PIN, b) #define PIN_SERLCD_SCLK_0 { MIOS32_SYS_STM_PINSET_0(E1_PORT, E1_PIN); MIOS32_SYS_STM_PINSET_0(E2_PORT, E2_PIN); } #define PIN_SERLCD_SCLK_1 { MIOS32_SYS_STM_PINSET_1(E1_PORT, E1_PIN); MIOS32_SYS_STM_PINSET_1(E2_PORT, E2_PIN); } /// ////////////////////////////////////////////////////////////////////////////////////////////////////////////////// ////////////////////////////////////////////////////////////////////////// // PINS for Additonl LCD 4 & 5 DIPCORE if needet // MIOS32_SYS_STM_PINSET(GPIOC, GPIO_Pin_13, data & 1); // J10B.D8 = ser // MIOS32_SYS_STM_PINSET_0(GPIOC, GPIO_Pin_14); // J10B.D9 = 0 (Clk) ////////////////////////////////////////////////////////////////////////// // /////////////////////////////////////////////////////////////////////////////////////////////////////////// // Initializes the Ports/Pins (aka J15) (which was once J15 in MIOS32_BOARD.c but now integrated in this Program directly) /////////////////////////////////////////////////////////////////////////////////////////////////////////// s32 PortInit(u32 mode) { // configure push-pull pins GPIO_InitTypeDef GPIO_InitStructure; GPIO_StructInit(&GPIO_InitStructure); GPIO_InitStructure.GPIO_Mode = GPIO_Mode_OUT; GPIO_InitStructure.GPIO_OType = GPIO_OType_PP; GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz; // 25 is weak driver to reduce transients GPIO_InitStructure.GPIO_Pin = CS1_PIN; GPIO_Init(CS1_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = CS2_PIN; GPIO_Init(CS2_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = CS3_PIN; // Extra CS-Lines GPIO_Init(CS3_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = CS4_PIN; // Extra CS-Lines GPIO_Init(CS4_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = SER_PIN; GPIO_Init(SER_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = E1_PIN; GPIO_Init(E1_PORT, &GPIO_InitStructure); GPIO_InitStructure.GPIO_Pin = RW_PIN; GPIO_Init(RW_PORT, &GPIO_InitStructure); // Activate all CS Lines PIN_CS1(0); // J15 CS1 Line PIN_CS2(0); // J15 CS2 Line PIN_CS3(0); // CS-Extra Line PIN_CS4(0); // CS-Extra Line PIN_RW(0); PIN_E1(0); return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // shift an 8bit data value to LCDs with serial interface //! (SCLK connected to J15A:E, Data line connected to J15A:RW) //! \param[in] data the 8bit value ///////////////////////////////////////////////////////////////////////////// s32 SerDataShift(u8 data) { MIOS32_IRQ_Disable(); int i; for(i=0; i<8; ++i, data <<= 1) { PIN_SERLCD_DATAOUT(data & 0x80); PIN_SERLCD_SCLK_0; PIN_SERLCD_SCLK_0; PIN_SERLCD_SCLK_1; PIN_SERLCD_SCLK_1; } PIN_SERLCD_SCLK_0; PIN_SERLCD_DATAOUT(0); MIOS32_IRQ_Enable(); return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // to set the RS pin // \param[in] rs state of the RS pin ///////////////////////////////////////////////////////////////////////////// s32 RS_Set(u8 rs) { PIN_SER(rs); return 0; } ///////////////////////////////////////////////////////////////////////////// // Select a LCD / Select CS LINE ///////////////////////////////////////////////////////////////////////////// static s32 APP_LCD_SERGLCD_CS_Set(u8 value, u8 all){ // Activate ALL Screens @ once if( all ) { PIN_CS1(0); PIN_CS2(0); PIN_CS3(0); PIN_CS4(0); } else { switch (mios32_lcd_device) { case 0: PIN_CS1(0); // the active Screen PIN_CS2(1); // deactivate PIN_CS3(1); // deactivate PIN_CS4(1); break; // deactivate case 1: PIN_CS1(1); // deactivate PIN_CS2(0); // the active Screen PIN_CS3(1); // deactivate PIN_CS4(1); break; // deactivate case 2: PIN_CS1(1); // deactivate PIN_CS2(1); // deactivate PIN_CS3(0); // the active Screen PIN_CS4(1); break; // deactivate case 3: PIN_CS1(1); // deactivate PIN_CS2(1); // deactivate PIN_CS3(1); // deactivate PIN_CS4(0); break; // the active Screen break; } } return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Initializes LCD driver ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Init(u32 mode) { PortInit(0); // Init the Ports & Pins (aka J15 + extra CS-Pins) // wait 500 mS to ensure that the reset is released { int i; for(i=0; i<500; ++i) MIOS32_DELAY_Wait_uS(1000); } // initialize LCDs APP_LCD_Cmd(0xa8); // Set MUX Ratio APP_LCD_Cmd(0x3f); APP_LCD_Cmd(0xd3); // Set Display Offset APP_LCD_Cmd(0x00); APP_LCD_Cmd(0x40); // Set Display Start Line APP_LCD_Cmd(0xa1); // Set Segment re-map: rotated APP_LCD_Cmd(0xc8); // Set COM Output Scan Direction: rotated APP_LCD_Cmd(0xda); // Set COM Pins hardware configuration APP_LCD_Cmd(0x12); APP_LCD_Cmd(0x81); // Set Contrast Control APP_LCD_Cmd(0x7f); // middle APP_LCD_Cmd(0xa4); // Disable Entiere Display On APP_LCD_Cmd(0xa6); // Set Normal Display APP_LCD_Cmd(0xd5); // Set OSC Frequency APP_LCD_Cmd(0x80); APP_LCD_Cmd(0x8d); // Enable charge pump regulator APP_LCD_Cmd(0x14); APP_LCD_Cmd(0xaf); // Display On APP_LCD_Cmd(0x20); // Enable Page mode APP_LCD_Cmd(0x02); return 0; } ///////////////////////////////////////////////////////////////////////////// // Sends data byte to LCD // IN: data byte in <data> ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Data(u8 data){ APP_LCD_SERGLCD_CS_Set(1, 0); // RS pin used to control DC RS_Set(1); //1: Data at D7 is treated as DISPLAY data, // written to Graphic Display Ram (GDDRAM) //0: Data at D7:0 is transfaired to the command register - treated as command // send data SerDataShift(data); // increment graphical cursor ++mios32_lcd_x; // if end of display segment reached: set X position of all segments to 0 if( mios32_lcd_x >= 128 ) { APP_LCD_Cmd(0x00); // set X=0 APP_LCD_Cmd(0x10); } return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Sends data byte to LCD --- Specially for Solid Oscilloscope Waves // IN: data byte in <data> ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_SCOPE(u8 h, u8 v, u8 pix){ // h=x, v=y, pix is 0 or 1 to activate a single pixel APP_LCD_SERGLCD_CS_Set(1, 0); //mios32_lcd_x = h; //mios32_lcd_y = v; // RS pin used to control DC RS_Set(1); // send data SerDataShift(pix); // increment graphical cursor // ++mios32_lcd_x; // if end of display segment reached: set X position of all segments to 0 //if( (mios32_lcd_x % mios32_lcd_parameters.width) == 0 ) { APP_LCD_Cmd(0x00); // set X=0 //APP_LCD_Cmd(0x10); } return 0; // no error } ///////////////////////////////////////////////////////////////////////////// // Sends command byte to LCD // IN: command byte in <cmd> // OUT: returns < 0 if display not available or timed out ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Cmd(u8 cmd){ APP_LCD_SERGLCD_CS_Set(1, 1); // select all LCDs RS_Set(0); // RS pin used to control DC SerDataShift(cmd); return 0; } ///////////////////////////////////////////////////////////////////////////// // Clear Screen ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_Clear() { s32 error = 0; u8 x, y; // use default font MIOS32_LCD_FontInit((u8 *)GLCD_FONT_NORMAL); // select all LCDs APP_LCD_SERGLCD_CS_Set(1, 1); // send data for(y=0; y<mios32_lcd_parameters.height/8; ++y) { error |= MIOS32_LCD_CursorSet(0, y); RS_Set(1); // RS pin used to control DC for(x=0; x<mios32_lcd_parameters.width; ++x) SerDataShift(0x00); } // set X=0, Y=0 error |= MIOS32_LCD_CursorSet(0, 0); return 0; } ///////////////////////////////////////////////////////////////////////////// // Clear Screen --- Special Variant which clear only the current selected Screen ///////////////////////////////////////////////////////////////////////////// s32 LCD_Clear(void) { s32 error = 0; u8 x, y; // Select the actually Selected LCD ONLY! APP_LCD_SERGLCD_CS_Set(1, 0); // send data for(y=0; y<mios32_lcd_parameters.height/8; ++y) { error |= MIOS32_LCD_CursorSet(0, y); RS_Set(1); // RS pin used to control DC for(x=0; x<mios32_lcd_parameters.width; ++x) SerDataShift(0x00); } // set X=0, Y=0 error |= MIOS32_LCD_CursorSet(0, 0); return 0; } ///////////////////////////////////////////////////////////////////////////// // Sets cursor to given position // IN: <column> and <line> ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_CursorSet(u16 column, u16 line) { // mios32_lcd_x/y set by MIOS32_LCD_CursorSet() function return APP_LCD_GCursorSet(mios32_lcd_x, mios32_lcd_y); } ///////////////////////////////////////////////////////////////////////////// // Sets graphical cursor to given position // IN: <x> and <y> // OUT: returns < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_GCursorSet(u16 x, u16 y){ s32 error = 0; // set X position error |= APP_LCD_Cmd(0x00 | (x & 0xf)); error |= APP_LCD_Cmd(0x10 | ((x>>4) & 0xf)); // set Y position error |= APP_LCD_Cmd(0xb0 | ((y>>3) & 7)); return error; } ///////////////////////////////////////////////////////////////////////////// // Initializes a single special character // IN: character number (0-7) in <num>, pattern in <table[8]> // OUT: returns < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_SpecialCharInit(u8 num, u8 table[8]) { s32 i; // send character number APP_LCD_Cmd(((num&7)<<3) | 0x40); // send 8 data bytes for(i=0; i<8; ++i) if( APP_LCD_Data(table[i]) < 0 ) return -1; // error during sending character // set cursor to original position return APP_LCD_CursorSet(mios32_lcd_column, mios32_lcd_line); } ///////////////////////////////////////////////////////////////////////////// // Sets the background colour // Only relevant for colour GLCDs ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_BColourSet(u32 rgb) { return -3; }// not supported ///////////////////////////////////////////////////////////////////////////// // Sets the foreground colour // Only relevant for colour GLCDs ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_FColourSet(u32 rgb) { return -3; }// not supported ///////////////////////////////////////////////////////////////////////////// // Sets a pixel in the bitmap // IN: bitmap, x/y position and colour value (value range depends on APP_LCD_COLOUR_DEPTH) // OUT: returns < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_BitmapPixelSet(mios32_lcd_bitmap_t bitmap, u16 x, u16 y, u32 colour) { if( x >= bitmap.width || y >= bitmap.height ) return -1; // pixel is outside bitmap // all GLCDs support the same bitmap scrambling u8 *pixel = (u8 *)&bitmap.memory[bitmap.line_offset*(y / 8) + x]; u8 mask = 1 << (y % 8); *pixel &= ~mask; if( colour ) *pixel |= mask; return -3; // not supported } ///////////////////////////////////////////////////////////////////////////// // Transfers a Bitmap within given boundaries to the LCD // IN: bitmap // OUT: returns < 0 on errors ///////////////////////////////////////////////////////////////////////////// s32 APP_LCD_BitmapPrint(mios32_lcd_bitmap_t bitmap){ // abort if max. width reached if( mios32_lcd_x >= mios32_lcd_parameters.width ) return -2; // all GLCDs support the same bitmap scrambling int line; int y_lines = (bitmap.height >> 3); u16 initial_x = mios32_lcd_x; u16 initial_y = mios32_lcd_y; for(line=0; line<y_lines; ++line) { // calculate pointer to bitmap line u8 *memory_ptr = bitmap.memory + line * bitmap.line_offset; // set graphical cursor after second line has reached if( line > 0 ) { mios32_lcd_x = initial_x; mios32_lcd_y += 8; APP_LCD_GCursorSet(mios32_lcd_x, mios32_lcd_y); } // transfer character int x; for(x=0; x<bitmap.width; ++x) APP_LCD_Data(*memory_ptr++); } // fix graphical cursor if more than one line has been print if( y_lines >= 1 ) { mios32_lcd_y = initial_y; APP_LCD_GCursorSet(mios32_lcd_x, mios32_lcd_y); } return 0; // no error }
Compatibility Wilba control surface with Core407V
Phatline replied to Polykobol's topic in MIDIbox SEQ
ok kenn mich aus... das panel wird erst entworfen natürlich möglich ist so wie ich das sehe ist das einfach ein http://www.ucapps.de/mbhp_midi_io.html nur halt 2 auf einer platine die line driver von midiphy kannst auch verwenden (obwohl ich einen da hätte den ich nicht mehr brauche - weil ich zwei habe) vom midiphy core her weis i ned- müsste pin compatibel zum Discovery Board sein. - aber das orginal könntest auch von mir haben. http://www.ucapps.de/mbhp_core_stm32f4.html da wäre halt sd slot und usb gleich auf einem board... musst selber nachmessen was von der größe her eher in dein Wunschgehäuse und Anschluss Panel passt. @ gate: direkt aus dem gehäuse... ja entweder via Linedriver für extern - oder via DINX4 intern http://www.ucapps.de/mbhp_din.html oder du baust dir https://www.midiphy.com/en/shop-details/121/50/seq-v4-eurorack-modules-essential-kit-midiphy-seq-v4-eurorack-modular-midi-cv-interface direkt ins gehäuse. für CV eben auch das midiphy module, oder halt. http://www.midibox.org/dokuwiki/aout_ng und dann verkabeln zu buchsen ihrgendwo im gehäuse (da hät ich was daheim falls die auflösung für dich reicht) in beiden fällen brauchst halt dann im sequencer die +-12V um das CV von 3V raufzuskalieren zu verwendbaren werten... -
tirol... oberösterreich - ok englisch ist nicht dein ding - guad ich will doch nur die Anschlussblende sehen aka Backpanel diese Rückansicht z.B. ist für ein core stm32F4... und ist offensichtlich für 2x Midi IO Module geschaffen für diese ausführung hätte ich alles daheim, bis auf das zweite MIDI IO... -
nope that is a plastic case made by ponoko... so why you dont post the panel - else i am out! why you want to use the midiphy core? use the orginal core? I ask because i have booth at home the lpc17 core (need different packbanel) the stm32F4 core '(need different backpanel)... the orginal stm32F4 core use the same microcontroller on a different developement board - like the waveshare from midiphy... ... i too have the linedriver pcb... i have a whole midibox labor with assembled modules at home - but if you wont show the backpanel - i cant help you anyway...
