1,284 -
72
Everything posted by Phatline
and "midiphy" stand for?
agreee... so what we call it? miniCore32, 10x4CORE, RFcore(reduced formfactor)....-names based in formsize. or a name based on the limited/reduced ports- fundimentalCore, basisCore, baseCore... or a name as tributs based of the inital designer - XRcore . while x as variable for size . f for formfactor... or something with midi in it. since core is a common widely used name also in other genres... midicore (not the smallest not the tallest the medium.,. and of course midi as protocoll view) new thread with choosen corename then in design concepts again. i have some time left. and have interest and use of it. so what we call it... and start
@AntichambreC "could we help you to improve it?'" if you have ideas... i definitivly would be in for some "minimal boards" work in that trace wide and smd quarz changings and maybe microsd footprintchange. dont know how many bords also depends on the price of course (have not much clue about pick and place and the time for stuffing that machines...) i find it practicable when the IO connections are in one row specially j89 and the midi . to plug it into a small io (10x10 for example) so they dont cross the middle of ui where are matrices buttons or leds. what improves you thought?
and improved the design which I populated here. ? then files for the "improved" design. ? or the info: are any connector positions(xy) have changed thx mike
@FantomXR ? thx for info you are right, was late last night... maybe i only saw HiSpeed and... didnt see: download the files (if you have eagle) and see: Size V0: 98,5mm x 48,5mm ? Features, Legacy ports: see screenshot, (there is the SD-Slot Missing, since @FantomXR said, he changed something?... and for me it is NOT necessery, in this picture, because i need only the Pin-Headers for a Sandwitch- Footage-Kicad-Part to import.) PURPOSE: (by looking @ shematic) J8/9 SRIO (for normal shiftregisters) Midi A+B (+HiSpeed? )(need external Optocoppler), J30 Displays(need external HC595), Bootloader-Switch(for program-alphas...debug), onboard-Voltage-Regulator (5V input regulated to 3,3V), Micro-SD-Slot(flat on board), USB over Pinheader (no onboard-socket), USB-Power-Jumper J6+J7 - Pedals+Fader are a bit J19-ish (AOUT-SPI) but thru a MCP3208? used as: "for an AINSER64-like-analog-scanning" (connect there a AIN64? dont know) SWD-Header (to program BOOTLOADER into board by using for a example a Discovery-Board), Reset-Header ... @FantomXR are the Connectors and Mount Holes still the same in current Version?
na i think i cant use - i need midi a and b. you have only one midi port when looking at your shematic and board? it has 2 midiports yes!
hei. is the rest of layout the same as the files you released here? (specially the j89 10 11... and the mounting holes?) i ask because i would then project around this- to simple plug your core into my UI... i would then if i get it fit - need some of those cores. if you make a run how many is minimum. and what is priceing. do the place machine pick all smd parts on top? mike.
very cool! post the suiting sd card socket... and all other usefull expirience...
i overworked the whole thing... now the usb ports are free, and all connectors are on back-location OBSOLATE: (the design is finally done with dipCoreF4 as brain
- 27 replies
- cc-recorder
- controlchange looper
(and 1 more)
Tagged with:
i made a video with a demo song - to see its practicable use - and some explaination - and talk (englisch)
- 11 replies
- 1
- phatline
- audio to clock
- (and 9 more)
yes... cant really help, but want to see this to get real (want some)
LoopA V2 Introduction, Features & Support Thread
Phatline replied to Hawkeye's topic in MIDIbox User Projects
would be great such pre- loopa board(s), i would make a stop motion film for the built -like i did before on other midibox-gear... and it also would make fun to hack into code. greets mike -
hey.. would take 2 . any possibility to load the clips including the ones on disk via program change? and feedback that the clip is free and virgin? ... i think on some clip launch matrix from external ... in my case blm and triggermatrix.... so program change for songs. bank change for scenes and feedback(a cc state for example) would be enough. to use it in a grown midisetup for live sets. jam it in and use it in sets. mike -
dont know ask in the seq4+ thread... since except the prototypes there are no seq4+ ever built, i dont know the time which is running into building this. but since it is kit there are less time and postage in parts to source, i guess...
so i see only2 options... orginal mongbox...since i dont find the modified or the beast with matching case (ask him he has a few ideas) ... since heidenreich case is group buy...
ans if he ask for what fore then tell him stm32f4 + 2*midi io
yes but the frontpanel is just a graphic file (svg) (i think vector graphic) so there is material colour, (dont know look at the his building tread, he was using formular or ponoko? they have materials which you can choose) i am not into this case, but maybe you can choose the incraveing fill color (or maybe i have to fill it with hand - pain in the ass...), because it is vector, you could placei your logo, or band banner on it, what ever, artwork... could look on font styles (but i think they must get transleted to vector graphics...could be tricky)
if you are sure. you want that acrylic. i will order it... this weekend i am busy. could look tuesday on the files and get me the costs and get me informed about that case. until that you have time to look at the other possibilitys... and what can be done (artwork on the acrylic one) bye mike
yes i would, but doing the case later, is a bit tricky: because of the LEDs, theyshould have to set to the right length,so they are looking nicelyinto the panel... mine are a few millimentersnow above the pcb,maybe to short for some panels. desolder double sided pcbs is pain in the ass, special when you are new on soldering (hot air, or working with flux paste).... but ok, i could give you some new leds for "later" and mount the whole thing on a wood plate (the modules are not stacked see triggermatrix V1 like: http://wiki.midibox.org/doku.php?id=triggermatrix)-which also would take some time in account, without any panels... and you could do the rest on your own... later. the question is make it sense? not really. it maybe ends up that you never got a case... i already had this cas: http://wiki.midibox.org/lib/exe/detail.php?id=triggermatrix&media=phatline:tm-generic-cs.jpg
hard to say, take a look at this: did not see the price,havent the time to search for it http://niroke.blogspot.com/2017/07/an-unofficial-build-guide-for-midibox.html
thats julianf... and the price and panels which i calculted above but: Product Description This is a set of panels for the desktop encloure. The enclosure itself is NOT included. so this is only front an backpanel, but without "enclosure" what means no case - they panels are for the heidenreich case, which is not in my list
yes: with that frontpanels from julianf no: when you choose/get a fully acrylic variant, you have to substract the 145€ and take your acrylic panel+case instead if you decide for a acrylic solution like this you may ask mongrol what he payed,and for the files... other cases... for example.... or or or heidenreich (which was an bulkorder...you may not get the case on this price...) ----hope that helps... have a nice weekend.
here are some costs that i have already calculated for a other human, that lost his interest after sawing the costs.... THERE IS NO CASE IN THE LIST!!! search for your prefered casing and the price and how to get and shipping costs and then you have your price: (heidenreich case is the one you saw, but there are a few other case-variants out there, search for it...) the time is rated with 15€ the our, what for me is way to less, and all the parts are the costs you have to pay anyway, also shipping costs for parts,because they come not from one supplier... so this is the absulut minimum you have to invest... i guess most of people will charge you more for it... and so do i. SEQV4 Wilba CS 1 € 0 00:00 € 0 seq4 cs pcb € 35 1 € 35 03:00 03:00 03:00 € 35 seq4 lcds 2x40 € 10 2 € 20 00:00 € 20 I have - green standard lcd 10 € with black text, other colors backgrounds ar going up to 50 each! But possible jog wheel knob € 4 1 € 4 00:00 € 4 seq rotary knobs € 2 16 € 24 00:00 € 24 seq frontpanel € 145 1 € 145 02:00 02:00 02:00 € 145 i have to order this from http://thebeast.co.uk/?product_cat=midibox because i dont have one seq encoder € 2 16 € 24 00:00 € 24 case € 0 Wires + Connectors € 25 1 € 25 00:30 00:30 00:30 € 25 dont know this exactly, well depend on what design we end up – this is without soldering time! screws, holder, clue small material € 25 1 € 25 01:00 01:00 € 25 dont know this exactly, well depend on what design we end up € 0 Core STM32F407G-DISC1 € 17 1 € 17 00:00 € 17 core pcb € 10 1 € 10 00:30 00:30 00:30 € 10 core parts € 13 1 € 13 00:00 € 13 midi io pcb € 7 2 € 14 00:20 00:40 00:40 € 14 midi io parts € 7 2 € 14 00:00 € 14 01:00 € 0 sourcing parts 07:40 € 115 time that has already invested € 485 summ for SEQ only
what are you willing to pay? what case do You prefer? you said live so metall? rack or desktop?
