DrBunsen
250 -
Everything posted by DrBunsen
DIY audio patchbay with digital routing....How hard?
DrBunsen replied to Nomical's topic in Design Concepts
Now that's just silly ;D -
Not so hard: in fact I'm vaguely working towards something similar. 1. Choose an analog crosspoint matrix IC from Analog Devices. Whichever one suits you for the number of ins, outs, etc. 2. Read all the documentation on that chip. 3. Design a control surface & display. 4. Design a PCB layout. 3. Write a MIOS app to spit the right digital signals into the chip and respond to the control surface/display. My impression is that the crosspoint matrix IC will handle multiple inputs to one output, one in to multiple outs, and any combinations thereof, whilst keeping levels nice. I'd suggest a LED matrix as part of your display, with 1 LED for each crosspoint. I have some other interface ideas I can show you if you like. You could perhaps choose the largest IC you could imagine using (and afford) and just implement the pins you'll need in the first version, saving the rest for later expansion. Have a look at the mod matrix on the SID control surface for a UI example. I think this is just a case of having balancing transformers on each in and out, and using a switching plug - ie a 6.5mm stereo headphone-type socket where a stereo jack make a balanced connection and a mono jack makes an unbalanced connection - or one of those combination XLR-jack plugs, which have an XLR socket with a 6.5mm mono socket in the middle. The XLR pins go to the balancing transformer and the 6.5mm socket pins bypass it. Or just two separate sockets. Whichever suits you better. Once it's in the IC it won't matter that it's not balanced. It might also be worth considering switchable +4db/-10db pads on the ins and outs. -
Mackie vlz 1204. How to convert internal PSU 110 to 220!?
DrBunsen replied to ganchan's topic in Miscellaneous
Hmm. Yes, if you know how to do this, do it. If you don't, get a licensed electrical technician to do it for you, or buy a stepdown. Don't kill yourself or your Mackie -
Yes: his software compatibility page lists some. There's also an interface from C-Lab, which apparently works with Supertrack. And some info on 6502 MIDI programming and some source code: German bad-English German bad-English
Found the roundup I was thinking of: it only covers drum sequencers though, and not all of them have MIDI. There's also a review of Dr T's Algorhythmic Composer on this page, and mention of a couple more here. (Dr T's Keyboard Controlled Sequencer (KCS) and Master Composer). Also the Kawasaki MIDI Work Station inc download link From poking around it looks as if the Prophet64 would rock if only it could output MIDI. I found this download site for non-game C64 software; under the Sound tab there are a good few apps to look at. Here's some more. Names I've seen crop up include Passport, Datel, SCI (Sequential Circuits) as well as the previously mentioned Moog. These are names of companies that made MIDI interfaces - no idea what their respective softwares were called.
CLOSED: Black Re'an P401 Soft-touch knobs - 39 cents each
DrBunsen replied to nebula's topic in Bulk Orders
Paid ;D -
Mmm, sounds like a good excuse to learn 6502 ASM ...
Here's how I imagine it functionally: | input [ ] buffer | |----, | | pre/post switch | | vol (/) \----(/)-- | | | | FX send level |----' | pan (/) / \ | | L R Repeat the FX send circuit for however many FX sends you want (FX1, FX2 etc). | [ ] | |----+---+---+ | | | | | \--)---)----(/)--- FX1 | | | | | | | | (/) | \- )----(/)--- FX2 | | | | | | | | | | | \---(/)--- FX3 |----+---+---' etc | (/) / \ | | L R And sum each FX channel to a master send volume. Return is pretty much the same as another input channel I guess. Leaving out the pre/post switch would make it a lot simpler. I suppose what I am talking about here is pretty much another master bus.
I'm almost certain it was CDM or C64 Music!. For some reason CDM ain't loading for me today. Here's some details and links to downloads for one MIDI capable sequencer: EA's Instant Music Looks like the Moog Song Producer is a nice package; here's a schematic, and the software's available in a link off this thread, as well as some nice pics of the user interface. However: (also from that thread) Still, if you could find (or make :) ) other software that was compatible, it would pretty much rock.
There's also a design for a DIY interface - don't ya just love ASCII schematics? ;D
Superb work lyle. Just a couple of quick questions: Can the channel board be configured as 4 mono inputs? What would be involved in providing FX sends and returns? Thanks for your hard work so far - the design looks very clean.
Hmm. Some blog .... somewhere ... did a roundup of all of them recently. I'll see if I can find it.
What do you know: Sparkfun have the HD4478 data sheet (warning: PDF). I'll have to read that. Seems wikipedia agrees
One for the LCD gurus. Is the following possible: I want to re-define all the alphabetical characters in a 16x4 LCD so that they display sideways. ie instead of using it as 4 rows of 16 characters, I want to turn it on its side and use it as 16 rows of 4 characters. I assume that this means creating a custom font. The LCDs won't be addressed often, or used in a time-critical way, so it's not important that they be HD44780 types, as long as they are supported in MIOS. Or am I going to end up using a GLCD?
LNRV - sounds like a lunar rover to me... I can't see the videos or your page for some reason, but nevertheless, well done
Well done on the DR110 hack. Bad luck on missing out on the SX64. I've got a thing for luggables, and IMHO they're easily the best of breed aesthetically. I'd love even a non-functioning SX64 for a case mod.
Low Cost DSP Freescale DSP evaluation Kit
DrBunsen replied to TheAncientOne's topic in Miscellaneous
Did you notice the PhoenixSID - a SID emulated in an FPGA (with external filters) http://myhdl.jandecaluwe.com/doku.php/projects:phoenixsid_65x81 But more than that: Python as a hardware description language http://myhdl.jandecaluwe.com/doku.php/start -
Well one of the guys on the QiX forum suggested using a MIDIbox core to control it ;D On the completely other hand, what about something like this? Altera DE1 multimedia FPGA development board. # Altera Cyclone II 2C20 FPGA with 20000 LEs {logic elements} # 8Mbyte (1M x 4 x 16) SDRAM # 4Mbyte Flash Memory # 512Kbyte(256Kx16) SRAM # SD Card Socket # 24-bit Audio CODEC with line-in, line-out, and microphone-in jacks # VGA out, RS-232, PS/2 , two 40-pin Expansion Headers Should be enough grunt there to set up both a simple soft-core CPU and some DSP -
Hmm, Freescale/QiX board looks nice ... 8 channels of audio IO... can't figure out what the CPU on it is though. Being Freescale I assume it's a 68k or PPC derivative, but can anyone give a definitive answer? -
Very nice. I like the retro tape selector buttons at the bottom especially. You could always drill out the bottom of some valves and stick flickering LEDs in them. Hey it's good enough for Behringer and Korg ...
Hmm, 12 amplitude controllers, a mixer and 2 envelopes. Those are the useful bits to me, bugger the oscillators
But when you have more than one cable, how does it know which is which ???
That's a mighty nice collection of resources you have there, Doug. Have you checked out Field-programmable analog arrays (FPAA)?
