Imp
    419
    4
Everything posted by Imp
  1. Since the Lead-Engine is monophonic, the Tribe will work. But you could also use any midi-keyboard available.
  2. You can program sequences in bassline-mode. The other engines (Lead/Poly/drum) need note data via midi-in.
  3. Imp
    sammich fpd file
    I feel a strange and sudden urge to buy a new toy... Where did it come from ? Is there any subliminal messaging going on here? :unsure:
  4. I managed to kill one of them too... They are kinda sensitive to unsteady connections, so I'd rule out a problem with your cable first, before replacing that Display.
  5. :w00t: Nice! One problem though: No backpanel and really thick walls, so it still requires a lot of work. Btw, it would make a nice Hamster-Coffin! :wink:
  6. Wiegesagt, probiers aus! Das Display erwartet an dem Pin entweder Low oder High. Löt mal ein Kabel dran und halt das andere Ende testweise auf Masse oder +5 und starte die kiste. Da wirst du schon sehen, obs falsch oder richtig war... Der "/" vor dem reset soll hier übrigens "nicht" bedeuten, also wahrscheinlich High für den Betrieb, LOW für den Reset.
  7. Naja, ist wohl ein reset, wa? Den würd ich mal auf Masse legen, so rein intuitiv. Das ganze würde ich direkt auf dem Display erledigen. Es kann auch sein, dass ich mich irre, dann funktionierts so nicht, aber kaputt geht das davon nicht.
  8. Sounds like broken filters IMHO. Are you sure your seller is reliable? Maybe someone else could check your SIDs?
  9. Did you switch on the filtermode (to L, B, H or a combination)? I know this should be obvious, but it's easy to miss. Another idea: Can you check if the capacitors have proper contact to the SIDs? I don't know how this looks on a sammich, but maybe you can measure resistance between the capacitor-legs and the pins of the SID. Here you can see which pins to check: SID schematic
  10. you say, you got little time to devote to hobbies, but you want to built something, which involves a lot of unnecessary effort. Your plan to have a dedicated button for every function isn't insane, it just shows that you need to read/think about it some more ;). The layered structure of the full control surface (or mb-6582) works really well and you can control each parameter. There is also the "Knobs"-layer, for wich you can freely configure, which parameters it controls. You can build patches really fast with the full CS. A Surface with dedicated encoders/buttons per parameter won't save you any time in the long run, considered how long it takes to build. For easy construction and a great result, get a mb-6582. It can be played via midi, so if your keyboards have that, there's no need for special interfacing.
  11. Wilba spricht copyPasta und GoogleTranslate ;)
  12. Please don't ;) Or maybe on another track, but this one would loose something, if you gave your voice a synthetic character. when i heard it the 1st time, i actually expected a vocoded voice ( or none at all) and was kinda surprised.
  13. I like it! It perfectly fits my mood today. It's also something special, cause you don't find melancholic chiptune on every corner ;)
  14. Facial expression FTW! I wish i could improvise like you...
  15. Imp
    Wohnung in München
    gibts sowas echt?
  16. Imp
    Wohnung in München
    Von wegen aufpassen: Es besteht keine Gefahr ;) Wir haben uns das Haus zeigen- und eine runtergeleiherte geschichtliche Belehrung über uns ergehen lassen. Dann sind wir gegangen und haben uns gefreut, dass wir keinen Stock im Popo haben. Und ja, es war eine schlagende Verbindung, als der Knilch das erwähnte war der Ofen erst recht aus.
  17. Imp
    Wohnung in München
    Hehe, krasser Zufall: Ich war heute mit meinem Stiefbruder hier in Braunschweig auf Wohnungssuche und wir sind dabei unbeabsichtigt bei einer Burschenschaft gelandet. Ich kann dazu nur soviel sagen: Die Herren haben komische Traditionen und gehören allesamt eher zur konservativen Sorte. Sie bieten meistens ziemlich günstige Zimmer an, um darüber Mitglieder zu werben, aber ich glaube man muss schon auf den ganzen Kram stehen um insgesamt damit glücklich zu werden. Für mich wäre das nichts.
  18. Imp
    clip u. signal LED
    Du hast die Originalschaltung an einer Stelle falsch interpretiert. Die roten Verbindungen müssen weg. Ansonsten gehts, glaube ich. Und bei den Potis musst du dran denken, dass zwischen den äußeren Pins meistens der komplette (Nenn)Widerstand vorliegt. Um einen einstellbaren Widerstand zu haben, musst du den Wiper verwenden, der mit dem mittleren Pin verbunden ist. Wenn du Spindeltrimmer nimmst, kann die Pinbelegung aber auch anders sein.
  19. Imp
    clip u. signal LED
    Also, da durchzublicken ist ehrlich gesagt ein bischen schwerer als nötig. Du kannst auf jeden fall schonmal statt der 2 tl072 einen tl074 nehmen. Ansonsten zeichne doch mal bitte den Plan dazu, dann wird das ganze auch etwas einfacher und übersichtlicher für mich. So muss ich ziemlich viel raten ;)
  20. Imp
    clip u. signal LED
    Das mit "10k ab der Mitte" ist nicht so einfach, wie du dir das vorstellst. Es gibt stereo-Potis, das sind 2 Potis hintereinander, die sich einen Schaft teilen, elektrisch aber unabhängig sind. So eins kannst du so beschalten, dass es zwei gegenläufige Spannungsteiler darstellt. Die Mittelstellung wäre dabei aber für beide Kanäle eben nicht die volle Lautsärke, sondern halt so, als hättest du eins der Lautstärke-Potis zur hälfte aufgedreht. Also entweder müsstest du dann mit dem schwächeren Signal leben, oder halt nochmal verstärken. Wenn du aber eh jedem Ausgang ein einzelnes Poti spendierst, ist ein zusätzliches Balance-Poti sowieso überflüssig.
  21. Imp
    clip u. signal LED
    Wenn du ein Poti als Spannungsteiler verwendest, verhält sich das genau so. 10kohm sind dafür ok. Wie man deine panningpotis realisiert weiss ich ehrlich gesagt nicht. Ich würde die ganzen otptionalen potis auch erstmal weglassen und dann wenn alles läuft nochmal drüber nachdenken, ob die wirklich einen Vorteil bringen.
  22. Imp
    clip u. signal LED
    Ich habe mal einen Kopfhörer-Verstärker gebaut und darin den tl072 gegen andere teuere Op-Amps antreten lassen. Die teuren haben weniger gerauscht und waren insgesamt von der Qualität einfach besser. Aber für deine Anwendung ist der tl072 schon genau richtig. Welchen meinst du? Deine verlinkte PDF hat 33 Seiten ;) 2V ist ok, aber du brauchst einen Vorwiderstand, der den Strom durch die LED begrenzt, sonst wechselt die relativ schnell ihre Farbe richtung schwarz.
  23. Imp
    clip u. signal LED
    Das hast du soweit richtig verstanden. Du musst halt noch die äußere Beschaltung des ICs aufbauen, wie in dem oben von dir verlinkten pdf unter "nicht invertierender Verstärker" beschrieben. Der Tl072 wird für fast alles zimelich häufig genommen, weil es ihn fast geschenkt gibt.
  24. Imp
    clip u. signal LED
    Da die passenden Op-amps (tl072 z.B.) eh in Stereo-Ausführung zu haben sind, und das auch preislich völlig egal ist, verstärkst du beide Signale einzeln und führst die Ausgänge zusammen. So beeinflussen sich die Eingagnssignale nicht gegenseitig. Ein Nachteil: Wenn sich die verstärkten Signale gegenseitig auslöschen, leuchtet deine LED nicht, auch wenn der festgelegte Pegel eigentlich überschritten wird. Ich würde einfach zwei LEDs nehmen.
  25. I have an Akai Tape Deck Selector, which is meant to chain several Decks, record from one to another etc. I plan to connect my effect-units instead of tapes, so i can change their order. For my sources, i have a little mixer.
