973 -
11
Everything posted by Shuriken
Facebook in general or the group?
According to the datasheet: E = 512 Kbytes of Flash memory G = 1024 Kbytes of Flash memory So i don't see a problem.
Then you should send me a PM
Hi everybody, I have two pcb available based on:http://midisizer.com/other/vbe-matching/ including the TE switch the price is 10 Euro. This does not exclude shipping. PCB have been made at OSH Park.
The Flatsequencer (MBSEQ V4 with TPD, battery powered)
Shuriken replied to Hawkeye's topic in MIDIbox SEQ
Nice work Peter! Offtopic: Weren't you supposed to build something else- 22 replies
- 1
- battery powered
- v4
(and 3 more)
Tagged with:
Good point, i have added the item to the menu
All the Icon stuff seems to be going EOL. At most places i looked the expansion cards and the master keyboards they go with are on sale. Offtopic: i got a notification off your post
Nobody sells the synths anymore either So i guess your solution will be the only way to use this, once the Useaudio software stops working on current Windows/OSX. Offtopic: i am looking into the notification problems.
Are you running the usb_midi_2x2_v1_010.zip application?
I would try with an external power instead of via the mini-USB port.
ubuntu linux - make arm-none-eabi-gcc: error
Shuriken replied to Phatline's topic in MIOS programming (C)
Sorry i put you on the wrong path, forgot about our custom toolchain. -
Good way to start 2016 What tool are you using to hold the pcb? looks interesting.
Check if /usr/bin/cc is present. If so then do: ln -s /usr/bin/cc /usr/bin/cc1 -
Hi, i have moved this to the section Midification. If you look into the topics in this section there are a lot of topics about the midifcations of organs.
Eenzelfde voor 9V. Dan kan je alle SIDs aan. Al kan je daar met een 1A exemplaar volstaan.
Not sure. On the Midibox CV 2 page at the Din Sync header it says: TODO: add interconnection diagram. But considering the other text: The signals are switching between 0V and 5V level, and should be protected with a serial 220 Ohm resistor (already part of the MBHP_DOUT module) i think you are not supposed to attach directly to an exposed IO pin anymore because it's not protected. Maybe TK can answer this?
What i understand from the docu J28 is either I2S or General Purpose IO. As you have not hooked up a DAC for Audio out, i guess it's just General stuff.
I assume you are using the General Purpose IO functions from J28. So wouldn't you be able to use J10A or B?
There is a problem with white spaces in the file. Try this project.hex, or remove them yourself and it should be ok.
I was wondering if anybody has any experience with cutting up a keybed? I have project in mind which (i think) requires a 37 keys keybed. Now the usual places do not seem to sell any fatar 37 keybeds anymore. So it might be easier and cheaper to find a donor midi controller. However 37 key variants are not that common. I read on the MI forum that a guy there just cut up the keybed of a Behringer UMX 49 controller. He also mentions that he performs such an action on a 61 keybed as well. Unfortunately the source is no longer active on the forum, so i cannot ask him. So maybe someone here has some experience with this?
port LPC1343 polysynth to MBHP_CORE_STM32F4?
Shuriken replied to tffshtt's topic in MIDIbox User Projects
I have moved this topic from Midibox NG to Midibox User Projects as this fits the bill better. Hopefully there will be a user who takes care of the project (code)
