Shuriken
Frequent Writer
    973
    11
Everything posted by Shuriken
  1. Facebook in general or the group?
  2. According to the datasheet: E = 512 Kbytes of Flash memory G = 1024 Kbytes of Flash memory So i don't see a problem.
  3. Then you should send me a PM
  4. Shuriken
    midibox parts
    What's the big green pcb? i don't recognize it.
  5. Hi everybody, I have two pcb available based on:http://midisizer.com/other/vbe-matching/ including the TE switch the price is 10 Euro. This does not exclude shipping. PCB have been made at OSH Park.
  6. Nice work Peter! Offtopic: Weren't you supposed to build something else
  7. Good point, i have added the item to the menu
  8. All the Icon stuff seems to be going EOL. At most places i looked the expansion cards and the master keyboards they go with are on sale. Offtopic: i got a notification off your post
  9. Nobody sells the synths anymore either So i guess your solution will be the only way to use this, once the Useaudio software stops working on current Windows/OSX. Offtopic: i am looking into the notification problems.
  10. Are you running the usb_midi_2x2_v1_010.zip application?
  11. I would try with an external power instead of via the mini-USB port.
  12. Sorry i put you on the wrong path, forgot about our custom toolchain.
  13. Good way to start 2016 What tool are you using to hold the pcb? looks interesting.
  14. Check if /usr/bin/cc is present. If so then do: ln -s /usr/bin/cc /usr/bin/cc1
  15. Shuriken
    new here
    Hi, i have moved this to the section Midification. If you look into the topics in this section there are a lot of topics about the midifcations of organs.
  16. Eenzelfde voor 9V. Dan kan je alle SIDs aan. Al kan je daar met een 1A exemplaar volstaan.
  17. Not sure. On the Midibox CV 2 page at the Din Sync header it says: TODO: add interconnection diagram. But considering the other text: The signals are switching between 0V and 5V level, and should be protected with a serial 220 Ohm resistor (already part of the MBHP_DOUT module) i think you are not supposed to attach directly to an exposed IO pin anymore because it's not protected. Maybe TK can answer this?
  18. What i understand from the docu J28 is either I2S or General Purpose IO. As you have not hooked up a DAC for Audio out, i guess it's just General stuff.
  19. I assume you are using the General Purpose IO functions from J28. So wouldn't you be able to use J10A or B?
  20. Shuriken
    Yeah do infills on the text and it will be much better.
  21. There is a problem with white spaces in the file. Try this project.hex, or remove them yourself and it should be ok.
  22. I was wondering if anybody has any experience with cutting up a keybed? I have project in mind which (i think) requires a 37 keys keybed. Now the usual places do not seem to sell any fatar 37 keybeds anymore. So it might be easier and cheaper to find a donor midi controller. However 37 key variants are not that common. I read on the MI forum that a guy there just cut up the keybed of a Behringer UMX 49 controller. He also mentions that he performs such an action on a 61 keybed as well. Unfortunately the source is no longer active on the forum, so i cannot ask him. So maybe someone here has some experience with this?
  23. Shuriken
    Looks nice, showing off that beautiful PCB
  24. I have moved this topic from Midibox NG to Midibox User Projects as this fits the bill better. Hopefully there will be a user who takes care of the project (code)
