973 -
11
Everything posted by Shuriken
"Upgraded" forum complaints/suggestions
Shuriken replied to latigid on's topic in MIDIbox Documentation Project
Yeah, i noticed it yesterday, so i changed the display format. It's not really a bug -
Maybe these help: http://www.colorado.edu/physics/phys3330/phys3330_fa09/pdfdocs/Diodes_3.pdf http://www.colorado.edu/physics/phys1020/phys1020_sp12/NagleLectures/nagle_phys1020_sp12_lectures12_given.pdf
Added to the list: gburksfoodeaterflokimongrol, i did not see you on the list...
"I wish I had a tact with a longer actuator" solution
Shuriken replied to Altitude's topic in Tips & Tricks
So no separate led anymore, but using the one inside the button looks nice. -
Yeah i see the difference, but cannot see any option in the software to enforce this. Edit: It seems to be a design decision in 4.x you can only over rule by altering custom.css. -
To respond: The encoding problem is a conversion problem. As Thorsten said probably not fixable.I am afraid it's also a conversion e.g. timezone problem.Might be just the active old ones, hence new ones are correctly displayed. I checked my album from 2009 and it looks ok.Not sure, might be a conversion problem as well.I cant find any settings on this. Might be just a new feature of the new version of the board software.The emoticon problem was fixed. I added the old ones. But it looks like in old post its still not parsed.Not sure.This should be fixed.I can't find anything setting on this. Maybe this setting was removed in the new version of the board software..Oh come on there is only 9 challenges -
MEC switches right? -
I have no experience with either the Tempest nor MPC5000. But a quick google gave me this:https://www.gearslutz.com/board/electronic-music-instruments-electronic-music-production/570431-dave-smith-instruments-tempest-73.html Maybe its helpfull? esp. the last post on that page.
I am very sorry for the people who have lost their money. And if the sad stories from Doug are true, i feel sorry for him. But that does not make it in anyway OK. The money is not his to take and he should have either not accept it or immediately return it when he realized he could not keep his end of the bargain. However after all these years i do not think it's very realistic to think that the he will ever refund any money. The money is probably long gone for what ever reason. It's hard pill to swallow but this is the harsh reality.
The two links of the DLL contain the exact same versions if i check in Details tab. I doubt there is anything newer then this.
I thought you still had problems with it using the non-ploytec mode. What changed?
Ich benutze dieses Ploytec driver. Das funktioniert gut fur Windows 8.1 und 10 - 64bit.
I think correct firmware is on the IIC Midi page itself: http://ucapps.de/mbhp_iic_midi.html in the Download section. @electrodancer; you seem to be pointing to a Diagnostic Application for the different ARM cores.
The Rigol DS1054Z looks nice and the price level is the same as the DS1052E a couple of years ago. I would go for that one if i were you. If money is an issue, the Owon SDS5032E is like a 100 euro cheaper. Personally i wouldn't buy a scope which requires a PC. You are totally dependant on the whim of the manufacturer. If they decide to stop supporting the scope you are stuck with a very expensive brick.
Full 16x16+X BLM with silicone buttons, matching case. Interested?
Shuriken replied to latigid on's topic in MIDIbox BLM
Darn, that does indeed look good. Very very cool! -
I think that FantomXR is working on a solution for the ledrings without the use of the LRE8x2 boards:
- 40 replies
- 1
- MBCV
- illuminated encoders
(and 1 more)
Tagged with:
There maybe a new batch. But not sure when. See:
The ASX requires 9V to work. Not sure what connector number. See this old picture for the connector: http://midibox.org/forums/uploads/1272923962/gallery_6528_21_101462.png
It's under IC7 :wink:
stm32f4 compiling errors > USB (ubuntu 14)
Shuriken replied to Phatline's topic in MIOS programming (C)
I assume you have gcc installed on Ubuntu. So shouldn't your path be like: export PATH=/home/tekkstar/mios32_toolchain/arm-none-eabi/bin:$PATH The way you have it now it will find the system binary first. -
How 'relevant' is the quad IIC at this point in time? I thought it was pretty much replaced by the Midi IO module.
Ah ok, that's pretty cool. That would completely remove the need for a pc. So i guess by firmware you mean the dsp code that normally is uploaded through the software of UseAudio. I would recommend not to distribute that for obvious reasons :wink:
With the prototype, can you just control parameters? or are you able for example to switch from minimax to b4000?
