julienvoirin Posted June 18, 2009 Report Share Posted June 18, 2009 machinecollective.org (xndr) could maybe build our panel and case in black satin acryl ? i ordered him a monome 40h top and bottom and the quality is just PERFECT ! btw is there dxf of the panel ?? Quote Link to comment Share on other sites More sharing options...
ilmenator Posted June 18, 2009 Report Share Posted June 18, 2009 Here are some close-up photos during construction... I don't think I showed these before.Hehe, now your fingerprints are on the web. They'll get you :P Quote Link to comment Share on other sites More sharing options...
Echopraxia Posted June 18, 2009 Report Share Posted June 18, 2009 That would be nice Julien. Maybe we can find out how much it would cost for the 31 orders of just the panel and then additionally a case. Wilba made the panel and doug is making the case so I assume we might just do the panel if we go this route? Concerning the people who are on the mini bulk order who would be interested in doing this?Regards,echo Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted June 18, 2009 Report Share Posted June 18, 2009 Wilba does only PCB ! he recommends Schaeffer for panel. Quote Link to comment Share on other sites More sharing options...
Echopraxia Posted June 18, 2009 Report Share Posted June 18, 2009 Yes. I meant he did the panel design. Right? Quote Link to comment Share on other sites More sharing options...
Wilba Posted June 18, 2009 Author Report Share Posted June 18, 2009 There is a DXF for the panel, but I am not sure how well the PCB would mount to acrylic... it's something I'm interested in though.The design relies on "studs" on the back of the panel. If you get a panel from Schaeffer/FPE, you can get them to make threaded holes on the back (that you don't see on the front). Then additional 10mm spacers are glued to the back for more support for the PCB. I don't think threaded holes is possible with acrylic (especially laser cut only). Perhaps countersunk screws through the panel, on left and right sides and more for the LCDs, might be enough... and/or plastic spacers glued in the middle. I do not recommend screws through the middle of the panel, there is little clearance.Ponoko is also a good option for a laser cut acrylic panel, they have a lot of materials in 3mm (even wood!), the only limitation is how to mount the PCB. If someone knows how to glue nylon to acrylic, that would be really cool :-) Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted June 19, 2009 Report Share Posted June 19, 2009 PCB would mount to acryliche use a sandwich technique with 2 acryl panels. the lower one has holes, screw and spacers.In black satin you see no screw behind the upper panel ;)it's a bit like threated holes from schaeffer if you cut the panel in 2 thicker ones.it is very clever and very cheap to do !his tonon + mortaise technique for the case is very good too.o make threaded holes on the backyeah as i did on SEQ_2U (dédicace à reboot) Quote Link to comment Share on other sites More sharing options...
Kyo Posted June 19, 2009 Report Share Posted June 19, 2009 Couldn't we use a metal panel with acryl enclosure ? Quote Link to comment Share on other sites More sharing options...
Jack Posted June 20, 2009 Report Share Posted June 20, 2009 I like both ideas.A mixed panel Frontpanel would also be nice:- Aluminium as base- Acryl for the lcd and the LEDs (iluminated midibox logo)Best RegardsJack Quote Link to comment Share on other sites More sharing options...
Wilba Posted June 21, 2009 Author Report Share Posted June 21, 2009 I was thinking about a laser-cut acrylic frontpanel as a cheaper alternative to aluminium... so I'll draw up the panel in Inkscape as if to get them made by Ponoko... that will give us an idea how much they'll cost for a small quantity. I still don't know the best way to mount the PCB to acrylic... it could be the "studs" on the left/right sides are replaced with screws through the panel. A clear LCD window could also be made to fit into a cutout of the same size... they should just snap in without requiring glue. I was considering making an entire case out of acrylic but it's not that easy to make a sloping desktop-style case, it might have to be a box with "endcheeks" that give it the slope.Please nag me if I haven't published panel layouts in Inkscape SVG files... err... give me a week :) Quote Link to comment Share on other sites More sharing options...
TheAncientOne Posted June 23, 2009 Report Share Posted June 23, 2009 An engraving comapny I talked to locally suggested back engraved acrylic. That way the letters can be filled, but the front panel is smooth, and stays clean better. Back engraved acrylic over alloy sounds like the best of both worlds, to me. Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted June 23, 2009 Report Share Posted June 23, 2009 laser-cut acrylic frontpanel as a cheaper alternative to aluminiumafter testing the resistance to weight of my monome's frontpanel, i think that Alu 3-4mm is better for frontpanel. Moreover the height of the spacer and encoder won't allow a 6-7 mm acryl frontpanel (the sandwich height with 2 acryl panels). But the case can be acryl ;) Quote Link to comment Share on other sites More sharing options...
Jack Posted July 5, 2009 Report Share Posted July 5, 2009 Hi Wilba,Please nag me if I haven't published panel layouts in Inkscape SVG files... err... give me a week :)Any update? Do you have a timeline? I must plan my vacation for building. :)Best RegardsJack Quote Link to comment Share on other sites More sharing options...
Wilba Posted July 6, 2009 Author Report Share Posted July 6, 2009 I guess I'm too busy to make the SVG files right now, sorry.What little spare time I have at the moment is spent running bulk orders. Quote Link to comment Share on other sites More sharing options...
ganchan Posted July 17, 2009 Report Share Posted July 17, 2009 i think i've not receive the mail :( Quote Link to comment Share on other sites More sharing options...
Wilba Posted July 17, 2009 Author Report Share Posted July 17, 2009 i think i've not receive the mail :(I'm only running a small bulk order for people willing to make/buy their own frontpanel and case."Small" for me is only 36 PCBs and less than US$1000 in parts... ;)This small bulk order is closed, it was announced months ago and people have had plenty of time to join.Once Doug is able to make panels/cases as per the original design, I'll run another bulk order for more PCBs and parts. Quote Link to comment Share on other sites More sharing options...
ganchan Posted July 18, 2009 Report Share Posted July 18, 2009 sorry you're right, i was away from the forum for too much time, then i've lost this.. too busy. :P Quote Link to comment Share on other sites More sharing options...
fussylizard Posted August 3, 2009 Report Share Posted August 3, 2009 Man it's so eighties you should view that pic on an EGA monitor.Top work W!I was going through this thread this weekend getting caught up and saw this. Probably the funniest comment I've seen yet. :-) Quote Link to comment Share on other sites More sharing options...
Tamiflu Posted August 4, 2009 Report Share Posted August 4, 2009 Gents,Looks like I've missed the boat on this one.Is there a plan to run another set of parts in the future ?If so, please count me in.Cheers - Gary Quote Link to comment Share on other sites More sharing options...
nebula Posted August 4, 2009 Report Share Posted August 4, 2009 Dude -- this is a VERY long thread I know, but ...Yes. Read the thread. Find the Wiki link. Add yourself.Welcome to the MIDIbox forum, but be warned: people who don't try to find answers for themselves tend to get lambasted around here! ;) Quote Link to comment Share on other sites More sharing options...
Wilba Posted August 5, 2009 Author Report Share Posted August 5, 2009 BTW PCBs for the "bleeding edge prototypers" have arrived. POIDH? GTFO! Quote Link to comment Share on other sites More sharing options...
Narwhal Posted August 5, 2009 Report Share Posted August 5, 2009 BTW PCBs for the "bleeding edge prototypers" have arrived. POIDH? GTFO!POIDH! Quote Link to comment Share on other sites More sharing options...
julienvoirin Posted August 5, 2009 Report Share Posted August 5, 2009 GTFO! :o :o :o :oU R so DIRTY Quote Link to comment Share on other sites More sharing options...
nILS Posted August 5, 2009 Report Share Posted August 5, 2009 :o :o :o :oU R so DIRTYTrue, but ? Quote Link to comment Share on other sites More sharing options...
Kyo Posted August 5, 2009 Report Share Posted August 5, 2009 BTW PCBs for the "bleeding edge prototypers" have arrived.Surgery table all set up. You can bring 'em in. Quote Link to comment Share on other sites More sharing options...
