doc
Frequent Writer-
1,079 -
Everything posted by doc
Ok. Da sollte aber einer sein. Allein der fehlende Widerstand an RD1 wird aber nicht zwangsläufig Dein Problem sein. Besorg dir den Widerstand und dann gehe die Midi-Troubleshooting-Guide weiter durch. DIe interessanten Tests kommen alle erst weiter unten ... ;D Gruss Doc
Mein Auto fährt nicht! Woran liegt es ?? Ne, mal ehrlich. Deine Fragestellung hat sich seit Deiner letzten Box nicht wesentlich verbessert ... *grins* Also. Du hast einen PIC mit Bootloader drin und willst MIOS installieren ?? - Du musst den Upload Befehl innerhalb der ersten zwei Sekunden nach dem Einschalten des Core starten. Gruss Doc
Gate is a simple On/Off - signal which is normally sended along with the CV. It is a "own signal". For example: If you press a key on a (analog) synthi it sends the CV on the CV-line and a ON on the GATE-line to the synthi. If you release the key Gate sends off. This signal is then used for signal forming stages, for example a ADSR to form the envelope. Or as a simple start/stop signal. It is a simple control-signal. Hope this helps. greets Doc
... and btw: If anyone has a problem with 500mA: Built a psu for your GM5's and ignore the specs ! ;D greets Doc
This topic has been moved to MIDIfication. [iurl]http://www.midibox.org/forum/index.php?topic=11765.0[/iurl]
Thats what I also think. It's a proofen standard design used all over the world. I also don't see a need for tantal cap. And be warned: Tantal caps are causing the most problems after a couple of time. If a cap fails in a circuit it is mostly a tantal! So to say: A troubleshooting "standard". greets Doc
But it is a very pretty horse ! ;D
*lol* @bill Your video is "Simply The Best" !!! ;D ;D Our No. 1! greets Doc
hehe. Let the monkey play: <object width="425" height="344"><param name="movie" value="http://www.youtube.com/watch?v=1fCXCAk4844&hl=de&fs=1"></param><param'>http://www.youtube.com/watch?v=1fCXCAk4844&hl=de&fs=1"></param><param name="allowFullScreen" value="true"></param><embed src="http://www.youtube.com/watch?v=1fCXCAk4844&hl=de&fs=1" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object> And here our german Nr. 1 from the same year: <object width="425" height="344"><param name="movie" value=" name="allowFullScreen" value="true"></param><embed src=" type="application/x-shockwave-flash" allowfullscreen="true" width="425" height="344"></embed></object>
So be warned ... Even if your LC runs in Mackie Emulation, the car will win !!
Have a look here at the MIXBUSTERS: http://www.mackie.com/enews/2008/06/introducing_the_mackie_mixbust_1.html greets Doc
No Viagra, or what ?? ;D ;D greets Doc
Nur der Form halber: DOUT hat keine Pull-down Widerstände. Die 220 Ohm Widerstände begrenzen den LED Strom, sonst nichts. Ob diese Widerstände bei nicht angeschlossenen DOUTs drin sind oder nicht ist eigentlich völlig egal. ;D Gruss Doc
Die sehen gar nicht schlecht aus. Auf jeden Fall lässte der Aufbau gezieltes "Modding" zu. Auf jeden Fall würde ich die Heizleitungen sauber verdrillen und einen Stand-by Schalter als erste Maßnahme empfehlen. Und wenn Du die Heizspannung abgreifts, kannst Du gleich Dein Stimmgerät mit einbauen. Platz genug wäre da! ;D Gruss Doc
not the right box for him! If I understood right, you want to control the host without VGA and keyboard & mouse. The LC would tell you the tracknames on the display. That is right. But how do you get the tracknames in the host. I think, that was/is your question. With Mackie Control you can control a lot ... but not all. The intention of this controller is partly to control the host. But not to control the PC! I think, you'll need two controllers. One like the LC to control the host and one Controller to control the PC. greets Doc
If you want to avoid trouble and if you don't want to program a lot: Use a DIN! You can also use a SMD 74HC165 if space is really an issue. greets Doc
Thats not true. Every LC uses the fullchain of 16 HC595. I once had a simular problem with flickering. I forgot one PIN 13 to ground on one or two registers. Doublecheck all connections. btw. It doesn't matter, if you "freewire" the DOUT chain. As long as the RC/SC/SO Lines are not too long (long= 50cm or more). Looking back in the troubleshooting section: 99% of all those problems were (are) bad wires or solders. greets Doc
... or tune 5 strings and use your well tuned ears for the last string ;D greets Doc
Ich kenne diese Taster noch aus meiner Zeit, als ich Flipper und Spielautomaten reparierte (So gegen 1986 ....). Als Transportschalter sind sie nur bedingt tauglich. Sie haben einen sehr hohen Druckpunkt, sind laut und sehr groß. Schnelles, präzises arbeiten wird damit erschwehrt. Optisch machen sie natürlich viel her. (Sie sagen: "Drück mich!") Dafür sind sie einigermaßen vandalensicher. Du kannst die LC dann mit einer Bierflasche bedienen. ;D ;D Gruss Doc
Ja,kannst Du. Schau Dir mal die lc_hlp.ini ganz unten an. Hier kannst Du die Positionien zuordnen. Gruss Doc
I hope you mean "Deutsch". If so, you'll have to try harder! ;D greets Doc
Hi, die Tasten werden, wie Du richtig vermutest, über die Schieberegister in den PIC eingelesen. Die DOUTs funktionieren genauso (nur eben anders herum, als Ausgänge). Am besten Du siehst Dir die Datenblätter zum 74HC165 und 74HC595 einmal an. Da werden viele Deiner Fragen beantwortet. Zum Timing kann ich Dir leider sehr wenig bis gar nix sagen. Für uns regelt das ganz brav MIOS. Da weiß Thorsten genaueres. Nur dazu soviel. Das Timing für DIN und DOUT ist eine recht kritische Angelegenheit. Jeglicher Eingriff in diese Kette klappt meistens nicht bzw scheitert am Timing. Zu Deinem Vorhaben mit der Tastatur: Zunächst einmal gibt es zahlreiche Beispiele im Forum, wie man eine Tastaturmatrix aufbaut bzw. ansteuert. Die MB6582 wird z.B. über eine Tastenmatrix bedient. Es gibt aber auch im WIKI ein Beispiel, wie eine C64 Tastatur angesteuert wird. Es wäre zunächst einmal gar kein Problem, z.B. eine PC-Tastatur direkt am PIC einzulesen. Aber in Verbindung mit MIOS oder eine Aplplikation erscheint mir das ungleich schwieriger. Um bei Deiner Box zu bleiben: Für eine MIDIbox LC würde man eigentlich gar keine Tastatur-Multiplex benötigen, da die Anzahl der freien PINs in einer DIN-Kette (max 128) voll und ganz ausreichen. Neben den 9 Encodern (=18) Eingänge und den 8 Touchsensoren, bleiben somit noch 102 mögliche Taster übrig. Das sind mehr, als das host Protokoll unterstützt. Ich weiß, dass beantwortet Dein Frage nicht. Wenn Du innerhalb der LC eine fertige Tastatur verwenden willst, solltest Du die X und Y Leitungen in einer DIN Matrix zusammenfassen. Das würde dann funktionieren. Zum Thema Tastaturen habe ich noch folgende Anregung (hat nix mit MIDIbox zu tun): Ich habe mir vor Längerem eine programmierbare POS Tastatur mit 140 Tasten besorgt und darauf die Hot-Keys von Cubase gelegt. Damit kann ich fast alle denkbaren Funktionen des hosts steuern, ohne Midibox und ohne wertvollen MIDI-Port. Ok. Das war jetzt Off-Topic. Viel mir aber gerade ein. Damit kann man nämlich wunderbar die Funktionen verwenden, die einem eine LC nie bieten kann. Gruss Doc
No, it doesn't help ...... it's a MUST !! Greets Doc
... deshalb habe ich es gelassen, wie es ist... ;D Gruss Doc
Das sind SMD Leds, die direkt auf der Platine verlötet sind. Durch die Drehknopfscheibe kann man sie erkennen. Es war ein Test. Allerdings muß man immer von oben draufschauen, um was zu erkennen. Ist also noch verbesserungswürdig. Man müsste einen Plexiglasring als Lichtleiter bis nach oben führen. Dann wäre es perfekt. Gruss Doc
